[U-Boot] [PATCH 1/2] NAND: show manufacturer and device ID for unknown chips
When the NAND part is not supported, it is useful to show the manufacturer and device ID to help debugging and reporting.
Signed-off-by: Florian Fainelli f.fainelli@gmail.com --- diff --git a/drivers/mtd/nand/nand_base.c b/drivers/mtd/nand/nand_base.c index 7171bdd..c1657de 100644 --- a/drivers/mtd/nand/nand_base.c +++ b/drivers/mtd/nand/nand_base.c @@ -2652,8 +2652,12 @@ static struct nand_flash_dev *nand_get_flash_type(struct mtd_info *mtd, } }
- if (!type) + if (!type) { + printk(KERN_INFO "%s: unknown NAND device: Manufacturer ID :" + " 0x%02x, Chip ID: 0x%02x\n", __func__, + *maf_id, dev_id); return ERR_PTR(-ENODEV); + }
if (!mtd->name) mtd->name = type->name;
Scott, anything from with the patch? Thanks!
- if (!type)
if (!type) {
*maf_id, dev_id);
I just got back from vacation, but the patches look reasonable.
- if (!type)
- if (!type) {
I'd leave out the space before the colon ("foo: bar", not "foo : bar"), though. I think that may be a regional style issue, but let's stick with what the rest of the code does.
-Scott
Florian Fainelli
Florian Fainelli
Scott Wood
