[U-Boot] [PATCH v2 0/3] Enable DM support for USB in LS2080
Add the device tree support for LS2080RDB nand boot. Enable the CONFIG_DM_USB in defconfigs and add the usb node in dts for LS2080.
Sriram Dash (3): armv8: LS2080A: Add device tree support for nand boot armv8: ls2080: Enable CONFIG_DM_USB in defconfigs armv8: ls2080: Add USB node in dts for ls2080
arch/arm/dts/fsl-ls2080a.dtsi | 14 ++++++++++++++ configs/ls2080aqds_SECURE_BOOT_defconfig | 1 + configs/ls2080aqds_defconfig | 1 + configs/ls2080aqds_nand_defconfig | 1 + configs/ls2080aqds_qspi_defconfig | 1 + configs/ls2080ardb_SECURE_BOOT_defconfig | 1 + configs/ls2080ardb_defconfig | 1 + configs/ls2080ardb_nand_defconfig | 4 ++++ 8 files changed, 24 insertions(+)
Add device tree support for LS2080ARDB nand boot.
Signed-off-by: Sriram Dash sriram.dash@nxp.com --- configs/ls2080ardb_nand_defconfig | 2 ++ 1 file changed, 2 insertions(+)
diff --git a/configs/ls2080ardb_nand_defconfig b/configs/ls2080ardb_nand_defconfig index 551f158..7183d76 100644 --- a/configs/ls2080ardb_nand_defconfig +++ b/configs/ls2080ardb_nand_defconfig @@ -1,5 +1,6 @@ CONFIG_ARM=y CONFIG_TARGET_LS2080ARDB=y +CONFIG_DEFAULT_DEVICE_TREE="fsl-ls2080a-rdb" CONFIG_SPL_LIBCOMMON_SUPPORT=y CONFIG_SPL_LIBGENERIC_SUPPORT=y CONFIG_SPL_I2C_SUPPORT=y @@ -27,6 +28,7 @@ CONFIG_CMD_PING=y CONFIG_CMD_CACHE=y CONFIG_CMD_EXT2=y CONFIG_CMD_FAT=y +CONFIG_OF_CONTROL=y CONFIG_NET_RANDOM_ETHADDR=y CONFIG_NETDEVICES=y CONFIG_E1000=y
This set is applied to fsl-qoriq master, awaiting upstream. Thanks.
York
Enables driver model flag CONFIG_DM_USB for LS2080A platform defconfigs.
Signed-off-by: Sriram Dash sriram.dash@nxp.com --- Changes in v2 - Rebase
configs/ls2080aqds_SECURE_BOOT_defconfig | 1 + configs/ls2080aqds_defconfig | 1 + configs/ls2080aqds_nand_defconfig | 1 + configs/ls2080aqds_qspi_defconfig | 1 + configs/ls2080ardb_SECURE_BOOT_defconfig | 1 + configs/ls2080ardb_defconfig | 1 + configs/ls2080ardb_nand_defconfig | 2 ++ 7 files changed, 8 insertions(+)
diff --git a/configs/ls2080aqds_SECURE_BOOT_defconfig b/configs/ls2080aqds_SECURE_BOOT_defconfig index 6a434c0..31e69b4 100644 --- a/configs/ls2080aqds_SECURE_BOOT_defconfig +++ b/configs/ls2080aqds_SECURE_BOOT_defconfig @@ -33,6 +33,7 @@ CONFIG_FSL_DSPI=y CONFIG_USB=y CONFIG_USB_XHCI_HCD=y CONFIG_USB_XHCI_DWC3=y +CONFIG_DM_USB=y CONFIG_USB_STORAGE=y CONFIG_RSA=y CONFIG_SPL_RSA=y diff --git a/configs/ls2080aqds_defconfig b/configs/ls2080aqds_defconfig index 53d5774..af52818 100644 --- a/configs/ls2080aqds_defconfig +++ b/configs/ls2080aqds_defconfig @@ -33,5 +33,6 @@ CONFIG_FSL_DSPI=y CONFIG_USB=y CONFIG_USB_XHCI_HCD=y CONFIG_USB_XHCI_DWC3=y +CONFIG_DM_USB=y CONFIG_USB_STORAGE=y CONFIG_EFI_LOADER_BOUNCE_BUFFER=y