[U-Boot] [PATCH] Convert CONFIG_SMC911X et al to Kconfig
This converts the following to Kconfig: CONFIG_SMC911X CONFIG_SMC911X_BASE CONFIG_SMC911X_32_BIT
There are a variety of boards that need some cleanup in their respective include/configs file, but here is a foundation for them to begin their transisiton.
Signed-off-by: Adam Ford aford173@gmail.com V2: Merge into 1 patch and rebase --- configs/cm_t3517_defconfig | 4 ++++ configs/cm_t35_defconfig | 4 ++++ configs/duovero_defconfig | 4 ++++ configs/igep0032_defconfig | 4 ++++ configs/igep00x0_defconfig | 4 ++++ configs/omap3_evm_defconfig | 4 ++++ configs/omap3_logic_defconfig | 4 ++++ configs/omap3_overo_defconfig | 4 ++++ configs/omap3_zoom1_defconfig | 3 +++ configs/twister_defconfig | 3 +++ include/configs/cm_t35.h | 3 +-- include/configs/cm_t3517.h | 3 --- include/configs/duovero.h | 4 ---- include/configs/omap3_evm.h | 7 ------- include/configs/omap3_igep00x0.h | 9 --------- include/configs/omap3_logic.h | 7 ------- include/configs/omap3_zoom1.h | 4 ---- include/configs/twister.h | 4 +--- 18 files changed, 40 insertions(+), 39 deletions(-)
diff --git a/configs/cm_t3517_defconfig b/configs/cm_t3517_defconfig index 8e7c072..3ed0b37 100644 --- a/configs/cm_t3517_defconfig +++ b/configs/cm_t3517_defconfig @@ -38,6 +38,10 @@ CONFIG_LED_STATUS_BOOT_ENABLE=y CONFIG_LED_STATUS_BOOT=0 CONFIG_MMC_OMAP_HS=y CONFIG_NAND=y +CONFIG_NETDEVICES=y +CONFIG_SMC911X=y +CONFIG_SMC911X_BASE=0x2C100000 +CONFIG_SMC911X_32_BIT=y CONFIG_SYS_NS16550=y CONFIG_OMAP3_SPI=y CONFIG_USB=y diff --git a/configs/cm_t35_defconfig b/configs/cm_t35_defconfig index 1515c92..bf11722 100644 --- a/configs/cm_t35_defconfig +++ b/configs/cm_t35_defconfig @@ -40,6 +40,10 @@ CONFIG_LED_STATUS_BOOT=0 CONFIG_MMC_OMAP_HS=y CONFIG_NAND=y CONFIG_SPL_NAND_SIMPLE=y +CONFIG_NETDEVICES=y +CONFIG_SMC911X=y +CONFIG_SMC911X_BASE=0x2C000000 +CONFIG_SMC911X_32_BIT=y CONFIG_SYS_NS16550=y CONFIG_OMAP3_SPI=y CONFIG_USB=y diff --git a/configs/duovero_defconfig b/configs/duovero_defconfig index feec2cf..b76da3e 100644 --- a/configs/duovero_defconfig +++ b/configs/duovero_defconfig @@ -23,6 +23,10 @@ CONFIG_CMD_EXT4_WRITE=y # CONFIG_SPL_EFI_PARTITION is not set CONFIG_SPL_PARTITION_UUIDS=y CONFIG_MMC_OMAP_HS=y +CONFIG_NETDEVICES=y +CONFIG_SMC911X=y +CONFIG_SMC911X_BASE=0x2C000000 +CONFIG_SMC911X_32_BIT=y CONFIG_SYS_NS16550=y CONFIG_OMAP3_SPI=y CONFIG_USB=y diff --git a/configs/igep0032_defconfig b/configs/igep0032_defconfig index 3138e96..0ea9e92 100644 --- a/configs/igep0032_defconfig +++ b/configs/igep0032_defconfig @@ -31,6 +31,10 @@ CONFIG_NET_RANDOM_ETHADDR=y CONFIG_MMC_OMAP_HS=y CONFIG_NAND=y CONFIG_SPL_NAND_SIMPLE=y +CONFIG_NETDEVICES=y +CONFIG_SMC911X=y +CONFIG_SMC911X_BASE=0x2C000000 +CONFIG_SMC911X_32_BIT=y CONFIG_SYS_NS16550=y CONFIG_OMAP3_SPI=y CONFIG_FAT_WRITE=y diff --git a/configs/igep00x0_defconfig b/configs/igep00x0_defconfig index 4f13b14..3294194 100644 --- a/configs/igep00x0_defconfig +++ b/configs/igep00x0_defconfig @@ -32,6 +32,10 @@ CONFIG_MMC_OMAP_HS=y CONFIG_NAND=y CONFIG_SPL_NAND_SIMPLE=y