[U-Boot-Users] U-boot-1.1.4 on MPC8540
Hi all,
I'm booting a newly compiled u-boot-1.1.4 image on my MPC8540, and it doesn't work. It hangs after this.. ************************************** U-Boot 1.1.4 (Nov 23 2006 - 10:34:07)
Freescale PowerPC Core: E500, Version: 2.0, (0x80200020) CPU: 8540, Version: 2.0, (0x80300020) Clock Configuration: CPU: 825 MHz, CCB: 330 MHz, DDR: 165 MHz, LBC: 82 MHz L1: D-cache 32 kB enabled I-cache 32 kB enabled
CPU: 825 MHz CCB: 330 MHz DDR: 165 MHz LBC: 82 MHz L1 D-cache 32KB, L1 I-cache 32KB enabled. I2C: ready DRAM: 256 MB PCIG8400 in PCI Host Mode. PCIG8400 not PCI Arbiter. ******************************************** I've carefully copied every setup from the u-boot-1.1.2 image which I've made. Now, how do I debug this,any help is greatly appreciated.
Thanks in advance. Revathy
Hi all,
I've carefully copied every setup from the u-boot-1.1.2 image which I've made. Now, how do I debug this.
On debugging , " In relocating the command table", *for* loop is going on infinite loop in lib/ppc/board.c. Can anyone help in this.
Please use current code. It makes little sense to hunt down problems with such old code.
I'm booting a newly compiled u-boot-1.1.4 image on my MPC8540, and it doesn't work. when i debugged i found in lib_ppc/board.c
for (cmdtp = &__u_boot_cmd_start; cmdtp != &__u_boot_cmd_end; cmdtp++)
&__u_boot_cmd_start=0fff3750
&__u_boot_cmd_end =0fff43b8 and cmdtp is encremanted as 0x18 each times..but it is not matching with u_boot_cmd_end so loop goes on until ffffffff and hangs.. what could be the problem.. can anyone plz help me to proceed.. Thanks Revathy
I already told you what to do, and I hereby repeat it once more. Note that I won't repeat it again:
Please use current code, i. e. top of tree from the git repository.
I think your loader script (.lds) is not up to date to work with your toolchain (ld version 2.16 or later). See the following commit.
http://www.denx.de/cgi-bin/gitweb.cgi?p=u-boot.git;a=commit;h=807d5d7319330e...
I had similar issue when I updated the toolchain and tried to compile 1.3 based board lds script. Obviously working with latest U-Boot does not help if your board was not in public git repository when this patch got in.
Tolunay
revathy
Tolunay Orkun
