[U-Boot] [PATCH] common: Remove invalid endianess conversion
do_bootm_standanlone() calls ntohl(images->ep) which is obviously wrong (find . -name '*.c' | xargs grep -n -- 'images->ep'). Without this conversion the code works correctly at least on ARM9. Addtionally "appl" must not be dereferenced with the "*" operator.
Signed-off-by: Christian Eggers ceggers@gmx.de --- common/cmd_bootm.c | 4 ++-- 1 file changed, 2 insertions(+), 2 deletions(-)
diff --git a/common/cmd_bootm.c b/common/cmd_bootm.c index a59ee95..c507e1d 100644 --- a/common/cmd_bootm.c +++ b/common/cmd_bootm.c @@ -514,8 +514,8 @@ static int do_bootm_standalone(int flag, int argc, char * const argv[], setenv_hex("filesize", images->os.image_len); return 0; } - appl = (int (*)(int, char * const []))(ulong)ntohl(images->ep); - (*appl)(argc, argv); + appl = (int (*)(int, char * const []))images->ep; + (appl)(argc, argv); return 0; }
Dear Christian Eggers,
What makes you so sure that this is "obvious" ? I think the image header is actually supposed to be in network byte order...
- appl = (int (*)(int, char * const []))images->ep;
- (appl)(argc, argv);
You are also making another change here - which looks as obscure to me as the first one.
Can you please provide a test case which is fixed by your modification?
Christian Eggers
