[U-Boot] [PATCH 2/3] iMX31: Add support to copy NAND Flash code to RAM
This code is executed from internal 2KB NAND Flash Controller RAM buffer and will copy the remaining U-Boot code from NAND Flash verifying its bad blocks (case it exists).
Signed-off-by: Alan Carvalho de Assis alan.assis@freescale.com --- cpu/arm1136/mx31/Makefile | 2 + cpu/arm1136/mx31/nand_copy.S | 263 +++++++++++++++++++++++++++++++++ include/asm-arm/arch-mx31/mx31-regs.h | 69 +++++++++ 3 files changed, 334 insertions(+), 0 deletions(-) create mode 100644 cpu/arm1136/mx31/nand_copy.S
diff --git a/cpu/arm1136/mx31/Makefile b/cpu/arm1136/mx31/Makefile index b648ffd..0490706 100644 --- a/cpu/arm1136/mx31/Makefile +++ b/cpu/arm1136/mx31/Makefile @@ -26,7 +26,9 @@ include $(TOPDIR)/config.mk LIB = $(obj)lib$(SOC).a
COBJS = interrupts.o serial.o generic.o +SOBJS-$(CONFIG_BOOT_FROM_NAND) = nand_copy.o
+SOBJS := $(SOBJS-y) SRCS := $(SOBJS:.o=.S) $(COBJS:.o=.c) OBJS := $(addprefix $(obj),$(SOBJS) $(COBJS))
diff --git a/cpu/arm1136/mx31/nand_copy.S b/cpu/arm1136/mx31/nand_copy.S new file mode 100644 index 0000000..7a2460c --- /dev/null +++ b/cpu/arm1136/mx31/nand_copy.S @@ -0,0 +1,263 @@ +/* + * Copyright (C) 2008 Freescale Semiconductor, Inc. + * + * Alan Carvalho de Assis alan.assis@freescale.com + * based on iMX31PDK RedBoot_200814 code. + * + * This program is free software; you can redistribute it and/or + * modify it under the terms of the GNU General Public License as + * published by the Free Software Foundation; either version 2 of + * the License, or (at your option) any later version. + * + * This program is distributed in the hope that it will be useful, + * but WITHOUT ANY WARRANTY; without even the implied warranty of + * MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE. See the + * GNU General Public License for more details. + * + * You should have received a copy of the GNU General Public License + * along with this program; if not, write to the Free Software + * Foundation, Inc., 59 Temple Place, Suite 330, Boston, + * MA 02111-1307 USA + */ + +#include <config.h> +#include <asm/arch/mx31-regs.h> + +.macro do_addr_input + and r3, r3, #0xFF + strh r3, [r12, #NFC_FLASH_ADDR_OFF] + mov r3, #NAND_FLASH_CONFIG2_FADD_EN + strh r3, [r12, #NFC_CONFIG2_OFF] + bl do_wait_op_done +.endm /* do_addr_input */ + +do_wait_op_done: +1: ldrh r3, [r12, #NFC_CONFIG2_OFF] + ands r3, r3, #NAND_FLASH_CONFIG2_INT_DONE + beq 1b + bx lr + +nfc_data_output: + mov r3, #(NAND_FLASH_CONFIG1_INT_MSK | NAND_FLASH_CONFIG1_ECC_EN) + strh r3, [r12, #NFC_CONFIG1_OFF] + strh r8, [r12, #NFC_BUF_ADDR_OFF] + mov r3, #FDO_PAGE_SPARE_VAL + strh r3, [r12, #NFC_CONFIG2_OFF] + bx lr + +.globl nand_copy +nand_copy: + /* Copy image from flash to SDRAM first */ + mov r0, #NFC_BASE_ADDR + add r2, r0, #0x800 /* 2K window */ + ldr r1, MXC_UBOOT_ROM_START + +1: ldmia r0!, {r3-r10} + stmia r1!, {r3-r10} + cmp r0, r2 + blo 1b + /* Jump to SDRAM */ + ldr r1, =0x0FFF + and r0, pc, r1 /* offset