[PATCH 0/8] ARM: dts: stm32: use lower-case hex for address
Replace upper-case hex with lower-case hex for address in STM32 device tree
Patrice Chotard (8): ARM: dts: stm32: Use lower-case hex for address for stm32mp15-u-boot.dtsi ARM: dts: stm32: Use lower-case hex for address for stm32f769-disco-u-boot.dtsi ARM: dts: stm32: Use lower-case hex for address for stm32746-disco-u-boot.dtsi ARM: dts: stm32: Use lower-case hex for address for stm32f7-u-boot.dtsi ARM: dts: stm32: Use lower-case hex for address for stm32f469-disco-u-boot.dtsi ARM: dts: stm32: Use lower-case hex for address for stm32f429-disco-u-boot.dtsi ARM: dts: stm32: Use lower-case hex for address for stm32f746g-eval-u-boot.dtsi ARM: dts: stm32: Use lower-case hex for address for stm32429i-eval-u-boot.dtsi
arch/arm/dts/stm32429i-eval-u-boot.dtsi | 2 +- arch/arm/dts/stm32746g-eval-u-boot.dtsi | 2 +- arch/arm/dts/stm32f429-disco-u-boot.dtsi | 2 +- arch/arm/dts/stm32f469-disco-u-boot.dtsi | 6 +++--- arch/arm/dts/stm32f7-u-boot.dtsi | 4 ++-- arch/arm/dts/stm32f746-disco-u-boot.dtsi | 2 +- arch/arm/dts/stm32f769-disco-u-boot.dtsi | 6 +++--- arch/arm/dts/stm32mp15-u-boot.dtsi | 8 ++++---- 8 files changed, 16 insertions(+), 16 deletions(-)
Replace upper-case hex with lower-case hex for address.
Signed-off-by: Patrice Chotard patrice.chotard@foss.st.com ---
arch/arm/dts/stm32mp15-u-boot.dtsi | 8 ++++---- 1 file changed, 4 insertions(+), 4 deletions(-)
diff --git a/arch/arm/dts/stm32mp15-u-boot.dtsi b/arch/arm/dts/stm32mp15-u-boot.dtsi index db23d80eef..e23d6c7d7e 100644 --- a/arch/arm/dts/stm32mp15-u-boot.dtsi +++ b/arch/arm/dts/stm32mp15-u-boot.dtsi @@ -50,8 +50,8 @@
compatible = "st,stm32mp1-ddr";
- reg = <0x5A003000 0x550 - 0x5A004000 0x234>; + reg = <0x5a003000 0x550 + 0x5a004000 0x234>;
clocks = <&rcc AXIDCG>, <&rcc DDRC1>, @@ -237,7 +237,7 @@ u-boot-stm32 { filename = "u-boot.stm32"; mkimage { - args = "-T stm32image -a 0xC0100000 -e 0xC0100000"; + args = "-T stm32image -a 0xc0100000 -e 0xc0100000"; u-boot { }; }; @@ -250,7 +250,7 @@ spl-stm32 { filename = "u-boot-spl.stm32"; mkimage { - args = "-T stm32image -a 0x2FFC2500 -e 0x2FFC2500"; + args = "-T stm32image -a 0x2ffc2500 -e 0x2ffc2500"; u-boot-spl { }; };
Reviewed-by: Patrick Delaunay patrick.delaunay@foss.st.com
Thanks Patrick
arch/arm/dts/stm32f769-disco-u-boot.dtsi | 6 +++--- 1 file changed, 3 insertions(+), 3 deletions(-)
diff --git a/arch/arm/dts/stm32f769-disco-u-boot.dtsi b/arch/arm/dts/stm32f769-disco-u-boot.dtsi index 7dfe430a40..5589b41652 100644 --- a/arch/arm/dts/stm32f769-disco-u-boot.dtsi +++ b/arch/arm/dts/stm32f769-disco-u-boot.dtsi @@ -53,9 +53,9 @@ soc { dsi: dsi@40016c00 { compatible = "st,stm32-dsi"; - reg = <0x40016C00 0x800>; + reg = <0x40016c00 0x800>; resets = <&rcc STM32F7_APB2_RESET(DSI)>; - clocks = <&rcc 0 STM32F7_APB2_CLOCK(DSI)>, + clocks = <&rcc 0 STM32F7_APB2_CLOCK(DSI)>, <&rcc 0 STM32F7_APB2_CLOCK(LTDC)>, <&clk_hse>; clock-names = "pclk", "px_clk", "ref"; @@ -227,7 +227,7 @@ };
&qspi { - reg = <0xA0001000 0x1000>, <0x90000000 0x4000000>; + reg = <0xa0001000 0x1000>, <0x90000000 0x4000000>; flash0: mx66l51235l@0 { #address-cells = <1>; #size-cells = <1>;
Thanks Patrick
arch/arm/dts/stm32f746-disco-u-boot.dtsi | 2 +- 1 file changed, 1 insertion(+), 1 deletion(-)
diff --git a/arch/arm/dts/stm32f746-disco-u-boot.dtsi b/arch/arm/dts/stm32f746-disco-u-boot.dtsi index 4f34fc9a8c..f88466fa60 100644 --- a/arch/arm/dts/stm32f746-disco-u-boot.dtsi +++ b/arch/arm/dts/stm32f746-disco-u-boot.dtsi @@ -228,7 +228,7 @@ };
