[PATCH 1/2] arm64: dts: armada-3720-espressobin: sync with downstream
This adds the disabled eMMC node.
Signed-off-by: Andre Heider a.heider@gmail.com --- arch/arm/dts/armada-3720-espressobin.dts | 63 +++++++++--------------- 1 file changed, 23 insertions(+), 40 deletions(-)
diff --git a/arch/arm/dts/armada-3720-espressobin.dts b/arch/arm/dts/armada-3720-espressobin.dts index 4534f5ff29..a66ab814eb 100644 --- a/arch/arm/dts/armada-3720-espressobin.dts +++ b/arch/arm/dts/armada-3720-espressobin.dts @@ -1,3 +1,4 @@ +// SPDX-License-Identifier: GPL-2.0+ /* * Device Tree file for Marvell Armada 3720 community board * (ESPRESSOBin) @@ -5,53 +6,15 @@ * * Gregory CLEMENT gregory.clement@free-electrons.com * Konstantin Porotchkin kostap@marvell.com - * - * This file is dual-licensed: you can use it either under the terms - * of the GPL or the X11 license, at your option. Note that this dual - * licensing only applies to this file, and not this project as a - * whole. - * - * a) This file is free software; you can redistribute it and/or - * modify it under the terms of the GNU General Public License as - * published by the Free Software Foundation; either version 2 of the - * License, or (at your option) any later version. - * - * This file is distributed in the hope that it will be useful - * but WITHOUT ANY WARRANTY; without even the implied warranty of - * MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE. See the - * GNU General Public License for more details. - * - * Or, alternatively - * - * b) Permission is hereby granted, free of charge, to any person - * obtaining a copy of this software and associated documentation - * files (the "Software"), to deal in the Software without - * restriction, including without limitation the rights to use - * copy, modify, merge, publish, distribute, sublicense, and/or - * sell copies of the Software, and to permit persons to whom the - * Software is furnished to do so, subject to the following - * conditions: - * - * The above copyright notice and this permission notice shall be - * included in all copies or substantial portions of the Software. - * - * THE SOFTWARE IS PROVIDED , WITHOUT WARRANTY OF ANY KIND - * EXPRESS OR IMPLIED, INCLUDING BUT NOT LIMITED TO THE WARRANTIES - * OF MERCHANTABILITY, FITNESS FOR A PARTICULAR PURPOSE AND - * NONINFRINGEMENT. IN NO EVENT SHALL THE AUTHORS OR COPYRIGHT - * HOLDERS BE LIABLE FOR ANY CLAIM, DAMAGES OR OTHER LIABILITY - * WHETHER IN AN ACTION OF CONTRACT, TORT OR OTHERWISE, ARISING - * FROM, OUT OF OR IN CONNECTION WITH THE SOFTWARE OR THE USE OR - * OTHER DEALINGS IN THE SOFTWARE. */ - /dts-v1/;
#include "armada-372x.dtsi"
/ { model = "Marvell Armada 3720 Community Board ESPRESSOBin"; - compatible = "marvell,armada-3720-espressobin", "marvell,armada3720", "marvell,armada3710"; + compatible = "marvell,armada-3720-espressobin", + "marvell,armada3720", "marvell,armada3710";
chosen { stdout-path = "serial0:115200n8"; @@ -121,6 +84,7 @@ status = "okay"; };
+/* J1 */ &sdhci0 { pinctrl-names = "default"; pinctrl-0 = <&sdio_pins>; @@ -130,6 +94,25 @@ status = "okay"; };
+/* U11 */ +&sdhci1 { + non-removable; + bus-width = <8>; + mmc-ddr-1_8v; + mmc-hs400-1_8v; + marvell,pad-type = "fixed-1-8v"; + pinctrl-names = "default"; + pinctrl-0 = <&mmc_pins>; + status = "disabled"; + + #address-cells = <1>; + #size-cells = <0>; + mmccard: mmccard@0 { + compatible = "mmc-card"; + reg = <0>; + }; +}; + &spi0 { status = "okay"; pinctrl-names = "default";
Add the downstream dts for the Espressobin with eMMC.