of pc */ + ldr r1, MXC_UBOOT_ROM_START + add r1, r1, #0x10 + add pc, r0, r1 + nop + nop + nop + nop + +nand_copy_main: + /* Check if x16/2kb page */ + ldr r7, =CCM_BASE + ldr r7, [r7, #0xC] + ands r7, r7, #(1 << 30) + + mov r0, #NAND_FLASH_BOOT + ldr r1, =AVIC_VECTOR0 + str r0, [r1] + mov r0, #MXCFIS_NAND + ldr r1, =AVIC_VECTOR1 + str r0, [r1] + + mov r0, #NFC_BASE_ADDR /* r0: nfc base. Reloaded after each page copying */ + mov r1, #0x800 /* r1: starting flash addr to be copied. Updated constantly */ + add r2, r0, #0x800 /* r2: end of 3rd RAM buf. Doesn't change */ + addeq r2, r0, #0x200 /* r2: end of 1st RAM buf. Doesn't change (only set for small page NAND) */ + add r12, r0, #0xE00 /* r12: NFC register base. Doesn't change */ + ldr r11, MXC_UBOOT_ROM_START + add r13, r11, #0x40000 /* r13: end of SDRAM address for copying. Doesn't change */ + add r11, r11, r1 /* r11: starting SDRAM address for copying. Updated constantly */ + + /* unlock internal buffer */ + mov r3, #0x2 + strh r3, [r12, #0xA] + +nfc_read_page: + mov r3, #0x0 + strh r3, [r12, #NFC_FLASH_CMD_OFF] + mov r3, #NAND_FLASH_CONFIG2_FCMD_EN + strh r3, [r12, #NFC_CONFIG2_OFF] + bl do_wait_op_done + + /* Check if x16/2kb page */ + ldr r7, =CCM_BASE + ldr r7, [r7, #0xC] + ands r7, r7, #(1 << 30) + bne nfc_addr_ops_2kb + + /* 1st addr cycle */ + mov r3, r1 + do_addr_input + /* 1st addr cycle */ + mov r3, r1, lsr #9 + do_addr_input + /* 1st addr cycle */ + mov r3, r1, lsr #17 + do_addr_input + /* 1st addr cycle */ + mov r3, r1, lsr #25 + do_addr_input + b end_of_nfc_addr_ops + +nfc_addr_ops_2kb: + /* 1st addr cycle */ + mov r3, #0 + and r3, r3, #0xFF + strh r3, [r12, #NFC_FLASH_ADDR_OFF] + mov r3, #NAND_FLASH_CONFIG2_FADD_EN + strh r3, [r12, #NFC_CONFIG2_OFF] + bl do_wait_op_done + mov r3, #0 + /* 2nd addr cycle */ + and r3, r3, #0xFF + strh r3, [r12, #NFC_FLASH_ADDR_OFF] + mov r3, #NAND_FLASH_CONFIG2_FADD_EN + strh r3, [r12, #NFC_CONFIG2_OFF] + bl do_wait_op_done + mov r3, r1, lsr #11 + /* 3rd addr cycle */ + and r3, r3, #0xFF + strh r3, [r12, #NFC_FLASH_ADDR_OFF] + mov r3, #NAND_FLASH_CONFIG2_FADD_EN + strh r3, [r12, #NFC_CONFIG2_OFF] + bl do_wait_op_done + mov r3, r1, lsr #19 + /* 4th addr cycle */ + and r3, r3, #0xFF + strh r3, [r12, #NFC_FLASH_ADDR_OFF] + mov r3, #NAND_FLASH_CONFIG2_FADD_EN + strh r3, [r12, #NFC_CONFIG2_OFF] + bl do_wait_op_done + mov r3, r1, lsr #27 + /* 5th addr cycle */ + and r3, r3, #0xFF + strh r3, [r12, #NFC_FLASH_ADDR_OFF] + mov r3, #NAND_FLASH_CONFIG2_FADD_EN + strh r3, [r12, #NFC_CONFIG2_OFF] + bl do_wait_op_done + + mov r3, #0x30 + strh r3, [r12, #NFC_FLASH_CMD_OFF] + mov r3, #NAND_FLASH_CONFIG2_FCMD_EN + strh r3, [r12, #NFC_CONFIG2_OFF] + bl do_wait_op_done + +end_of_nfc_addr_ops: + mov r8, #0 + bl nfc_data_output + bl do_wait_op_done + + /* Check if x16/2kb page */ + ldr r7, =CCM_BASE + ldr r7, [r7, #0xC] + ands r7, r7, #(1 << 30) + beq nfc_addr_data_output_done_512 + + /* For 2K page - 2nd 512 */ + mov r8, #1 + bl nfc_data_output + bl