[U-Boot] [U-boot] [Patch v3] mtd: nand: davinci: add header file for driver definitions
The definitions inside emif_defs.h concern davinci nand driver and should be in it's header. So create header file for davinci nand driver and move definitions from emif_defs.h and nand_defs.h to it.
Acked-by: Vitaly Andrianov vitalya@ti.com Signed-off-by: Ivan Khoronzhuk ivan.khoronzhuk@ti.com ---
v3..v2 - move drivers/mtd/nand/davinci_nand.h to arch/arm/include/asm/ti-common/davinci_nand.h - apply changes also for davinci platforms
v2..v1 - no functional changes
arch/arm/cpu/arm926ejs/davinci/da850_lowlevel.c | 2 +- arch/arm/cpu/armv7/keystone/aemif.c | 2 +- arch/arm/include/asm/arch-davinci/emif_defs.h | 72 ---------------------- arch/arm/include/asm/arch-davinci/hardware.h | 1 - arch/arm/include/asm/arch-davinci/nand_defs.h | 38 ------------ arch/arm/include/asm/arch-keystone/nand_defs.h | 23 ------- arch/arm/include/asm/arch-tnetv107x/emif_defs.h | 1 - arch/arm/include/asm/arch-tnetv107x/hardware.h | 2 + arch/arm/include/asm/arch-tnetv107x/nand_defs.h | 23 ------- .../emif_defs.h => ti-common/davinci_nand.h} | 56 ++++++++++++----- board/Barix/ipam390/ipam390.c | 2 +- board/ait/cam_enc_4xx/cam_enc_4xx.c | 2 +- board/davinci/da8xxevm/da830evm.c | 3 +- board/davinci/da8xxevm/da850evm.c | 2 +- board/davinci/dm355evm/dm355evm.c | 3 +- board/davinci/dm355leopard/dm355leopard.c | 2 +- board/davinci/dm365evm/dm365evm.c | 3 +- board/davinci/dm6467evm/dm6467evm.c | 3 +- board/davinci/ea20/ea20.c | 2 +- board/davinci/sonata/sonata.c | 2 +- board/enbw/enbw_cmc/enbw_cmc.c | 2 +- board/omicron/calimain/calimain.c | 2 +- board/ti/k2hk_evm/board.c | 1 - board/ti/tnetv107xevm/sdb_board.c | 2 +- drivers/mtd/nand/davinci_nand.c | 3 +- include/configs/davinci_dm6467evm.h | 2 + include/configs/k2hk_evm.h | 2 + include/configs/tnetv107x_evm.h | 2 + 28 files changed, 65 insertions(+), 195 deletions(-) delete mode 100644 arch/arm/include/asm/arch-davinci/emif_defs.h delete mode 100644 arch/arm/include/asm/arch-davinci/nand_defs.h delete mode 100644 arch/arm/include/asm/arch-keystone/nand_defs.h delete mode 100644 arch/arm/include/asm/arch-tnetv107x/emif_defs.h delete mode 100644 arch/arm/include/asm/arch-tnetv107x/nand_defs.h rename arch/arm/include/asm/{arch-keystone/emif_defs.h => ti-common/davinci_nand.h} (55%)
diff --git a/arch/arm/cpu/arm926ejs/davinci/da850_lowlevel.c b/arch/arm/cpu/arm926ejs/davinci/da850_lowlevel.c index b91e948..19730ce 100644 --- a/arch/arm/cpu/arm926ejs/davinci/da850_lowlevel.c +++ b/arch/arm/cpu/arm926ejs/davinci/da850_lowlevel.c @@ -14,7 +14,7 @@ #include <asm/arch/hardware.h> #include <asm/arch/davinci_misc.h> #include <asm/arch/ddr2_defs.h> -#include <asm/arch/emif_defs.h> +#include <asm/ti-common/davinci_nand.h> #include <asm/arch/pll_defs.h>
