[PATCH] mtd: nand: denali: Add SPL image loader
Add image loader used by the NAND SPL into the full Denali NAND driver. This allows usage of the full Denali NAND driver in SPL instead of the reduced SPL-only version.
Signed-off-by: Tien Fong Chee tien.fong.chee@intel.com Signed-off-by: Jit Loon Lim jit.loon.lim@intel.com --- drivers/mtd/nand/raw/denali.c | 55 +++++++++++++++++++++++++++++++++++ 1 file changed, 55 insertions(+)
diff --git a/drivers/mtd/nand/raw/denali.c b/drivers/mtd/nand/raw/denali.c index c827f80281..499b4acc6e 100644 --- a/drivers/mtd/nand/raw/denali.c +++ b/drivers/mtd/nand/raw/denali.c @@ -7,7 +7,9 @@
#include <common.h> #include <dm.h> +#include <hang.h> #include <malloc.h> +#include <memalign.h> #include <nand.h> #include <asm/cache.h> #include <asm/dma-mapping.h> @@ -1374,3 +1376,56 @@ free_buf:
return ret; } + +#ifdef CONFIG_SPL_BUILD +int nand_spl_load_image(u32 offset, u32 len, void *dst) +{ + size_t count = len, actual = 0, page_align_overhead = 0; + u32 page_align_offset = 0; + u8 *page_buffer; + int err = 0; + struct mtd_info *mtd; + + if (!len || !dst) + return -EINVAL; + + mtd = get_nand_dev_by_index(nand_curr_device); + if (!mtd) + hang(); + + if ((offset & (mtd->writesize - 1)) != 0) { + page_buffer = malloc_cache_aligned(mtd->writesize); + if (!page_buffer) { + debug("Error: allocating buffer\n"); + return -ENOMEM; + } + + page_align_overhead = offset % mtd->writesize; + page_align_offset = (offset / mtd->writesize) * mtd->writesize; + count = mtd->writesize; + + err = nand_read_skip_bad(mtd, page_align_offset, &count, + &actual, mtd->size, page_buffer); + + if (err) + return err; + + count -= page_align_overhead; + count = min((size_t)len, count); + memcpy(dst, page_buffer + page_align_overhead, count); + free(page_buffer); + + len -= count; + if (!len) + return err; + + offset += count; + dst += count; + count = len; + } + + return nand_read_skip_bad(mtd, offset, &count, &actual, mtd->size, dst); +} + +void nand_deselect(void) {} +#endif
+ MTD Maintainers
Hi
- MTD Maintainers
Please take a look of commit 9f6a14c47ff95354185248ea6e7b1c695e64939e and implement nand_spl_adjust_offset. I think that same can be used by any cpu that has enough space inside the first stage boot.
Michael
Michael
Jagan Teki
Jit Loon Lim
Michael Nazzareno Trimarchi
