[PATCH] ARM: dts: xilinx: Fix I2C and SPI bus warnings
Ported over from https://patchwork.kernel.org/patch/10599941/
Signed-off-by: Florian Klink flokli@flokli.de --- arch/arm/dts/zynq-zc702.dts | 12 ++++++------ arch/arm/dts/zynq-zc770-xm010.dts | 2 +- arch/arm/dts/zynq-zc770-xm013.dts | 2 +- 3 files changed, 8 insertions(+), 8 deletions(-)
diff --git a/arch/arm/dts/zynq-zc702.dts b/arch/arm/dts/zynq-zc702.dts index d10695740f..b043d341d6 100644 --- a/arch/arm/dts/zynq-zc702.dts +++ b/arch/arm/dts/zynq-zc702.dts @@ -181,17 +181,17 @@ #address-cells = <1>; #size-cells = <0>; reg = <7>; - hwmon@52 { + hwmon@34 { compatible = "ti,ucd9248"; - reg = <52>; + reg = <0x34>; }; - hwmon@53 { + hwmon@35 { compatible = "ti,ucd9248"; - reg = <53>; + reg = <0x35>; }; - hwmon@54 { + hwmon@36 { compatible = "ti,ucd9248"; - reg = <54>; + reg = <0x36>; }; }; }; diff --git a/arch/arm/dts/zynq-zc770-xm010.dts b/arch/arm/dts/zynq-zc770-xm010.dts index e1f34653ec..c547d7921d 100644 --- a/arch/arm/dts/zynq-zc770-xm010.dts +++ b/arch/arm/dts/zynq-zc770-xm010.dts @@ -72,7 +72,7 @@ status = "okay"; num-cs = <4>; is-decoded-cs = <0>; - flash@0 { + flash@1 { compatible = "sst25wf080", "jedec,spi-nor"; reg = <1>; spi-max-frequency = <1000000>; diff --git a/arch/arm/dts/zynq-zc770-xm013.dts b/arch/arm/dts/zynq-zc770-xm013.dts index 05a49982cc..bdf0c2f956 100644 --- a/arch/arm/dts/zynq-zc770-xm013.dts +++ b/arch/arm/dts/zynq-zc770-xm013.dts @@ -67,7 +67,7 @@ status = "okay"; num-cs = <4>; is-decoded-cs = <0>; - eeprom: eeprom@0 { + eeprom: eeprom@2 { at25,byte-len = <8192>; at25,addr-mode = <2>; at25,page-size = <32>;
Florian Klink
