[RFC 0/2] A/B firmware update based in eMMC boot partition.
From: "Ying-Chun Liu (PaulLiu)" paul.liu@linaro.org
Hi all,
I've implemented A/B firmware update based on eMMC hw partitions. Normally we have 2 boot partitions on eMMC. One is active and another is inactive. We can then flash the firmware to the inactive one and make it active.
Also when booting we can write protect the current active one. And left the inactive partition still writable.
So I make 2 commits that implements the following features: 1. Write protect "active" boot area when board init. 2. flash firmware to inactive boot area. 3. Change the inactive boot area after firmware update.
Thanks.
Ying-Chun Liu (PaulLiu) (2): drivers: mmc: write protect active boot area after mmc init. drivers: dfu: flash firmware to inactive boot area and active it
drivers/dfu/dfu_mmc.c | 32 +++++++++++++++++++++--- drivers/mmc/Kconfig | 10 ++++++++ drivers/mmc/mmc.c | 58 +++++++++++++++++++++++++++++++++++++++++++ include/dfu.h | 1 + 4 files changed, 98 insertions(+), 3 deletions(-)
This commit implements write protection for active boot partition for eMMC. The active boot partition is write protected, and it is still able to write to the inactive boot partition.
Signed-off-by: Ying-Chun Liu (PaulLiu) paul.liu@linaro.org Cc: Peng Fan peng.fan@nxp.com Cc: Jaehoon Chung jh80.chung@samsung.com --- drivers/mmc/Kconfig | 10 ++++++++ drivers/mmc/mmc.c | 58 +++++++++++++++++++++++++++++++++++++++++++++ 2 files changed, 68 insertions(+)
diff --git a/drivers/mmc/Kconfig b/drivers/mmc/Kconfig index e0927ce1c9..c4bae743e6 100644 --- a/drivers/mmc/Kconfig +++ b/drivers/mmc/Kconfig @@ -100,6 +100,16 @@ config MMC_HW_PARTITIONING This adds a command and an API to do hardware partitioning on eMMC devices.
+config MMC_WRITE_PROTECT_ACTIVE_BOOT + bool "Write protection for active boot partition (eMMC)" + depends on MMC_HW_PARTITIONING + default n + help + Write protection for active boot partition when mmc initialized. + This option protects the active boot partition so that it cannot + be written. But it is still able to write to the inactive boot + partition. + config SUPPORT_EMMC_RPMB bool "Support eMMC replay protected memory block (RPMB)" imply CMD_MMC_RPMB diff --git a/drivers/mmc/mmc.c b/drivers/mmc/mmc.c index 4d9871d69f..8620918749 100644 --- a/drivers/mmc/mmc.c +++ b/drivers/mmc/mmc.c @@ -860,6 +860,60 @@ int mmc_boot_wp(struct mmc *mmc) return mmc_switch(mmc, EXT_CSD_CMD_SET_NORMAL, EXT_CSD_BOOT_WP, 1); }
+/** + * mmc_boot_wp_single_partition() - set write protection to a boot partition. + * + * This function sets a single boot partition to protect and leave the + * other partition writable. + * + * @param mmc the mmc device. + * @param partition 0 - first boot partition, 1 - second boot partition. + */ +int mmc_boot_wp_single_partition(struct mmc *mmc, int partition) +{ + u8 value; + int ret; + + value = 1; + + if (partition == 0) { + value |= 0x80; + ret = mmc_switch(mmc, + EXT_CSD_CMD_SET_NORMAL, + EXT_CSD_BOOT_WP, + value); + } else if (partition == 1) { + value |= 0x80; + value |= 0x02; + ret = mmc_switch(mmc, + EXT_CSD_CMD_SET_NORMAL, + EXT_CSD_BOOT_WP, + value); + } else { + ret = mmc_boot_wp(mmc); + } + + return ret; +} + +/** + * mmc_boot_wp_active_partition() - set write protection to active boot + * partition. + * + * @param mmc the mmc device. + */ +static int mmc_boot_wp_active_partition(struct mmc *mmc) +{ + u8 part; + + if (mmc->part_config == MMCPART_NOAVAILABLE) + return -EOPNOTSUPP; + + part = EXT_CSD_EXTRACT_BOOT_PART(mmc->part_config); + + return mmc_boot_wp_single_partition(mmc, part - 1); +} + #if !CONFIG_IS_ENABLED(MMC_TINY) static int mmc_set_card_speed(struct mmc *mmc, enum bus_mode mode, bool hsdowngrade) @@ -2925,6 +2979,10 @@ static int mmc_complete_init(struct mmc *mmc) mmc->has_init = 0; else mmc->has_init = 1; + + if (!err && CONFIG_IS_ENABLED(MMC_WRITE_PROTECT_ACTIVE_BOOT)) + mmc_boot_wp_active_partition(mmc); + return err; }
It seems that you want to enable Write-protect about boot partition without additional command, right? After initialized eMMC, how to update image into boot partition?
