Re: [DNX#2006040142000517] [U-Boot-Users] [PATCH] MPC8xx: Parameter Area Relo [...]
Hello list,
inside the automatic U-Boot patch tracking system a new ticket [DNX#2006040142000517] was created:
<snip>
Hello Wolfgang,
This patch adds full support for parameter area relocation on MPC8xx. This is needed if you want to simultaneously use devices that have overlapping parameter areas, such as SCC1/I2C, SCC2/SPI, SCC3/SMC1, SCC4/SMC2 (SCCx should be in Ethernet mode). The details are in doc/README.mpc8xx_upatch.
Both ROM-based relocation solution and microcode patch are supported. Selection is automatic.
In addition to that, this patch contains some minor enhancements for MPC8xx SPI driver and "sspi" command, which were kind of difficult to separate (I had to do everything together in order to be able to test it).
Changelog entry
- Added support for I2C, SPI and SMC parameter area relocation on MPC8xx
- Modified MPC8xx SPI driver to make it compatible with sspi command
- Minor enhanements to "sspi" command for better compatibility with
"eeprom" command Patch by Vladimir Gurevich vag@paulidav.org
Thanks, Vladimir
</snip>
Your U-Boot support team
DENX Support System
