[PATCH V2 0/7] arm64: binman: use binman symbols for imx
V2: resolve some CI failure include patch 7
binman symbol is a good feature, but only used on X86 for now. This patchset is to use it for i.MX8M platform.
The current imx8m ddr phy firmware consumes lots of space, because we pad them to the largest 32KB and 16KB for IMEM and DMEM.
With this patchset we use binman symbols to get firmware location and size, we could save near 36KB with i.MX8MP-EVK.
Please help check and test
Peng Fan (7): spl: guard u_boot_any with X86 arm: dts: imx8m: update binman ddr firmware node name armv8: u-boot-spl.lds: mark __image_copy_start as symbol tools: binman: section: replace @ with - ddr: imx8m: helper: load ddr firmware according to binman symbols arm: dts: imx8m: shrink ddr firmware size to actual file size binman_sym: guard with CONFIG_SPL_BINMAN_SYMBOLS
arch/arm/cpu/armv8/u-boot-spl.lds | 2 +- arch/arm/dts/imx8mm-u-boot.dtsi | 16 +++--- arch/arm/dts/imx8mn-beacon-kit-u-boot.dtsi | 8 +-- .../dts/imx8mn-bsh-smm-s2-u-boot-common.dtsi | 4 +- arch/arm/dts/imx8mn-ddr4-evk-u-boot.dtsi | 8 +-- arch/arm/dts/imx8mn-evk-u-boot.dtsi | 8 +-- .../dts/imx8mn-var-som-symphony-u-boot.dtsi | 8 +-- arch/arm/dts/imx8mn-venice-u-boot.dtsi | 16 +++--- arch/arm/dts/imx8mp-u-boot.dtsi | 8 +-- arch/arm/dts/imx8mq-cm-u-boot.dtsi | 8 +-- arch/arm/dts/imx8mq-u-boot.dtsi | 16 +++--- common/spl/spl.c | 8 ++- common/spl/spl_ram.c | 4 ++ drivers/ddr/imx/imx8m/helper.c | 53 +++++++++++++++---- include/binman_sym.h | 2 +- tools/binman/etype/section.py | 2 +- tools/binman/test/u_boot_binman_syms.c | 1 + tools/binman/test/u_boot_binman_syms_size.c | 1 + 18 files changed, 109 insertions(+), 64 deletions(-)
set the symbol as weak not work if LTO is enabled. Since u_boot_any is only used on X86 for now, so guard it with X86, otherwise build break if we use BINMAN_SYMBOLS on i.MX.
Signed-off-by: Peng Fan peng.fan@nxp.com --- common/spl/spl.c | 8 ++++++-- common/spl/spl_ram.c | 4 ++++ 2 files changed, 10 insertions(+), 2 deletions(-)
diff --git a/common/spl/spl.c b/common/spl/spl.c index c8c463f80bd..4b28180467a 100644 --- a/common/spl/spl.c +++ b/common/spl/spl.c @@ -50,7 +50,7 @@ DECLARE_GLOBAL_DATA_PTR;
u32 *boot_params_ptr = NULL;
-#if CONFIG_IS_ENABLED(BINMAN_SYMBOLS) +#if CONFIG_IS_ENABLED(BINMAN_SYMBOLS) && CONFIG_IS_ENABLED(X86) /* See spl.h for information about this */ binman_sym_declare(ulong, u_boot_any, image_pos); binman_sym_declare(ulong, u_boot_any, size); @@ -148,7 +148,7 @@ void spl_fixup_fdt(void *fdt_blob) #endif }
-#if CONFIG_IS_ENABLED(BINMAN_SYMBOLS) +#if CONFIG_IS_ENABLED(BINMAN_SYMBOLS) && CONFIG_IS_ENABLED(X86) ulong spl_get_image_pos(void) { #ifdef CONFIG_VPL @@ -221,7 +221,11 @@ __weak struct image_header *spl_get_load_buffer(ssize_t offset, size_t size)
void spl_set_header_raw_uboot(struct spl_image_info *spl_image) { +#if CONFIG_IS_ENABLED(X86) ulong u_boot_pos = binman_sym(ulong, u_boot_any, image_pos); +#else + ulong u_boot_pos = BINMAN_SYM_MISSING; +#endif
spl_image->size = CONFIG_SYS_MONITOR_LEN;
diff --git a/common/spl/spl_ram.c b/common/spl/spl_ram.c index 82964592571..083b14102ee 100644 --- a/common/spl/spl_ram.c +++ b/common/spl/spl_ram.c @@ -70,7 +70,11 @@ static int spl_ram_load_image(struct spl_image_info *spl_image, load.read = spl_ram_load_read; spl_load_simple_fit(spl_image, &load, 0, header); } else { +#if CONFIG_IS_ENABLED(X86) ulong u_boot_pos = binman_sym(ulong, u_boot_any, image_pos); +#else + ulong u_boot_pos = BINMAN_SYM_MISSING; +#endif
debug("Legacy image\n"); /*
We are migrating to use BINMAN SYMBOLS, the current name is not a valid binman type, so update to use blob-ext@[1,2,3,4].