Best Regards, Jaehoon Chung
- bool "Write protection for active boot partition (eMMC)"
- depends on MMC_HW_PARTITIONING
- default n
- help
partition.
- mmc_boot_wp_single_partition() - set write protection to a boot partition.
- This function sets a single boot partition to protect and leave the
- other partition writable.
- @param mmc the mmc device.
- @param partition 0 - first boot partition, 1 - second boot partition.
- u8 value;
- int ret;
- value = 1;
- if (partition == 0) {
value |= 0x80;
EXT_CSD_BOOT_WP,
value);
- } else if (partition == 1) {
value |= 0x80;
value |= 0x02;
EXT_CSD_BOOT_WP,
value);
- } else {
- return ret;
- mmc_boot_wp_active_partition() - set write protection to active boot
- partition.
- u8 part;
- if (mmc->part_config == MMCPART_NOAVAILABLE)
return -EOPNOTSUPP;
- part = EXT_CSD_EXTRACT_BOOT_PART(mmc->part_config);
- return mmc_boot_wp_single_partition(mmc, part - 1);
- if (!err && CONFIG_IS_ENABLED(MMC_WRITE_PROTECT_ACTIVE_BOOT))
- return err;
Hi Jaehoon,
There are 2 boot partitions on eMMC. So the active one is write-protected. Users can write the new firmware to another boot partition (inactive) which is not write-protected. And then switch it on.
In U-boot, execute "mmc wp" write-protect all of the boot partitions. Maybe we can add an additional command that just write-protect only one boot partition.
Yours, Paul
eMMC
devices.
default n
help
partition.
partition.
u8 value;
int ret;
value = 1;
value |= 0x80;
EXT_CSD_BOOT_WP,
value);
value |= 0x80;
value |= 0x02;
EXT_CSD_BOOT_WP,
value);
} else {
return ret;
- partition.
u8 part;
return -EOPNOTSUPP;
return err;
Hi Paul
On 1/27/22 10:23, Paul Liu wrote:
Hi Jaehoon,
I know there are two boot partitions. Well, it seems that is for A/B switching scheme, right?
Yours, Paul
eMMC
devices.
default n
help
partition.
partition.
u8 value;
int ret;
value = 1;
value |= 0x80;
Use macro instead of 0x80.
EXT_CSD_BOOT_WP,
value);
value |= 0x80;
value |= 0x02;
Ditto.
EXT_CSD_BOOT_WP,
value);
} else {
how aboutusing switch statements?
switch (partition) { case 0: value |= 0x80; case 1: value |= 0x02; mmc_switch(); break;
default: mmc_boot_wp();
return ret;
- partition.
u8 part;
return -EOPNOTSUPP;
I think that "if (CONFIG_IS_ENABLED(MMC_WRITE_PROTECT_ACTIVE_BOOT) && !err)" is more better.
Need to handle error.
return err;
This commit implement flash to the inactive boot partition of eMMC when dfu_alt_info set mmcpart to "inactive". After flash to the inactive boot partition. It will switch the active partition to the one that just flashed.
