[U-Boot] [PATCH] AVR32, i386, m68k, MIPS, NIOS, NIOS2 and SPARC: Fix building without CONFIG_CMD_NET
Saw that this got already fixed for ppc. Duno why nobody considered the other archs as well!
Signed-off-by: Marcel Ziswiler marcel.ziswiler@noser.com --- lib_avr32/board.c | 2 ++ lib_i386/board.c | 2 ++ lib_m68k/board.c | 2 ++ lib_mips/board.c | 2 ++ lib_nios/board.c | 2 ++ lib_nios2/board.c | 2 ++ lib_sparc/board.c | 3 +++ 7 files changed, 15 insertions(+), 0 deletions(-)
diff --git a/lib_avr32/board.c b/lib_avr32/board.c index 917ed6c..654f39b 100644 --- a/lib_avr32/board.c +++ b/lib_avr32/board.c @@ -331,7 +331,9 @@ void board_init_r(gd_t *new_gd, ulong dest_addr) /* initialize environment */ env_relocate();
+#ifdef CONFIG_CMD_NET bd->bi_ip_addr = getenv_IPaddr ("ipaddr"); +#endif
stdio_init(); jumptable_init(); diff --git a/lib_i386/board.c b/lib_i386/board.c index f3b6348..af81cd5 100644 --- a/lib_i386/board.c +++ b/lib_i386/board.c @@ -280,8 +280,10 @@ void board_init_r(gd_t *id, ulong ram_start) show_boot_progress(0x26);
+#ifdef CONFIG_CMD_NET /* IP Address */ bd_data.bi_ip_addr = getenv_IPaddr ("ipaddr"); +#endif
#if defined(CONFIG_PCI) /* diff --git a/lib_m68k/board.c b/lib_m68k/board.c index 732023d..f0aac98 100644 --- a/lib_m68k/board.c +++ b/lib_m68k/board.c @@ -545,6 +545,7 @@ void board_init_r (gd_t *id, ulong dest_addr) /* relocate environment function pointers etc. */ env_relocate ();
+#ifdef CONFIG_CMD_NET /* * Fill in missing fields of bd_info. * We do this here, where we have "normal" access to the @@ -553,6 +554,7 @@ void board_init_r (gd_t *id, ulong dest_addr) * the environment is in EEPROM. */ bd->bi_ip_addr = getenv_IPaddr ("ipaddr"); +#endif
WATCHDOG_RESET ();
diff --git a/lib_mips/board.c b/lib_mips/board.c index b2d113e..5c35884 100644 --- a/lib_mips/board.c +++ b/lib_mips/board.c @@ -370,8 +370,10 @@ void board_init_r (gd_t *id, ulong dest_addr) /* relocate environment function pointers etc. */ env_relocate();
+#ifdef CONFIG_CMD_NET /* IP Address */ bd->bi_ip_addr = getenv_IPaddr("ipaddr"); +#endif
#if defined(CONFIG_PCI) /* diff --git a/lib_nios/board.c b/lib_nios/board.c index 5d2fb2e..e782884 100644 --- a/lib_nios/board.c +++ b/lib_nios/board.c @@ -121,7 +121,9 @@ void board_init (void) WATCHDOG_RESET (); env_relocate();
WATCHDOG_RESET (); stdio_init(); diff --git a/lib_nios2/board.c b/lib_nios2/board.c index 41d3297..699de2e 100644 --- a/lib_nios2/board.c +++ b/lib_nios2/board.c @@ -125,7 +125,9 @@ void board_init (void) WATCHDOG_RESET (); env_relocate();
WATCHDOG_RESET (); stdio_init(); diff --git a/lib_sparc/board.c b/lib_sparc/board.c index 11eea60..35e7359 100644 --- a/lib_sparc/board.c +++ b/lib_sparc/board.c @@ -361,8 +361,11 @@ void board_init_f(ulong bootflag) mac_read_from_eeprom(); #endif
+#ifdef CONFIG_CMD_NET /* IP Address */ bd->bi_ip_addr = getenv_IPaddr("ipaddr"); +#endif + #if defined(CONFIG_PCI) /* * Do pci configuration
Any hint how/where it was fixed for ppc? Hopefully this fix can give us a hint how to fix it for all other architectures. Wolfgang doesn't seem to like fix below ;)
Best regards
Dirk
Signed-off-by: Marcel Ziswilermarcel.ziswiler@noser.com
WATCHDOG_RESET ();
- #if defined(CONFIG_PCI) /*
- Do pci configuration
Dirk Behme
Marcel Ziswiler