do_wait_op_done + + /* 3rd 512 */ + mov r8, #2 + bl nfc_data_output + bl do_wait_op_done + + /* 4th 512 */ + mov r8, #3 + bl nfc_data_output + bl do_wait_op_done + + /* check for bad block */ + mov r3, r1, lsl #(32-17) /* get rid of block number */ + cmp r3, #(0x800 << (32-17)) /* check if not page 0 or 1 */ + b nfc_addr_data_output_done + +nfc_addr_data_output_done_512: + /* check for bad block */ + mov r3, r1, lsl #(32-5-9) /* get rid of block number */ + cmp r3, #(512 << (32-5-9)) /* check if not page 0 or 1 */ + +nfc_addr_data_output_done: + bhi copy_good_blk + add r4, r0, #0x800 /* r3 -> spare area buf 0 */ + ldrh r4, [r4, #0x4] + and r4, r4, #0xFF00 + cmp r4, #0xFF00 + beq copy_good_blk + /* really sucks. Bad block!!!! */ + cmp r3, #0x0 + beq skip_bad_block + + /* even suckier since we already read the first page! */ + /* Check if x16/2kb page */ + ldr r7, =CCM_BASE + ldr r7, [r7, #0xC] + ands r7, r7, #(1 << 30) + + subeq r11, r11, #512 /* rewind 1 page for the sdram pointer */ + subeq r1, r1, #512 /* rewind 1 page for the flash pointer */ + + /* for 2k page */ + subne r11, r11, #0x800 /* rewind 1 page for the sdram pointer */ + subne r1, r1, #0x800 /* rewind 1 page for the flash pointer */ + +skip_bad_block: + /* Check if x16/2kb page */ + ldr r7, =CCM_BASE + ldr r7, [r7, #0xC] + ands r7, r7, #(1 << 30) + + addeq r1, r1, #(32*512) + addne r1, r1, #(64*2048) + b nfc_read_page + +copy_good_blk: + /* copying page */ +1: ldmia r0!, {r3-r10} + stmia r11!, {r3-r10} + cmp r0, r2 + blo 1b + cmp r11, r13 + bge nand_copy_main_done + /* Check if x16/2kb page */ + ldr r7, =CCM_BASE + ldr r7, [r7, #0xC] + ands r7, r7, #(1 << 30) + + addeq r1, r1, #0x200 + addne r1, r1, #0x800 + mov r0, #NFC_BASE_ADDR + b nfc_read_page + +nand_copy_main_done: + /* Restore stack pointer since sp has been re-used in this file */ + ldr sp, =CFG_INTERNAL_SRAM_STACK + /* Restore return address and return to caller */ + ldr lr, [sp] + bx lr + +MXC_UBOOT_ROM_START: .word 0x87F00000 +UBOOT_IMAGE_SIZE: .word 0x40000 + diff --git a/include/asm-arm/arch-mx31/mx31-regs.h b/include/asm-arm/arch-mx31/mx31-regs.h index b04a718..1c5c121 100644 --- a/include/asm-arm/arch-mx31/mx31-regs.h +++ b/include/asm-arm/arch-mx31/mx31-regs.h @@ -84,8 +84,14 @@ #define IPU_CONF_IC_EN (1<<1) #define IPU_CONF_SCI_EN (1<<0)
+#define ARM_PPMRR 0x40000015 + #define WDOG_BASE 0x53FDC000
+#define AVIC_BASE 0x68000000 +#define AVIC_VECTOR0 (AVIC_BASE + 0x100) +#define AVIC_VECTOR1 (AVIC_BASE + 0x104) + /* * Signal Multiplexing (IOMUX) */ @@ -168,4 +174,67 @@ #define CS5_BASE 0xB6000000 #define PCMCIA_MEM_BASE 0xC0000000