&qspi { - reg = <0xA0001000 0x1000>, <0x90000000 0x1000000>; + reg = <0xa0001000 0x1000>, <0x90000000 0x1000000>; qflash0: n25q128a@0 { #address-cells = <1>; #size-cells = <1>;
Thanks Patrick
arch/arm/dts/stm32f7-u-boot.dtsi | 4 ++-- 1 file changed, 2 insertions(+), 2 deletions(-)
diff --git a/arch/arm/dts/stm32f7-u-boot.dtsi b/arch/arm/dts/stm32f7-u-boot.dtsi index 46bd1102df..c1b2ac25c3 100644 --- a/arch/arm/dts/stm32f7-u-boot.dtsi +++ b/arch/arm/dts/stm32f7-u-boot.dtsi @@ -7,7 +7,7 @@
fmc: fmc@A0000000 { compatible = "st,stm32-fmc"; - reg = <0xA0000000 0x1000>; + reg = <0xa0000000 0x1000>; clocks = <&rcc 0 STM32F7_AHB3_CLOCK(FMC)>; pinctrl-0 = <&fmc_pins>; pinctrl-names = "default"; @@ -46,7 +46,7 @@ compatible = "st,stm32f469-qspi"; #address-cells = <1>; #size-cells = <0>; - reg = <0xA0001000 0x1000>, <0x90000000 0x10000000>; + reg = <0xa0001000 0x1000>, <0x90000000 0x10000000>; reg-names = "qspi", "qspi_mm"; interrupts = <92>; spi-max-frequency = <108000000>;
Thanks Patrick
arch/arm/dts/stm32f469-disco-u-boot.dtsi | 6 +++--- 1 file changed, 3 insertions(+), 3 deletions(-)
diff --git a/arch/arm/dts/stm32f469-disco-u-boot.dtsi b/arch/arm/dts/stm32f469-disco-u-boot.dtsi index 9eda8f535b..cd173623ef 100644 --- a/arch/arm/dts/stm32f469-disco-u-boot.dtsi +++ b/arch/arm/dts/stm32f469-disco-u-boot.dtsi @@ -34,7 +34,7 @@
fmc: fmc@A0000000 { compatible = "st,stm32-fmc"; - reg = <0xA0000000 0x1000>; + reg = <0xa0000000 0x1000>; clocks = <&rcc 0 STM32F4_AHB3_CLOCK(FMC)>; st,syscfg = <&syscfg>; pinctrl-0 = <&fmc_pins_d32>; @@ -70,7 +70,7 @@ compatible = "st,stm32f469-qspi"; #address-cells = <1>; #size-cells = <0>; - reg = <0xA0001000 0x1000>, <0x90000000 0x10000000>; + reg = <0xa0001000 0x1000>, <0x90000000 0x10000000>; reg-names = "qspi", "qspi_mm"; interrupts = <91>; spi-max-frequency = <108000000>; @@ -236,7 +236,7 @@ };
&qspi { - reg = <0xA0001000 0x1000>, <0x90000000 0x1000000>; + reg = <0xa0001000 0x1000>, <0x90000000 0x1000000>; flash0: n25q128a@0 { #address-cells = <1>; #size-cells = <1>;
Thanks Patrick
arch/arm/dts/stm32f429-disco-u-boot.dtsi | 2 +- 1 file changed, 1 insertion(+), 1 deletion(-)
diff --git a/arch/arm/dts/stm32f429-disco-u-boot.dtsi b/arch/arm/dts/stm32f429-disco-u-boot.dtsi index 297cc56144..c993f86be8 100644 --- a/arch/arm/dts/stm32f429-disco-u-boot.dtsi +++ b/arch/arm/dts/stm32f429-disco-u-boot.dtsi @@ -33,7 +33,7 @@
fmc: fmc@A0000000 { compatible = "st,stm32-fmc"; - reg = <0xA0000000 0x1000>; + reg = <0xa0000000 0x1000>; clocks = <&rcc 0 STM32F4_AHB3_CLOCK(FMC)>; pinctrl-0 = <&fmc_pins>; pinctrl-names = "default";
Thanks Patrick
arch/arm/dts/stm32746g-eval-u-boot.dtsi | 2 +- 1 file changed, 1 insertion(+), 1 deletion(-)
diff --git a/arch/arm/dts/stm32746g-eval-u-boot.dtsi b/arch/arm/dts/stm32746g-eval-u-boot.dtsi index f2195a6c51..8550ef7863 100644 --- a/arch/arm/dts/stm32746g-eval-u-boot.dtsi +++ b/arch/arm/dts/stm32746g-eval-u-boot.dtsi @@ -177,7 +177,7 @@ };
&qspi { - reg = <0xA0001000 0x1000>, <0x90000000 0x4000000>; + reg = <0xa0001000 0x1000>, <0x90000000 0x4000000>; qflash0: n25q512a@0 { #address-cells = <1>; #size-cells = <1>;
Thanks Patrick
arch/arm/dts/stm32429i-eval-u-boot.dtsi | 2 +- 1 file changed, 1 insertion(+), 1 deletion(-)
diff --git a/arch/arm/dts/stm32429i-eval-u-boot.dtsi b/arch/arm/dts/stm32429i-eval-u-boot.dtsi index 09d9d9ab9b..fcab9ae977 100644 --- a/arch/arm/dts/stm32429i-eval-u-boot.dtsi +++ b/arch/arm/dts/stm32429i-eval-u-boot.dtsi @@ -33,7 +33,7 @@
Thanks Patrick
Hi
For the series, applied to to u-boot-stm32/next
Thanks Patrice
Patrice CHOTARD
Patrice Chotard
Patrick DELAUNAY
