[U-Boot] [PATCH 1/3] mach-imx: Adding new argument for SIP call interface
Need to pass total 5 arguments for SIP HAB call on i.MX8MQ, so update the interface to add new argument.
Signed-off-by: Ye Li ye.li@nxp.com --- arch/arm/include/asm/mach-imx/sys_proto.h | 3 ++- arch/arm/mach-imx/imx_bootaux.c | 4 ++-- arch/arm/mach-imx/sip.c | 4 +++- drivers/misc/imx8/fuse.c | 2 +- 4 files changed, 8 insertions(+), 5 deletions(-)
diff --git a/arch/arm/include/asm/mach-imx/sys_proto.h b/arch/arm/include/asm/mach-imx/sys_proto.h index aa66fdc88f..139a7638c1 100644 --- a/arch/arm/include/asm/mach-imx/sys_proto.h +++ b/arch/arm/include/asm/mach-imx/sys_proto.h @@ -143,7 +143,8 @@ int mxs_wait_mask_set(struct mxs_register_32 *reg, u32 mask, u32 timeout); int mxs_wait_mask_clr(struct mxs_register_32 *reg, u32 mask, u32 timeout);
unsigned long call_imx_sip(unsigned long id, unsigned long reg0, - unsigned long reg1, unsigned long reg2); + unsigned long reg1, unsigned long reg2, + unsigned long reg3); unsigned long call_imx_sip_ret2(unsigned long id, unsigned long reg0, unsigned long *reg1, unsigned long reg2, unsigned long reg3); diff --git a/arch/arm/mach-imx/imx_bootaux.c b/arch/arm/mach-imx/imx_bootaux.c index 18d7e6819c..3d9422d5a2 100644 --- a/arch/arm/mach-imx/imx_bootaux.c +++ b/arch/arm/mach-imx/imx_bootaux.c @@ -26,7 +26,7 @@ int arch_auxiliary_core_up(u32 core_id, ulong boot_private_data)
/* Enable M4 */ #ifdef CONFIG_IMX8M - call_imx_sip(IMX_SIP_SRC, IMX_SIP_SRC_M4_START, 0, 0); + call_imx_sip(IMX_SIP_SRC, IMX_SIP_SRC_M4_START, 0, 0, 0); #else clrsetbits_le32(SRC_BASE_ADDR + SRC_M4_REG_OFFSET, SRC_M4C_NON_SCLR_RST_MASK, SRC_M4_ENABLE_MASK); @@ -38,7 +38,7 @@ int arch_auxiliary_core_up(u32 core_id, ulong boot_private_data) int arch_auxiliary_core_check_up(u32 core_id) { #ifdef CONFIG_IMX8M - return call_imx_sip(IMX_SIP_SRC, IMX_SIP_SRC_M4_STARTED, 0, 0); + return call_imx_sip(IMX_SIP_SRC, IMX_SIP_SRC_M4_STARTED, 0, 0, 0); #else unsigned int val;
diff --git a/arch/arm/mach-imx/sip.c b/arch/arm/mach-imx/sip.c index 968e7cf309..fca520c671 100644 --- a/arch/arm/mach-imx/sip.c +++ b/arch/arm/mach-imx/sip.c @@ -7,7 +7,8 @@ #include <asm/arch/sys_proto.h>
unsigned long call_imx_sip(unsigned long id, unsigned long reg0, - unsigned long reg1, unsigned long reg2) + unsigned long reg1, unsigned long reg2, + unsigned long reg3) { struct pt_regs regs;
@@ -15,6 +16,7 @@ unsigned long call_imx_sip(unsigned long id, unsigned long reg0, regs.regs[1] = reg0; regs.regs[2] = reg1; regs.regs[3] = reg2; + regs.regs[4] = reg3;
smc_call(®s);
diff --git a/drivers/misc/imx8/fuse.c b/drivers/misc/imx8/fuse.c index 2f2fad2c17..1309215d4d 100644 --- a/drivers/misc/imx8/fuse.c +++ b/drivers/misc/imx8/fuse.c @@ -74,7 +74,7 @@ int fuse_prog(u32 bank, u32 word, u32 val) }
return call_imx_sip(FSL_SIP_OTP_WRITE, (unsigned long)word, - (unsigned long)val, 0); + (unsigned long)val, 0, 0); }
int fuse_override(u32 bank, u32 word, u32 val)
Add function for reading SECO-FW commit id.
