[U-Boot] [PATCH] mx31pdk: Remove board config.mk file
config.mk files should not be used in board level directory.
Remove this file and also use CONFIG_SYS_TEXT_BASE_SPL, which is the correct base address for the SPL case.
Signed-off-by: Fabio Estevam fabio.estevam@freescale.com --- board/freescale/mx31pdk/config.mk | 5 ----- nand_spl/board/freescale/mx31pdk/Makefile | 3 ++- 2 files changed, 2 insertions(+), 6 deletions(-) delete mode 100644 board/freescale/mx31pdk/config.mk
diff --git a/board/freescale/mx31pdk/config.mk b/board/freescale/mx31pdk/config.mk deleted file mode 100644 index de2c642..0000000 --- a/board/freescale/mx31pdk/config.mk +++ /dev/null @@ -1,5 +0,0 @@ -ifdef CONFIG_NAND_SPL -CONFIG_SYS_TEXT_BASE = 0x87ec0000 -else -CONFIG_SYS_TEXT_BASE = 0x87f00000 -endif diff --git a/nand_spl/board/freescale/mx31pdk/Makefile b/nand_spl/board/freescale/mx31pdk/Makefile index e6ec10a..a5dc0ce 100644 --- a/nand_spl/board/freescale/mx31pdk/Makefile +++ b/nand_spl/board/freescale/mx31pdk/Makefile @@ -1,4 +1,5 @@ CONFIG_NAND_SPL = y +CONFIG_SYS_TEXT_BASE_SPL := 0x87ec0000
include $(TOPDIR)/config.mk include $(TOPDIR)/nand_spl/board/$(BOARDDIR)/config.mk @@ -6,7 +7,7 @@ include $(TOPDIR)/nand_spl/board/$(BOARDDIR)/config.mk nandobj := $(OBJTREE)/nand_spl/
LDSCRIPT= $(TOPDIR)/nand_spl/board/$(BOARDDIR)/u-boot.lds -LDFLAGS := -T $(nandobj)u-boot.lds -Ttext $(CONFIG_SYS_TEXT_BASE) $(LDFLAGS) \ +LDFLAGS := -T $(nandobj)u-boot.lds -Ttext $(CONFIG_SYS_TEXT_BASE_SPL) $(LDFLAGS) \ $(LDFLAGS_FINAL) AFLAGS += -DCONFIG_SPL_BUILD -DCONFIG_NAND_SPL CFLAGS += -DCONFIG_SPL_BUILD -DCONFIG_NAND_SPL
Hi Fabio,
It sounds good. I'll wait only a couple of days for comments, then I will merge into u-boot-imx.
Acked-by: Stefano Babic sbabic@denx.de
Best regards, Stefano Babic
Hi Stefano,
On Fri, Sep 9, 2011 at 1:04 PM, Stefano Babic sbabic@denx.de wrote: ...
Please wait until I address Scott's suggestion.
Thanks,
Fabio Estevam
Any reason not to define this in the board config header?
-Scott
Fabio Estevam
Fabio Estevam
Scott Wood
Stefano Babic