Signed-off-by: Peng Fan peng.fan@nxp.com --- arch/arm/dts/imx8mm-u-boot.dtsi | 8 ++++---- arch/arm/dts/imx8mn-bsh-smm-s2-u-boot-common.dtsi | 4 ++-- arch/arm/dts/imx8mn-venice-u-boot.dtsi | 8 ++++---- arch/arm/dts/imx8mq-u-boot.dtsi | 8 ++++---- 4 files changed, 14 insertions(+), 14 deletions(-)
diff --git a/arch/arm/dts/imx8mm-u-boot.dtsi b/arch/arm/dts/imx8mm-u-boot.dtsi index 9f66cdb65a9..5de55a2d80b 100644 --- a/arch/arm/dts/imx8mm-u-boot.dtsi +++ b/arch/arm/dts/imx8mm-u-boot.dtsi @@ -39,25 +39,25 @@ filename = "u-boot-spl.bin"; };
- 1d-imem { + imem_1d: blob-ext@1 { filename = "lpddr4_pmu_train_1d_imem.bin"; size = <0x8000>; type = "blob-ext"; };
- 1d-dmem { + dmem_1d: blob-ext@2 { filename = "lpddr4_pmu_train_1d_dmem.bin"; size = <0x4000>; type = "blob-ext"; };
- 2d-imem { + imem_2d: blob-ext@3 { filename = "lpddr4_pmu_train_2d_imem.bin"; size = <0x8000>; type = "blob-ext"; };
- 2d-dmem { + dmem_2d: blob-ext@4 { filename = "lpddr4_pmu_train_2d_dmem.bin"; size = <0x4000>; type = "blob-ext"; diff --git a/arch/arm/dts/imx8mn-bsh-smm-s2-u-boot-common.dtsi b/arch/arm/dts/imx8mn-bsh-smm-s2-u-boot-common.dtsi index 46a9d7fd78b..5a52b73d7e9 100644 --- a/arch/arm/dts/imx8mn-bsh-smm-s2-u-boot-common.dtsi +++ b/arch/arm/dts/imx8mn-bsh-smm-s2-u-boot-common.dtsi @@ -111,13 +111,13 @@ filename = "u-boot-spl.bin"; };
- 1d-imem { + imem_1d: blob-ext@1 { filename = "ddr3_imem_1d.bin"; size = <0x8000>; type = "blob-ext"; };
- 1d_dmem { + dmem_1d: blob-ext@2 { filename = "ddr3_dmem_1d.bin"; size = <0x4000>; type = "blob-ext"; diff --git a/arch/arm/dts/imx8mn-venice-u-boot.dtsi b/arch/arm/dts/imx8mn-venice-u-boot.dtsi index 35819553879..67922146963 100644 --- a/arch/arm/dts/imx8mn-venice-u-boot.dtsi +++ b/arch/arm/dts/imx8mn-venice-u-boot.dtsi @@ -126,25 +126,25 @@ filename = "u-boot-spl.bin"; };
- 1d_dmem { + dmem_1d: blob-ext@2 { filename = "lpddr4_pmu_train_1d_dmem.bin"; size = <0x4000>; type = "blob-ext"; };
- 2d_imem { + imem_2d: blob-ext@3 { filename = "lpddr4_pmu_train_2d_imem.bin"; size = <0x8000>; type = "blob-ext"; };
- 2d_dmem { + dmem_2d: blob-ext@4 { filename = "lpddr4_pmu_train_2d_dmem.bin"; size = <0x4000>; type = "blob-ext"; diff --git a/arch/arm/dts/imx8mq-u-boot.dtsi b/arch/arm/dts/imx8mq-u-boot.dtsi index 912a3d4a356..389414ad26f 100644 --- a/arch/arm/dts/imx8mq-u-boot.dtsi +++ b/arch/arm/dts/imx8mq-u-boot.dtsi @@ -46,25 +46,25 @@ filename = "u-boot-spl.bin"; };
In arch/arm/lib/sections.c there is below code: char __image_copy_start[0] __section(".__image_copy_start"); But actually 'objdump -t spl/u-boot-spl' not able to find out symbol '__image_copy_start' for binman update image-pos/size.
So update link file
Signed-off-by: Peng Fan peng.fan@nxp.com --- arch/arm/cpu/armv8/u-boot-spl.lds | 2 +- 1 file changed, 1 insertion(+), 1 deletion(-)
diff --git a/arch/arm/cpu/armv8/u-boot-spl.lds b/arch/arm/cpu/armv8/u-boot-spl.lds index 730eb93dbc3..9b1e7d46287 100644 --- a/arch/arm/cpu/armv8/u-boot-spl.lds +++ b/arch/arm/cpu/armv8/u-boot-spl.lds @@ -23,7 +23,7 @@ SECTIONS { .text : { . = ALIGN(8); - *(.__image_copy_start) + __image_copy_start = .; CPUDIR/start.o (.text*) *(.text*) } >.sram
In arch/arm/dts/imx8mp-u-boot.dtsi, there are blob-ext@1, blob-ext@2 and etc which is for packing ddr phy firmware. However we could not declare symbol name such as 'binman_sym_declare(ulong, blob_ext@1, image_pos)', because '@' is not allowed, so we choose to declare the symbol 'binman_sym_declare(ulong, blob_ext_1, image_pos);' with '@' replaced with '_'. It does not impact if there is no '@' in section name.