Signed-off-by: Andre Heider a.heider@gmail.com --- arch/arm/dts/Makefile | 1 + arch/arm/dts/armada-3720-espressobin-emmc.dts | 19 +++++++++++++++++++ doc/README.marvell | 8 ++++++-- 3 files changed, 26 insertions(+), 2 deletions(-) create mode 100644 arch/arm/dts/armada-3720-espressobin-emmc.dts
diff --git a/arch/arm/dts/Makefile b/arch/arm/dts/Makefile index 5e34192be6..8f1958b5a7 100644 --- a/arch/arm/dts/Makefile +++ b/arch/arm/dts/Makefile @@ -202,6 +202,7 @@ dtb-$(CONFIG_ARCH_TEGRA) += tegra20-harmony.dtb \ dtb-$(CONFIG_ARCH_MVEBU) += \ armada-3720-db.dtb \ armada-3720-espressobin.dtb \ + armada-3720-espressobin-emmc.dtb \ armada-3720-turris-mox.dtb \ armada-3720-uDPU.dtb \ armada-375-db.dtb \ diff --git a/arch/arm/dts/armada-3720-espressobin-emmc.dts b/arch/arm/dts/armada-3720-espressobin-emmc.dts new file mode 100644 index 0000000000..0dd59af9c0 --- /dev/null +++ b/arch/arm/dts/armada-3720-espressobin-emmc.dts @@ -0,0 +1,19 @@ +// SPDX-License-Identifier: GPL-2.0+ +/* + * Copyright (C) 2018 Marvell International Ltd. + */ + +#include "armada-3720-espressobin.dts" + +/ { + model = "Marvell Armada 3720 Community Board ESPRESSOBin (eMMC)"; + compatible = "marvell,armada-3720-espressobin", + "marvell,armada-3720-espressobin-emmc", + "marvell,armada3720", "marvell,armada3710"; + +}; + +/* U11 */ +&sdhci1 { + status = "okay"; +}; diff --git a/doc/README.marvell b/doc/README.marvell index 5416bc3035..c5cab2fb38 100644 --- a/doc/README.marvell +++ b/doc/README.marvell @@ -43,8 +43,12 @@ Build Procedure In order to prevent this, the required device-tree MUST be set during compilation. All device-tree files are located in ./arch/arm/dts/ folder.
- For other DB boards (MacchiatoBin, EspressoBin and 3700 DB board) compile u-boot with - just default device-tree from defconfig using: + For the EspressoBin with eMMC compile u-boot and set the required device-tree using: + + # make DEVICE_TREE=armada-3720-espressobin-emmc + + For other DB boards (MacchiatoBin, EspressoBin without eMMC and 3700 DB board) compile + u-boot with just default device-tree from defconfig using:
# make
Add support for additional EspressoBIN board with installed eMMC device (U11). Starting from this patch the DEVICE_TREE= must be added to "make" in order to distinguish between platforms wth and without eMMC on board. Regualr (no eMMC) EspressoBIN builds should use DTS file named armada-3720-espressobin and build for boards with eMMC installed the DTS named armada-3720-espressobin-emmc. The default device tree string is now removed from mvebu_espressobin-88f3720_defconfig config file. Update build documentation accordingly.
