[U-Boot] [PATCH] board: ti: am571x: Add 666MHz support for AM571x IDK
AM571x supports DDR running at 666MHz. Right now it is clocked at 532MHz which is lower than what is supported. In order to have maximum performance on AM571-IDK, switch DDR to 666MHz.
Signed-off-by: Steve Kipisz s-kipisz2@ti.com Signed-off-by: Lokesh Vutla lokeshvutla@ti.com --- arch/arm/include/asm/omap_common.h | 1 + board/ti/am57xx/board.c | 35 +++++++++++++++++++++++++++++++++-- 2 files changed, 34 insertions(+), 2 deletions(-)
diff --git a/arch/arm/include/asm/omap_common.h b/arch/arm/include/asm/omap_common.h index d7e453e579..8b296c9685 100644 --- a/arch/arm/include/asm/omap_common.h +++ b/arch/arm/include/asm/omap_common.h @@ -596,6 +596,7 @@ extern struct prcm_regs const omap4_prcm; extern struct prcm_regs const dra7xx_prcm; extern struct dplls const **dplls_data; extern struct dplls dra7xx_dplls; +extern struct dplls dra72x_dplls; extern struct vcores_data const **omap_vcores; extern const u32 sys_clk_array[8]; extern struct omap_sys_ctrl_regs const **ctrl; diff --git a/board/ti/am57xx/board.c b/board/ti/am57xx/board.c index 7e7056cf71..3d15cb1dbf 100644 --- a/board/ti/am57xx/board.c +++ b/board/ti/am57xx/board.c @@ -223,11 +223,39 @@ static const u32 beagle_x15_emif2_ddr3_ext_phy_ctrl_const_regs[] = { 0x0 };
+static const struct emif_regs am571x_emif1_ddr3_666mhz_emif_regs = { + .sdram_config_init = 0x61863332, + .sdram_config = 0x61863332, + .sdram_config2 = 0x08000000, + .ref_ctrl = 0x0000514d, + .ref_ctrl_final = 0x0000144a, + .sdram_tim1 = 0xd333887c, + .sdram_tim2 = 0x40b37fe3, + .sdram_tim3 = 0x409f8ada, + .read_idle_ctrl = 0x00050000, + .zq_config = 0x5007190b, + .temp_alert_config = 0x00000000, + .emif_ddr_phy_ctlr_1_init = 0x0024400f, + .emif_ddr_phy_ctlr_1 = 0x0e24400f, + .emif_ddr_ext_phy_ctrl_1 = 0x10040100, + .emif_ddr_ext_phy_ctrl_2 = 0x00910091, + .emif_ddr_ext_phy_ctrl_3 = 0x00950095, + .emif_ddr_ext_phy_ctrl_4 = 0x009b009b, + .emif_ddr_ext_phy_ctrl_5 = 0x009e009e, + .emif_rd_wr_lvl_rmp_win = 0x00000000, + .emif_rd_wr_lvl_rmp_ctl = 0x80000000, + .emif_rd_wr_lvl_ctl = 0x00000000, + .emif_rd_wr_exec_thresh = 0x00000305 +}; + void emif_get_reg_dump(u32 emif_nr, const struct emif_regs **regs) { switch (emif_nr) { case 1: - *regs = &beagle_x15_emif1_ddr3_532mhz_emif_regs; + if (board_is_am571x_idk()) + *regs = &am571x_emif1_ddr3_666mhz_emif_regs; + else + *regs = &beagle_x15_emif1_ddr3_532mhz_emif_regs; break; case 2: *regs = &beagle_x15_emif2_ddr3_532mhz_emif_regs; @@ -513,7 +541,10 @@ void vcores_init(void) void hw_data_init(void) { *prcm = &dra7xx_prcm; - *dplls_data = &dra7xx_dplls; + if (is_dra72x()) + *dplls_data = &dra72x_dplls; + else + *dplls_data = &dra7xx_dplls; *ctrl = &dra7xx_ctrl; }
Signed-off-by: Steve Kipisz s-kipisz2@ti.com Signed-off-by: Lokesh Vutla lokeshvutla@ti.com Reviewed-by: Tom Rini trini@konsulko.com
Lokesh Vutla