Signed-off-by: Peng Fan peng.fan@nxp.com --- tools/binman/etype/section.py | 2 +- 1 file changed, 1 insertion(+), 1 deletion(-)
diff --git a/tools/binman/etype/section.py b/tools/binman/etype/section.py index bd67238b919..e3f362b442b 100644 --- a/tools/binman/etype/section.py +++ b/tools/binman/etype/section.py @@ -875,7 +875,7 @@ class Entry_section(Entry): entries[entry.GetPath()] = entry for entry in to_add.values(): self._CollectEntries(entries, entries_by_name, entry) - entries_by_name[add_entry.name] = add_entry + entries_by_name[add_entry.name.replace('@', '-')] = add_entry
def MissingArgs(self, entry, missing): """Report a missing argument, if enabled
By reading binman symbols, we no need hard coded IMEM_LEN/DMEM_LEN after we update the binman dtsi to drop 0x8000/0x4000 length for the firmware.
And that could save binary size for many KBs.
Signed-off-by: Peng Fan peng.fan@nxp.com --- drivers/ddr/imx/imx8m/helper.c | 53 ++++++++++++++++++++++++++++------ 1 file changed, 44 insertions(+), 9 deletions(-)
diff --git a/drivers/ddr/imx/imx8m/helper.c b/drivers/ddr/imx/imx8m/helper.c index f23904bf712..b10ba602665 100644 --- a/drivers/ddr/imx/imx8m/helper.c +++ b/drivers/ddr/imx/imx8m/helper.c @@ -4,6 +4,7 @@ */
#include <common.h> +#include <binman_sym.h> #include <log.h> #include <spl.h> #include <asm/global_data.h> @@ -25,15 +26,30 @@ DECLARE_GLOBAL_DATA_PTR; #define DMEM_OFFSET_ADDR 0x00054000 #define DDR_TRAIN_CODE_BASE_ADDR IP2APB_DDRPHY_IPS_BASE_ADDR(0)
+binman_sym_declare(ulong, blob_ext_1, image_pos); +binman_sym_declare(ulong, blob_ext_1, size); + +binman_sym_declare(ulong, blob_ext_2, image_pos); +binman_sym_declare(ulong, blob_ext_2, size); + +#if !IS_ENABLED(CONFIG_IMX8M_DDR3L) +binman_sym_declare(ulong, blob_ext_3, image_pos); +binman_sym_declare(ulong, blob_ext_3, size); + +binman_sym_declare(ulong, blob_ext_4, image_pos); +binman_sym_declare(ulong, blob_ext_4, size); +#endif + /* We need PHY iMEM PHY is 32KB padded */ void ddr_load_train_firmware(enum fw_type type) { u32 tmp32, i; u32 error = 0; - unsigned long pr_to32, pr_from32; - unsigned long fw_offset = type ? IMEM_2D_OFFSET : 0; - unsigned long imem_start = (unsigned long)&_end + fw_offset; - unsigned long dmem_start; + uint32_t pr_to32, pr_from32; + uint32_t fw_offset = type ? IMEM_2D_OFFSET : 0; + uint32_t imem_start = (uint32_t)&_end + fw_offset; + uint32_t dmem_start; + uint32_t imem_len = IMEM_LEN, dmem_len = DMEM_LEN;
#ifdef CONFIG_SPL_OF_CONTROL if (gd->fdt_blob && !fdt_check_header(gd->fdt_blob)) { @@ -43,11 +59,30 @@ void ddr_load_train_firmware(enum fw_type type) } #endif
- dmem_start = imem_start + IMEM_LEN; + if (CONFIG_IS_ENABLED(BINMAN_SYMBOLS)) { + switch (type) { + case FW_1D_IMAGE: + imem_start = binman_sym(ulong, blob_ext_1, image_pos); + imem_len = binman_sym(ulong, blob_ext_1, size); + dmem_start = binman_sym(ulong, blob_ext_2, image_pos); + dmem_len = binman_sym(ulong, blob_ext_2, size); + break; + case FW_2D_IMAGE: +#if !IS_ENABLED(CONFIG_IMX8M_DDR3L) + imem_start = binman_sym(ulong, blob_ext_3, image_pos); + imem_len = binman_sym(ulong, blob_ext_3, size); + dmem_start = binman_sym(ulong, blob_ext_4, image_pos); + dmem_len = binman_sym(ulong, blob_ext_4, size); +#endif + break; + } + } + + dmem_start = imem_start + imem_len;
pr_from32 = imem_start; pr_to32 = DDR_TRAIN_CODE_BASE_ADDR + 4 * IMEM_OFFSET_ADDR; - for (i = 0x0; i < IMEM_LEN; ) { + for (i = 0x0; i < imem_len; ) { tmp32 = readl(pr_from32); writew(tmp32 & 0x0000ffff, pr_to32); pr_to32 += 4; @@ -59,7 +94,7 @@ void ddr_load_train_firmware(enum fw_type type)