void davinci_enable_uart0(void) diff --git a/arch/arm/cpu/armv7/keystone/aemif.c b/arch/arm/cpu/armv7/keystone/aemif.c index 9b26886..bcbb95a 100644 --- a/arch/arm/cpu/armv7/keystone/aemif.c +++ b/arch/arm/cpu/armv7/keystone/aemif.c @@ -10,7 +10,7 @@ #include <common.h> #include <asm/io.h> #include <asm/arch/clock.h> -#include <asm/arch/emif_defs.h> +#include <asm/ti-common/davinci_nand.h>
#define AEMIF_CFG_SELECT_STROBE(v) ((v) ? 1 << 31 : 0) #define AEMIF_CFG_EXTEND_WAIT(v) ((v) ? 1 << 30 : 0) diff --git a/arch/arm/include/asm/arch-davinci/emif_defs.h b/arch/arm/include/asm/arch-davinci/emif_defs.h deleted file mode 100644 index 7e19cfe..0000000 --- a/arch/arm/include/asm/arch-davinci/emif_defs.h +++ /dev/null @@ -1,72 +0,0 @@ -/* - * Copyright (C) 2007 Sergey Kubushyn ksi@koi8.net - * - * SPDX-License-Identifier: GPL-2.0+ - */ -#ifndef _EMIF_DEFS_H_ -#define _EMIF_DEFS_H_ - -#include <asm/arch/hardware.h> - -struct davinci_emif_regs { - u_int32_t ercsr; - u_int32_t awccr; - u_int32_t sdbcr; - u_int32_t sdrcr; - u_int32_t ab1cr; - u_int32_t ab2cr; - u_int32_t ab3cr; - u_int32_t ab4cr; - u_int32_t sdtimr; - u_int32_t ddrsr; - u_int32_t ddrphycr; - u_int32_t ddrphysr; - u_int32_t totar; - u_int32_t totactr; - u_int32_t ddrphyid_rev; - u_int32_t sdsretr; - u_int32_t eirr; - u_int32_t eimr; - u_int32_t eimsr; - u_int32_t eimcr; - u_int32_t ioctrlr; - u_int32_t iostatr; - u_int8_t rsvd0[8]; - u_int32_t nandfcr; - u_int32_t nandfsr; - u_int8_t rsvd1[8]; - u_int32_t nandfecc[4]; - u_int8_t rsvd2[60]; - u_int32_t nand4biteccload; - u_int32_t nand4bitecc[4]; - u_int32_t nanderradd1; - u_int32_t nanderradd2; - u_int32_t nanderrval1; - u_int32_t nanderrval2; -}; - -#define davinci_emif_regs \ - ((struct davinci_emif_regs *)DAVINCI_ASYNC_EMIF_CNTRL_BASE) - -#define DAVINCI_NANDFCR_NAND_ENABLE(n) (1 << (n-2)) -#define DAVINCI_NANDFCR_4BIT_ECC_SEL_MASK (3 << 4) -#define DAVINCI_NANDFCR_4BIT_ECC_SEL(n) ((n-2) << 4) -#define DAVINCI_NANDFCR_1BIT_ECC_START(n) (1 << (8 + (n-2))) -#define DAVINCI_NANDFCR_4BIT_ECC_START (1 << 12) -#define DAVINCI_NANDFCR_4BIT_CALC_START (1 << 13) -#define DAVINCI_NANDFCR_CS2NAND (1 << 0) - -/* Chip Select setup */ -#define DAVINCI_ABCR_STROBE_SELECT (1 << 31) -#define DAVINCI_ABCR_EXT_WAIT (1 << 30) -#define DAVINCI_ABCR_WSETUP(n) (n << 26) -#define DAVINCI_ABCR_WSTROBE(n) (n << 20) -#define DAVINCI_ABCR_WHOLD(n) (n << 17) -#define DAVINCI_ABCR_RSETUP(n) (n << 13) -#define DAVINCI_ABCR_RSTROBE(n) (n << 7) -#define DAVINCI_ABCR_RHOLD(n) (n << 4) -#define DAVINCI_ABCR_TA(n) (n << 2) -#define DAVINCI_ABCR_ASIZE_16BIT 1 -#define DAVINCI_ABCR_ASIZE_8BIT 0 - -#endif diff --git a/arch/arm/include/asm/arch-davinci/hardware.h b/arch/arm/include/asm/arch-davinci/hardware.h index 98fe56e..a4eb0bd 100644 --- a/arch/arm/include/asm/arch-davinci/hardware.h +++ b/arch/arm/include/asm/arch-davinci/hardware.h @@ -597,7 +597,6 @@ static inline enum davinci_clk_ids