diff --git a/configs/ls2080aqds_nand_defconfig b/configs/ls2080aqds_nand_defconfig index 8eb4121..f09809d 100644 --- a/configs/ls2080aqds_nand_defconfig +++ b/configs/ls2080aqds_nand_defconfig @@ -42,5 +42,6 @@ CONFIG_FSL_QSPI=y CONFIG_USB=y CONFIG_USB_XHCI_HCD=y CONFIG_USB_XHCI_DWC3=y +CONFIG_DM_USB=y CONFIG_USB_STORAGE=y CONFIG_EFI_LOADER_BOUNCE_BUFFER=y diff --git a/configs/ls2080aqds_qspi_defconfig b/configs/ls2080aqds_qspi_defconfig index 5917f60..2b24a94 100644 --- a/configs/ls2080aqds_qspi_defconfig +++ b/configs/ls2080aqds_qspi_defconfig @@ -34,5 +34,6 @@ CONFIG_FSL_QSPI=y CONFIG_USB=y CONFIG_USB_XHCI_HCD=y CONFIG_USB_XHCI_DWC3=y +CONFIG_DM_USB=y CONFIG_USB_STORAGE=y CONFIG_EFI_LOADER_BOUNCE_BUFFER=y diff --git a/configs/ls2080ardb_SECURE_BOOT_defconfig b/configs/ls2080ardb_SECURE_BOOT_defconfig index 932a4bd..a62d864 100644 --- a/configs/ls2080ardb_SECURE_BOOT_defconfig +++ b/configs/ls2080ardb_SECURE_BOOT_defconfig @@ -33,6 +33,7 @@ CONFIG_FSL_DSPI=y CONFIG_USB=y CONFIG_USB_XHCI_HCD=y CONFIG_USB_XHCI_DWC3=y +CONFIG_DM_USB=y CONFIG_USB_STORAGE=y CONFIG_RSA=y CONFIG_SPL_RSA=y diff --git a/configs/ls2080ardb_defconfig b/configs/ls2080ardb_defconfig index c477961..bbf2a74 100644 --- a/configs/ls2080ardb_defconfig +++ b/configs/ls2080ardb_defconfig @@ -33,5 +33,6 @@ CONFIG_FSL_DSPI=y CONFIG_USB=y CONFIG_USB_XHCI_HCD=y CONFIG_USB_XHCI_DWC3=y +CONFIG_DM_USB=y CONFIG_USB_STORAGE=y CONFIG_EFI_LOADER_BOUNCE_BUFFER=y diff --git a/configs/ls2080ardb_nand_defconfig b/configs/ls2080ardb_nand_defconfig index 7183d76..98a00e2 100644 --- a/configs/ls2080ardb_nand_defconfig +++ b/configs/ls2080ardb_nand_defconfig @@ -33,9 +33,11 @@ CONFIG_NET_RANDOM_ETHADDR=y CONFIG_NETDEVICES=y CONFIG_E1000=y CONFIG_SYS_NS16550=y +CONFIG_DM=y CONFIG_USB=y CONFIG_USB_XHCI_HCD=y CONFIG_USB_XHCI_DWC3=y +CONFIG_DM_USB=y CONFIG_USB_STORAGE=y CONFIG_OF_LIBFDT=y CONFIG_EFI_LOADER_BOUNCE_BUFFER=y
Add the USB node for LS2080 in dts.
Signed-off-by: Sriram Dash sriram.dash@nxp.com --- Changes in v2 - No change
arch/arm/dts/fsl-ls2080a.dtsi | 14 ++++++++++++++ 1 file changed, 14 insertions(+)
diff --git a/arch/arm/dts/fsl-ls2080a.dtsi b/arch/arm/dts/fsl-ls2080a.dtsi index b308c8b..f76e981 100644 --- a/arch/arm/dts/fsl-ls2080a.dtsi +++ b/arch/arm/dts/fsl-ls2080a.dtsi @@ -75,4 +75,18 @@ reg-names = "QuadSPI", "QuadSPI-memory"; num-cs = <4>; }; + + usb0: usb3@3100000 { + compatible = "fsl,layerscape-dwc3"; + reg = <0x0 0x3100000 0x0 0x10000>; + interrupts = <0 80 0x4>; /* Level high type */ + dr_mode = "host"; + }; + + usb1: usb3@3110000 { + compatible = "fsl,layerscape-dwc3"; + reg = <0x0 0x3110000 0x0 0x10000>; + interrupts = <0 81 0x4>; /* Level high type */ + dr_mode = "host"; + }; };
Sriram Dash
york sun