CONFIG_MTD_UBI_FASTMAP=y +CONFIG_NETDEVICES=y +CONFIG_SMC911X=y +CONFIG_SMC911X_BASE=0x2C000000 +CONFIG_SMC911X_32_BIT=y CONFIG_SYS_NS16550=y CONFIG_OMAP3_SPI=y CONFIG_FAT_WRITE=y diff --git a/configs/omap3_evm_defconfig b/configs/omap3_evm_defconfig index 14348ee..7173b5d 100644 --- a/configs/omap3_evm_defconfig +++ b/configs/omap3_evm_defconfig @@ -43,6 +43,10 @@ CONFIG_MMC_OMAP_HS=y CONFIG_MTD=y CONFIG_NAND=y CONFIG_SPL_NAND_SIMPLE=y +CONFIG_NETDEVICES=y +CONFIG_SMC911X=y +CONFIG_SMC911X_BASE=0x2C000000 +CONFIG_SMC911X_32_BIT=y CONFIG_DM_SERIAL=y CONFIG_SYS_NS16550=y CONFIG_OMAP3_SPI=y diff --git a/configs/omap3_logic_defconfig b/configs/omap3_logic_defconfig index aacd24a..3352933 100644 --- a/configs/omap3_logic_defconfig +++ b/configs/omap3_logic_defconfig @@ -36,6 +36,10 @@ CONFIG_NAND=y CONFIG_SYS_NAND_U_BOOT_LOCATIONS=y CONFIG_SYS_NAND_U_BOOT_OFFS=0x80000 CONFIG_SPL_NAND_SIMPLE=y +CONFIG_NETDEVICES=y +CONFIG_SMC911X=y +CONFIG_SMC911X_BASE=0x08000000 +CONFIG_SMC911X_32_BIT=y CONFIG_SYS_NS16550=y CONFIG_OMAP3_SPI=y CONFIG_USB=y diff --git a/configs/omap3_overo_defconfig b/configs/omap3_overo_defconfig index 6f94fe6..ea01cd1 100644 --- a/configs/omap3_overo_defconfig +++ b/configs/omap3_overo_defconfig @@ -42,6 +42,10 @@ CONFIG_ENV_IS_IN_NAND=y CONFIG_MMC_OMAP_HS=y CONFIG_NAND=y CONFIG_SPL_NAND_SIMPLE=y +CONFIG_NETDEVICES=y +CONFIG_SMC911X=y +CONFIG_SMC911X_BASE=0x2C000000 +CONFIG_SMC911X_32_BIT=y CONFIG_SYS_NS16550=y CONFIG_OMAP3_SPI=y CONFIG_USB=y diff --git a/configs/omap3_zoom1_defconfig b/configs/omap3_zoom1_defconfig index e50de33..b1a8b5e 100644 --- a/configs/omap3_zoom1_defconfig +++ b/configs/omap3_zoom1_defconfig @@ -32,6 +32,9 @@ CONFIG_EFI_PARTITION=y CONFIG_ENV_IS_IN_NAND=y CONFIG_MMC_OMAP_HS=y CONFIG_NAND=y +CONFIG_NETDEVICES=y +CONFIG_SMC911X=y +CONFIG_SMC911X_32_BIT=y CONFIG_SYS_NS16550=y CONFIG_OMAP3_SPI=y CONFIG_FAT_WRITE=y diff --git a/configs/twister_defconfig b/configs/twister_defconfig index 98fc376..0eefddd 100644 --- a/configs/twister_defconfig +++ b/configs/twister_defconfig @@ -33,6 +33,9 @@ CONFIG_MMC_OMAP_HS=y CONFIG_NAND=y CONFIG_NAND_OMAP_GPMC_PREFETCH=y CONFIG_SPL_NAND_SIMPLE=y +CONFIG_NETDEVICES=y +CONFIG_SMC911X=y +CONFIG_SMC911X_BASE=0x2C000000 CONFIG_SYS_NS16550=y CONFIG_USB=y CONFIG_USB_EHCI_HCD=y diff --git a/include/configs/cm_t35.h b/include/configs/cm_t35.h index 985237c..4e1cc9f 100644 --- a/include/configs/cm_t35.h +++ b/include/configs/cm_t35.h @@ -208,8 +208,7 @@ #define CONFIG_ENV_ADDR 0x260000
#if defined(CONFIG_CMD_NET) -#define CONFIG_SMC911X -#define CONFIG_SMC911X_32_BIT + #define CM_T3X_SMC911X_BASE 0x2C000000 #define SB_T35_SMC911X_BASE (CM_T3X_SMC911X_BASE + (16 << 20)) #define CONFIG_SMC911X_BASE CM_T3X_SMC911X_BASE diff --git a/include/configs/cm_t3517.h b/include/configs/cm_t3517.h index 4a31944..fbb1135 100644 --- a/include/configs/cm_t3517.h +++ b/include/configs/cm_t3517.h @@ -213,9 +213,6 @@ #define CONFIG_DRIVER_TI_EMAC #define CONFIG_DRIVER_TI_EMAC_USE_RMII #define CONFIG_MII -#define CONFIG_SMC911X -#define CONFIG_SMC911X_32_BIT -#define CONFIG_SMC911X_BASE (0x2C000000 + (16 << 20)) #define CONFIG_ARP_TIMEOUT 200UL #define CONFIG_NET_RETRY_COUNT 5 #endif /* CONFIG_CMD_NET */ diff --git a/include/configs/duovero.h b/include/configs/duovero.h index c4496a7..96644b1 100644 --- a/include/configs/duovero.h +++ b/include/configs/duovero.h @@ -30,10 +30,6 @@
