[U-Boot] [PATCH] spl: spl_mmc: fix mmc Falcon mode regression
91199f4a5a21a7cf9dd9e7c05e295a042f8c2b7e broke mmc based Falcon mode.
The block_read function returns the number of blocks read thus the error check needs to look for a return of 0 blocks read.
Cc: Paul Kocialkowski contact@paulk.fr Signed-off-by: Tim Harvey tharvey@gateworks.com --- common/spl/spl_mmc.c | 2 +- 1 file changed, 1 insertion(+), 1 deletion(-)
diff --git a/common/spl/spl_mmc.c b/common/spl/spl_mmc.c index 5d688d6..c96345e 100644 --- a/common/spl/spl_mmc.c +++ b/common/spl/spl_mmc.c @@ -76,7 +76,7 @@ static int mmc_load_image_raw_os(struct mmc *mmc) CONFIG_SYS_MMCSD_RAW_MODE_ARGS_SECTOR, CONFIG_SYS_MMCSD_RAW_MODE_ARGS_SECTORS, (void *)CONFIG_SYS_SPL_ARGS_ADDR); - if (err) { + if (err == 0) { #ifdef CONFIG_SPL_LIBCOMMON_SUPPORT printf("spl: mmc block read error\n"); #endif
Damn, it seems that I messed up return code checks. My sincerest apologies for that.
I will check for other potential mistakes introduced by that commit.
Acked-by: Paul Kocialkowski contact@paulk.fr
- if (err) {
- if (err == 0) {
- if (err) {
- if (err == 0) {
Applied to u-boot-imx, thanks!
Best regards, Stefano Babic
Paul Kocialkowski
Stefano Babic
Tim Harvey