Change-Id: Id1a4f3ca01a6e52df57bf7279f33f0fe45f8ed18 Signed-off-by: Konstantin Porotchkin kostap@marvell.com Reviewed-on: http://vgitil04.il.marvell.com:8080/61290 Tested-by: iSoC Platform CI ykjenk@marvell.com [a.heider: adapt to mainline] Signed-off-by: Andre Heider a.heider@gmail.com --- v2: base upon downstream patch
arch/arm/dts/Makefile | 1 + arch/arm/dts/armada-3720-espressobin-emmc.dts | 19 +++++++++++++++++++ configs/mvebu_espressobin-88f3720_defconfig | 1 - doc/README.marvell | 7 ++++++- 4 files changed, 26 insertions(+), 2 deletions(-) create mode 100644 arch/arm/dts/armada-3720-espressobin-emmc.dts
diff --git a/arch/arm/dts/Makefile b/arch/arm/dts/Makefile index 5e34192be6..8f1958b5a7 100644 --- a/arch/arm/dts/Makefile +++ b/arch/arm/dts/Makefile @@ -202,6 +202,7 @@ dtb-$(CONFIG_ARCH_TEGRA) += tegra20-harmony.dtb \ dtb-$(CONFIG_ARCH_MVEBU) += \ armada-3720-db.dtb \ armada-3720-espressobin.dtb \ + armada-3720-espressobin-emmc.dtb \ armada-3720-turris-mox.dtb \ armada-3720-uDPU.dtb \ armada-375-db.dtb \ diff --git a/arch/arm/dts/armada-3720-espressobin-emmc.dts b/arch/arm/dts/armada-3720-espressobin-emmc.dts new file mode 100644 index 0000000000..0dd59af9c0 --- /dev/null +++ b/arch/arm/dts/armada-3720-espressobin-emmc.dts @@ -0,0 +1,19 @@ +// SPDX-License-Identifier: GPL-2.0+ +/* + * Copyright (C) 2018 Marvell International Ltd. + */ + +#include "armada-3720-espressobin.dts" + +/ { + model = "Marvell Armada 3720 Community Board ESPRESSOBin (eMMC)"; + compatible = "marvell,armada-3720-espressobin", + "marvell,armada-3720-espressobin-emmc", + "marvell,armada3720", "marvell,armada3710"; + +}; + +/* U11 */ +&sdhci1 { + status = "okay"; +}; diff --git a/configs/mvebu_espressobin-88f3720_defconfig b/configs/mvebu_espressobin-88f3720_defconfig index 0c1c92d4ff..99f421d841 100644 --- a/configs/mvebu_espressobin-88f3720_defconfig +++ b/configs/mvebu_espressobin-88f3720_defconfig @@ -11,7 +11,6 @@ CONFIG_ENV_SECT_SIZE=0x10000 CONFIG_DM_GPIO=y CONFIG_DEBUG_UART_BASE=0xd0012000 CONFIG_DEBUG_UART_CLOCK=25804800 -CONFIG_DEFAULT_DEVICE_TREE="armada-3720-espressobin" CONFIG_DEBUG_UART=y CONFIG_AHCI=y CONFIG_DISTRO_DEFAULTS=y diff --git a/doc/README.marvell b/doc/README.marvell index 5416bc3035..ffd0544aef 100644 --- a/doc/README.marvell +++ b/doc/README.marvell @@ -43,7 +43,12 @@ Build Procedure In order to prevent this, the required device-tree MUST be set during compilation. All device-tree files are located in ./arch/arm/dts/ folder.
- For other DB boards (MacchiatoBin, EspressoBin and 3700 DB board) compile u-boot with + For the EspressoBin board without soldered eMMC device use + # make DEVICE_TREE=armada-3720-espressobin + For the EspressoBin board with populated eMMC device use + # make DEVICE_TREE=armada-3720-espressobin-emmc + + For other DB boards (MacchiatoBin, and 3700 DB board) compile u-boot with just default device-tree from defconfig using:
# make
Why? Is not it better to have the most common non-emmc version by default instead forcing people to specify another compile time option? IIRC mmc versions are very rare.
- armada-3720-espressobin-emmc.dtb \ armada-3720-turris-mox.dtb \ armada-3720-uDPU.dtb \ armada-375-db.dtb \
- Copyright (C) 2018 Marvell International Ltd.
- model = "Marvell Armada 3720 Community Board ESPRESSOBin (eMMC)";
- status = "okay";
# make
-- 2.28.0
That's actually what my v1 did, but other mvebu boards do it as well, as does downstream (which is where this patch original comes from). So I went ahead and kept it consistent.
But sure, I can change it again.
Thanks, Andre
- status = "okay";
# make
-- 2.28.0
If Marvell did something in their 2 years old unmaintained fork it does not mean that upstream U-Boot must copy+paste whole Marvell code including suspicious whitespace changes if there is no good reason for it.