get_async3_src(void) #if defined(CONFIG_SOC_DM365) #include <asm/arch/aintc_defs.h> #include <asm/arch/ddr2_defs.h> -#include <asm/arch/emif_defs.h> #include <asm/arch/gpio.h> #include <asm/arch/pll_defs.h> #include <asm/arch/psc_defs.h> diff --git a/arch/arm/include/asm/arch-davinci/nand_defs.h b/arch/arm/include/asm/arch-davinci/nand_defs.h deleted file mode 100644 index dee1c6f..0000000 --- a/arch/arm/include/asm/arch-davinci/nand_defs.h +++ /dev/null @@ -1,38 +0,0 @@ -/* - * Copyright (C) 2007 Sergey Kubushyn ksi@koi8.net - * - * Parts shamelesly stolen from Linux Kernel source tree. - * - * ------------------------------------------------------------ - * - * SPDX-License-Identifier: GPL-2.0+ - */ -#ifndef _NAND_DEFS_H_ -#define _NAND_DEFS_H_ - -#include <asm/arch/hardware.h> - -#ifdef CONFIG_SOC_DM646X -#define MASK_CLE 0x80000 -#define MASK_ALE 0x40000 -#else -#define MASK_CLE 0x10 -#define MASK_ALE 0x08 -#endif - -#ifdef CONFIG_SYS_NAND_MASK_CLE -#undef MASK_CLE -#define MASK_CLE CONFIG_SYS_NAND_MASK_CLE -#endif -#ifdef CONFIG_SYS_NAND_MASK_ALE -#undef MASK_ALE -#define MASK_ALE CONFIG_SYS_NAND_MASK_ALE -#endif - -#define NAND_READ_START 0x00 -#define NAND_READ_END 0x30 -#define NAND_STATUS 0x70 - -extern void davinci_nand_init(struct nand_chip *nand); - -#endif diff --git a/arch/arm/include/asm/arch-keystone/nand_defs.h b/arch/arm/include/asm/arch-keystone/nand_defs.h deleted file mode 100644 index 58417db..0000000 --- a/arch/arm/include/asm/arch-keystone/nand_defs.h +++ /dev/null @@ -1,23 +0,0 @@ -/* - * nand driver definitions to re-use davinci nand driver on Keystone2 - * - * (C) Copyright 2012-2014 - * Texas Instruments Incorporated, <www.ti.com> - * (C) Copyright 2007 Sergey Kubushyn ksi@koi8.net - * - * SPDX-License-Identifier: GPL-2.0+ - */ -#ifndef _NAND_DEFS_H_ -#define _NAND_DEFS_H_ - -#include <asm/arch/hardware.h> -#include <linux/mtd/nand.h> - -#define MASK_CLE 0x4000 -#define MASK_ALE 0x2000 - -#define NAND_READ_START 0x00 -#define NAND_READ_END 0x30 -#define NAND_STATUS 0x70 - -#endif diff --git a/arch/arm/include/asm/arch-tnetv107x/emif_defs.h b/arch/arm/include/asm/arch-tnetv107x/emif_defs.h deleted file mode 100644 index 9969a01..0000000 --- a/arch/arm/include/asm/arch-tnetv107x/emif_defs.h +++ /dev/null @@ -1 +0,0 @@ -#include <asm/arch-davinci/emif_defs.h> diff --git a/arch/arm/include/asm/arch-tnetv107x/hardware.h b/arch/arm/include/asm/arch-tnetv107x/hardware.h index 2a7ca4e..d458e0b 100644 --- a/arch/arm/include/asm/arch-tnetv107x/hardware.h +++ b/arch/arm/include/asm/arch-tnetv107x/hardware.h @@ -155,4 +155,6 @@ int wdt_kick(void); #define INTC_HINT_EN (TNETV107X_INTC_BASE + 0x1500) #define INTC_EN_CLR0 (TNETV107X_INTC_BASE + 0x380)