#define CONFIG_SYS_ENABLE_PADS_ALL
-#define CONFIG_SMC911X -#define CONFIG_SMC911X_32_BIT -#define CONFIG_SMC911X_BASE 0x2C000000 - /* GPIO */
/* ENV related config options */ diff --git a/include/configs/omap3_evm.h b/include/configs/omap3_evm.h index f12e26c..7354558 100644 --- a/include/configs/omap3_evm.h +++ b/include/configs/omap3_evm.h @@ -84,13 +84,6 @@ /* USB EHCI */ #define CONFIG_SYS_USB_FAT_BOOT_PARTITION 1
-/* SMSC911x Ethernet */ -#if defined(CONFIG_CMD_NET) -#define CONFIG_SMC911X -#define CONFIG_SMC911X_32_BIT -#define CONFIG_SMC911X_BASE 0x2C000000 -#endif /* CONFIG_CMD_NET */ - /* Environment */ #define CONFIG_PREBOOT "usb start"
diff --git a/include/configs/omap3_igep00x0.h b/include/configs/omap3_igep00x0.h index aa7188b..51f2e22 100644 --- a/include/configs/omap3_igep00x0.h +++ b/include/configs/omap3_igep00x0.h @@ -101,15 +101,6 @@
#endif
-/* - * SMSC911x Ethernet - */ -#if defined(CONFIG_CMD_NET) -#define CONFIG_SMC911X -#define CONFIG_SMC911X_32_BIT -#define CONFIG_SMC911X_BASE 0x2C000000 -#endif /* (CONFIG_CMD_NET) */ - #define CONFIG_MTD_PARTITIONS #define CONFIG_SYS_MTDPARTS_RUNTIME
diff --git a/include/configs/omap3_logic.h b/include/configs/omap3_logic.h index 1e3de43..1bb6878 100644 --- a/include/configs/omap3_logic.h +++ b/include/configs/omap3_logic.h @@ -237,13 +237,6 @@ #define CONFIG_ENV_OFFSET 0x260000 #define CONFIG_ENV_ADDR 0x260000
-/* SMSC922x Ethernet */ -#if defined(CONFIG_CMD_NET) -#define CONFIG_SMC911X -#define CONFIG_SMC911X_32_BIT -#define CONFIG_SMC911X_BASE 0x08000000 -#endif /* (CONFIG_CMD_NET) */ - /* Defines for SPL */
/* NAND: SPL falcon mode configs */ diff --git a/include/configs/omap3_zoom1.h b/include/configs/omap3_zoom1.h index cbbe7d4..53923f1 100644 --- a/include/configs/omap3_zoom1.h +++ b/include/configs/omap3_zoom1.h @@ -155,11 +155,7 @@ #define CONFIG_ENV_ADDR 0x260000
#ifdef CONFIG_CMD_NET -/* Ethernet (LAN9211 from SMSC9118 family) */ -#define CONFIG_SMC911X -#define CONFIG_SMC911X_32_BIT #define CONFIG_SMC911X_BASE DEBUG_BASE - #endif
#endif /* __CONFIG_H */ diff --git a/include/configs/twister.h b/include/configs/twister.h index bec402e..777504b 100644 --- a/include/configs/twister.h +++ b/include/configs/twister.h @@ -27,9 +27,7 @@ /* * Miscellaneous configurable options */ -#define CONFIG_SMC911X -#define CONFIG_SMC911X_16_BIT -#define CONFIG_SMC911X_BASE 0x2C000000 + #define CONFIG_SMC911X_NO_EEPROM
#define CONFIG_EXTRA_ENV_SETTINGS CONFIG_TAM3517_SETTINGS \
Note that this was missing the drivers/net/Kconfig part, so I grabbed that again and really merged it in. I've also migrated all users and that meant migrating CONFIG_SMC911X_16_BIT, and it's now applied to u-boot/master, thanks!
Adam Ford
