[PATCH] net: dwmac_meson8b: do not set TX delay in TXID & RXID
When the PHY interface is set as TXID & RXID, the delays should be taken from DT, but first they should not be hardcoded since the PHY driver will set them.
Fixes: 798424e857 ("net: designware: add Amlogic Meson8b & later glue driver") Signed-off-by: Neil Armstrong narmstrong@baylibre.com --- drivers/net/dwmac_meson8b.c | 23 +++++++++++++++++++---- 1 file changed, 19 insertions(+), 4 deletions(-)
diff --git a/drivers/net/dwmac_meson8b.c b/drivers/net/dwmac_meson8b.c index c0b6ef4994..40cd8370b0 100644 --- a/drivers/net/dwmac_meson8b.c +++ b/drivers/net/dwmac_meson8b.c @@ -59,8 +59,6 @@ static int dwmac_setup_axg(struct udevice *dev, struct eth_pdata *edata) switch (edata->phy_interface) { case PHY_INTERFACE_MODE_RGMII: case PHY_INTERFACE_MODE_RGMII_ID: - case PHY_INTERFACE_MODE_RGMII_RXID: - case PHY_INTERFACE_MODE_RGMII_TXID: /* Set RGMII mode */ setbits_le32(plat->regs + ETH_REG_0, AXG_ETH_REG_0_PHY_INTF_RGMII | AXG_ETH_REG_0_TX_PHASE(1) | @@ -69,6 +67,15 @@ static int dwmac_setup_axg(struct udevice *dev, struct eth_pdata *edata) AXG_ETH_REG_0_CLK_EN); break;
+ case PHY_INTERFACE_MODE_RGMII_RXID: + case PHY_INTERFACE_MODE_RGMII_TXID: + /* TOFIX: handle amlogic,tx-delay-ns & rx-internal-delay-ps from DT */ + setbits_le32(plat->regs + ETH_REG_0, AXG_ETH_REG_0_PHY_INTF_RGMII | + AXG_ETH_REG_0_TX_RATIO(4) | + AXG_ETH_REG_0_PHY_CLK_EN | + AXG_ETH_REG_0_CLK_EN); + break; + case PHY_INTERFACE_MODE_RMII: /* Set RMII mode */ out_le32(plat->regs + ETH_REG_0, AXG_ETH_REG_0_PHY_INTF_RMII | @@ -90,8 +97,6 @@ static int dwmac_setup_gx(struct udevice *dev, struct eth_pdata *edata) switch (edata->phy_interface) { case PHY_INTERFACE_MODE_RGMII: case PHY_INTERFACE_MODE_RGMII_ID: - case PHY_INTERFACE_MODE_RGMII_RXID: - case PHY_INTERFACE_MODE_RGMII_TXID: /* Set RGMII mode */ setbits_le32(plat->regs + ETH_REG_0, GX_ETH_REG_0_PHY_INTF | GX_ETH_REG_0_TX_PHASE(1) | @@ -101,6 +106,16 @@ static int dwmac_setup_gx(struct udevice *dev, struct eth_pdata *edata)
break;
+ case PHY_INTERFACE_MODE_RGMII_RXID: + case PHY_INTERFACE_MODE_RGMII_TXID: + /* TOFIX: handle amlogic,tx-delay-ns & rx-internal-delay-ps from DT */ + setbits_le32(plat->regs + ETH_REG_0, GX_ETH_REG_0_PHY_INTF | + GX_ETH_REG_0_TX_RATIO(4) | + GX_ETH_REG_0_PHY_CLK_EN | + GX_ETH_REG_0_CLK_EN); + + break; + case PHY_INTERFACE_MODE_RMII: /* Set RMII mode */ out_le32(plat->regs + ETH_REG_0, GX_ETH_REG_0_INVERT_RMII_CLK |
On Wed, May 5, 2021 at 10:55 AM Neil Armstrong narmstrong@baylibre.com wrote:
break;
break;
break;
-- 2.25.1
Reviewed-by: Ramon Fried rfried.dev@gmail.com
break;
break;
break;
-- 2.25.1
Thanks,
Applied to u-boot-amlogic,
Neil
Neil Armstrong
Ramon Fried
