[PATCH 0/4] zynqmp: Add support for sending pmufw config object overlay
this small series is extending firmware interface for sending pmufw configuration overlay with asking for access to certain device. This infrastructure can be used via command or via power domain driver.
Thanks, Michal
Michal Simek (4): xilinx: firmware: Introduce zynqmp_pmufw_node() for loading PMU fragments firmware: zynqmp: Move loading message to debug firmware: zynqmp: Do not report error if node is already configured arm64: zynqmp: Add command for disabling loading other overlays
board/xilinx/zynqmp/cmds.c | 16 ++++++++ drivers/firmware/firmware-zynqmp.c | 60 +++++++++++++++++++++++++++++- include/zynqmp_firmware.h | 2 + 3 files changed, 77 insertions(+), 1 deletion(-)
Introduce zynqmp_pmufw_node() for loading PMU configuration fragment for enabling IPs. Firmware driver has small overlay where NODE id is added and config fragment is sent to PMUFW. There is a need to build PMUFW with fragment support.
drivers/firmware/firmware-zynqmp.c | 32 ++++++++++++++++++++++++++++++ include/zynqmp_firmware.h | 1 + 2 files changed, 33 insertions(+)
diff --git a/drivers/firmware/firmware-zynqmp.c b/drivers/firmware/firmware-zynqmp.c index 342dbc13dfdf..10240ddccd3b 100644 --- a/drivers/firmware/firmware-zynqmp.c +++ b/drivers/firmware/firmware-zynqmp.c @@ -27,6 +27,38 @@ struct zynqmp_power { struct mbox_chan rx_chan; } zynqmp_power;
+#define NODE_ID_LOCATION 5 + +static unsigned int xpm_configobject[] = { + /**********************************************************************/ + /* HEADER */ + 2, /* Number of remaining words in the header */ + 1, /* Number of sections included in config object */ + PM_CONFIG_OBJECT_TYPE_OVERLAY, /* Type of Config object as overlay */ + /**********************************************************************/ + /* SLAVE SECTION */ + + PM_CONFIG_SLAVE_SECTION_ID, /* Section ID */ + 1, /* Number of slaves */ + + 0, /* Node ID which will be changed below */ + PM_SLAVE_FLAG_IS_SHAREABLE, + PM_CONFIG_IPI_PSU_CORTEXA53_0_MASK | + PM_CONFIG_IPI_PSU_CORTEXR5_0_MASK | + PM_CONFIG_IPI_PSU_CORTEXR5_1_MASK, /* IPI Mask */ +}; + +int zynqmp_pmufw_node(u32 id) +{ + /* Record power domain id */ + xpm_configobject[NODE_ID_LOCATION] = id; + + zynqmp_pmufw_load_config_object(xpm_configobject, + sizeof(xpm_configobject)); + + return 0; +} + static int ipi_req(const u32 *req, size_t req_len, u32 *res, size_t res_maxlen) { struct zynqmp_ipi_msg msg; diff --git a/include/zynqmp_firmware.h b/include/zynqmp_firmware.h index 19c004e91993..76c161806a0d 100644 --- a/include/zynqmp_firmware.h +++ b/include/zynqmp_firmware.h @@ -367,6 +367,7 @@ enum pm_ioctl_id { #define PAYLOAD_ARG_CNT 5U
unsigned int zynqmp_firmware_version(void); +int zynqmp_pmufw_node(u32 id); void zynqmp_pmufw_load_config_object(const void *cfg_obj, size_t size); int xilinx_pm_request(u32 api_id, u32 arg0, u32 arg1, u32 arg2, u32 arg3, u32 *ret_payload);
Power domain driver is using this function for every IP which is PD listed. This can end up with a lot of messages which end up in boot log. That's why show it only in EL3 as was used in past.
drivers/firmware/firmware-zynqmp.c | 3 ++- 1 file changed, 2 insertions(+), 1 deletion(-)
diff --git a/drivers/firmware/firmware-zynqmp.c b/drivers/firmware/firmware-zynqmp.c index 10240ddccd3b..d6dd5a394ee9 100644 --- a/drivers/firmware/firmware-zynqmp.c +++ b/drivers/firmware/firmware-zynqmp.c @@ -131,7 +131,8 @@ void zynqmp_pmufw_load_config_object(const void *cfg_obj, size_t size) int err; u32 ret_payload[PAYLOAD_ARG_CNT];
- printf("Loading new PMUFW cfg obj (%ld bytes)\n", size); + if (IS_ENABLED(CONFIG_SPL_BUILD)) + printf("Loading new PMUFW cfg obj (%ld bytes)\n", size);
flush_dcache_range((ulong)cfg_obj, (ulong)(cfg_obj + size));
Power domain driver sends PM fragment to PMUFW. It is sent for every node which is listed in DT. But some nodes could be already enabled but driver is not capable to find it out. That's why it blinly sents request for every listed IP. When PMUFW response by XST_PM_ALREADY_CONFIGURED error code there is no need to show any error message because node is already enabled. That's why cover this case with message when DEBUG is enabled.