Signed-off-by: Anatolij Gustschin agust@denx.de --- arch/arm/include/asm/arch-imx8/sci/sci.h | 1 + drivers/misc/imx8/scu_api.c | 27 ++++++++++++++++++++++++ 2 files changed, 28 insertions(+)
diff --git a/arch/arm/include/asm/arch-imx8/sci/sci.h b/arch/arm/include/asm/arch-imx8/sci/sci.h index 14ee6f999b..df5c60d4ce 100644 --- a/arch/arm/include/asm/arch-imx8/sci/sci.h +++ b/arch/arm/include/asm/arch-imx8/sci/sci.h @@ -81,6 +81,7 @@ int sc_misc_get_control(sc_ipc_t ipc, sc_rsrc_t resource, sc_ctrl_t ctrl, void sc_misc_get_boot_dev(sc_ipc_t ipc, sc_rsrc_t *boot_dev); void sc_misc_boot_status(sc_ipc_t ipc, sc_misc_boot_status_t status); void sc_misc_build_info(sc_ipc_t ipc, u32 *build, u32 *commit); +void sc_misc_seco_build_info(sc_ipc_t ipc, u32 *version, u32 *commit); int sc_misc_otp_fuse_read(sc_ipc_t ipc, u32 word, u32 *val); int sc_misc_get_temp(sc_ipc_t ipc, sc_rsrc_t resource, sc_misc_temp_t temp, s16 *celsius, s8 *tenths); diff --git a/drivers/misc/imx8/scu_api.c b/drivers/misc/imx8/scu_api.c index b2fdeef13a..44d0165c3f 100644 --- a/drivers/misc/imx8/scu_api.c +++ b/drivers/misc/imx8/scu_api.c @@ -349,6 +349,33 @@ void sc_misc_build_info(sc_ipc_t ipc, u32 *build, u32 *commit) *commit = RPC_U32(&msg, 4); }
+void sc_misc_seco_build_info(sc_ipc_t ipc, u32 *version, u32 *commit) +{ + struct udevice *dev = gd->arch.scu_dev; + int size = sizeof(struct sc_rpc_msg_s); + struct sc_rpc_msg_s msg; + int ret; + + if (!dev) + hang(); + + RPC_VER(&msg) = SC_RPC_VERSION; + RPC_SVC(&msg) = SC_RPC_SVC_MISC; + RPC_FUNC(&msg) = MISC_FUNC_SECO_BUILD_INFO; + RPC_SIZE(&msg) = 1; + + ret = misc_call(dev, SC_FALSE, &msg, size, &msg, size); + if (ret < 0) { + printf("%s: err: %d\n", __func__, ret); + return; + } + + if (version) + *version = RPC_U32(&msg, 0); + if (commit) + *commit = RPC_U32(&msg, 4); +} + int sc_misc_otp_fuse_read(sc_ipc_t ipc, u32 word, u32 *val) { struct udevice *dev = gd->arch.scu_dev;
Hi Anatolij
Subject: [PATCH 2/3] imx8: add sc_misc_seco_build_info()
sc_seco_build_info already in Stefano's tree.
Thanks, Peng.