Signed-off-by: Ying-Chun Liu (PaulLiu) paul.liu@linaro.org Cc: Lukasz Majewski lukma@denx.de --- drivers/dfu/dfu_mmc.c | 32 +++++++++++++++++++++++++++++--- include/dfu.h | 1 + 2 files changed, 30 insertions(+), 3 deletions(-)
diff --git a/drivers/dfu/dfu_mmc.c b/drivers/dfu/dfu_mmc.c index 3dab5a5f63..3c1f2018d3 100644 --- a/drivers/dfu/dfu_mmc.c +++ b/drivers/dfu/dfu_mmc.c @@ -198,6 +198,7 @@ int dfu_write_medium_mmc(struct dfu_entity *dfu, u64 offset, void *buf, long *len) { int ret = -1; + struct mmc *mmc;
switch (dfu->layout) { case DFU_RAW_ADDR: @@ -218,6 +219,17 @@ int dfu_write_medium_mmc(struct dfu_entity *dfu, dfu_get_layout(dfu->layout)); }
+ if (!ret && dfu->data.mmc.hw_partition_inactive) { + mmc = find_mmc_device(dfu->data.mmc.dev_num); + if (!mmc) { + pr_err("Device MMC %d - not found!", + dfu->data.mmc.dev_num); + return -ENODEV; + } + + mmc_set_part_conf(mmc, 0, dfu->data.mmc.hw_partition, 0); + } + return ret; }
@@ -384,15 +396,29 @@ int dfu_fill_entity_mmc(struct dfu_entity *dfu, char *devstr, char *s) dfu->data.mmc.lba_start = second_arg; dfu->data.mmc.lba_size = third_arg; dfu->data.mmc.lba_blk_size = mmc->read_bl_len; + dfu->data.mmc.hw_partition_inactive = false;
/* * Check for an extra entry at dfu_alt_info env variable * specifying the mmc HW defined partition number */ if (s) - if (!strcmp(strsep(&s, " "), "mmcpart")) - dfu->data.mmc.hw_partition = - simple_strtoul(s, NULL, 0); + if (!strcmp(strsep(&s, " "), "mmcpart")) { + if (!strcmp(s, "inactive")) { + u8 part_boot; + u8 part_target; + + part_boot = EXT_CSD_EXTRACT_BOOT_PART(mmc->part_config); + part_target = 3 - part_boot; + dfu->data.mmc.hw_partition = + part_target; + dfu->data.mmc.hw_partition_inactive = + true; + } else { + dfu->data.mmc.hw_partition = + simple_strtoul(s, NULL, 0); + } + }
} else if (!strcmp(entity_type, "part")) { struct disk_partition partinfo; diff --git a/include/dfu.h b/include/dfu.h index f6868982df..7fbcf03063 100644 --- a/include/dfu.h +++ b/include/dfu.h @@ -53,6 +53,7 @@ struct mmc_internal_data {
/* eMMC HW partition access */ int hw_partition; + bool hw_partition_inactive;
/* FAT/EXT */ unsigned int dev;
Dear Ying-Chun Liu,
We have been doing software updates using U-Boot scripts etc. for many, many years. But during that time a large number of restrictions and shortcomings became clear. this is why projects like SWUpdate [1] came into life, and U-Boot supports this only with very basic features:
- watchdog support to reset a hanging system - boot counter to switch to an alternate boot command in case of too many failed boot attempts
That's all. Not more is needed, and not more should be used in U-Boot.
I'm not sure if you know SWUpdate - if not, you should definitely look into it. I strongly recommend not to try to reinvent that wheel - poorly - in U-Boot. We have been there before, and got rid of this approach for a pretty long list of good reasons.
[1] https://sbabic.github.io/swupdate/
Hello,
Am Tue, Jan 25, 2022 at 03:43:29PM +0100 schrieb Wolfgang Denk:
Dear Ying-Chun Liu,
FWIW, if you don't want to reinvent the wheel and evaluate alternatives, you might also want to checkout RAUC [1]. It has builtin support for that eMMC boot partition scenario. The u-boot integration is not as sophisticated as for other bootloaders, but I got that running with u-boot last year on raw NAND flash and it's a lot better than hacking together your own A/B update scheme scripts.
HTH & Greets Alex
On Tue, Jan 25, 2022 at 03:43:29PM +0100, Wolfgang Denk wrote:
Dear Ying-Chun Liu,
[snip]
I just want to chime in here and agree with the overall point that Wolfgang is making. There are a number of update schemes that handle firmware (to whatever level can be safely done) and I see U-Boot's role here as to support these mechanisms as easily and cleanly as possible (so, watchdog, bootcount, etc, etc) but to not implement a specific scheme directly.
participants (6)
Alexander Dahl
Jaehoon Chung
Paul Liu
Ying-Chun Liu