And in my opinion, if we know that eMMC espressobin versions are rare and DTS file for non-eMMC version is compatible with eMMC espressobin HW, I do not see reason why not to have DTS file for non-eMMC version chosen by default. It would really simplify compilation and setup for most of people. And also it would simplify bisecting git repository for other Espressobin developers in case of some U-boot failure.
Thanks, Andre
- status = "okay";
- For the EspressoBin board without soldered eMMC device use
- For the EspressoBin board with populated eMMC device use
- For other DB boards (MacchiatoBin, and 3700 DB board) compile u-boot with just default device-tree from defconfig using: # make
-- 2.28.0
Hehe, of course not, there're changes I didn't carry over :) And that one whitespace change added a line break to a +80 char line, which I opted for.
Those are two good points, thanks. I'll change it!
Thanks, Andre
- status = "okay";
-- 2.28.0
Add support for additional EspressoBIN board with installed eMMC device (U11). EspressoBIN boards with eMMC installed should use the DTS named armada-3720-espressobin-emmc. Update build documentation accordingly.
Change-Id: Id1a4f3ca01a6e52df57bf7279f33f0fe45f8ed18 Signed-off-by: Konstantin Porotchkin kostap@marvell.com Reviewed-on: http://vgitil04.il.marvell.com:8080/61290 Tested-by: iSoC Platform CI ykjenk@marvell.com [a.heider: adapt to mainline] Signed-off-by: Andre Heider a.heider@gmail.com --- v2: base upon downstream patch v3: keep CONFIG_DEFAULT_DEVICE_TREE for non-emmc boards
arch/arm/dts/Makefile | 1 + arch/arm/dts/armada-3720-espressobin-emmc.dts | 19 +++++++++++++++++++ doc/README.marvell | 7 +++++-- 3 files changed, 25 insertions(+), 2 deletions(-) create mode 100644 arch/arm/dts/armada-3720-espressobin-emmc.dts
diff --git a/arch/arm/dts/Makefile b/arch/arm/dts/Makefile index 5e34192be6..8f1958b5a7 100644 --- a/arch/arm/dts/Makefile +++ b/arch/arm/dts/Makefile @@ -202,6 +202,7 @@ dtb-$(CONFIG_ARCH_TEGRA) += tegra20-harmony.dtb \ dtb-$(CONFIG_ARCH_MVEBU) += \ armada-3720-db.dtb \ armada-3720-espressobin.dtb \ + armada-3720-espressobin-emmc.dtb \ armada-3720-turris-mox.dtb \ armada-3720-uDPU.dtb \ armada-375-db.dtb \ diff --git a/arch/arm/dts/armada-3720-espressobin-emmc.dts b/arch/arm/dts/armada-3720-espressobin-emmc.dts new file mode 100644 index 0000000000..0dd59af9c0 --- /dev/null +++ b/arch/arm/dts/armada-3720-espressobin-emmc.dts @@ -0,0 +1,19 @@ +// SPDX-License-Identifier: GPL-2.0+ +/* + * Copyright (C) 2018 Marvell International Ltd. + */ + +#include "armada-3720-espressobin.dts" + +/ { + model = "Marvell Armada 3720 Community Board ESPRESSOBin (eMMC)"; + compatible = "marvell,armada-3720-espressobin", + "marvell,armada-3720-espressobin-emmc", + "marvell,armada3720", "marvell,armada3710"; + +}; + +/* U11 */ +&sdhci1 { + status = "okay"; +}; diff --git a/doc/README.marvell b/doc/README.marvell index 5416bc3035..be07f31f8c 100644 --- a/doc/README.marvell +++ b/doc/README.marvell @@ -43,8 +43,11 @@ Build Procedure In order to prevent this, the required device-tree MUST be set during compilation. All device-tree files are located in ./arch/arm/dts/ folder.
- For other DB boards (MacchiatoBin, EspressoBin and 3700 DB board) compile u-boot with - just default device-tree from defconfig using: + For the EspressoBin board with populated eMMC device use + # make DEVICE_TREE=armada-3720-espressobin-emmc + + For other DB boards (MacchiatoBin, EspressoBin without soldered eMMC and 3700 DB board) + compile u-boot with just default device-tree from defconfig using:
# make
Now it looks good for me!
