[U-Boot] [PATCH] udoo: Add initial support for mx6q udoo board
Add basic support for mx6q udoo board.
For further information about Udoo board: http://www.udoo.org/
Tested booting a mainline device tree kernel and a Yocto rootfs from mmc.
Signed-off-by: Fabio Estevam fabio.estevam@freescale.com --- board/udoo/Makefile | 26 +++++++ board/udoo/udoo.c | 110 ++++++++++++++++++++++++++ boards.cfg | 1 + include/configs/udoo.h | 206 +++++++++++++++++++++++++++++++++++++++++++++++++ 4 files changed, 343 insertions(+) create mode 100644 board/udoo/Makefile create mode 100644 board/udoo/udoo.c create mode 100644 include/configs/udoo.h
diff --git a/board/udoo/Makefile b/board/udoo/Makefile new file mode 100644 index 0000000..1f0f6c7 --- /dev/null +++ b/board/udoo/Makefile @@ -0,0 +1,26 @@ +# +# (C) Copyright 2013 Freescale Semiconductor, Inc. +# +# SPDX-License-Identifier: GPL-2.0+ +# + +include $(TOPDIR)/config.mk + +LIB = $(obj)lib$(BOARD).o + +COBJS := udoo.o + +SRCS := $(COBJS:.o=.c) +OBJS := $(addprefix $(obj),$(COBJS)) + +$(LIB): $(obj).depend $(OBJS) + $(call cmd_link_o_target, $(OBJS)) + +######################################################################### + +# defines $(obj).depend target +include $(SRCTREE)/rules.mk + +sinclude $(obj).depend + +######################################################################### diff --git a/board/udoo/udoo.c b/board/udoo/udoo.c new file mode 100644 index 0000000..180d0c9 --- /dev/null +++ b/board/udoo/udoo.c @@ -0,0 +1,110 @@ +/* + * Copyright (C) 2013 Freescale Semiconductor, Inc. + * + * Author: Fabio Estevam fabio.estevam@freescale.com + * + * SPDX-License-Identifier: GPL-2.0+ + */ + +#include <asm/arch/clock.h> +#include <asm/arch/imx-regs.h> +#include <asm/arch/iomux.h> +#include <asm/arch/mx6-pins.h> +#include <asm/errno.h> +#include <asm/gpio.h> +#include <asm/imx-common/iomux-v3.h> +#include <mmc.h> +#include <fsl_esdhc.h> +#include <asm/arch/crm_regs.h> +#include <asm/io.h> +#include <asm/arch/sys_proto.h> + +DECLARE_GLOBAL_DATA_PTR; + +#define UART_PAD_CTRL (PAD_CTL_PUS_100K_UP | \ + PAD_CTL_SPEED_MED | PAD_CTL_DSE_40ohm | \ + PAD_CTL_SRE_FAST | PAD_CTL_HYS) + +#define USDHC_PAD_CTRL (PAD_CTL_PUS_47K_UP | \ + PAD_CTL_SPEED_LOW | PAD_CTL_DSE_80ohm | \ + PAD_CTL_SRE_FAST | PAD_CTL_HYS) + +#define WDT_EN IMX_GPIO_NR(5, 4) +#define WDT_TRG IMX_GPIO_NR(3, 19) + +int dram_init(void) +{ + gd->ram_size = (phys_size_t)CONFIG_DDR_MB * 1024 * 1024; + + return 0; +} + +static iomux_v3_cfg_t const uart2_pads[] = { + MX6_PAD_EIM_D26__UART2_TXD | MUX_PAD_CTRL(UART_PAD_CTRL), + MX6_PAD_EIM_D27__UART2_RXD | MUX_PAD_CTRL(UART_PAD_CTRL), +}; + +static iomux_v3_cfg_t const usdhc3_pads[] = { + MX6_PAD_SD3_CLK__USDHC3_CLK | MUX_PAD_CTRL(USDHC_PAD_CTRL), + MX6_PAD_SD3_CMD__USDHC3_CMD | MUX_PAD_CTRL(USDHC_PAD_CTRL), + MX6_PAD_SD3_DAT0__USDHC3_DAT0 | MUX_PAD_CTRL(USDHC_PAD_CTRL), + MX6_PAD_SD3_DAT1__USDHC3_DAT1 | MUX_PAD_CTRL(USDHC_PAD_CTRL), + MX6_PAD_SD3_DAT2__USDHC3_DAT2 | MUX_PAD_CTRL(USDHC_PAD_CTRL), + MX6_PAD_SD3_DAT3__USDHC3_DAT3 | MUX_PAD_CTRL(USDHC_PAD_CTRL), +}; + +static iomux_v3_cfg_t const wdog_pads[] = { + MX6_PAD_EIM_A24__GPIO_5_4 | MUX_PAD_CTRL(NO_PAD_CTRL), + MX6_PAD_EIM_D19__GPIO_3_19, +}; + +static void setup_iomux_uart(void) +{ + imx_iomux_v3_setup_multiple_pads(uart2_pads, ARRAY_SIZE(uart2_pads)); +} + +static void setup_iomux_wdog(void) +{ + imx_iomux_v3_setup_multiple_pads(wdog_pads, ARRAY_SIZE(wdog_pads)); + gpio_direction_output(WDT_TRG, 0); + gpio_direction_output(WDT_EN, 1); +} + +static struct fsl_esdhc_cfg usdhc_cfg = { USDHC3_BASE_ADDR }; + +int board_mmc_getcd(struct mmc *mmc) +{ + return 1; /* Always present */ +} + +int board_mmc_init(bd_t *bis) +{ + imx_iomux_v3_setup_multiple_pads(usdhc3_pads, ARRAY_SIZE(usdhc3_pads)); + usdhc_cfg.sdhc_clk = mxc_get_clock(MXC_ESDHC3_CLK); + usdhc_cfg.max_bus_width = 4; + + return fsl_esdhc_initialize(bis, &usdhc_cfg); +} + +int board_early_init_f(void) +{ + setup_iomux_wdog(); + setup_iomux_uart(); + + return 0; +} + +int board_init(void) +{ + /* address of boot parameters */ + gd->bd->bi_boot_params = PHYS_SDRAM + 0x100; + + return 0; +} + +int checkboard(void) +{ + puts("Board: Udoo\n"); + + return 0; +} diff --git a/boards.cfg b/boards.cfg index 9fc77fb..66c998a 100644 --- a/boards.cfg +++ b/boards.cfg @@ -283,6 +283,7 @@ Active arm armv7 mx5 freescale mx53smd Active arm armv7 mx5 genesi mx51_efikamx mx51_efikamx mx51_efikamx:MACH_TYPE=MACH_TYPE_MX51_EFIKAMX,IMX_CONFIG=board/genesi/mx51_efikamx/imximage_mx.cfg - Active arm armv7 mx5 genesi mx51_efikamx mx51_efikasb mx51_efikamx:MACH_TYPE=MACH_TYPE_MX51_EFIKASB,IMX_CONFIG=board/genesi/mx51_efikamx/imximage_sb.cfg - Active arm armv7 mx5 ttcontrol vision2 vision2 vision2:IMX_CONFIG=board/ttcontrol/vision2/imximage_hynix.cfg Stefano Babic sbabic@denx.de +Active arm armv7 mx6 - udoo udoo_quad udoo:IMX_CONFIG=board/boundary/nitrogen6x/nitrogen6q.cfg,MX6Q,DDR_MB=1024 Fabio Estevam fabio.estevam@freescale.com Active arm armv7 mx6 - wandboard wandboard_dl wandboard:IMX_CONFIG=board/boundary/nitrogen6x/nitrogen6dl.cfg,MX6DL,DDR_MB=1024 Fabio Estevam fabio.estevam@freescale.com Active arm armv7 mx6 - wandboard wandboard_quad wandboard:IMX_CONFIG=board/boundary/nitrogen6x/nitrogen6q2g.cfg,MX6Q,DDR_MB=2048 Fabio Estevam fabio.estevam@freescale.com Active arm armv7 mx6 - wandboard wandboard_solo wandboard:IMX_CONFIG=board/boundary/nitrogen6x/nitrogen6s.cfg,MX6S,DDR_MB=512 Fabio Estevam fabio.estevam@freescale.com diff --git a/include/configs/udoo.h b/include/configs/udoo.h new file mode 100644 index 0000000..78df071 --- /dev/null +++ b/include/configs/udoo.h @@ -0,0 +1,206 @@ +/* + * Copyright (C) 2013 Freescale Semiconductor, Inc. + * + * Configuration settings for Udoo board. + * + * SPDX-License-Identifier: GPL-2.0+ + */ + +#ifndef __CONFIG_H +#define __CONFIG_H + +#include <asm/arch/imx-regs.h> +#include <asm/imx-common/gpio.h> +#include <asm/sizes.h> + +#define CONFIG_MX6 +#define CONFIG_DISPLAY_CPUINFO +#define CONFIG_DISPLAY_BOARDINFO + +#define MACH_TYPE_UDOO 4800 +#define CONFIG_MACH_TYPE MACH_TYPE_UDOO + +#define CONFIG_CMDLINE_TAG +#define CONFIG_SETUP_MEMORY_TAGS +#define CONFIG_INITRD_TAG +#define CONFIG_REVISION_TAG + +/* Size of malloc() pool */ +#define CONFIG_SYS_MALLOC_LEN (2 * SZ_1M) + +#define CONFIG_BOARD_EARLY_INIT_F +#define CONFIG_MXC_GPIO + +#define CONFIG_MXC_UART +#define CONFIG_MXC_UART_BASE UART2_BASE + +/* allow to overwrite serial and ethaddr */ +#define CONFIG_ENV_OVERWRITE +#define CONFIG_CONS_INDEX 1 +#define CONFIG_BAUDRATE 115200 + +/* Command definition */ +#include <config_cmd_default.h> + +#undef CONFIG_CMD_IMLS + +#define CONFIG_CMD_BMODE +#define CONFIG_CMD_SETEXPR + +#define CONFIG_BOOTDELAY 3 + +#define CONFIG_SYS_MEMTEST_START 0x10000000 +#define CONFIG_SYS_MEMTEST_END (CONFIG_SYS_MEMTEST_START + 500 * SZ_1M) +#define CONFIG_LOADADDR 0x12000000 +#define CONFIG_SYS_TEXT_BASE 0x17800000 + +/* MMC Configuration */ +#define CONFIG_FSL_ESDHC +#define CONFIG_FSL_USDHC +#define CONFIG_SYS_FSL_ESDHC_ADDR 0 + +#define CONFIG_MMC +#define CONFIG_CMD_MMC +#define CONFIG_GENERIC_MMC +#define CONFIG_BOUNCE_BUFFER +#define CONFIG_CMD_EXT2 +#define CONFIG_CMD_FAT +#define CONFIG_DOS_PARTITION + +#define CONFIG_DEFAULT_FDT_FILE "imx6q-udoo.dtb" + +#define CONFIG_EXTRA_ENV_SETTINGS \ + "script=boot.scr\0" \ + "uimage=uImage\0" \ + "console=ttymxc1\0" \ + "splashpos=m,m\0" \ + "fdt_high=0xffffffff\0" \ + "initrd_high=0xffffffff\0" \ + "fdt_file=" CONFIG_DEFAULT_FDT_FILE "\0" \ + "fdt_addr=0x11000000\0" \ + "boot_fdt=try\0" \ + "ip_dyn=yes\0" \ + "mmcdev=0\0" \ + "mmcpart=1\0" \ + "mmcroot=/dev/mmcblk0p2 rootwait rw\0" \ + "update_sd_firmware_filename=u-boot.imx\0" \ + "update_sd_firmware=" \ + "if test ${ip_dyn} = yes; then " \ + "setenv get_cmd dhcp; " \ + "else " \ + "setenv get_cmd tftp; " \ + "fi; " \ + "if mmc dev ${mmcdev}; then " \ + "if ${get_cmd} ${update_sd_firmware_filename}; then " \ + "setexpr fw_sz ${filesize} / 0x200; " \ + "setexpr fw_sz ${fw_sz} + 1; " \ + "mmc write ${loadaddr} 0x2 ${fw_sz}; " \ + "fi; " \ + "fi\0" \ + "mmcargs=setenv bootargs console=${console},${baudrate} " \ + "root=${mmcroot}\0" \ + "loadbootscript=" \ + "fatload mmc ${mmcdev}:${mmcpart} ${loadaddr} ${script};\0" \ + "bootscript=echo Running bootscript from mmc ...; " \ + "source\0" \ + "loaduimage=fatload mmc ${mmcdev}:${mmcpart} ${loadaddr} ${uimage}\0" \ + "loadfdt=fatload mmc ${mmcdev}:${mmcpart} ${fdt_addr} ${fdt_file}\0" \ + "mmcboot=echo Booting from mmc ...; " \ + "run mmcargs; " \ + "if test ${boot_fdt} = yes || test ${boot_fdt} = try; then " \ + "if run loadfdt; then " \ + "bootm ${loadaddr} - ${fdt_addr}; " \ + "else " \ + "if test ${boot_fdt} = try; then " \ + "bootm; " \ + "else " \ + "echo WARN: Cannot load the DT; " \ + "fi; " \ + "fi; " \ + "else " \ + "bootm; " \ + "fi;\0" \ + "netargs=setenv bootargs console=${console},${baudrate} " \ + "root=/dev/nfs " \ + "ip=dhcp nfsroot=${serverip}:${nfsroot},v3,tcp\0" \ + "netboot=echo Booting from net ...; " \ + "run netargs; " \ + "if test ${ip_dyn} = yes; then " \ + "setenv get_cmd dhcp; " \ + "else " \ + "setenv get_cmd tftp; " \ + "fi; " \ + "${get_cmd} ${uimage}; " \ + "if test ${boot_fdt} = yes || test ${boot_fdt} = try; then " \ + "if ${get_cmd} ${fdt_addr} ${fdt_file}; then " \ + "bootm ${loadaddr} - ${fdt_addr}; " \ + "else " \ + "if test ${boot_fdt} = try; then " \ + "bootm; " \ + "else " \ + "echo WARN: Cannot load the DT; " \ + "fi; " \ + "fi; " \ + "else " \ + "bootm; " \ + "fi;\0" + +#define CONFIG_BOOTCOMMAND \ + "mmc dev ${mmcdev}; if mmc rescan; then " \ + "if run loadbootscript; then " \ + "run bootscript; " \ + "else " \ + "if run loaduimage; then " \ + "run mmcboot; " \ + "else run netboot; " \ + "fi; " \ + "fi; " \ + "else run netboot; fi" + +/* Miscellaneous configurable options */ +#define CONFIG_SYS_LONGHELP +#define CONFIG_SYS_HUSH_PARSER +#define CONFIG_SYS_PROMPT "=> " +#define CONFIG_AUTO_COMPLETE +#define CONFIG_SYS_CBSIZE 256 + +/* Print Buffer Size */ +#define CONFIG_SYS_PBSIZE (CONFIG_SYS_CBSIZE + sizeof(CONFIG_SYS_PROMPT) + 16) +#define CONFIG_SYS_MAXARGS 16 +#define CONFIG_SYS_BARGSIZE CONFIG_SYS_CBSIZE + +#define CONFIG_SYS_LOAD_ADDR CONFIG_LOADADDR +#define CONFIG_SYS_HZ 1000 + +#define CONFIG_CMDLINE_EDITING + +/* Physical Memory Map */ +#define CONFIG_NR_DRAM_BANKS 1 +#define PHYS_SDRAM MMDC0_ARB_BASE_ADDR + +#define CONFIG_SYS_SDRAM_BASE PHYS_SDRAM +#define CONFIG_SYS_INIT_RAM_ADDR IRAM_BASE_ADDR +#define CONFIG_SYS_INIT_RAM_SIZE IRAM_SIZE + +#define CONFIG_SYS_INIT_SP_OFFSET \ + (CONFIG_SYS_INIT_RAM_SIZE - GENERATED_GBL_DATA_SIZE) +#define CONFIG_SYS_INIT_SP_ADDR \ + (CONFIG_SYS_INIT_RAM_ADDR + CONFIG_SYS_INIT_SP_OFFSET) + +/* FLASH and environment organization */ +#define CONFIG_SYS_NO_FLASH + +#define CONFIG_ENV_SIZE (8 * 1024) + +#define CONFIG_ENV_IS_IN_MMC +#define CONFIG_ENV_OFFSET (6 * 64 * 1024) +#define CONFIG_SYS_MMC_ENV_DEV 0 + +#define CONFIG_OF_LIBFDT +#define CONFIG_CMD_BOOTZ + +#ifndef CONFIG_SYS_DCACHE_OFF +#define CONFIG_CMD_CACHE +#endif + +#endif /* __CONFIG_H * */
Applied to u-boot-imx, -next branch, thanks !
Best regards, Stefano Babic
Fabio Estevam
Stefano Babic