+#define DAVINCI_ASYNC_EMIF_CNTRL_BASE TNETV107X_ASYNC_EMIF_CNTRL_BASE + #endif /* __ASM_ARCH_HARDWARE_H */ diff --git a/arch/arm/include/asm/arch-tnetv107x/nand_defs.h b/arch/arm/include/asm/arch-tnetv107x/nand_defs.h deleted file mode 100644 index b298fba..0000000 --- a/arch/arm/include/asm/arch-tnetv107x/nand_defs.h +++ /dev/null @@ -1,23 +0,0 @@ -/* - * TNETV107X: NAND definitions - * - * SPDX-License-Identifier: GPL-2.0+ - */ -#ifndef _NAND_DEFS_H_ -#define _NAND_DEFS_H_ - -#include <asm/arch/hardware.h> -#include <asm/arch/emif_defs.h> - -#define DAVINCI_ASYNC_EMIF_CNTRL_BASE TNETV107X_ASYNC_EMIF_CNTRL_BASE - -#define MASK_CLE 0x4000 -#define MASK_ALE 0x2000 - -#define NAND_READ_START 0x00 -#define NAND_READ_END 0x30 -#define NAND_STATUS 0x70 - -extern void davinci_nand_init(struct nand_chip *nand); - -#endif diff --git a/arch/arm/include/asm/arch-keystone/emif_defs.h b/arch/arm/include/asm/ti-common/davinci_nand.h similarity index 55% rename from arch/arm/include/asm/arch-keystone/emif_defs.h rename to arch/arm/include/asm/ti-common/davinci_nand.h index a3378aa..5930e2d 100644 --- a/arch/arm/include/asm/arch-keystone/emif_defs.h +++ b/arch/arm/include/asm/ti-common/davinci_nand.h @@ -1,23 +1,44 @@ /* - * emif definitions to re-use davinci emif driver on Keystone2 + * NAND Flash Driver * - * (C) Copyright 2012-2014 - * Texas Instruments Incorporated, <www.ti.com> - * (C) Copyright 2007 Sergey Kubushyn ksi@koi8.net + * Copyright (C) 2006-2014 Texas Instruments. * - * SPDX-License-Identifier: GPL-2.0+ + * Based on Linux DaVinci NAND driver by TI. */ -#ifndef _EMIF_DEFS_H_ -#define _EMIF_DEFS_H_
-#include <asm/arch/hardware.h> +#ifndef _DAVINCI_NAND_H_ +#define _DAVINCI_NAND_H_ + +#include <linux/mtd/nand.h> + +#define NAND_READ_START 0x00 +#define NAND_READ_END 0x30 +#define NAND_STATUS 0x70 + +#define MASK_CLE 0x10 +#define MASK_ALE 0x08 + +#ifdef CONFIG_SYS_NAND_MASK_CLE +#undef MASK_CLE +#define MASK_CLE CONFIG_SYS_NAND_MASK_CLE +#endif +#ifdef CONFIG_SYS_NAND_MASK_ALE +#undef MASK_ALE +#define MASK_ALE CONFIG_SYS_NAND_MASK_ALE +#endif
struct davinci_emif_regs { uint32_t ercsr; uint32_t awccr; uint32_t sdbcr; uint32_t sdrcr; - uint32_t abncr[4]; + union { + uint32_t abncr[4]; + uint32_t ab1cr; + uint32_t ab2cr; + uint32_t ab3cr; + uint32_t ab4cr; + }; uint32_t sdtimr; uint32_t ddrsr; uint32_t ddrphycr; @@ -56,18 +77,21 @@ struct davinci_emif_regs { #define DAVINCI_NANDFCR_1BIT_ECC_START(n) (1 << (8 + ((n) - 2))) #define DAVINCI_NANDFCR_4BIT_ECC_START (1 << 12) #define DAVINCI_NANDFCR_4BIT_CALC_START (1 << 13) +#define DAVINCI_NANDFCR_CS2NAND (1 << 0)
/* Chip Select setup */ #define DAVINCI_ABCR_STROBE_SELECT (1 << 31) #define DAVINCI_ABCR_EXT_WAIT (1 << 30) -#define DAVINCI_ABCR_WSETUP(n) ((n) << 26) -#define DAVINCI_ABCR_WSTROBE(n) ((n) << 20) -#define DAVINCI_ABCR_WHOLD(n) ((n) << 17) -#define DAVINCI_ABCR_RSETUP(n) ((n) << 13) -#define DAVINCI_ABCR_RSTROBE(n) ((n) << 7) -#define DAVINCI_ABCR_RHOLD(n) ((n) << 4) -#define DAVINCI_ABCR_TA(n) ((n) << 2) +#define DAVINCI_ABCR_WSETUP(n) (n << 26) +#define DAVINCI_ABCR_WSTROBE(n) (n << 20) +#define DAVINCI_ABCR_WHOLD(n) (n << 17) +#define DAVINCI_ABCR_RSETUP(n) (n << 13) +#define DAVINCI_ABCR_RSTROBE(n) (n << 7) +#define DAVINCI_ABCR_RHOLD(n) (n << 4) +#define DAVINCI_ABCR_TA(n) (n << 2) #define DAVINCI_ABCR_ASIZE_16BIT 1 #define DAVINCI_ABCR_ASIZE_8BIT 0