+/* + * NAND controller + */ +#define NFC_BASE_ADDR 0xB8000000 +#define NFC_REGS (NFC_BASE_ADDR + 0xE00) + +/* + * Addresses for NFC registers + */ +#define NFC_BUF_SIZE_OFF 0 +#define NFC_BUF_SIZE (*((volatile u16 *)(NFC_REGS + NFC_BUF_SIZE_OFF))) +#define NFC_BUF_ADDR_OFF 0x04 +#define NFC_BUF_ADDR (*((volatile u16 *)(NFC_REGS + NFC_BUF_ADDR_OFF))) +#define NFC_FLASH_ADDR_OFF 0x06 +#define NFC_FLASH_ADDR (*((volatile u16 *)(NFC_REGS + NFC_FLASH_ADDR_OFF))) +#define NFC_FLASH_CMD_OFF 0x08 +#define NFC_FLASH_CMD (*((volatile u16 *)(NFC_REGS + NFC_FLASH_CMD_OFF))) +#define NFC_CONFIG_OFF 0x0A +#define NFC_CONFIG (*((volatile u16 *)(NFC_REGS + NFC_CONFIG_OFF))) +#define NFC_ECC_RSLT_OFF 0x0C +#define NFC_ECC_STATUS_RESULT (*((volatile u16 *)(NFC_REGS + NFC_ECC_RSLT_OFF))) +#define NFC_RSLTMAIN_AREA_OFF 0x0E +#define NFC_RSLTMAIN_AREA (*((volatile u16 *)(NFC_REGS + NFC_RSLTMAIN_AREA_OFF))) +#define NFC_RSLTSPARE_AREA_OFF 0x10 +#define NFC_RSLTSPARE_AREA (*((volatile u16 *)(NFC_REGS + NFC_RSLTSPARE_AREA_OFF))) +#define NFC_WRPROT_OFF 0x12 +#define NFC_WRPROT (*((volatile u16 *)(NFC_REGS + NFC_WRPROT_OFF))) +#define NFC_UNLCKSTART_BLK_OFF 0x14 +#define NFC_UNLCKSTART_BLKADDR (*((volatile u16 *)(NFC_REGS + NFC_UNLOCKSTART_BLK_OFF))) +#define NFC_UNLCKEND_BLK_OFF 0x16 +#define NFC_UNLCKEND_BLKADDR (*((volatile u16 *)(NFC_REGS + NFC_UNLOCKEND_BLK_OFF))) +#define NFC_NF_WRPRST_OFF 0x18 +#define NFC_NF_WRPRST (*((volatile u16 *)(NFC_REGS + NFC_NF_WRPRST_OFF))) +#define NFC_CONFIG1_OFF 0x1A +#define NFC_CONFIG1 (*((volatile u16 *)(NFC_REGS + NFC_CONFIG1_OFF))) +#define NFC_CONFIG2_OFF 0x1C +#define NFC_CONFIG2 (*((volatile u16 *)(NFC_REGS + NFC_CONFIG2_OFF))) + +#define RAM_BUFFER_ADDRESS_RBA_3 0x3 +#define NFC_BUFSIZE_1KB 0x0 +#define NFC_BUFSIZE_2KB 0x1 +#define NFC_CONFIGURATION_UNLOCKED 0x2 +#define ECC_STATUS_RESULT_NO_ERR 0x0 +#define ECC_STATUS_RESULT_1BIT_ERR 0x1 +#define ECC_STATUS_RESULT_2BIT_ERR 0x2 +#define NF_WR_PROT_UNLOCK 0x4 +#define NAND_FLASH_CONFIG1_FORCE_CE (1 << 7) +#define NAND_FLASH_CONFIG1_RST (1 << 6) +#define NAND_FLASH_CONFIG1_BIG (1 << 5) +#define NAND_FLASH_CONFIG1_INT_MSK (1 << 4) +#define NAND_FLASH_CONFIG1_ECC_EN (1 << 3) +#define NAND_FLASH_CONFIG1_SP_EN (1 << 2) +#define NAND_FLASH_CONFIG2_INT_DONE (1 << 15) +#define NAND_FLASH_CONFIG2_FDO_PAGE (0 << 3) +#define NAND_FLASH_CONFIG2_FDO_ID (2 << 3) +#define NAND_FLASH_CONFIG2_FDO_STATUS (4 << 3) +#define NAND_FLASH_CONFIG2_FDI_EN (1 << 2) +#define NAND_FLASH_CONFIG2_FADD_EN (1 << 1) +#define NAND_FLASH_CONFIG2_FCMD_EN (1 << 0) +#define FDO_PAGE_SPARE_VAL 0x8 +#define NAND_FLASH_BOOT 0x10000000 +#define MXCFIS_NAND 0x10000000 + #endif /* __ASM_ARCH_MX31_REGS_H */
Last time Scott Wood suggested to use nand_spl you replied "I think using nand_spl is the best approach, but it will needs more effort to complete." and "Anyway, right now we can have iMX31PDK booting with this code as an option for users willing to use U-Boot in this board." So, what's the status of this effort? If this your new submission, which still doesn't use nand_spl is not really targeted for upstream merge, I think, it would be better not to mark these mails "PATCH". Or have I missed anything?
Thanks Guennadi
- Copyright (C) 2008 Freescale Semiconductor, Inc.
- Alan Carvalho de Assis alan.assis@freescale.com
- based on iMX31PDK RedBoot_200814 code.
