[U-Boot] [PATCH] mx25pdk: Remove CONFIG_SYS_GENERIC_BOARD
With CONFIG_SYS_GENERIC_BOARD the board hangs after issuing a 'save' command.
Remove CONFIG_SYS_GENERIC_BOARD until this issue can be fixed properly.
Signed-off-by: Fabio Estevam fabio.estevam@freescale.com --- Stefano,
I will not have time to debug this prior to 2014.07 version.
It would be better if this patch could be applied so that mx25pdk keeps working in 2014.07. I can then investigate and provide a proper fix after 2014.07 is out.
include/configs/mx25pdk.h | 2 -- 1 file changed, 2 deletions(-)
diff --git a/include/configs/mx25pdk.h b/include/configs/mx25pdk.h index cfaf6ca..aff2419 100644 --- a/include/configs/mx25pdk.h +++ b/include/configs/mx25pdk.h @@ -26,8 +26,6 @@ #define CONFIG_SETUP_MEMORY_TAGS #define CONFIG_INITRD_TAG
-#define CONFIG_SYS_GENERIC_BOARD - #define CONFIG_MACH_TYPE MACH_TYPE_MX25_3DS
/* Size of malloc() pool */
Hi Fabio,
Stefano,
Ok, understood - applied to u-boot-imx, thanks !
Best regards, Stefano Babic
Fabio Estevam
Stefano Babic