+void davinci_nand_init(struct nand_chip *nand); + #endif diff --git a/board/Barix/ipam390/ipam390.c b/board/Barix/ipam390/ipam390.c index ae88b42..6ce8960 100644 --- a/board/Barix/ipam390/ipam390.c +++ b/board/Barix/ipam390/ipam390.c @@ -20,7 +20,7 @@ #include <spi.h> #include <spi_flash.h> #include <asm/arch/hardware.h> -#include <asm/arch/emif_defs.h> +#include <asm/ti-common/davinci_nand.h> #include <asm/arch/emac_defs.h> #include <asm/arch/pinmux_defs.h> #include <asm/io.h> diff --git a/board/ait/cam_enc_4xx/cam_enc_4xx.c b/board/ait/cam_enc_4xx/cam_enc_4xx.c index 7e1b16a..1f816b3 100644 --- a/board/ait/cam_enc_4xx/cam_enc_4xx.c +++ b/board/ait/cam_enc_4xx/cam_enc_4xx.c @@ -16,7 +16,7 @@ #include <netdev.h> #include <asm/io.h> #include <asm/arch/hardware.h> -#include <asm/arch/nand_defs.h> +#include <asm/ti-common/davinci_nand.h> #include <asm/arch/davinci_misc.h> #ifdef CONFIG_DAVINCI_MMC #include <mmc.h> diff --git a/board/davinci/da8xxevm/da830evm.c b/board/davinci/da8xxevm/da830evm.c index 4f5c780..c40587f 100644 --- a/board/davinci/da8xxevm/da830evm.c +++ b/board/davinci/da8xxevm/da830evm.c @@ -25,12 +25,11 @@ #include <net.h> #include <netdev.h> #include <asm/arch/hardware.h> -#include <asm/arch/emif_defs.h> #include <asm/arch/emac_defs.h> #include <asm/arch/pinmux_defs.h> #include <asm/io.h> #include <nand.h> -#include <asm/arch/nand_defs.h> +#include <asm/ti-common/davinci_nand.h> #include <asm/arch/davinci_misc.h>
#ifdef CONFIG_DAVINCI_MMC diff --git a/board/davinci/da8xxevm/da850evm.c b/board/davinci/da8xxevm/da850evm.c index 85b4830..b9ca38e 100644 --- a/board/davinci/da8xxevm/da850evm.c +++ b/board/davinci/da8xxevm/da850evm.c @@ -16,7 +16,7 @@ #include <spi.h> #include <spi_flash.h> #include <asm/arch/hardware.h> -#include <asm/arch/emif_defs.h> +#include <asm/ti-common/davinci_nand.h> #include <asm/arch/emac_defs.h> #include <asm/arch/pinmux_defs.h> #include <asm/io.h> diff --git a/board/davinci/dm355evm/dm355evm.c b/board/davinci/dm355evm/dm355evm.c index 10422b2..e5a958f 100644 --- a/board/davinci/dm355evm/dm355evm.c +++ b/board/davinci/dm355evm/dm355evm.c @@ -8,8 +8,7 @@ #include <nand.h> #include <asm/io.h> #include <asm/arch/hardware.h> -#include <asm/arch/emif_defs.h> -#include <asm/arch/nand_defs.h> +#include <asm/ti-common/davinci_nand.h> #include <asm/arch/davinci_misc.h> #include <net.h> #include <netdev.h> diff --git a/board/davinci/dm355leopard/dm355leopard.c b/board/davinci/dm355leopard/dm355leopard.c