[PATCH 0/5] DFU: new entity types and minor improvements
Hi All,
This patchset adds support for SKIP and SCRIPT entity types to the DFU subsystem. They significantly extends the flexibility of the DFU subsystem. Together with the recently posted 'Add MBR partition table creation and verify command' patchset it allows to create the whole partition table during the board flashing when one prepares a proper script. It also easies the flashing by allowing to use the same images for different board variants/types, as each board can now use only the relevant images and skip the other ones without returning a failure.
Best regards Marek Szyprowski Samsung R&D Institute Poland
Jaehoon Chung (1): dfu: add 'SKIP' entity
Marek Szyprowski (4): dfu: mmc: use the default MMC device if entity specifies it as -1 dfu: add 'SCRIPT' entity dfu: add support for the dfu_alt_info reintialization from the flashed script thor: add support for the dfu_alt_info reintialization from the flashed script
cmd/dfu.c | 14 ++++++++++++- cmd/thordown.c | 19 +++++++++++------- common/dfu.c | 3 +++ drivers/dfu/dfu.c | 6 +++++- drivers/dfu/dfu_mmc.c | 39 ++++++++++++++++++++++++++++++++----- drivers/usb/gadget/f_thor.c | 3 +++ include/dfu.h | 4 ++++ include/thor.h | 2 ++ 8 files changed, 76 insertions(+), 14 deletions(-)
Use the default MMC device set in the command line if entity specifies it as -1. This allows to use the same dfu_alt_info string for different MMC devices (like embedded eMMC and external SD card if data layout is the same on both devices).
Signed-off-by: Marek Szyprowski m.szyprowski@samsung.com --- drivers/dfu/dfu_mmc.c | 7 ++++--- 1 file changed, 4 insertions(+), 3 deletions(-)
diff --git a/drivers/dfu/dfu_mmc.c b/drivers/dfu/dfu_mmc.c index 691d01c7eb..784d0ec76b 100644 --- a/drivers/dfu/dfu_mmc.c +++ b/drivers/dfu/dfu_mmc.c @@ -316,7 +316,7 @@ void dfu_free_entity_mmc(struct dfu_entity *dfu) int dfu_fill_entity_mmc(struct dfu_entity *dfu, char *devstr, char *s) { const char *entity_type; - size_t second_arg; + ssize_t second_arg; size_t third_arg;
struct mmc *mmc; @@ -339,7 +339,7 @@ int dfu_fill_entity_mmc(struct dfu_entity *dfu, char *devstr, char *s) * Base 0 means we'll accept (prefixed with 0x or 0) base 16, 8, * with default 10. */ - second_arg = simple_strtoul(argv[1], NULL, 0); + second_arg = simple_strtol(argv[1], NULL, 0); third_arg = simple_strtoul(argv[2], NULL, 0);
mmc = find_mmc_device(dfu->data.mmc.dev_num); @@ -406,7 +406,8 @@ int dfu_fill_entity_mmc(struct dfu_entity *dfu, char *devstr, char *s)
/* if it's NOT a raw write */ if (strcmp(entity_type, "raw")) { - dfu->data.mmc.dev = second_arg; + dfu->data.mmc.dev = (second_arg != -1) ? second_arg : + dfu->data.mmc.dev_num; dfu->data.mmc.part = third_arg; }
Define a new 'SKIP' type for DFU entities. The flashed data are simply ignored without returning any error values.
This allows to have the same board flashing procedure and images for the different board types or variants, where each board uses only the images relevant to it and skips the rest.
