[U-Boot-Users] can u-boot run standalone in qemu(qemu-system-arm) without kernel image(for mainstone II)
hi, all
I'm a newbie to both u-boot and qemu. Maybe it's a silly question, but I can not find the solution through the Internet for almost 2 weeks, sorry :(
Here is my question:
I wanna run u-boot as a standalone app (or image?) in qemu, and I do't wanna any create linux image. Is that possible? I just wanna to study u-boot.
And now, my idea is to create a flash image with u-boot, how about this way?
Any reply would be appreciated. Thank you in advance :)
stones.
wong wrote:
hi, all
I have no idea if it is possible with that particular emulation, but I did something similar with qemu-system-mips. Qemu loads a bootloader binary image on startup (if available) with most emulations, for you it should be named arm_bios.bin probably. You can tell Qemu from what directory to load it with the -L option, so just create a symlink to u-boot.bin named arm_bios.bin and launch qemu-system-mips -L . /dev/null (/dev/null is needed so it will not complain that you have no kernel and no disk image)
When you pass the -kernel option to qemu, it usually has a very small internal bootloader to setup a few registers and pass control to the kernel. I know it does this for mips.
It depends on how that particular machine is emulated. Check the -pflash option Qemu, it might help.
Regards, Vlad
this works for me , assuming you are in the u-boot directory $ make versatile_config $ make $ qemu-system-arm -nographic -m 256 -M versatileab -kernel u-boot.bin
wong-10 wrote:
hi, all
stones.
This SF.net email is sponsored by: Microsoft Defy all challenges. Microsoft(R) Visual Studio 2008. http://clk.atdmt.com/MRT/go/vse0120000070mrt/direct/01/ _______________________________________________ U-Boot-Users mailing list U-Boot-Users@lists.sourceforge.net https://lists.sourceforge.net/lists/listinfo/u-boot-users
maxki
Vlad Lungu
wong