pr_from32 = dmem_start; pr_to32 = DDR_TRAIN_CODE_BASE_ADDR + 4 * DMEM_OFFSET_ADDR; - for (i = 0x0; i < DMEM_LEN; ) { + for (i = 0x0; i < dmem_len; ) { tmp32 = readl(pr_from32); writew(tmp32 & 0x0000ffff, pr_to32); pr_to32 += 4; @@ -72,7 +107,7 @@ void ddr_load_train_firmware(enum fw_type type) debug("check ddr_pmu_train_imem code\n"); pr_from32 = imem_start; pr_to32 = DDR_TRAIN_CODE_BASE_ADDR + 4 * IMEM_OFFSET_ADDR; - for (i = 0x0; i < IMEM_LEN; ) { + for (i = 0x0; i < imem_len; ) { tmp32 = (readw(pr_to32) & 0x0000ffff); pr_to32 += 4; tmp32 += ((readw(pr_to32) & 0x0000ffff) << 16); @@ -93,7 +128,7 @@ void ddr_load_train_firmware(enum fw_type type) debug("check ddr4_pmu_train_dmem code\n"); pr_from32 = dmem_start; pr_to32 = DDR_TRAIN_CODE_BASE_ADDR + 4 * DMEM_OFFSET_ADDR; - for (i = 0x0; i < DMEM_LEN;) { + for (i = 0x0; i < dmem_len;) { tmp32 = (readw(pr_to32) & 0x0000ffff); pr_to32 += 4; tmp32 += ((readw(pr_to32) & 0x0000ffff) << 16);
switch (type) {
case FW_1D_IMAGE:
break;
case FW_2D_IMAGE:
break;
dmem_start = imem_start + imem_len; pr_from32 = imem_start; pr_to32 = DDR_TRAIN_CODE_BASE_ADDR + 4 * IMEM_OFFSET_ADDR;
-- 2.36.0
Peng,
While this compiles and works, it generates a lot of warnings due to cating from pointer to integer of diff size: CC spl/drivers/ddr/imx/imx8m/helper.o drivers/ddr/imx/imx8m/helper.c: In function ‘ddr_load_train_firmware’: drivers/ddr/imx/imx8m/helper.c:50:24: warning: cast from pointer to integer of different size [-Wpointer-to-int-cast] uint32_t imem_start = (uint32_t)&_end + fw_offset; ^ In file included from drivers/ddr/imx/imx8m/helper.c:11: ./arch/arm/include/asm/io.h:26:28: warning: cast to pointer from integer of different size [-Wint-to-pointer-cast] #define __arch_getl(a) (*(volatile unsigned int *)(a)) ^ ./arch/arm/include/asm/io.h:108:31: note: in expansion of macro ‘__arch_getl’ #define readl(c) ({ u32 __v = __arch_getl(c); __iormb(); __v; }) ^~~~~~~~~~~ drivers/ddr/imx/imx8m/helper.c:86:11: note: in expansion of macro ‘readl’ tmp32 = readl(pr_from32); ^~~~~ ./arch/arm/include/asm/io.h:30:29: warning: cast to pointer from integer of different size [-Wint-to-pointer-cast] #define __arch_putw(v,a) (*(volatile unsigned short *)(a) = (v)) ^ ./arch/arm/include/asm/io.h:102:48: note: in expansion of macro ‘__arch_putw’ #define writew(v,c) ({ u16 __v = v; __iowmb(); __arch_putw(__v,c); __v; }) ^~~~~~~~~~~ drivers/ddr/imx/imx8m/helper.c:87:3: note: in expansion of macro ‘writew’ writew(tmp32 & 0x0000ffff, pr_to32); ^~~~~~ ./arch/arm/include/asm/io.h:30:29: warning: cast to pointer from integer of different size [-Wint-to-pointer-cast] #define __arch_putw(v,a) (*(volatile unsigned short *)(a) = (v)) ^ ./arch/arm/include/asm/io.h:102:48: note: in expansion of macro ‘__arch_putw’ #define writew(v,c) ({ u16 __v = v; __iowmb(); __arch_putw(__v,c); __v; }) ^~~~~~~~~~~ drivers/ddr/imx/imx8m/helper.c:89:3: note: in expansion of macro ‘writew’ writew((tmp32 >> 16) & 0x0000ffff, pr_to32); ^~~~~~ ./arch/arm/include/asm/io.h:26:28: warning: cast to pointer from integer of different size [-Wint-to-pointer-cast] #define __arch_getl(a) (*(volatile unsigned int *)(a)) ^ ./arch/arm/include/asm/io.h:108:31: note: in expansion of macro ‘__arch_getl’ #define readl(c) ({ u32 __v = __arch_getl(c); __iormb(); __v; }) ^~~~~~~~~~~ drivers/ddr/imx/imx8m/helper.c:98:11: note: in expansion of macro ‘readl’ tmp32 = readl(pr_from32); ^~~~~ ./arch/arm/include/asm/io.h:30:29: warning: cast to pointer from integer of