Signed-off-by: Jaehoon Chung jh80.chung@samsung.com [mszyprow: rephrased commit message and subject] Signed-off-by: Marek Szyprowski m.szyprowski@samsung.com --- drivers/dfu/dfu.c | 2 +- drivers/dfu/dfu_mmc.c | 9 +++++++++ include/dfu.h | 1 + 3 files changed, 11 insertions(+), 1 deletion(-)
diff --git a/drivers/dfu/dfu.c b/drivers/dfu/dfu.c index 501a60b344..fc32a53323 100644 --- a/drivers/dfu/dfu.c +++ b/drivers/dfu/dfu.c @@ -614,7 +614,7 @@ const char *dfu_get_dev_type(enum dfu_device_type t) const char *dfu_get_layout(enum dfu_layout l) { const char *const dfu_layout[] = {NULL, "RAW_ADDR", "FAT", "EXT2", - "EXT3", "EXT4", "RAM_ADDR" }; + "EXT3", "EXT4", "RAM_ADDR", "SKIP" }; return dfu_layout[l]; }
diff --git a/drivers/dfu/dfu_mmc.c b/drivers/dfu/dfu_mmc.c index 784d0ec76b..d1af11d94c 100644 --- a/drivers/dfu/dfu_mmc.c +++ b/drivers/dfu/dfu_mmc.c @@ -108,6 +108,8 @@ static int mmc_file_op(enum dfu_op op, struct dfu_entity *dfu, case DFU_FS_EXT4: fstype = FS_TYPE_EXT; break; + case DFU_SKIP: + return 0; default: printf("%s: Layout (%s) not (yet) supported!\n", __func__, dfu_get_layout(dfu->layout)); @@ -204,6 +206,9 @@ int dfu_write_medium_mmc(struct dfu_entity *dfu, case DFU_FS_EXT4: ret = mmc_file_buf_write(dfu, offset, buf, len); break; + case DFU_SKIP: + ret = 0; + break; default: printf("%s: Layout (%s) not (yet) supported!\n", __func__, dfu_get_layout(dfu->layout)); @@ -238,6 +243,8 @@ int dfu_get_medium_size_mmc(struct dfu_entity *dfu, u64 *size) if (ret < 0) return ret; return 0; + case DFU_SKIP: + return 0; default: printf("%s: Layout (%s) not (yet) supported!\n", __func__, dfu_get_layout(dfu->layout)); @@ -399,6 +406,8 @@ int dfu_fill_entity_mmc(struct dfu_entity *dfu, char *devstr, char *s) dfu->layout = DFU_FS_FAT; } else if (!strcmp(entity_type, "ext4")) { dfu->layout = DFU_FS_EXT4; + } else if (!strcmp(entity_type, "skip")) { + dfu->layout = DFU_SKIP; } else { pr_err("Memory layout (%s) not supported!\n", entity_type); return -ENODEV; diff --git a/include/dfu.h b/include/dfu.h index a767adee41..0b1dae0b3b 100644 --- a/include/dfu.h +++ b/include/dfu.h @@ -33,6 +33,7 @@ enum dfu_layout { DFU_FS_EXT3, DFU_FS_EXT4, DFU_RAM_ADDR, + DFU_SKIP, };
enum dfu_op {
Define a new 'SCRIPT' type for DFU entities. The downloaded data are treated as simple u-boot's scripts and executed with run_command_list() function.
Flashing the 'SCRIPT' entity might result in changing the 'dfu_alt_info' environment variable from the flashed script, so add a global variable for tracking the potential need to reinitialize the dfu_alt_info related structures.