drivers/firmware/firmware-zynqmp.c | 6 ++++++ 1 file changed, 6 insertions(+)
diff --git a/drivers/firmware/firmware-zynqmp.c b/drivers/firmware/firmware-zynqmp.c index d6dd5a394ee9..a80e73307982 100644 --- a/drivers/firmware/firmware-zynqmp.c +++ b/drivers/firmware/firmware-zynqmp.c @@ -21,6 +21,7 @@ #define PMUFW_PAYLOAD_ARG_CNT 8
#define XST_PM_NO_ACCESS 2002L +#define XST_PM_ALREADY_CONFIGURED 2009L
struct zynqmp_power { struct mbox_chan tx_chan; @@ -143,6 +144,11 @@ void zynqmp_pmufw_load_config_object(const void *cfg_obj, size_t size) return; }
+ if (err == XST_PM_ALREADY_CONFIGURED) { + debug("PMUFW Node is already configured\n"); + return; + } + if (err) printf("Cannot load PMUFW configuration object (%d)\n", err);
Add command "zynqmp pmufw node close" to disable permission to load additional pmufw config overlays. This command will make sure that any other sw will ask for changing permission.
board/xilinx/zynqmp/cmds.c | 16 ++++++++++++++++ drivers/firmware/firmware-zynqmp.c | 19 +++++++++++++++++++ include/zynqmp_firmware.h | 1 + 3 files changed, 36 insertions(+)
diff --git a/board/xilinx/zynqmp/cmds.c b/board/xilinx/zynqmp/cmds.c index 5a277c712f60..2ab9596248c0 100644 --- a/board/xilinx/zynqmp/cmds.c +++ b/board/xilinx/zynqmp/cmds.c @@ -209,6 +209,19 @@ static int do_zynqmp_pmufw(struct cmd_tbl *cmdtp, int flag, int argc, if (argc != cmdtp->maxargs) return CMD_RET_USAGE;
+ if (!strncmp(argv[2], "node", 4)) { + u32 id; + + if (!strncmp(argv[3], "close", 5)) + return zynqmp_pmufw_config_close(); + + id = dectoul(argv[3], NULL); + + printf("Enable permission for node ID %d\n", id); + + return zynqmp_pmufw_node(id); + } + addr = hextoul(argv[2], NULL); size = hextoul(argv[3], NULL);
@@ -416,6 +429,9 @@ static char zynqmp_help_text[] = " lock(0)/split(1)\n" #endif "zynqmp pmufw address size - load PMU FW configuration object\n" + "zynqmp pmufw node <id> - load PMU FW configuration object\n" + "zynqmp pmufw node close - disable config object loading\n" + " node: keyword, id: NODE_ID in decimal format\n" "zynqmp rsa srcaddr srclen mod exp rsaop -\n" " Performs RSA encryption and RSA decryption on blob of data\n" " at srcaddr and puts it back in srcaddr using modulus and\n" diff --git a/drivers/firmware/firmware-zynqmp.c b/drivers/firmware/firmware-zynqmp.c index a80e73307982..2ba0b3a7c5c6 100644 --- a/drivers/firmware/firmware-zynqmp.c +++ b/drivers/firmware/firmware-zynqmp.c @@ -49,6 +49,25 @@ static unsigned int xpm_configobject[] = { PM_CONFIG_IPI_PSU_CORTEXR5_1_MASK, /* IPI Mask */ };
+static unsigned int xpm_configobject_close[] = { + /**********************************************************************/ + /* HEADER */ + 2, /* Number of remaining words in the header */ + 1, /* Number of sections included in config object */ + PM_CONFIG_OBJECT_TYPE_OVERLAY, /* Type of Config object as overlay */ + /**********************************************************************/ + /* SET CONFIG SECTION */ + PM_CONFIG_SET_CONFIG_SECTION_ID, + 0U, /* Loading permission to Overlay config object */ +}; + +int zynqmp_pmufw_config_close(void) +{ + zynqmp_pmufw_load_config_object(xpm_configobject_close, + sizeof(xpm_configobject_close)); + return 0; +} + int zynqmp_pmufw_node(u32 id) { /* Record power domain id */ diff --git a/include/zynqmp_firmware.h b/include/zynqmp_firmware.h index 76c161806a0d..50bf4ef39535 100644 --- a/include/zynqmp_firmware.h +++ b/include/zynqmp_firmware.h @@ -368,6 +368,7 @@ enum pm_ioctl_id {
unsigned int zynqmp_firmware_version(void); int zynqmp_pmufw_node(u32 id); +int zynqmp_pmufw_config_close(void); void zynqmp_pmufw_load_config_object(const void *cfg_obj, size_t size); int xilinx_pm_request(u32 api_id, u32 arg0, u32 arg1, u32 arg2, u32 arg3, u32 *ret_payload);
pá 14. 1. 2022 v 13:25 odesílatel Michal Simek michal.simek@xilinx.com napsal:
Thanks, Michal
-- 2.34.1
Applied. M
Michal Simek
Michal Simek
