[U-Boot] [PULL] u-boot-socfpga/master
The following changes since commit 3721208fa7fdb2af6ac13300d5d81433742c6ba1:
x86: Remove Graeme Russ from the git alias file (2015-12-21 09:37:46 -0500)
git://git.denx.de/u-boot-socfpga.git master
for you to fetch changes up to f464a631426a30ffcbf2d7f732e678df1b684be8:
arm: socfpga: Fix USB doesn't work on socdk board (2015-12-23 04:04:46 +0100)
---------------------------------------------------------------- Chin Liang See (24): arm: socfpga: Consolidate SDMMC environment arm: socfpga: cyclone5_socdk: Consolidate SDMMC environment arm: socfpga: arria5_socdk: Consolidate SDMMC environment arm: socfpga: de0_nano_soc: Consolidate SDMMC environment arm: socfpga: mcvevk: Consolidate SDMMC environment arm: socfpga: sockit: Consolidate SDMMC environment arm: socfpga: socrates: Consolidate SDMMC environment arm: socfpga: Enabling MTD default partitions arm: socfpga: Enable ubi and ubifs support arm: socfpga: cyclone5: Undefine CONFIG_SPI_FLASH_USE_4K_SECTORS arm: socfpga: arria5: Undefine CONFIG_SPI_FLASH_USE_4K_SECTORS arm: socfpga: sr1500: Undefine CONFIG_SPI_FLASH_USE_4K_SECTORS arm: socfpga: cyclone5_socdk: Enable ubiload console command arm: socfpga: arria5_socdk: Enable ubiload console command arm: socfpga: sockit: Enable ubiload console command arm: socfpga: sr1500: Enable ubiload console command arm: socfpga: cyclone5_socdk: Enable qspiload console command arm: socfpga: arria5_socdk: Enable qspiload console command arm: socfpga: sockit: Enable qspiload console command arm: socfpga: sr1500: Enable qspiload console command arm: socfpga: cyclone5_socdk: Update qspiboot to use UBIFS arm: socfpga: arria5_socdk: Update qspiboot to use UBIFS arm: socfpga: sockit: Update qspiboot to use UBIFS arm: socfpga: sr1500: Update qspiboot to use UBIFS
Marek Vasut (11): arm: socfpga: Actually enable L2 cache net: designware: Zap CONFIG_DW_AUTONEG net: designware: Zap trailing backslash arm: socfpga: Make /soc available in pre-reloc arm: socfpga: Enable simple bus in SPL on all boards arm: socfpga: Define NAND reset bit arm: socfpga: Unreset NAND in SPL arm: socfpga: Unreset NAND in U-Boot arm: socfpga: Enable SPL MMC/SPI support only if DM_MMC/SPI is enabled arm: socfpga: Enable DFU MMC support only if DM_MMC is enabled arm: socfpga: Add support for Denali NAND controller
Thomas Chou (1): net: eth_designware: select PHYLIB in Kconfig
shengjiangwu (3): arm: socfpga: Fix emac1 doesn't work on socdk board arm: socfpga: Fix QSPI doesn't work on socdk board arm: socfpga: Fix USB doesn't work on socdk board
arch/arm/dts/socfpga_cyclone5_socdk.dts | 4 ++++ arch/arm/mach-socfpga/include/mach/reset_manager.h | 3 ++- arch/arm/mach-socfpga/misc.c | 17 +++++++++++++++-- arch/arm/mach-socfpga/spl.c | 1 + board/altera/cyclone5-socdk/qts/pinmux_config.h | 64 ++++++++++++++++++++++++++++++++-------------------------------- board/altera/cyclone5-socdk/qts/pll_config.h | 4 ++-- board/spear/spear600/spear600.c | 3 --- configs/socfpga_arria5_defconfig | 2 ++ configs/socfpga_cyclone5_defconfig | 2 ++ configs/socfpga_sr1500_defconfig | 1 + drivers/net/Kconfig | 1 + drivers/net/designware.c | 18 +++++++----------- include/configs/axs101.h | 6 ------ include/configs/bf609-ezkit.h | 1 - include/configs/galileo.h | 1 - include/configs/socfpga_arria5_socdk.h | 12 ++++++------ include/configs/socfpga_common.h | 69 +++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++-- include/configs/socfpga_cyclone5_socdk.h | 12 ++++++------ include/configs/socfpga_de0_nano_soc.h | 2 -- include/configs/socfpga_mcvevk.h | 2 -- include/configs/socfpga_sockit.h | 9 +++++++-- include/configs/socfpga_socrates.h | 2 -- include/configs/socfpga_sr1500.h | 10 ++++++---- include/configs/spear-common.h | 1 - include/configs/stv0991.h | 1 - include/configs/sunxi-common.h | 2 -- include/configs/tb100.h | 1 - include/configs/x600.h | 1 - 28 files changed, 161 insertions(+), 91 deletions(-)