+void sc_misc_seco_build_info(sc_ipc_t ipc, u32 *version, u32 *commit) {
- struct udevice *dev = gd->arch.scu_dev;
- int size = sizeof(struct sc_rpc_msg_s);
- struct sc_rpc_msg_s msg;
- int ret;
- if (!dev)
hang();
- RPC_VER(&msg) = SC_RPC_VERSION;
- RPC_SVC(&msg) = SC_RPC_SVC_MISC;
- RPC_FUNC(&msg) = MISC_FUNC_SECO_BUILD_INFO;
- RPC_SIZE(&msg) = 1;
- ret = misc_call(dev, SC_FALSE, &msg, size, &msg, size);
- if (ret < 0) {
return;
- if (version)
- if (commit)
int sc_misc_otp_fuse_read(sc_ipc_t ipc, u32 word, u32 *val) { struct udevice *dev = gd->arch.scu_dev; -- 2.17.1
Hi Peng,
On Tue, 22 Oct 2019 02:47:28 +0000 Peng Fan peng.fan@nxp.com wrote: ...
Ah, I didn't notice it, must have been merged recently.
Thanks for pointing!
-- Anatolij
Hi Peng,
sc_seco_build_info() in current git master works on i.MX8QXP MEK board, but it doesn't work on my custom board with different blobs. Here U-Boot triggers system reset somewhere in sc_seco_build_info()->misc_call().
With sc_misc_seco_build_info() in this patch getting the IDs works, I've following IDs on this board: SCFW 65afe5f6, SECO-FW 9d71fd5b, ATF d6451cc
The differences: sc_seco_build_info() uses SC_RPC_SVC_SECO/SECO_FUNC_BUILD_INFO, sc_misc_seco_build_info() uses SC_RPC_SVC_MISC/MISC_FUNC_SECO_BUILD_INFO.
Any idea why sc_seco_build_info() ends in system reset?
Thanks,
-- Anatolij
Subject: Re: [PATCH 2/3] imx8: add sc_misc_seco_build_info()
Hi Peng,
You might need to update your seco/scfw.
Thanks, Peng
Thanks,
-- Anatolij
Borrow ID reading code from Ye Li (NXP U-Boot, commit ID 5b443e3e2617) and add the commit IDs to the environment.
Signed-off-by: Anatolij Gustschin agust@denx.de --- arch/arm/mach-imx/imx8/misc.c | 61 ++++++++++++++++++++++++++++++++++- 1 file changed, 60 insertions(+), 1 deletion(-)
diff --git a/arch/arm/mach-imx/imx8/misc.c b/arch/arm/mach-imx/imx8/misc.c index fe73e29eee..b0693358e7 100644 --- a/arch/arm/mach-imx/imx8/misc.c +++ b/arch/arm/mach-imx/imx8/misc.c @@ -1,6 +1,9 @@ // SPDX-License-Identifier: GPL-2.0+ #include <common.h> #include <asm/arch/sci/sci.h> +#include <asm/arch/sys_proto.h> + +DECLARE_GLOBAL_DATA_PTR;
int sc_pm_setup_uart(sc_rsrc_t uart_rsrc, sc_pm_clock_rate_t clk_rate) { @@ -25,9 +28,28 @@ int sc_pm_setup_uart(sc_rsrc_t uart_rsrc, sc_pm_clock_rate_t clk_rate) return 0; }
+#define FSL_SIP_BUILDINFO 0xC2000003 +#define FSL_SIP_BUILDINFO_GET_COMMITHASH 0x00 +extern uint32_t _end_ofs; + +static void set_buildinfo_to_env(uint32_t scfw, uint32_t secofw, + char *mkimage, char *atf) +{ + if (!mkimage || !atf) + return; + + env_set("commit_mkimage", mkimage); + env_set("commit_atf", atf); + env_set_hex("commit_scfw", (ulong)scfw); + env_set_hex("commit_secofw", (ulong)secofw); +} + void build_info(void) { + u32 seco_build = 0, seco_commit = 0; u32 sc_build = 0, sc_commit = 0; + ulong atf_commit = 0; + char *mkimage_commit, *temp;
