Re: [U-Boot] [PATCH 4/6] mmc: Continue polling MMC card for OCR only if it is still not ready
Hi Troy,
From: Troy Kisky [mailto:troy.kisky@boundarydevices.com] Sent: Friday, March 20, 2015 9:39 PM To: Peng.Fan@freescale.com; Gabbasov, Andrew; u-boot@lists.denx.de Cc: Eric Nelson Subject: Re: [U-Boot] [PATCH 4/6] mmc: Continue polling MMC card for OCR only if it is still not ready
[skipped]
Here's another patch that solves the problem a little earlier. It has this disadvantage of being slightly bigger, though it makes the code look
better.
https://github.com/boundarydevices/u-boot-imx6/commit/c0260ca
I have a couple of doubts regarding that patch.
First, my personal taste objects to such duplicating of the code (I mean setting of version, ocr, rca, etc fields of mmc structure). If we'll have to change or add anything to these settings, we'll have to make the same change in 2 different place, which is error-prone and extremely inconvenient from maintenance point of view.
Second, what about SPI mode? Doesn't this patch skip retrieving of OCR register with a special command for SPI host case (thus setting ocr field incorrectly), if the card comes to ready state with the first attempt?
Thanks.
Best regards, Andrew
On 3/23/2015 12:38 AM, Andrew Gabbasov wrote:
Hi Troy,
[skipped]
better.
That's a good argument for a subroutine to be doing that work instead of in two places.
Hi Troy,
From: Troy Kisky [mailto:troy.kisky@boundarydevices.com] Sent: Monday, March 23, 2015 11:09 PM To: Gabbasov, Andrew; Peng.Fan@freescale.com; u-boot@lists.denx.de Cc: Eric Nelson Subject: Re: [U-Boot] [PATCH 4/6] mmc: Continue polling MMC card for OCR only if it is still not ready
Hi Troy,
[skipped]
better.
in two
places.
In some sense the second function of these two (mmc_complete_op_cond()) is exactly such subroutine ;-) It is doing this work of final settings and actions after making OCR polling. Although completing the polling itself in some cases too. Actually, it seems that introducing of one more service function would make the code a little too "chopped" into too small pieces, and also further less similar to SD (as opposed to MMC) case.
Thanks.
On 3/24/2015 9:33 AM, Andrew Gabbasov wrote:
Hi Troy,
Hi Troy,
[skipped]
better.
in two
places.
Thanks.
I've already said that I'm fine with any patch that fixes the problem, so there is no need to convince me of anything. I just wanted to show that setting the pending flag, when the command is actually complete, does not make a lot of sense.
Thanks Troy
From: Troy Kisky [mailto:troy.kisky@boundarydevices.com] Sent: Tuesday, March 24, 2015 9:03 PM To: Gabbasov, Andrew; Peng.Fan@freescale.com; u-boot@lists.denx.de Cc: Eric Nelson Subject: Re: [U-Boot] [PATCH 4/6] mmc: Continue polling MMC card for OCR only if it is still not ready
Hi Troy,
Hi Troy,
[skipped]
better.
in two
places.
Thanks.
there is
of
sense.
I absolutely agree. In fact, this flag in current implementation just indicates the branch that the MMC card case is being processed. If the version field, differing SD and MMC cases, would be set a little earlier, for example, directly in mmc_start_init(), we could just use !IS_SD() instead of this pending flag. And thinking further, it's not quite clear why the splitting of OCR polling was done for MMC case only, but not for SD too. So, there is still the room for further improving the code, may be even some reorganizing, but I had to stop somewhere, unless there is the direct necessity ;-)
Thanks.
Hi Andrew,
On Mar 24, 2015, at 21:02 , Andrew Gabbasov andrew_gabbasov@mentor.com wrote:
Hi Troy,
Hi Troy,
[skipped]
better.
in two
places.
Thanks.
there is
of
sense.
Your patch fixes the current problem nicely. There is a lot of cruft around, we’ll get around looking it at some point in the future (yeah, maybe) :)
Thanks for the good work, it’s fine as it is right now.
Thanks.
Regards
— Pantelis
Andrew Gabbasov
Pantelis Antoniou
Troy Kisky
