[U-Boot] Please pull u-boot-marvell master
Hi Tom,
please pull from marvell/master. The changes include Stefan's Armada 38x series which reached v3 on the mailing list and two more Marvell Armada related fixes.
The following changes since commit ace97d26176a3ebc9ec07738450de93eea35975c:
Merge branch 'zynq' of git://www.denx.de/git/u-boot-microblaze (2015-04-29 06:46:33 -0400)
git://git.denx.de/u-boot-marvell.git
for you to fetch changes up to 2083db7a75792d317a8e726e8be72abea8941d03:
arm: mvebu: Remove "u-boot.kwb" CONFIG_BUILD_TARGET for non-SPL targets (2015-05-05 14:32:05 +0200)
---------------------------------------------------------------- Stefan Roese (15): arm: armada-xp: Move SoC sources to mach-mvebu arm: armada-xp: Move SoC headers to mach-mvebu/include/mach arm: mvebu: Move mvebu-common into mach-mvebu arm: mvebu: Change header macros from ARMADA_XP to MVEBU arm: mvebu: Remove unreferenced define arm: mvebu: Only define MV88F78X60 for Armada XP arm: mvebu: Move CONFIG_SPL_LDSCRIPT to common header arm: mvebu: Add basic Armada 38x support arm: mvebu: Change network init code to allow a more flexible setup arm: mvebu: Remove coherency configuration arm: mvebu: mv-common.h: Add CONFIG_PREBOOT arm: mvebu: Add d-cache invalidate before enabling the d-cache arm: mvebu: Add Armada A38x DB-88F6820-GP board support arm: mvebu: db-mv784mp-gp: Fix ECC I2C address arm: mvebu: Remove "u-boot.kwb" CONFIG_BUILD_TARGET for non-SPL targets
arch/arm/Kconfig | 6 ++ arch/arm/Makefile | 5 +- arch/arm/cpu/armv7/Makefile | 1 - arch/arm/cpu/armv7/armada-xp/Makefile | 9 -- arch/arm/mach-mvebu/Makefile | 24 +++++ arch/arm/{cpu/armv7/armada-xp => mach-mvebu}/cpu.c | 96 +++++++++++++++---- arch/arm/{mvebu-common => mach-mvebu}/dram.c | 0 arch/arm/{mvebu-common => mach-mvebu}/gpio.c | 0 .../include/mach}/config.h | 17 ++-- .../include/mach}/cpu.h | 13 ++- .../include/mach}/soc.h | 20 ++-- .../armv7/armada-xp => mach-mvebu}/lowlevel_spl.S | 0 arch/arm/{mvebu-common => mach-mvebu}/mbus.c | 3 - .../{mvebu-common => mach-mvebu}/serdes/Makefile | 0 .../serdes/board_env_spec.h | 0 .../serdes/high_speed_env_lib.c | 0 .../serdes/high_speed_env_spec.c | 0 .../serdes/high_speed_env_spec.h | 0 arch/arm/{cpu/armv7/armada-xp => mach-mvebu}/spl.c | 0 arch/arm/{mvebu-common => mach-mvebu}/timer.c | 0 .../{mvebu-common => mach-mvebu}/u-boot-spl.lds | 0 board/Marvell/db-88f6820-gp/Kconfig | 15 +++ board/Marvell/db-88f6820-gp/Makefile | 7 ++ board/Marvell/db-88f6820-gp/binary.0 | 16 ++++ board/Marvell/db-88f6820-gp/db-88f6820-gp.c | 103 +++++++++++++++++++++ board/Marvell/db-88f6820-gp/kwbimage.cfg | 12 +++ board/Marvell/db-mv784mp-gp/Kconfig | 2 +- board/Marvell/db-mv784mp-gp/db-mv784mp-gp.c | 3 +- board/maxbcm/Kconfig | 2 +- board/maxbcm/maxbcm.c | 2 +- configs/db-88f6820-gp_defconfig | 2 + drivers/ddr/mvebu/ddr3_axp.h | 2 +- include/configs/db-88f6820-gp.h | 72 ++++++++++++++ include/configs/db-mv784mp-gp.h | 3 +- include/configs/maxbcm.h | 3 +- include/configs/mv-common.h | 1 + 36 files changed, 379 insertions(+), 60 deletions(-) delete mode 100644 arch/arm/cpu/armv7/armada-xp/Makefile create mode 100644 arch/arm/mach-mvebu/Makefile rename arch/arm/{cpu/armv7/armada-xp => mach-mvebu}/cpu.c (71%) rename arch/arm/{mvebu-common => mach-mvebu}/dram.c (100%) rename arch/arm/{mvebu-common => mach-mvebu}/gpio.c (100%) rename arch/arm/{include/asm/arch-armada-xp => mach-mvebu/include/mach}/config.h (86%) rename arch/arm/{include/asm/arch-armada-xp => mach-mvebu/include/mach}/cpu.h (93%) rename arch/arm/{include/asm/arch-armada-xp => mach-mvebu/include/mach}/soc.h (81%) rename arch/arm/{cpu/armv7/armada-xp => mach-mvebu}/lowlevel_spl.S (100%) rename arch/arm/{mvebu-common => mach-mvebu}/mbus.c (99%) rename arch/arm/{mvebu-common => mach-mvebu}/serdes/Makefile (100%) rename arch/arm/{mvebu-common => mach-mvebu}/serdes/board_env_spec.h (100%) rename arch/arm/{mvebu-common => mach-mvebu}/serdes/high_speed_env_lib.c (100%) rename arch/arm/{mvebu-common => mach-mvebu}/serdes/high_speed_env_spec.c (100%) rename arch/arm/{mvebu-common => mach-mvebu}/serdes/high_speed_env_spec.h (100%) rename arch/arm/{cpu/armv7/armada-xp => mach-mvebu}/spl.c (100%) rename arch/arm/{mvebu-common => mach-mvebu}/timer.c (100%) rename arch/arm/{mvebu-common => mach-mvebu}/u-boot-spl.lds (100%) create mode 100644 board/Marvell/db-88f6820-gp/Kconfig create mode 100644 board/Marvell/db-88f6820-gp/Makefile create mode 100644 board/Marvell/db-88f6820-gp/binary.0 create mode 100644 board/Marvell/db-88f6820-gp/db-88f6820-gp.c create mode 100644 board/Marvell/db-88f6820-gp/kwbimage.cfg create mode 100644 configs/db-88f6820-gp_defconfig create mode 100644 include/configs/db-88f6820-gp.h
Regards, Luka
On Tue, May 05, 2015 at 12:50:01PM +0000, Luka Perkov wrote:
Hi Tom,
Luka Perkov
