[U-Boot] [UBOOT][PATCH] mtd: spi: fix quad bit set path
Currently, flash quad bit is set in "spi_flash_validate_params" and later at the end in the same api, we write 0 to status register for few flashes, thereby overriding the quad bit set. This fix moves the quad bit setting outside this api in "spi_flash_probe_slave"
Signed-off-by: Sourav Poddar sourav.poddar@ti.com --- drivers/mtd/spi/sf_probe.c | 20 ++++++++++---------- 1 file changed, 10 insertions(+), 10 deletions(-)
diff --git a/drivers/mtd/spi/sf_probe.c b/drivers/mtd/spi/sf_probe.c index 0a46fe3..8482f08 100644 --- a/drivers/mtd/spi/sf_probe.c +++ b/drivers/mtd/spi/sf_probe.c @@ -197,16 +197,6 @@ static struct spi_flash *spi_flash_validate_params(struct spi_slave *spi, /* Go for default supported write cmd */ flash->write_cmd = CMD_PAGE_PROGRAM;
- /* Set the quad enable bit - only for quad commands */ - if ((flash->read_cmd == CMD_READ_QUAD_OUTPUT_FAST) || - (flash->read_cmd == CMD_READ_QUAD_IO_FAST) || - (flash->write_cmd == CMD_QUAD_PAGE_PROGRAM)) { - if (spi_flash_set_qeb(flash, idcode[0])) { - debug("SF: Fail to set QEB for %02x\n", idcode[0]); - return NULL; - } - } - /* Read dummy_byte: dummy byte is determined based on the * dummy cycles of a particular command. * Fast commands - dummy_byte = dummy_cycles/8 @@ -327,6 +317,16 @@ static struct spi_flash *spi_flash_probe_slave(struct spi_slave *spi) if (!flash) goto err_read_id;
+ /* Set the quad enable bit - only for quad commands */ + if ((flash->read_cmd == CMD_READ_QUAD_OUTPUT_FAST) || + (flash->read_cmd == CMD_READ_QUAD_IO_FAST) || + (flash->write_cmd == CMD_QUAD_PAGE_PROGRAM)) { + if (spi_flash_set_qeb(flash, idcode[0])) { + debug("SF: Fail to set QEB for %02x\n", idcode[0]); + return NULL; + } + } + #ifdef CONFIG_OF_CONTROL if (spi_flash_decode_fdt(gd->fdt_blob, flash)) { debug("SF: FDT decode error\n");
return NULL;
return NULL;
#ifdef CONFIG_OF_CONTROL if (spi_flash_decode_fdt(gd->fdt_blob, flash)) { debug("SF: FDT decode error\n"); -- 1.7.9.5
Applied to u-boot-spi/master
thanks!
Jagan Teki
Sourav Poddar