- MA 02111-1307 USA
- and r3, r3, #0xFF
- strh r3, [r12, #NFC_FLASH_ADDR_OFF]
- mov r3, #NAND_FLASH_CONFIG2_FADD_EN
- strh r3, [r12, #NFC_CONFIG2_OFF]
- bl do_wait_op_done
- ands r3, r3, #NAND_FLASH_CONFIG2_INT_DONE
- beq 1b
- bx lr
+nfc_data_output:
- mov r3, #(NAND_FLASH_CONFIG1_INT_MSK | NAND_FLASH_CONFIG1_ECC_EN)
- strh r3, [r12, #NFC_CONFIG1_OFF]
- strh r8, [r12, #NFC_BUF_ADDR_OFF]
- mov r3, #FDO_PAGE_SPARE_VAL
- bx lr
- /* Copy image from flash to SDRAM first */
- mov r0, #NFC_BASE_ADDR
- add r2, r0, #0x800 /* 2K window */
- ldr r1, MXC_UBOOT_ROM_START
- stmia r1!, {r3-r10}
- cmp r0, r2
- blo 1b
- /* Jump to SDRAM */
- ldr r1, =0x0FFF
- and r0, pc, r1 /* offset of pc */
- add r1, r1, #0x10
- add pc, r0, r1
- nop
- nop
- nop
- nop
+nand_copy_main:
- /* Check if x16/2kb page */
- ldr r7, =CCM_BASE
- ldr r7, [r7, #0xC]
- ands r7, r7, #(1 << 30)
- mov r0, #NAND_FLASH_BOOT
- ldr r1, =AVIC_VECTOR0
- str r0, [r1]
- mov r0, #MXCFIS_NAND
- ldr r1, =AVIC_VECTOR1
- str r0, [r1]
- mov r0, #NFC_BASE_ADDR /* r0: nfc base. Reloaded after each page copying */
- mov r1, #0x800 /* r1: starting flash addr to be copied.
- add r2, r0, #0x800 /* r2: end of 3rd RAM buf. Doesn't change */
- addeq r2, r0, #0x200 /* r2: end of 1st RAM buf. Doesn't change
- add r12, r0, #0xE00 /* r12: NFC register base. Doesn't change */
- ldr r11, MXC_UBOOT_ROM_START
- add r13, r11, #0x40000 /* r13: end of SDRAM address for copying.
Doesn't change */
- add r11, r11, r1 /* r11: starting SDRAM address for copying.
- /* unlock internal buffer */
- mov r3, #0x2
- strh r3, [r12, #0xA]
+nfc_read_page:
- mov r3, #0x0
- strh r3, [r12, #NFC_FLASH_CMD_OFF]
- mov r3, #NAND_FLASH_CONFIG2_FCMD_EN
- ldr r7, =CCM_BASE
- bne nfc_addr_ops_2kb
- /* 1st addr cycle */
- mov r3, r1
- do_addr_input
- mov r3, r1, lsr #9
- do_addr_input
- mov r3, r1, lsr #17
- do_addr_input
- mov r3, r1, lsr #25
- do_addr_input
- b end_of_nfc_addr_ops
+nfc_addr_ops_2kb:
- mov r3, #0
- and r3, r3, #0xFF
- mov r3, #0
- /* 2nd addr cycle */
- and r3, r3, #0xFF
- mov r3, r1, lsr #11
- /* 3rd addr cycle */
- and r3, r3, #0xFF
- mov r3, r1, lsr #19
- /* 4th addr cycle */
- and r3, r3, #0xFF
- mov r3, r1, lsr #27
- /* 5th addr cycle */
- and r3, r3, #0xFF
- mov r3, #0x30
- mov r8, #0
- bl nfc_data_output
- ldr r7, =CCM_BASE
- beq nfc_addr_data_output_done_512
- /* For 2K page - 2nd 512 */
- mov r8, #1
- /* 3rd 512 */
- mov r8, #2
- /* 4th 512 */
- mov r8, #3
- /* check for bad block */
- mov r3, r1, lsl #(32-17) /* get rid of block number */
- cmp r3, #(0x800 << (32-17)) /* check if not page 0 or 1 */
- b nfc_addr_data_output_done
- mov r3, r1, lsl #(32-5-9) /* get rid of block number */
- cmp r3, #(512 << (32-5-9)) /* check if not page 0 or 1 */
- bhi copy_good_blk
- add r4, r0, #0x800 /* r3 -> spare area buf 0 */
- ldrh r4, [r4, #0x4]
- and r4, r4, #0xFF00
- cmp r4, #0xFF00
- beq copy_good_blk
- /* really sucks. Bad block!!!! */
- cmp r3, #0x0
- beq skip_bad_block
- /* even suckier since we already read the first page! */
- ldr r7, =CCM_BASE
- subeq r11, r11, #512 /* rewind 1 page for the sdram pointer */
- subeq r1, r1, #512 /* rewind 1 page for the flash pointer */
- /* for 2k page */
- subne r11, r11, #0x800 /* rewind 1 page for the sdram pointer */
- subne r1, r1, #0x800 /* rewind 1 page for the flash pointer */
+skip_bad_block:
- ldr r7, =CCM_BASE