The only missing part is test these changes.
- status = "okay";
# make
-- 2.28.0
Thanks, Stefan
- status = "okay";
# make
Viele Grüße, Stefan
- Device Tree file for Marvell Armada 3720 community board
- (ESPRESSOBin)
@@ -5,53 +6,15 @@
- Gregory CLEMENT gregory.clement@free-electrons.com
- Konstantin Porotchkin kostap@marvell.com
- This file is dual-licensed: you can use it either under the terms
- of the GPL or the X11 license, at your option. Note that this dual
- licensing only applies to this file, and not this project as a
- whole.
- a) This file is free software; you can redistribute it and/or
- Or, alternatively
- b) Permission is hereby granted, free of charge, to any person
conditions:
You are changing license of whole file. Have all contributors and copyright holders agreed with it?
/dts-v1/;
There is no change on these two lines, right?
- non-removable;
- bus-width = <8>;
- mmc-ddr-1_8v;
- mmc-hs400-1_8v;
- marvell,pad-type = "fixed-1-8v";
- pinctrl-names = "default";
- pinctrl-0 = <&mmc_pins>;
- status = "disabled";
- #address-cells = <1>;
- #size-cells = <0>;
- mmccard: mmccard@0 {
reg = <0>;
&spi0 { status = "okay"; pinctrl-names = "default"; -- 2.28.0
- (ESPRESSOBin)
@@ -5,53 +6,15 @@
- whole.
- Or, alternatively
conditions:
These are all downstream changes, I haven't added any additional changes!
/dts-v1/;
Right, just white spaces.
- non-removable;
- bus-width = <8>;
- mmc-ddr-1_8v;
- mmc-hs400-1_8v;
reg = <0>;
- &spi0 { status = "okay"; pinctrl-names = "default";
-- 2.28.0
Hi Andre,
- (ESPRESSOBin)
@@ -5,53 +6,15 @@
- whole.
- Or, alternatively
conditions:
First I though that you have been syncing the file with the Linux kernel version. But now I see that its sync'ed with downstream U-Boot most likely. As for the license of the file: The Linux kernel version has this SPDX tag:
// SPDX-License-Identifier: (GPL-2.0+ OR MIT)
Changing this to this tag would haven been fine (AFAICT). But using a diffent one from a downstream U-Boot repository is a bit troublesome for my taste.
Can't you sync with Linux dts/dtsi files instead at some point?
Thanks, Stefan
/dts-v1/;
- non-removable;
- bus-width = <8>;
- mmc-ddr-1_8v;
- mmc-hs400-1_8v;
reg = <0>;
-- 2.28.0
Viele Grüße, Stefan
Hi Stefan,
On 04/09/2020 14:02, Stefan Roese wrote:
Hi Andre,
- whole.
of the
- Or, alternatively
- * conditions:
at some point, yes. As far as I understand that's not yet possible due to the comphy driver. Quoting Marek's cover letter "[PATCH u-boot-marvell 00/11] Armada 37xx: port comphy to generic-phys (PLEASE TEST)" from 19th April:
I have ported the COMPHY and UTMI PHY drivers from Linux to U-Boot. With this we are able to abandon the current comphy_a3700 driver, which is incompatible with Linux' device trees. So if we want to have DTS files for A3720 boards identical to Linux', we have to do this.
So unfortunately we can't use Linux' dts files for a3700 yet. Marek said he plans to work on that set again in the near future, so hopefully that lands rather sooner than later ;)
Thanks, Andre
Hi Andre,
On 04.09.20 14:35, Andre Heider wrote:
<snip>
Ah, thanks. I remember now. ;)
Can you then please drop the sync with the downstream dts and better only make the necessary changes for eMMC? In a git bisectable way please?
I know that nobody can test this right now. Perhaps Kostya or somebody at Marvell be help out here?
Thanks, Stefan
On 04/09/2020 14:40, Stefan Roese wrote:
Hi Andre,
<snip>
> I have ported the COMPHY and UTMI PHY drivers from Linux to U-Boot. > With this we are able to abandon the current comphy_a3700 driver, which > is incompatible with Linux' device trees. So if we want to have DTS > files for A3720 boards identical to Linux', we have to do this.