I had to add one more patch, so below is an updated one:
for you to fetch changes up to e662573822d24dcdc079d29ff397cb8bacf97b27:
arm: socfpga: Fix i2c mux on cyclone5-socdk board (2015-12-23 16:11:49 +0100)
---------------------------------------------------------------- Chin Liang See (25): arm: socfpga: Consolidate SDMMC environment arm: socfpga: cyclone5_socdk: Consolidate SDMMC environment arm: socfpga: arria5_socdk: Consolidate SDMMC environment arm: socfpga: de0_nano_soc: Consolidate SDMMC environment arm: socfpga: mcvevk: Consolidate SDMMC environment arm: socfpga: sockit: Consolidate SDMMC environment arm: socfpga: socrates: Consolidate SDMMC environment arm: socfpga: Enabling MTD default partitions arm: socfpga: Enable ubi and ubifs support arm: socfpga: cyclone5: Undefine CONFIG_SPI_FLASH_USE_4K_SECTORS arm: socfpga: arria5: Undefine CONFIG_SPI_FLASH_USE_4K_SECTORS arm: socfpga: sr1500: Undefine CONFIG_SPI_FLASH_USE_4K_SECTORS arm: socfpga: cyclone5_socdk: Enable ubiload console command arm: socfpga: arria5_socdk: Enable ubiload console command arm: socfpga: sockit: Enable ubiload console command arm: socfpga: sr1500: Enable ubiload console command arm: socfpga: cyclone5_socdk: Enable qspiload console command arm: socfpga: arria5_socdk: Enable qspiload console command arm: socfpga: sockit: Enable qspiload console command arm: socfpga: sr1500: Enable qspiload console command arm: socfpga: cyclone5_socdk: Update qspiboot to use UBIFS arm: socfpga: arria5_socdk: Update qspiboot to use UBIFS arm: socfpga: sockit: Update qspiboot to use UBIFS arm: socfpga: sr1500: Update qspiboot to use UBIFS arm: socfpga: Fix i2c mux on cyclone5-socdk board
arch/arm/dts/socfpga_cyclone5_socdk.dts | 4 ++++ arch/arm/mach-socfpga/include/mach/reset_manager.h | 3 ++- arch/arm/mach-socfpga/misc.c | 17 +++++++++++++++-- arch/arm/mach-socfpga/spl.c | 1 + board/altera/cyclone5-socdk/qts/pinmux_config.h | 68 ++++++++++++++++++++++++++++++++++---------------------------------- board/altera/cyclone5-socdk/qts/pll_config.h | 4 ++-- board/spear/spear600/spear600.c | 3 --- configs/socfpga_arria5_defconfig | 2 ++ configs/socfpga_cyclone5_defconfig | 2 ++ configs/socfpga_sr1500_defconfig | 1 + drivers/net/Kconfig | 1 + drivers/net/designware.c | 18 +++++++----------- include/configs/axs101.h | 6 ------ include/configs/bf609-ezkit.h | 1 - include/configs/galileo.h | 1 - include/configs/socfpga_arria5_socdk.h | 12 ++++++------ include/configs/socfpga_common.h | 69 +++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++-- include/configs/socfpga_cyclone5_socdk.h | 12 ++++++------ include/configs/socfpga_de0_nano_soc.h | 2 -- include/configs/socfpga_mcvevk.h | 2 -- include/configs/socfpga_sockit.h | 9 +++++++-- include/configs/socfpga_socrates.h | 2 -- include/configs/socfpga_sr1500.h | 10 ++++++---- include/configs/spear-common.h | 1 - include/configs/stv0991.h | 1 - include/configs/sunxi-common.h | 2 -- include/configs/tb100.h | 1 - include/configs/x600.h | 1 - 28 files changed, 163 insertions(+), 93 deletions(-)
