[U-Boot] fw_env.config settings for Digilent ZedBoard (Zynq 7020 Soc)
I'm using a Digilent ZedBoard with a Xilinx Zynq 7020 SoC. The kernel is from Analog Devices and is a fork of 4.0.0 (according to the Makefile).
I am struggling to work out the fw_env.config file required to use with fw_printenv/fw_saveenv. fw_printenv continually gives me CRC error and uses the defaults.
Google hasn't provided much assistance, with some people reporting that the settings required are different to what /proc/mtd shows.
Here is info from /proc/mtd and my /etc/fw_env.config.
root@bjs:~# cat /proc/mtd
dev: size erasesize name mtd0: 00500000 00010000 "boot" mtd1: 00020000 00010000 "bootenv" mtd2: 00020000 00010000 "config" mtd3: 00a80000 00010000 "image" mtd4: 01040000 00010000 "spare"
root@bjs:~# cat /etc/fw_env.config
# Configuration file for fw_(printenv/setenv) utility. # Up to two entries are valid, in this case the redundant # environment sector is assumed present. # MTD device name Device offset Env. size Flash sector size # /dev/mtd1 0x0000 0x20000 0x40000 # /dev/mtd1 0x0000 0x20000 0x20000 # /dev/mtd1 0x0000 0x20000 0x10000 # /dev/mtd2 0x0000 0x20000 0x40000 # /dev/mtd2 0x0000 0x20000 0x20000 /dev/mtd2 0x0000 0x20000 0x10000
Does anyone have any insight into what the correct fw_env.config settings should be from the above info?
How can I find out the correct settings. Is there a command in u-boot itself which will report the correct information?
Thanks, Brendan.
On Sun, 6 Dec 2015 12:01:08 +1100 "Brendan Simon (eTRIX)" brendan.simon@etrix.com.au wrote:
Using /dev/mtd2 in /etc/fw_env.config might be wrong. First, you need to figure out which mtd partition contains the sectors with U-Boot environment variables. According to /proc/mtd info it could be the mtd1, if the mtd partitions layout under linux is correct. To check it, just run
dd if=/dev/mtd1 | hexdump -C
If the dumped data looks like environment variables, e.g.
00000000 a5 72 49 1b 01 61 64 64 63 6f 6e 73 3d 73 65 74 |.rI..addcons=set| 00000010 65 6e 76 20 62 6f 6f 74 61 72 67 73 20 24 7b 62 |env bootargs ${b| 00000020 6f 6f 74 61 72 67 73 7d 20 63 6f 6e 73 6f 6c 65 |ootargs} console| 00000030 3d 24 7b 63 6f 6e 73 6f 6c 65 7d 2c 24 7b 62 61 |=${console},${ba| ...
then the mtd1 device is correct. Use it in fw_env.config. To determine other parameters for fw_env.config you need to check the used environment configuration in the U-Boot source, in the board's config file (include/configs/zyng_zed.h, include/configs/zynq-common.h). Search for CONFIG_ENV_SIZE, CONFIG_ENV_SECT_SIZE and CONFIG_ENV_OFFSET macros.
for ZedBoard, you probably can not. It depends on the U-Boot configuration. If the "mtd" command support is compiled in and the "mtdparts" environment variable is set properly, then it could be possible to output some info.
HTH,
Anatolij
Hi. see inline comments below ...
So u-boot sources tell me the ENV_OFFSET is at 0xE0000 and the ENV_SIZE is (128 << 10) = 0x20000 I tried dd with "bs=1 skip=917504" and could not find anything in mtd1 or mtd2 ... I finally tried mtd0 and found env vars :) I updated /etc/fw_env.config to the following and now fw_printenv works and no crc errors are reported. Yay :)
/dev/mtd0 0xE0000 0x20000 0x20000
Is it normal for the environment to not be at offset 0x0 and not be in it's own dedicated mtd partition?
"mtd" command is not compiled in. Might try a custom build of u-boot.
Thanks, Brendan.
On Mon, 7 Dec 2015 22:38:53 +1100 "Brendan Simon (eTRIX)" brendan.simon@etrix.com.au wrote: ...
It might be normal for Zynq boards. The mtd partition layout is passed to the kernel in the device tree, and the .dts file author decided to define this layout with common partition for U-Boot and its environment for some reason.
Thanks,
Anatolij
Anatolij Gustschin