/* Get SCFW build and commit id */ sc_misc_build_info(-1, &sc_build, &sc_commit); @@ -35,5 +57,42 @@ void build_info(void) printf("SCFW does not support build info\n"); sc_commit = 0; /* Display 0 if build info not supported */ } - printf("Build: SCFW %x\n", sc_commit); + + /* Get SECO FW build and commit id */ + sc_misc_seco_build_info(-1, &seco_build, &seco_commit); + if (!seco_build) { + debug("SECO FW does not support build info\n"); + /* Display 0 when the build info is not supported */ + seco_commit = 0; + } + + /* + * Get imx-mkimage commit id. + * The imx-mkimage puts the commit hash behind the end of u-boot.bin + */ + mkimage_commit = (char *)(ulong)(CONFIG_SYS_TEXT_BASE + _end_ofs + + fdt_totalsize(gd->fdt_blob)); + temp = mkimage_commit + 8; + *temp = '\0'; + + if (strlen(mkimage_commit) == 0) { + debug("IMX-MKIMAGE does not support build info\n"); + mkimage_commit = "0"; /* Display 0 */ + } + + /* Get ARM Trusted Firmware commit id */ + atf_commit = call_imx_sip(FSL_SIP_BUILDINFO, + FSL_SIP_BUILDINFO_GET_COMMITHASH, 0, 0, 0); + if (atf_commit == 0xffffffff) { + debug("ATF does not support build info\n"); + atf_commit = 0x30; /* Display 0 */ + } + + printf("Build: SCFW %08x, SECO-FW %08x\n" + " IMX-MKIMAGE %s, ATF %s\n", + sc_commit, seco_commit, mkimage_commit, (char *)&atf_commit); + + /* Set all to env */ + set_buildinfo_to_env(sc_commit, seco_commit, mkimage_commit, + (char *)&atf_commit); }
Hi Anatolij,
Subject: [PATCH 3/3] imx8: output SECO-FW, ATF and imx-mkimage commit IDs
- if (!mkimage || !atf)
return;
- env_set("commit_mkimage", mkimage);
- env_set("commit_atf", atf);
- env_set_hex("commit_scfw", (ulong)scfw);
- env_set_hex("commit_secofw", (ulong)secofw); }
- /* Get SECO FW build and commit id */
- sc_misc_seco_build_info(-1, &seco_build, &seco_commit);
Use sc_seco_build_info.
- if (!seco_build) {
seco_commit = 0;
- mkimage_commit = (char *)(ulong)(CONFIG_SYS_TEXT_BASE + _end_ofs
- temp = mkimage_commit + 8;
- *temp = '\0';
- if (strlen(mkimage_commit) == 0) {
We no need imx-mkimage, use mkimage in U-Boot no need this piece code.
Regards, Peng.
- /* Get ARM Trusted Firmware commit id */
- atf_commit = call_imx_sip(FSL_SIP_BUILDINFO,
- if (atf_commit == 0xffffffff) {
- printf("Build: SCFW %08x, SECO-FW %08x\n"
*)&atf_commit);
- /* Set all to env */
- set_buildinfo_to_env(sc_commit, seco_commit, mkimage_commit,
2.17.1
Hi Peng,
On Tue, 22 Oct 2019 02:49:53 +0000 Peng Fan peng.fan@nxp.com wrote: ...
OK, will do in v2.
will drop it in v2 patch.
-- Anatolij
- call_imx_sip(IMX_SIP_SRC, IMX_SIP_SRC_M4_START, 0, 0, 0);
- return call_imx_sip(IMX_SIP_SRC, IMX_SIP_SRC_M4_STARTED, 0, 0, 0);
unsigned long reg3)
smc_call(®s);
2.17.1
Reviewed-by: Patrick Wildt patrick@blueri.se
On Mon, 21 Oct 2019 17:58:49 +0200 Anatolij Gustschin agust@denx.de wrote: ...
with current git master this patch breaks building imx8m-power-domain.c. I'll fix it v2 patch.
-- Anatolij
Anatolij Gustschin
Patrick Wildt
Peng Fan
