[U-Boot-Users] [PATCH] mpc83xx: fix ITX[GP] O=builddir builds
make: *** No rule to make target `/work/wd/tmp/board/mpc8349itx/u-boot.lds', needed by `/work/wd/tmp/u-boot'. Stop.
Both the ITX and ITX-GP fail when you use "make O=<some dir> ..." or "BUILD_DIR=<some dir> ./MAKEALL ..."
Signed-off-by: Kim Phillips kim.phillips@freescale.com --- board/mpc8349itx/config.mk | 6 ------ 1 files changed, 0 insertions(+), 6 deletions(-)
diff --git a/board/mpc8349itx/config.mk b/board/mpc8349itx/config.mk index 1901fdc..79f1765 100644 --- a/board/mpc8349itx/config.mk +++ b/board/mpc8349itx/config.mk @@ -29,9 +29,3 @@ sinclude $(OBJTREE)/board/$(BOARDDIR)/config.tmp ifndef TEXT_BASE TEXT_BASE = 0xFEF00000 endif - -ifneq ($(OBJTREE),$(SRCTREE)) -# We are building u-boot in a separate directory, use generated -# .lds script from OBJTREE directory. -LDSCRIPT := $(OBJTREE)/board/$(BOARDDIR)/u-boot.lds -endif
Can I pull this from the 83xx repo, or shall I add it directly?
Kim Phillips
