[U-Boot] [PATCH v2] powerpc/p1_p2_rdb_pc: print -PC suffix in board name
Currently the -PC variants of the P1/P2 RDB boards do not print it on boot -- e.g. a P2020RDB-PC will claim to be a plain P2020RDB. Besides being incorrect, this can confuse a user into building U-Boot for P2020RDB rather than P2020RDB-PC, resulting in a board that does not boot.
P1024RDB and P1025RDB are not included, as these boards apparently do not have -PC as part of their name, even though they are supported by p1_p2_rdb_pc.
The P2020RDB variant covered by this is apparently P2020RDB-PCA rather than P2020RDB-PC.
Signed-off-by: Scott Wood scottwood@freescale.com --- v2: s/P2020RDB-PC/P2020RDB-PCA/ as Sean Geary pointed out to me. It looks like P2020RDB-PC itself might be supported by the old P2020RDB platform, but it's not clear what the actual differences are beyond different DDR (which we should be able to deal with dynamically). Documentation is difficult to come by, even within Freescale.
Perhaps we should remove the old P1_P2_RDB platform unless we can figure out what it's supposed to be supporting and if it is succeeding at doing so. It seems to be bitrotting -- lots of differences compared to p1_p2_rdb_pc that have nothing to do with differences between the boards. Even the target name capitalization is inconsistent. :-).
include/configs/p1_p2_rdb_pc.h | 10 +++++----- 1 file changed, 5 insertions(+), 5 deletions(-)
diff --git a/include/configs/p1_p2_rdb_pc.h b/include/configs/p1_p2_rdb_pc.h index a8882d4..b18f4a0 100644 --- a/include/configs/p1_p2_rdb_pc.h +++ b/include/configs/p1_p2_rdb_pc.h @@ -31,7 +31,7 @@ #endif
#if defined(CONFIG_P1020MBG) -#define CONFIG_BOARDNAME "P1020MBG" +#define CONFIG_BOARDNAME "P1020MBG-PC" #define CONFIG_P1020 #define CONFIG_VSC7385_ENET #define CONFIG_SLIC @@ -41,7 +41,7 @@ #endif
#if defined(CONFIG_P1020UTM) -#define CONFIG_BOARDNAME "P1020UTM" +#define CONFIG_BOARDNAME "P1020UTM-PC" #define CONFIG_P1020 #define __SW_BOOT_MASK 0x03 #define __SW_BOOT_NOR 0xe0 @@ -49,7 +49,7 @@ #endif
#if defined(CONFIG_P1020RDB) -#define CONFIG_BOARDNAME "P1020RDB" +#define CONFIG_BOARDNAME "P1020RDB-PC" #define CONFIG_NAND_FSL_ELBC #define CONFIG_P1020 #define CONFIG_SPI_FLASH @@ -64,7 +64,7 @@ #endif
#if defined(CONFIG_P1021RDB) -#define CONFIG_BOARDNAME "P1021RDB" +#define CONFIG_BOARDNAME "P1021RDB-PC" #define CONFIG_NAND_FSL_ELBC #define CONFIG_P1021 #define CONFIG_QE @@ -111,7 +111,7 @@ #endif
#if defined(CONFIG_P2020RDB) -#define CONFIG_BOARDNAME "P2020RDB" +#define CONFIG_BOARDNAME "P2020RDB-PCA" #define CONFIG_NAND_FSL_ELBC #define CONFIG_P2020 #define CONFIG_SPI_FLASH
Scott Wood
