[PATCH 1/2] pinctrl: renesas: Replace ifdeffery with IS_ENABLED()
Switch ifdef in sh_gpio_get_value() to IS_ENABLED() macro. The CONFIG_RCAR_GEN3 will never have SPL counterpart, so the IS_ENABLED() macro is the right one here. No functional change, except for improved build test coverage.
Signed-off-by: Marek Vasut marek.vasut+renesas@mailbox.org --- drivers/gpio/sh_pfc.c | 6 +++--- 1 file changed, 3 insertions(+), 3 deletions(-)
diff --git a/drivers/gpio/sh_pfc.c b/drivers/gpio/sh_pfc.c index 988f7e9bbad..92522b63bbe 100644 --- a/drivers/gpio/sh_pfc.c +++ b/drivers/gpio/sh_pfc.c @@ -568,10 +568,10 @@ static int sh_gpio_get_value(struct pinmux_info *gpioc, unsigned gpio)
if (!gpioc || get_data_reg(gpioc, gpio, &dr, &bit) != 0) return -1; -#if defined(CONFIG_RCAR_GEN3) - if ((gpioc->gpios[gpio].flags & PINMUX_FLAG_TYPE) == PINMUX_TYPE_INPUT) + + if (IS_ENABLED(CONFIG_RCAR_GEN3) && + ((gpioc->gpios[gpio].flags & PINMUX_FLAG_TYPE) == PINMUX_TYPE_INPUT)) offset += 4; -#endif
return gpio_read_bit(dr, offset, bit); }
Remove PFC info table entries which are never instantiated, since there are no drivers for those. No functional change.
Signed-off-by: Marek Vasut marek.vasut+renesas@mailbox.org --- drivers/pinctrl/renesas/sh_pfc.h | 15 --------------- 1 file changed, 15 deletions(-)
diff --git a/drivers/pinctrl/renesas/sh_pfc.h b/drivers/pinctrl/renesas/sh_pfc.h index 59d447ead5c..0ab743e80d5 100644 --- a/drivers/pinctrl/renesas/sh_pfc.h +++ b/drivers/pinctrl/renesas/sh_pfc.h @@ -309,21 +309,6 @@ extern const struct sh_pfc_soc_info r8a77980_pinmux_info; extern const struct sh_pfc_soc_info r8a77990_pinmux_info; extern const struct sh_pfc_soc_info r8a77995_pinmux_info; extern const struct sh_pfc_soc_info r8a779a0_pinmux_info; -extern const struct sh_pfc_soc_info r8a779f0_pinmux_info; -extern const struct sh_pfc_soc_info r8a779g0_pinmux_info; -extern const struct sh_pfc_soc_info sh7203_pinmux_info; -extern const struct sh_pfc_soc_info sh7264_pinmux_info; -extern const struct sh_pfc_soc_info sh7269_pinmux_info; -extern const struct sh_pfc_soc_info sh73a0_pinmux_info; -extern const struct sh_pfc_soc_info sh7720_pinmux_info; -extern const struct sh_pfc_soc_info sh7722_pinmux_info; -extern const struct sh_pfc_soc_info sh7723_pinmux_info; -extern const struct sh_pfc_soc_info sh7724_pinmux_info; -extern const struct sh_pfc_soc_info sh7734_pinmux_info; -extern const struct sh_pfc_soc_info sh7757_pinmux_info; -extern const struct sh_pfc_soc_info sh7785_pinmux_info; -extern const struct sh_pfc_soc_info sh7786_pinmux_info; -extern const struct sh_pfc_soc_info shx3_pinmux_info;
/* ----------------------------------------------------------------------------- * Helper macros to create pin and port lists
