[U-Boot] Fwd: Patman use (was: [PATCHv2] common/memsize.c: Simplify RAM size detection)
(Sorry Albert for the dup, I accidentally sent the reply only to you.)
---------- Forwarded message ---------- From: Eddy Petrișor eddy.petrisor@gmail.com Date: 2016-02-05 9:06 GMT+02:00 Subject: Re: Patman use (was: [U-Boot] [PATCHv2] common/memsize.c: Simplify RAM size detection) To: Albert ARIBAUD albert.u.boot@aribaud.net
2016-02-03 19:48 GMT+02:00 Albert ARIBAUD albert.u.boot@aribaud.net:
Hello Eddy,
(re-titling)
Actually I tried using patman, but got all sorts of errors and wasn't able to use it. Then I manually sent the patches with git send-email,
If you can send with git send-email, then you should be able to, and should, use patman. What were these errors?
0 eddy@heidi ~/usr/src/u-boot $ ./tools/patman/patman -n -c1
[git:simplfy_get_ram_size] Cleaned 1 patches Traceback (most recent call last): File "./tools/patman/patman", line 158, in <module> options.add_maintainers) File "/home/eddy/usr/src/u-boot/tools/patman/series.py", line 222, in MakeCcFile raise_on_error=raise_on_error) File "/home/eddy/usr/src/u-boot/tools/patman/gitutil.py", line 321, in BuildEmailList raw += LookupEmail(item, alias, raise_on_error=raise_on_error) File "/home/eddy/usr/src/u-boot/tools/patman/gitutil.py", line 495, in LookupEmail raise ValueError, msg ValueError: Alias 'common' not found
-- Eddy Petrișor
Hi Eddy,
Hello Eddy,
(re-titling)
You can use -t to ignore missing tags.
Eddy Petrișor
