[U-Boot] [PATCH 1/6] mips: ath79: Rename get_bootstrap into ath79_get_bootstrap
Add a platform prefix for function name in order to make more readable, and move it into ath79.h
Signed-off-by: Wills Wang wills.wang@live.com Acked-by: Marek Vasut marex@denx.de ---
arch/mips/mach-ath79/ar933x/clk.c | 4 ++-- arch/mips/mach-ath79/ar933x/ddr.c | 4 ++-- arch/mips/mach-ath79/ar934x/clk.c | 6 +++--- arch/mips/mach-ath79/ar934x/ddr.c | 4 ++-- arch/mips/mach-ath79/include/mach/ath79.h | 1 + arch/mips/mach-ath79/include/mach/reset.h | 14 -------------- arch/mips/mach-ath79/qca953x/clk.c | 4 ++-- arch/mips/mach-ath79/qca953x/ddr.c | 4 ++-- arch/mips/mach-ath79/reset.c | 2 +- 9 files changed, 15 insertions(+), 28 deletions(-) delete mode 100644 arch/mips/mach-ath79/include/mach/reset.h
diff --git a/arch/mips/mach-ath79/ar933x/clk.c b/arch/mips/mach-ath79/ar933x/clk.c index 9fcd496..6d98efc 100644 --- a/arch/mips/mach-ath79/ar933x/clk.c +++ b/arch/mips/mach-ath79/ar933x/clk.c @@ -9,7 +9,7 @@ #include <asm/addrspace.h> #include <asm/types.h> #include <mach/ar71xx_regs.h> -#include <mach/reset.h> +#include <mach/ath79.h>
DECLARE_GLOBAL_DATA_PTR;
@@ -17,7 +17,7 @@ static u32 ar933x_get_xtal(void) { u32 val;
- val = get_bootstrap(); + val = ath79_get_bootstrap(); if (val & AR933X_BOOTSTRAP_REF_CLK_40) return 40000000; else diff --git a/arch/mips/mach-ath79/ar933x/ddr.c b/arch/mips/mach-ath79/ar933x/ddr.c index 7f20d34..2a25e23 100644 --- a/arch/mips/mach-ath79/ar933x/ddr.c +++ b/arch/mips/mach-ath79/ar933x/ddr.c @@ -10,7 +10,7 @@ #include <asm/addrspace.h> #include <asm/types.h> #include <mach/ar71xx_regs.h> -#include <mach/reset.h> +#include <mach/ath79.h>
@@ -114,7 +114,7 @@ void ddr_init(void) writel(DDR_CONF_REG_VAL, regs + AR71XX_DDR_REG_CONFIG); writel(DDR_CONF2_REG_VAL, regs + AR71XX_DDR_REG_CONFIG2);
- val = get_bootstrap(); + val = ath79_get_bootstrap(); if (val & AR933X_BOOTSTRAP_DDR2) { /* AHB maximum timeout */ writel(0xfffff, regs + AR933X_DDR_REG_TIMEOUT_MAX); diff --git a/arch/mips/mach-ath79/ar934x/clk.c b/arch/mips/mach-ath79/ar934x/clk.c index 9c65184..9b41d3d 100644 --- a/arch/mips/mach-ath79/ar934x/clk.c +++ b/arch/mips/mach-ath79/ar934x/clk.c @@ -9,7 +9,7 @@ #include <asm/addrspace.h> #include <asm/types.h> #include <mach/ar71xx_regs.h> -#include <mach/reset.h> +#include <mach/ath79.h> #include <wait_bit.h>
DECLARE_GLOBAL_DATA_PTR; @@ -119,7 +119,7 @@ void ar934x_pll_init(const u16 cpu_mhz, const u16 ddr_mhz, const u16 ahb_mhz) writel(0x03000000, srif_regs + 0x188); /* Undocumented reg :-) */
/* Test for 40MHz XTAL */ - reg = get_bootstrap(); + reg = ath79_get_bootstrap(); if (reg & AR934X_BOOTSTRAP_REF_CLK_40) { xtal_40 = 1; cpu_srif = 0x41c00000; @@ -214,7 +214,7 @@ static u32 ar934x_get_xtal(void) { u32 val;
- val = get_bootstrap(); + val = ath79_get_bootstrap(); if (val & AR934X_BOOTSTRAP_REF_CLK_40) return 40000000; else diff --git a/arch/mips/mach-ath79/ar934x/ddr.c b/arch/mips/mach-ath79/ar934x/ddr.c index 4621d58..2ba1efa 100644 --- a/arch/mips/mach-ath79/ar934x/ddr.c +++ b/arch/mips/mach-ath79/ar934x/ddr.c @@ -11,7 +11,7 @@ #include <asm/addrspace.h> #include <asm/types.h> #include <mach/ar71xx_regs.h> -#include <mach/reset.h> +#include <mach/ath79.h>