different size [-Wint-to-pointer-cast] #define __arch_putw(v,a) (*(volatile unsigned short *)(a) = (v)) ^ ./arch/arm/include/asm/io.h:102:48: note: in expansion of macro ‘__arch_putw’ #define writew(v,c) ({ u16 __v = v; __iowmb(); __arch_putw(__v,c); __v; }) ^~~~~~~~~~~ drivers/ddr/imx/imx8m/helper.c:99:3: note: in expansion of macro ‘writew’ writew(tmp32 & 0x0000ffff, pr_to32); ^~~~~~ ./arch/arm/include/asm/io.h:30:29: warning: cast to pointer from integer of different size [-Wint-to-pointer-cast] #define __arch_putw(v,a) (*(volatile unsigned short *)(a) = (v)) ^ ./arch/arm/include/asm/io.h:102:48: note: in expansion of macro ‘__arch_putw’ #define writew(v,c) ({ u16 __v = v; __iowmb(); __arch_putw(__v,c); __v; }) ^~~~~~~~~~~ drivers/ddr/imx/imx8m/helper.c:101:3: note: in expansion of macro ‘writew’ writew((tmp32 >> 16) & 0x0000ffff, pr_to32); ^~~~~~ ./arch/arm/include/asm/io.h:25:28: warning: cast to pointer from integer of different size [-Wint-to-pointer-cast] #define __arch_getw(a) (*(volatile unsigned short *)(a)) ^ ./arch/arm/include/asm/io.h:107:31: note: in expansion of macro ‘__arch_getw’ #define readw(c) ({ u16 __v = __arch_getw(c); __iormb(); __v; }) ^~~~~~~~~~~ drivers/ddr/imx/imx8m/helper.c:111:12: note: in expansion of macro ‘readw’ tmp32 = (readw(pr_to32) & 0x0000ffff); ^~~~~ ./arch/arm/include/asm/io.h:25:28: warning: cast to pointer from integer of different size [-Wint-to-pointer-cast] #define __arch_getw(a) (*(volatile unsigned short *)(a)) ^ ./arch/arm/include/asm/io.h:107:31: note: in expansion of macro ‘__arch_getw’ #define readw(c) ({ u16 __v = __arch_getw(c); __iormb(); __v; }) ^~~~~~~~~~~ drivers/ddr/imx/imx8m/helper.c:113:14: note: in expansion of macro ‘readw’ tmp32 += ((readw(pr_to32) & 0x0000ffff) << 16); ^~~~~ ./arch/arm/include/asm/io.h:26:28: warning: cast to pointer from integer of different size [-Wint-to-pointer-cast] #define __arch_getl(a) (*(volatile unsigned int *)(a)) ^ ./arch/arm/include/asm/io.h:108:31: note: in expansion of macro ‘__arch_getl’ #define readl(c) ({ u32 __v = __arch_getl(c); __iormb(); __v; }) ^~~~~~~~~~~ drivers/ddr/imx/imx8m/helper.c:115:16: note: in expansion of macro ‘readl’ if (tmp32 != readl(pr_from32)) { ^~~~~ In file included from include/linux/printk.h:4, from include/linux/kernel.h:5, from include/linux/bitops.h:22, from ./arch/arm/include/asm/arch/imx-regs.h:87, from include/configs/imx8m.h:11, from include/configs/imx8mm_venice.h:9, from include/config.h:4, from include/common.h:16, from drivers/ddr/imx/imx8m/helper.c:6: drivers/ddr/imx/imx8m/helper.c:116:10: warning: format ‘%lx’ expects argument of type ‘long unsigned int’, but argument 2 has type ‘uint32_t’ {aka ‘unsigned in ’} [-Wformat=] debug("%lx %lx\n", pr_from32, pr_to32); ^~~~~~~~~~~ include/log.h:165:21: note: in definition of macro ‘pr_fmt’ #define pr_fmt(fmt) fmt ^~~ include/log.h:285:2: note: in expansion of macro ‘debug_cond’ debug_cond(_DEBUG, fmt, ##args) ^~~~~~~~~~ drivers/ddr/imx/imx8m/helper.c:116:4: note: in expansion of macro ‘debug’ debug("%lx %lx\n", pr_from32, pr_to32); ^~~~~ drivers/ddr/imx/imx8m/helper.c:116:10: warning: format ‘%lx’ expects argument of type ‘long unsigned int’, but argument 3 has type ‘uint32_t’ {aka ‘unsigned in ’} [-Wformat=] debug("%lx %lx\n", pr_from32, pr_to32); ^~~~~~~~~~~ include/log.h:165:21: note: in definition of macro ‘pr_fmt’ #define pr_fmt(fmt) fmt ^~~ include/log.h:285:2: note: in expansion of macro ‘debug_cond’ debug_cond(_DEBUG, fmt, ##args) ^~~~~~~~~~ drivers/ddr/imx/imx8m/helper.c:116:4: note: in expansion of macro ‘debug’ debug("%lx %lx\n", pr_from32, pr_to32); ^~~~~ In file included from drivers/ddr/imx/imx8m/helper.c:11: ./arch/arm/include/asm/io.h:25:28: warning: cast to pointer from integer of different size [-Wint-to-pointer-cast] #define __arch_getw(a) (*(volatile unsigned short *)(a)) ^ ./arch/arm/include/asm/io.h:107:31: note: in expansion of macro ‘__arch_getw’ #define readw(c) ({ u16 __v = __arch_getw(c); __iormb(); __v; }) ^~~~~~~~~~~ drivers/ddr/imx/imx8m/helper.c:132:12: note: in expansion of macro ‘readw’ tmp32 = (readw(pr_to32) & 0x0000ffff); ^~~~~ ./arch/arm/include/asm/io.h:25:28: warning: cast to pointer from integer of different size [-Wint-to-pointer-cast] #define __arch_getw(a) (*(volatile unsigned short *)(a)) ^ ./arch/arm/include/asm/io.h:107:31: note: in expansion of macro ‘__arch_getw’ #define readw(c) ({ u16 __v = __arch_getw(c); __iormb(); __v; }) ^~~~~~~~~~~ drivers/ddr/imx/imx8m/helper.c:134:14: note: in expansion of macro ‘readw’ tmp32 += ((readw(pr_to32) & 0x0000ffff) << 16); ^~~~~ ./arch/arm/include/asm/io.h:26:28: warning: cast to pointer from integer of different size [-Wint-to-pointer-cast] #define __arch_getl(a) (*(volatile unsigned int *)(a)) ^ ./arch/arm/include/asm/io.h:108:31: note: in expansion of macro ‘__arch_getl’ #define readl(c) ({ u32 __v = __arch_getl(c); __iormb(); __v; }) ^~~~~~~~~~~ drivers/ddr/imx/imx8m/helper.c:135:16: note: in expansion of macro ‘readl’ if (tmp32 != readl(pr_from32)) { ^~~~~ In file included from include/linux/printk.h:4, from include/linux/kernel.h:5, from include/linux/bitops.h:22, from ./arch/arm/include/asm/arch/imx-regs.h:87, from include/configs/imx8m.h:11, from include/configs/imx8mm_venice.h:9, from include/config.h:4, from include/common.h:16, from drivers/ddr/imx/imx8m/helper.c:6: drivers/ddr/imx/imx8m/helper.c:136:10: warning: format ‘%lx’ expects argument of type ‘long unsigned int’, but argument 2 has type ‘uint32_t’ {aka ‘unsigned in ’} [-Wformat=] debug("%lx %lx\n", pr_from32, pr_to32); ^~~~~~~~~~~ include/log.h:165:21: note: in definition of macro ‘pr_fmt’ #define pr_fmt(fmt) fmt ^~~ include/log.h:285:2: note: in expansion of macro ‘debug_cond’ debug_cond(_DEBUG, fmt, ##args) ^~~~~~~~~~ drivers/ddr/imx/imx8m/helper.c:136:4: note: in expansion of macro ‘debug’ debug("%lx %lx\n", pr_from32, pr_to32); ^~~~~ drivers/ddr/imx/imx8m/helper.c:136:10: warning: format ‘%lx’ expects argument of type ‘long unsigned int’, but argument 3 has type ‘uint32_t’ {aka ‘unsigned in ’} [-Wformat=] debug("%lx %lx\n", pr_from32, pr_to32); ^~~~~~~~~~~ include/log.h:165:21: note: in definition of macro ‘pr_fmt’ #define pr_fmt(fmt) fmt ^~~ include/log.h:285:2: note: in expansion of macro ‘debug_cond’ debug_cond(_DEBUG, fmt, ##args) ^~~~~~~~~~ drivers/ddr/imx/imx8m/helper.c:136:4: note: in expansion of macro ‘debug’ debug("%lx %lx\n", pr_from32, pr_to32); ^~~~~
Best Regards,
Tim
Tim,
Subject: Re: [PATCH V2 5/7] ddr: imx8m: helper: load ddr firmware according to binman symbols
firmware.
DMEM_OFFSET_ADDR
+binman_sym_declare(ulong, blob_ext_4, image_pos); +binman_sym_declare(ulong, blob_ext_4, size); #endif
switch (type) {
case FW_1D_IMAGE:
break;
case FW_2D_IMAGE:
+size); #endif
break;
-- 2.36.0
Peng,
I not met this warning. Maybe toolchain version, anyway let me check.
Thanks, Peng.
Best Regards,
Tim
After we switch to use BINMAN_SYMBOLS, there is no need to pad the file size to 0x8000 and 0x4000. After we use BINMAN_SYMBOLS, the u-boot-spl-ddr.bin shrink about 36KB with i.MX8MP-EVK.