- addeq r1, r1, #(32*512)
- addne r1, r1, #(64*2048)
- b nfc_read_page
+copy_good_blk:
- /* copying page */
- stmia r11!, {r3-r10}
- cmp r0, r2
- blo 1b
- cmp r11, r13
- bge nand_copy_main_done
- ldr r7, =CCM_BASE
- addeq r1, r1, #0x200
- addne r1, r1, #0x800
- b nfc_read_page
- /* Restore stack pointer since sp has been re-used in this file */
- ldr sp, =CFG_INTERNAL_SRAM_STACK
- /* Restore return address and return to caller */
- ldr lr, [sp]
- bx lr
- Signal Multiplexing (IOMUX)
- NAND controller
- Addresses for NFC registers
1.5.4.3 _______________________________________________ U-Boot mailing list U-Boot@lists.denx.de http://lists.denx.de/mailman/listinfo/u-boot
--- Guennadi Liakhovetski, Ph.D.
DENX Software Engineering GmbH, MD: Wolfgang Denk & Detlev Zundel HRB 165235 Munich, Office: Kirchenstr.5, D-82194 Groebenzell, Germany Phone: +49-8142-66989-0 Fax: +49-8142-66989-80 Email: office@denx.de
Hi Guennadi,
This patch is just a rebase of previous patch, to be merged on u-boot-arm/master repository. I don't have nand_spl working until now.
I am new sending patches to u-boot mailing list. So what is the problem when calling it of "PATCH"? Please, let me know about my mistake, can you explain about it?
Thanks Guennadi
Best Regards,
Alan
Hi Guennadi,
My understanding was, that the patch in this form, i.e., not using nand_spl should _not_ be accepted in the mainline and you sent it to the list just as a FYI for users willing to use your solution. That's why I suggested not to mark it as a "PATCH." I haven't followed discussions of your previous submissions of this patch very closely, so I might have missed something, but I would agree with Scott and wait until a nand_spl version of this patch appears, and _not_ apply this patch in its present form.
Thanks Guennadi --- Guennadi Liakhovetski, Ph.D.
Dear Alan,
In message 37367b3a0810231758y5a3ad19do42e40fbf5128f0@mail.gmail.com you wrote:
It will not be merged to arm/master ...
...because we are waiting for nand_spl code.
The problem is that we told you we will only add code that fits intop the existing framework, i. e. nand_spl
2008/10/24 Wolfgang Denk wd@denx.de:
Dear Alan,
Where can one find developer documentation for nand_spl? Also, is there any ARM board supporting this already?
The nand_spl for the i.MX31 has to fit within 2048 bytes, along with some of the usual low_levelinit.S stuff.
/Magnus
doc/README.nand-boot-ppc440
nand_spl/board/samsung/smdk6400/
src/u-boot$ ls -l nand_spl/u-boot-spl.bin -rwxrwxr-x 1 ***** ***** 2840 2008-10-23 09:22 nand_spl/u-boot-spl.bin
So, you "just" need to reduce it by about 30%:-)
Also, for anyone implementing a new nand_spl board, please, change the SPL-image name from nand_spl/u-boot-spl-16k.bin to something more flexible:-)
Hi Guennadi,
Thank you very much! I found your explanation very useful. Sorry about my mistake. Really is better get the right implementation integrated at first than apply other patch to remove the wrong implementation and add the new one.
I am going to implement it on nand_spl.
Thanks
Thank you very much,
Guennadi
Alan
Dear "Alan Carvalho de Assis",
In message 37367b3a0810230551m2aacfeb8l3b932f8f2a0b3058@mail.gmail.com you wrote:
NAK.
All this should be in nand_spl/, I think.
Scott, am I right?
NAK.
Scott, am I right?
Yes.
-Scott
participants (5)
Magnus Lilja
Scott Wood
