[PATCH] arm64: zynqmp: Fix r5 mode for cpu release command
The cpu release command for r5 mode (lockstep/split) argument accepts only string. But the zynqmp tcminit command accepts string or number for r5 mode (lockstep/split or 0/1) argument. To fix the r5 mode argument, the common argument (lockstep/split or 0/1) is used across different u-boot commands. Use the strcmp() instead of strncmp() to make uniform the r5 mode (lockstep/split or 0/1) for the zynqmp tcminit and cpu release command.
Signed-off-by: Padmarao Begari padmarao.begari@amd.com --- arch/arm/mach-zynqmp/mp.c | 4 ++-- 1 file changed, 2 insertions(+), 2 deletions(-)
diff --git a/arch/arm/mach-zynqmp/mp.c b/arch/arm/mach-zynqmp/mp.c index 6e6da8008f..448bc53286 100644 --- a/arch/arm/mach-zynqmp/mp.c +++ b/arch/arm/mach-zynqmp/mp.c @@ -352,7 +352,7 @@ int cpu_release(u32 nr, int argc, char *const argv[]) */ flush_dcache_all();
- if (!strncmp(argv[1], "lockstep", 8)) { + if (!strcmp(argv[1], "lockstep") || !strcmp(argv[1], "0")) { if (nr != ZYNQMP_CORE_RPU0) { printf("Lockstep mode should run on ZYNQMP_CORE_RPU0\n"); return 1; @@ -369,7 +369,7 @@ int cpu_release(u32 nr, int argc, char *const argv[]) dcache_enable(); set_r5_halt_mode(nr, RELEASE, LOCK); mark_r5_used(nr, LOCK); - } else if (!strncmp(argv[1], "split", 5)) { + } else if (!strcmp(argv[1], "split") || !strcmp(argv[1], "1")) { printf("R5 split mode\n"); set_r5_reset(nr, SPLIT); set_r5_tcm_mode(SPLIT);
Applied. M
Michal Simek
Padmarao Begari