Signed-off-by: Peng Fan peng.fan@nxp.com --- arch/arm/dts/imx8mm-u-boot.dtsi | 8 ++++---- arch/arm/dts/imx8mn-beacon-kit-u-boot.dtsi | 8 ++++---- arch/arm/dts/imx8mn-ddr4-evk-u-boot.dtsi | 8 ++++---- arch/arm/dts/imx8mn-evk-u-boot.dtsi | 8 ++++---- arch/arm/dts/imx8mn-var-som-symphony-u-boot.dtsi | 8 ++++---- arch/arm/dts/imx8mn-venice-u-boot.dtsi | 8 ++++---- arch/arm/dts/imx8mp-u-boot.dtsi | 8 ++++---- arch/arm/dts/imx8mq-cm-u-boot.dtsi | 8 ++++---- arch/arm/dts/imx8mq-u-boot.dtsi | 8 ++++---- 9 files changed, 36 insertions(+), 36 deletions(-)
diff --git a/arch/arm/dts/imx8mm-u-boot.dtsi b/arch/arm/dts/imx8mm-u-boot.dtsi index 5de55a2d80b..19a2da30f51 100644 --- a/arch/arm/dts/imx8mm-u-boot.dtsi +++ b/arch/arm/dts/imx8mm-u-boot.dtsi @@ -41,25 +41,25 @@
imem_1d: blob-ext@1 { filename = "lpddr4_pmu_train_1d_imem.bin"; - size = <0x8000>; + align-end = <4>; type = "blob-ext"; };
dmem_1d: blob-ext@2 { filename = "lpddr4_pmu_train_1d_dmem.bin"; - size = <0x4000>; + align-end = <4>; type = "blob-ext"; };
imem_2d: blob-ext@3 { filename = "lpddr4_pmu_train_2d_imem.bin"; - size = <0x8000>; + align-end = <4>; type = "blob-ext"; };
dmem_2d: blob-ext@4 { filename = "lpddr4_pmu_train_2d_dmem.bin"; - size = <0x4000>; + align-end = <4>; type = "blob-ext"; }; }; diff --git a/arch/arm/dts/imx8mn-beacon-kit-u-boot.dtsi b/arch/arm/dts/imx8mn-beacon-kit-u-boot.dtsi index eb1dd8debba..e1740fa31a6 100644 --- a/arch/arm/dts/imx8mn-beacon-kit-u-boot.dtsi +++ b/arch/arm/dts/imx8mn-beacon-kit-u-boot.dtsi @@ -149,22 +149,22 @@
blob_1: blob-ext@1 { filename = "lpddr4_pmu_train_1d_imem.bin"; - size = <0x8000>; + align-end = <4>; };
blob_2: blob-ext@2 { filename = "lpddr4_pmu_train_1d_dmem.bin"; - size = <0x4000>; + align-end = <4>; };
blob_3: blob-ext@3 { filename = "lpddr4_pmu_train_2d_imem.bin"; - size = <0x8000>; + align-end = <4>; };
blob_4: blob-ext@4 { filename = "lpddr4_pmu_train_2d_dmem.bin"; - size = <0x4000>; + align-end = <4>; }; };
diff --git a/arch/arm/dts/imx8mn-ddr4-evk-u-boot.dtsi b/arch/arm/dts/imx8mn-ddr4-evk-u-boot.dtsi index 4d0ecb07d4f..1fe2d0fd507 100644 --- a/arch/arm/dts/imx8mn-ddr4-evk-u-boot.dtsi +++ b/arch/arm/dts/imx8mn-ddr4-evk-u-boot.dtsi @@ -157,22 +157,22 @@
blob_1: blob-ext@1 { filename = "ddr4_imem_1d_201810.bin"; - size = <0x8000>; + align-end = <4>; };
blob_2: blob-ext@2 { filename = "ddr4_dmem_1d_201810.bin"; - size = <0x4000>; + align-end = <4>; };
blob_3: blob-ext@3 { filename = "ddr4_imem_2d_201810.bin"; - size = <0x8000>; + align-end = <4>; };
blob_4: blob-ext@4 { filename = "ddr4_dmem_2d_201810.bin"; - size = <0x4000>; + align-end = <4>; }; };
diff --git a/arch/arm/dts/imx8mn-evk-u-boot.dtsi b/arch/arm/dts/imx8mn-evk-u-boot.dtsi index 3db46d4cbcb..4f6dcf307b2 100644 --- a/arch/arm/dts/imx8mn-evk-u-boot.dtsi +++ b/arch/arm/dts/imx8mn-evk-u-boot.dtsi @@ -38,22 +38,22 @@
diff --git a/arch/arm/dts/imx8mn-var-som-symphony-u-boot.dtsi b/arch/arm/dts/imx8mn-var-som-symphony-u-boot.dtsi index 6e37622cca7..55530abf832 100644 --- a/arch/arm/dts/imx8mn-var-som-symphony-u-boot.dtsi +++ b/arch/arm/dts/imx8mn-var-som-symphony-u-boot.dtsi @@ -132,25 +132,25 @@
1d-imem { filename = "ddr4_imem_1d.bin"; - size = <0x8000>; + align-end = <4>; type = "blob-ext"; };