Signed-off-by: Marek Szyprowski m.szyprowski@samsung.com --- drivers/dfu/dfu.c | 6 +++++- drivers/dfu/dfu_mmc.c | 23 +++++++++++++++++++++-- include/dfu.h | 3 +++ 3 files changed, 29 insertions(+), 3 deletions(-)
diff --git a/drivers/dfu/dfu.c b/drivers/dfu/dfu.c index fc32a53323..eccfb4c745 100644 --- a/drivers/dfu/dfu.c +++ b/drivers/dfu/dfu.c @@ -26,6 +26,8 @@ static struct hash_algo *dfu_hash_algo; static unsigned long dfu_timeout = 0; #endif
+bool dfu_reinit_needed = false; + /* * The purpose of the dfu_flush_callback() function is to * provide callback for dfu user @@ -139,6 +141,8 @@ int dfu_init_env_entities(char *interface, char *devstr) char *env_bkp; int ret = 0;
+ dfu_reinit_needed = false; + #ifdef CONFIG_SET_DFU_ALT_INFO set_dfu_alt_info(interface, devstr); #endif @@ -614,7 +618,7 @@ const char *dfu_get_dev_type(enum dfu_device_type t) const char *dfu_get_layout(enum dfu_layout l) { const char *const dfu_layout[] = {NULL, "RAW_ADDR", "FAT", "EXT2", - "EXT3", "EXT4", "RAM_ADDR", "SKIP" }; + "EXT3", "EXT4", "RAM_ADDR", "SKIP", "SCRIPT" }; return dfu_layout[l]; }
diff --git a/drivers/dfu/dfu_mmc.c b/drivers/dfu/dfu_mmc.c index d1af11d94c..e63fa84ce4 100644 --- a/drivers/dfu/dfu_mmc.c +++ b/drivers/dfu/dfu_mmc.c @@ -16,6 +16,7 @@ #include <fat.h> #include <mmc.h> #include <part.h> +#include <command.h>
static unsigned char *dfu_file_buf; static u64 dfu_file_buf_len; @@ -206,6 +207,9 @@ int dfu_write_medium_mmc(struct dfu_entity *dfu, case DFU_FS_EXT4: ret = mmc_file_buf_write(dfu, offset, buf, len); break; + case DFU_SCRIPT: + ret = run_command_list(buf, *len, 0); + break; case DFU_SKIP: ret = 0; break; @@ -221,9 +225,21 @@ int dfu_flush_medium_mmc(struct dfu_entity *dfu) { int ret = 0;
- if (dfu->layout != DFU_RAW_ADDR) { - /* Do stuff here. */ + switch (dfu->layout) { + case DFU_FS_FAT: + case DFU_FS_EXT4: ret = mmc_file_buf_write_finish(dfu); + break; + case DFU_SCRIPT: + /* script may have changed the dfu_alt_info */ + dfu_reinit_needed = true; + break; + case DFU_RAW_ADDR: + case DFU_SKIP: + break; + default: + printf("%s: Layout (%s) not (yet) supported!\n", __func__, + dfu_get_layout(dfu->layout)); }
return ret; @@ -243,6 +259,7 @@ int dfu_get_medium_size_mmc(struct dfu_entity *dfu, u64 *size) if (ret < 0) return ret; return 0; + case DFU_SCRIPT: case DFU_SKIP: return 0; default: @@ -408,6 +425,8 @@ int dfu_fill_entity_mmc(struct dfu_entity *dfu, char *devstr, char *s) dfu->layout = DFU_FS_EXT4; } else if (!strcmp(entity_type, "skip")) { dfu->layout = DFU_SKIP; + } else if (!strcmp(entity_type, "script")) { + dfu->layout = DFU_SCRIPT; } else { pr_err("Memory layout (%s) not supported!\n", entity_type); return -ENODEV; diff --git a/include/dfu.h b/include/dfu.h index 0b1dae0b3b..d18b701728 100644 --- a/include/dfu.h +++ b/include/dfu.h @@ -34,6 +34,7 @@ enum dfu_layout { DFU_FS_EXT4, DFU_RAM_ADDR, DFU_SKIP, + DFU_SCRIPT, };
enum dfu_op { @@ -497,6 +498,8 @@ static inline int dfu_fill_entity_virt(struct dfu_entity *dfu, char *devstr, } #endif
+extern bool dfu_reinit_needed; + #if CONFIG_IS_ENABLED(DFU_WRITE_ALT) /** * dfu_write_by_name() - write data to DFU medium
Reinitialize DFU USB gadget after flashing the 'SCRIPT' entity to ensure that the potential changes to the 'dfu_alt_info' environment variable are applied.