index 5341843..53902f9 100644 --- a/board/davinci/dm355leopard/dm355leopard.c +++ b/board/davinci/dm355leopard/dm355leopard.c @@ -9,7 +9,7 @@ #include <asm/io.h> #include <asm/arch/hardware.h> #include <asm/arch/gpio.h> -#include <asm/arch/nand_defs.h> +#include <asm/ti-common/davinci_nand.h> #include <asm/arch/davinci_misc.h> #include <net.h> #include <netdev.h> diff --git a/board/davinci/dm365evm/dm365evm.c b/board/davinci/dm365evm/dm365evm.c index ceffd4d..24bec56 100644 --- a/board/davinci/dm365evm/dm365evm.c +++ b/board/davinci/dm365evm/dm365evm.c @@ -8,8 +8,7 @@ #include <nand.h> #include <asm/io.h> #include <asm/arch/hardware.h> -#include <asm/arch/emif_defs.h> -#include <asm/arch/nand_defs.h> +#include <asm/ti-common/davinci_nand.h> #include <asm/arch/gpio.h> #include <netdev.h> #include <asm/arch/davinci_misc.h> diff --git a/board/davinci/dm6467evm/dm6467evm.c b/board/davinci/dm6467evm/dm6467evm.c index 469c9ba..e51cc9e 100644 --- a/board/davinci/dm6467evm/dm6467evm.c +++ b/board/davinci/dm6467evm/dm6467evm.c @@ -8,7 +8,8 @@ #include <netdev.h> #include <asm/io.h> #include <nand.h> -#include <asm/arch/nand_defs.h> +#include <asm/arch/hardware.h> +#include <asm/ti-common/davinci_nand.h>
DECLARE_GLOBAL_DATA_PTR;
diff --git a/board/davinci/ea20/ea20.c b/board/davinci/ea20/ea20.c index c4444c7..66804d7 100644 --- a/board/davinci/ea20/ea20.c +++ b/board/davinci/ea20/ea20.c @@ -19,7 +19,7 @@ #include <net.h> #include <netdev.h> #include <asm/arch/hardware.h> -#include <asm/arch/emif_defs.h> +#include <asm/ti-common/davinci_nand.h> #include <asm/arch/emac_defs.h> #include <asm/io.h> #include <asm/arch/davinci_misc.h> diff --git a/board/davinci/sonata/sonata.c b/board/davinci/sonata/sonata.c index aa04041..f5c3258 100644 --- a/board/davinci/sonata/sonata.c +++ b/board/davinci/sonata/sonata.c @@ -14,7 +14,7 @@
#include <common.h> #include <nand.h> -#include <asm/arch/nand_defs.h> +#include <asm/ti-common/davinci_nand.h> #include <asm/arch/hardware.h> #include <asm/arch/davinci_misc.h>
diff --git a/board/enbw/enbw_cmc/enbw_cmc.c b/board/enbw/enbw_cmc/enbw_cmc.c index 39efe20..53b8362 100644 --- a/board/enbw/enbw_cmc/enbw_cmc.c +++ b/board/enbw/enbw_cmc/enbw_cmc.c @@ -29,7 +29,7 @@ #include <asm/io.h> #include <asm/arch/da850_lowlevel.h> #include <asm/arch/davinci_misc.h> -#include <asm/arch/emif_defs.h> +#include <asm/ti-common/davinci_nand.h> #include <asm/arch/emac_defs.h> #include <asm/arch/gpio.h> #include <asm/arch/pinmux_defs.h> diff --git a/board/omicron/calimain/calimain.c b/board/omicron/calimain/calimain.c index dd28915..32f2b20 100644 --- a/board/omicron/calimain/calimain.c +++ b/board/omicron/calimain/calimain.c @@ -18,7 +18,7 @@ #include <asm/io.h> #include <asm/arch/hardware.h> #include <asm/arch/gpio.h> -#include <asm/arch/emif_defs.h> +#include <asm/ti-common/davinci_nand.h> #include <asm/arch/emac_defs.h> #include <asm/arch/pinmux_defs.h> #include <asm/arch/davinci_misc.h> diff --git a/board/ti/k2hk_evm/board.c b/board/ti/k2hk_evm/board.c index dc39139..53f26b2 100644 --- a/board/ti/k2hk_evm/board.c +++ b/board/ti/k2hk_evm/board.c @@ -16,7 +16,6 @@ #include <asm/arch/clock.h> #include <asm/io.h> #include <asm/mach-types.h> -#include <asm/arch/nand_defs.h> #include <asm/arch/emac_defs.h> #include <asm/arch/psc_defs.h>
diff --git a/board/ti/tnetv107xevm/sdb_board.c b/board/ti/tnetv107xevm/sdb_board.c index a95434b..a84ec84 100644 --- a/board/ti/tnetv107xevm/sdb_board.c +++ b/board/ti/tnetv107xevm/sdb_board.c @@ -11,7 +11,7 @@ #include <asm/arch/clock.h> #include <asm/io.h> #include <asm/mach-types.h> -#include <asm/arch/nand_defs.h> +#include <asm/ti-common/davinci_nand.h> #include <asm/arch/mux.h>
DECLARE_GLOBAL_DATA_PTR; diff --git a/drivers/mtd/nand/davinci_nand.c b/drivers/mtd/nand/davinci_nand.c index 75b03a7..5d42509 100644 --- a/drivers/mtd/nand/davinci_nand.c +++ b/drivers/mtd/nand/davinci_nand.c @@ -32,8 +32,7 @@ #include <common.h> #include <asm/io.h> #include <nand.h> -#include <asm/arch/nand_defs.h> -#include <asm/arch/emif_defs.h> +#include <asm/ti-common/davinci_nand.h>
/* Definitions for 4-bit hardware ECC */ #define NAND_TIMEOUT 10240 diff --git a/include/configs/davinci_dm6467evm.h b/include/configs/davinci_dm6467evm.h index 8a3c453..50c7e23 100644 --- a/include/configs/davinci_dm6467evm.h +++ b/include/configs/davinci_dm6467evm.h @@ -78,6 +78,8 @@ extern unsigned int davinci_arm_clk_get(void); #define CONFIG_SYS_NO_FLASH #ifdef CONFIG_SYS_USE_NAND #define CONFIG_NAND_DAVINCI +#define CONFIG_SYS_NAND_MASK_CLE 0x80000 +#define CONFIG_SYS_NAND_MASK_ALE 0x40000 #define CONFIG_SYS_NAND_CS 2 #undef CONFIG_ENV_IS_IN_FLASH #define CONFIG_ENV_IS_IN_NAND diff --git a/include/configs/k2hk_evm.h b/include/configs/k2hk_evm.h index 6ba7e62..61f41ed 100644 --- a/include/configs/k2hk_evm.h +++ b/include/configs/k2hk_evm.h @@ -136,6 +136,8 @@ #define CONFIG_SYS_NAND_USE_FLASH_BBT #define CONFIG_SYS_NAND_4BIT_HW_ECC_OOBFIRST #define CONFIG_SYS_NAND_PAGE_2K +#define CONFIG_SYS_NAND_MASK_CLE 0x4000 +#define CONFIG_SYS_NAND_MASK_ALE 0x2000
#define CONFIG_SYS_NAND_LARGEPAGE #define CONFIG_SYS_NAND_BASE_LIST { 0x30000000, } diff --git a/include/configs/tnetv107x_evm.h b/include/configs/tnetv107x_evm.h index 162826f..90d0a82 100644 --- a/include/configs/tnetv107x_evm.h +++ b/include/configs/tnetv107x_evm.h @@ -62,6 +62,8 @@ #define CONFIG_SYS_NO_FLASH #define CONFIG_ENV_IS_IN_NAND #define CONFIG_NAND_DAVINCI +#define CONFIG_SYS_NAND_MASK_CLE 0x4000 +#define CONFIG_SYS_NAND_MASK_ALE 0x2000 #define CONFIG_ENV_SIZE (SZ_128K) #define CONFIG_SYS_NAND_HW_ECC #define CONFIG_SYS_NAND_1BIT_ECC
Fixed a few more bits of davinci fallout and applied to u-boot-ti/master, thanks!
Thanks
Ivan Khoronzhuk