@@ -45,7 +45,7 @@ void ar934x_ddr_init(const u16 cpu_mhz, const u16 ddr_mhz, const u16 ahb_mhz) ddr_regs = map_physmem(AR71XX_DDR_CTRL_BASE, AR71XX_DDR_CTRL_SIZE, MAP_NOCACHE);
- reg = get_bootstrap(); + reg = ath79_get_bootstrap(); if (reg & AR934X_BOOTSTRAP_SDRAM_DISABLED) { /* DDR */ if (reg & AR934X_BOOTSTRAP_DDR1) { /* DDR 1 */ memtype = AR934X_DDR1; diff --git a/arch/mips/mach-ath79/include/mach/ath79.h b/arch/mips/mach-ath79/include/mach/ath79.h index 17af082..582c028 100644 --- a/arch/mips/mach-ath79/include/mach/ath79.h +++ b/arch/mips/mach-ath79/include/mach/ath79.h @@ -140,6 +140,7 @@ static inline int soc_is_qca956x(void) return soc_is_tp9343() || soc_is_qca9561(); }
+u32 ath79_get_bootstrap(void); int ath79_eth_reset(void); int ath79_usb_reset(void);
diff --git a/arch/mips/mach-ath79/include/mach/reset.h b/arch/mips/mach-ath79/include/mach/reset.h deleted file mode 100644 index c383bfe..0000000 --- a/arch/mips/mach-ath79/include/mach/reset.h +++ /dev/null @@ -1,14 +0,0 @@ -/* - * Copyright (C) 2015-2016 Wills Wang wills.wang@live.com - * - * SPDX-License-Identifier: GPL-2.0+ - */ - -#ifndef __ASM_MACH_RESET_H -#define __ASM_MACH_RESET_H - -#include <linux/types.h> - -u32 get_bootstrap(void); - -#endif /* __ASM_MACH_RESET_H */ diff --git a/arch/mips/mach-ath79/qca953x/clk.c b/arch/mips/mach-ath79/qca953x/clk.c index ef0a28e..533356c 100644 --- a/arch/mips/mach-ath79/qca953x/clk.c +++ b/arch/mips/mach-ath79/qca953x/clk.c @@ -9,7 +9,7 @@ #include <asm/addrspace.h> #include <asm/types.h> #include <mach/ar71xx_regs.h> -#include <mach/reset.h> +#include <mach/ath79.h>
@@ -17,7 +17,7 @@ static u32 qca953x_get_xtal(void) { u32 val;
- val = get_bootstrap(); + val = ath79_get_bootstrap(); if (val & QCA953X_BOOTSTRAP_REF_CLK_40) return 40000000; else diff --git a/arch/mips/mach-ath79/qca953x/ddr.c b/arch/mips/mach-ath79/qca953x/ddr.c index ac0130c..c6049d8 100644 --- a/arch/mips/mach-ath79/qca953x/ddr.c +++ b/arch/mips/mach-ath79/qca953x/ddr.c @@ -10,7 +10,7 @@ #include <asm/addrspace.h> #include <asm/types.h> #include <mach/ar71xx_regs.h> -#include <mach/reset.h> +#include <mach/ath79.h>
@@ -226,7 +226,7 @@ void ddr_init(void)
regs = map_physmem(AR71XX_DDR_CTRL_BASE, AR71XX_DDR_CTRL_SIZE, MAP_NOCACHE); - val = get_bootstrap(); + val = ath79_get_bootstrap(); if (val & QCA953X_BOOTSTRAP_DDR1) { writel(DDR_CTL_CONFIG_VAL, regs + QCA953X_DDR_REG_CTL_CONF); udelay(10); diff --git a/arch/mips/mach-ath79/reset.c b/arch/mips/mach-ath79/reset.c index a88bcbc..33bf979 100644 --- a/arch/mips/mach-ath79/reset.c +++ b/arch/mips/mach-ath79/reset.c @@ -45,7 +45,7 @@ void _machine_restart(void) /* NOP */; }
-u32 get_bootstrap(void) +u32 ath79_get_bootstrap(void) { void __iomem *base; u32 reg = 0;
Am 30.05.2016 um 16:54 schrieb Wills Wang:
applied to u-boot-mips, thanks!
Daniel Schwierzeck
Wills Wang