Signed-off-by: Marek Szyprowski m.szyprowski@samsung.com --- cmd/dfu.c | 14 +++++++++++++- common/dfu.c | 3 +++ 2 files changed, 16 insertions(+), 1 deletion(-)
diff --git a/cmd/dfu.c b/cmd/dfu.c index 7310595a02..89b1b2268e 100644 --- a/cmd/dfu.c +++ b/cmd/dfu.c @@ -34,6 +34,7 @@ static int do_dfu(struct cmd_tbl *cmdtp, int flag, int argc, char *const argv[]) #if defined(CONFIG_DFU_TIMEOUT) || defined(CONFIG_DFU_OVER_TFTP) unsigned long value = 0; #endif + bool retry = false;
if (argc >= 4) { interface = argv[2]; @@ -68,7 +69,18 @@ static int do_dfu(struct cmd_tbl *cmdtp, int flag, int argc, char *const argv[])
int controller_index = simple_strtoul(usb_controller, NULL, 0);
- run_usb_dnl_gadget(controller_index, "usb_dnl_dfu"); + do { + retry = false; + run_usb_dnl_gadget(controller_index, "usb_dnl_dfu"); + + if (dfu_reinit_needed) { + dfu_free_entities(); + ret = dfu_init_env_entities(interface, devstring); + if (ret) + goto done; + retry = true; + } + } while (retry);
done: dfu_free_entities(); diff --git a/common/dfu.c b/common/dfu.c index d23cf67f19..16bd1ba588 100644 --- a/common/dfu.c +++ b/common/dfu.c @@ -98,6 +98,9 @@ int run_usb_dnl_gadget(int usbctrl_index, char *usb_dnl_gadget) } #endif
+ if (dfu_reinit_needed) + goto exit; + WATCHDOG_RESET(); usb_gadget_handle_interrupts(usbctrl_index); }
Reinitialize dfu_env_entities after flashing the 'SCRIPT' entity to ensure that the potential changes to the 'dfu_alt_info' environment variable are applied.
Signed-off-by: Marek Szyprowski m.szyprowski@samsung.com --- cmd/thordown.c | 19 ++++++++++++------- drivers/usb/gadget/f_thor.c | 3 +++ include/thor.h | 2 ++ 3 files changed, 17 insertions(+), 7 deletions(-)
diff --git a/cmd/thordown.c b/cmd/thordown.c index ae20dddfdd..838764ccef 100644 --- a/cmd/thordown.c +++ b/cmd/thordown.c @@ -52,13 +52,18 @@ int do_thor_down(struct cmd_tbl *cmdtp, int flag, int argc, char *const argv[]) goto exit; }
- ret = thor_handle(); - if (ret) { - pr_err("THOR failed: %d\n", ret); - ret = CMD_RET_FAILURE; - goto exit; - } - + do { + ret = thor_handle(); + if (ret == THOR_DFU_REINIT_NEEDED) { + dfu_free_entities(); + ret = dfu_init_env_entities(interface, devstring); + } + if (ret) { + pr_err("THOR failed: %d\n", ret); + ret = CMD_RET_FAILURE; + goto exit; + } + } while (ret == 0); exit: g_dnl_unregister(); usb_gadget_release(controller_index); diff --git a/drivers/usb/gadget/f_thor.c b/drivers/usb/gadget/f_thor.c index 88fc87f2e9..3e69746ee6 100644 --- a/drivers/usb/gadget/f_thor.c +++ b/drivers/usb/gadget/f_thor.c @@ -30,6 +30,7 @@ #include <linux/usb/cdc.h> #include <g_dnl.h> #include <dfu.h> +#include <thor.h>
#include "f_thor.h"
@@ -735,6 +736,8 @@ int thor_handle(void) printf("%s: No data received!\n", __func__); break; } + if (dfu_reinit_needed) + return THOR_DFU_REINIT_NEEDED; }
return 0; diff --git a/include/thor.h b/include/thor.h index 62501bda17..ee67ab0a27 100644 --- a/include/thor.h +++ b/include/thor.h @@ -12,6 +12,8 @@
#include <linux/usb/composite.h>
+#define THOR_DFU_REINIT_NEEDED 0xFFFFFFFE + int thor_handle(void); int thor_init(void); int thor_add(struct usb_configuration *c);
Hi Marek,
On 12/17/20 9:10 PM, Marek Szyprowski wrote:
Hi All,
I sent the patch about skip entity. At that time, Lukasz mentioned to update dfu documentation.
https://patchwork.ozlabs.org/project/uboot/patch/20201109115757.24601-1-jh80...
Could you update also README.dfu and Minkyu's reviewed-tag about my patch?
Best Regards, Jaehoon Chung
Hi Jaehoon,
Thanks for pointing this. I missed that. I will include your v2 patch and also update the readme about the SCRIPT type.
Best regards
Jaehoon Chung
Marek Szyprowski