Sure, I've just sent v2, completely redone. That also prepares synching from Linux, actually already imports two dts from from there.
Regards, Andre
Hi Andre,
<snip>
So synchronization with Linux DTS files needs to wait until Armada comphy patches are finished and merged into mainline U-Boot.
On Fri, Sep 4, 2020 at 1:35 PM Andre Heider a.heider@gmail.com wrote:
Hi Stefan,
Hi Andre,
- (ESPRESSOBin)
@@ -5,53 +6,15 @@
- whole.
of the
- Or, alternatively
conditions:
The way U-Boot usually deals with this is syncs as much of the Linux ones as possible and if there's bits not in the Linux one that's needed to make/keep U-Boot working they add it in a XXX-u-boot.dtsi file. There's a number of examples in the arch/arm/dts directory.
Hello Peter! The main issue is that U-Boot has different comphy driver as Linux kernel and these two different implementations also needs different DTS files. Marek is working on patches to replace U-Boot comphy driver from Linux and then U-Boot will also use comphy DTS definitions from Linux.
I think it does not make sense to spend time on thinking and implementing how to semi-synchronize DTS files from kernel as after comphy U-Boot driver changes, DTS files would be again changed.
- (ESPRESSOBin)
@@ -5,53 +6,15 @@
- whole.
- Or, alternatively
conditions:
/dts-v1/;
- non-removable;
- bus-width = <8>;
- mmc-ddr-1_8v;
- mmc-hs400-1_8v;
reg = <0>;
Anyway, Andre, have you tested these Marvell's patches on top of U-Boot from master git branch? Because espressobin with eMMC is rather rare (do not know who has this board for testing; do you really have it?) and from my experience with previous patches I know that Marvell's patches does not always work on current upstream U-Boot.
- (ESPRESSOBin)
@@ -5,53 +6,15 @@
- whole.
- Or, alternatively
conditions:
/dts-v1/;
- non-removable;
- bus-width = <8>;
- mmc-ddr-1_8v;
- mmc-hs400-1_8v;
reg = <0>;
I haven't tested it on a espressobin emmc myself, but the node is the same as for arch/arm/dts/armada-3720-db.dts and almost the same as for arch/arm/dts/armada-3720-uDPU.dts.
Thanks, Andre
-- 2.28.0
- non-removable;
- bus-width = <8>;
- mmc-ddr-1_8v;
- mmc-hs400-1_8v;
reg = <0>;
I think changes should be tested prior merged them into upstream. Untested patches can cause other hidden issues.
Also as I wrote, other SD patches for EspressoBin copied+pasted from Marvell's did not worked as is applied on current upstream U-Boot. And also argument that "patch is similar as other node" is not reason to not test changed. As a first thing which I did for SD card support on EspressoBin was that I copied DTS node from Turris MOX... and on EspressoBin it did not worked. On MOX was card working fine.
- non-removable;
- bus-width = <8>;
- mmc-ddr-1_8v;
- mmc-hs400-1_8v;
reg = <0>;
Like an utterly broken u-boot for 2 years due to data aborts? :)
I would test the patches if I had the hardware, but I just don't.
Maybe someone with an espressobin-emmc reads and tests this. And I can try to find users on e.g. the openwrt forums. But I wouldn't hold my breath...
Thanks, Andre
- non-removable;
- bus-width = <8>;
- mmc-ddr-1_8v;
- mmc-hs400-1_8v;
reg = <0>;
Exactly!
Another option could be to solder eMMC on existing non-eMMC EspressoBin board, but this is rather very hard without expensive equipment.
Anyway, if there are no users with hardware I think it does not make sense to try supporting such HW combination.
Thanks, Stefan
- (ESPRESSOBin)
@@ -5,53 +6,15 @@
- whole.
- Or, alternatively
conditions:
/dts-v1/;
- non-removable;
- bus-width = <8>;
- mmc-ddr-1_8v;
- mmc-hs400-1_8v;
reg = <0>;
Viele Grüße, Stefan
Andre Heider
Pali Rohár
Peter Robinson
Stefan Roese