1d_dmem { filename = "ddr4_dmem_1d.bin"; - size = <0x4000>; + align-end = <4>; type = "blob-ext"; };
2d_imem { filename = "ddr4_imem_2d.bin"; - size = <0x8000>; + align-end = <4>; type = "blob-ext"; };
2d_dmem { filename = "ddr4_dmem_2d.bin"; - size = <0x4000>; + align-end = <4>; type = "blob-ext"; }; }; diff --git a/arch/arm/dts/imx8mn-venice-u-boot.dtsi b/arch/arm/dts/imx8mn-venice-u-boot.dtsi index 67922146963..e3a0b170347 100644 --- a/arch/arm/dts/imx8mn-venice-u-boot.dtsi +++ b/arch/arm/dts/imx8mn-venice-u-boot.dtsi @@ -128,25 +128,25 @@
dmem_2d: blob-ext@4 { filename = "lpddr4_pmu_train_2d_dmem.bin"; - size = <0x4000>; + align-end = <4>; type = "blob-ext"; }; }; diff --git a/arch/arm/dts/imx8mp-u-boot.dtsi b/arch/arm/dts/imx8mp-u-boot.dtsi index 20edd90cfad..274515a010e 100644 --- a/arch/arm/dts/imx8mp-u-boot.dtsi +++ b/arch/arm/dts/imx8mp-u-boot.dtsi @@ -63,22 +63,22 @@
blob_1: blob-ext@1 { filename = "lpddr4_pmu_train_1d_imem_202006.bin"; - size = <0x8000>; + align-end = <4>; };
blob_2: blob-ext@2 { filename = "lpddr4_pmu_train_1d_dmem_202006.bin"; - size = <0x4000>; + align-end = <4>; };
blob_3: blob-ext@3 { filename = "lpddr4_pmu_train_2d_imem_202006.bin"; - size = <0x8000>; + align-end = <4>; };
blob_4: blob-ext@4 { filename = "lpddr4_pmu_train_2d_dmem_202006.bin"; - size = <0x4000>; + align-end = <4>; }; };
diff --git a/arch/arm/dts/imx8mq-cm-u-boot.dtsi b/arch/arm/dts/imx8mq-cm-u-boot.dtsi index e2f4b0e740d..9538a04ed97 100644 --- a/arch/arm/dts/imx8mq-cm-u-boot.dtsi +++ b/arch/arm/dts/imx8mq-cm-u-boot.dtsi @@ -30,22 +30,22 @@
diff --git a/arch/arm/dts/imx8mq-u-boot.dtsi b/arch/arm/dts/imx8mq-u-boot.dtsi index 389414ad26f..1495869fcd2 100644 --- a/arch/arm/dts/imx8mq-u-boot.dtsi +++ b/arch/arm/dts/imx8mq-u-boot.dtsi @@ -48,25 +48,25 @@
There is case that CONFIG_BINMAN is defined, but CONFIG_SPL_BINMAN_SYMBOLS is not defined. In that case, there will be build failure. So use CONFIG_SPL_BINMAN_SYMBOLS to guard the macros, and define CONFIG_SPL_BINMAN_SYMBOLS in binman syms test.
Signed-off-by: Peng Fan peng.fan@nxp.com --- include/binman_sym.h | 2 +- tools/binman/test/u_boot_binman_syms.c | 1 + tools/binman/test/u_boot_binman_syms_size.c | 1 + 3 files changed, 3 insertions(+), 1 deletion(-)
diff --git a/include/binman_sym.h b/include/binman_sym.h index 72e6765fe52..548d8f5654c 100644 --- a/include/binman_sym.h +++ b/include/binman_sym.h @@ -13,7 +13,7 @@
#define BINMAN_SYM_MISSING (-1UL)
-#ifdef CONFIG_BINMAN +#ifdef CONFIG_SPL_BINMAN_SYMBOLS
/** * binman_symname() - Internal function to get a binman symbol name diff --git a/tools/binman/test/u_boot_binman_syms.c b/tools/binman/test/u_boot_binman_syms.c index 37fc339ce84..f4a4d1f6846 100644 --- a/tools/binman/test/u_boot_binman_syms.c +++ b/tools/binman/test/u_boot_binman_syms.c @@ -6,6 +6,7 @@ */
#define CONFIG_BINMAN +#define CONFIG_SPL_BINMAN_SYMBOLS #include <binman_sym.h>
binman_sym_declare(unsigned long, u_boot_spl_any, offset); diff --git a/tools/binman/test/u_boot_binman_syms_size.c b/tools/binman/test/u_boot_binman_syms_size.c index 7224bc1863c..3a01d8ca4be 100644 --- a/tools/binman/test/u_boot_binman_syms_size.c +++ b/tools/binman/test/u_boot_binman_syms_size.c @@ -6,6 +6,7 @@ */
binman_sym_declare(char, u_boot_spl, pos);
Peng Fan (OSS)
Tim Harvey
