[U-Boot] [RFC 0/6] Convert mxsfb to DM_VIDEO
This series of patches refactors and extends NXP mxsfb video driver to be build with DM_VIDEO enabled. DTS files must additionally include 'u-boot,dm-pre-reloc' property in soc and child nodes to enable driver binding to mxsfb device.
Also enables DM_VIDEO by default for Colibri iMX7 eMMC edition.
Igor Opaniuk (6): video: mxsfb: change mxs_lcd_init signature video: mxsfb: reorder includes video: mxsfb: refactor video_hw_init() video: mxsfb: add DM_VIDEO support ARM: dts: colibri_imx7: Add lcdif node colibri_imx7_emmc: enable DM_VIDEO
arch/arm/dts/imx7-colibri-emmc.dts | 2 + arch/arm/dts/imx7-colibri.dtsi | 28 ++++ arch/arm/mach-imx/cpu.c | 2 +- arch/arm/mach-imx/mx7/soc.c | 2 +- configs/colibri_imx7_emmc_defconfig | 2 +- drivers/video/mxsfb.c | 219 +++++++++++++++++++++++----- include/configs/colibri_imx7.h | 2 +- 7 files changed, 213 insertions(+), 44 deletions(-)
Provide directly framebuffer address instead of pointer to GraphicDevice struct, which will let to re-use this function in DM_VIDEO configurations.
Signed-off-by: Igor Opaniuk igor.opaniuk@toradex.com --- drivers/video/mxsfb.c | 9 ++++----- 1 file changed, 4 insertions(+), 5 deletions(-)
diff --git a/drivers/video/mxsfb.c b/drivers/video/mxsfb.c index 02fde05908..0f3a10b0f6 100644 --- a/drivers/video/mxsfb.c +++ b/drivers/video/mxsfb.c @@ -46,8 +46,7 @@ __weak void mxsfb_system_setup(void) * le:89,ri:164,up:23,lo:10,hs:10,vs:10,sync:0,vmode:0 */
-static void mxs_lcd_init(GraphicDevice *panel, - struct ctfb_res_modes *mode, int bpp) +static void mxs_lcd_init(u32 fb_addr, struct ctfb_res_modes *mode, int bpp) { struct mxs_lcdif_regs *regs = (struct mxs_lcdif_regs *)MXS_LCDIF_BASE; uint32_t word_len = 0, bus_width = 0; @@ -112,8 +111,8 @@ static void mxs_lcd_init(GraphicDevice *panel, writel((0 << LCDIF_VDCTRL4_DOTCLK_DLY_SEL_OFFSET) | mode->xres, ®s->hw_lcdif_vdctrl4);
- writel(panel->frameAdrs, ®s->hw_lcdif_cur_buf); - writel(panel->frameAdrs, ®s->hw_lcdif_next_buf); + writel(fb_addr, ®s->hw_lcdif_cur_buf); + writel(fb_addr, ®s->hw_lcdif_next_buf);
/* Flush FIFO first */ writel(LCDIF_CTRL1_FIFO_CLEAR, ®s->hw_lcdif_ctrl1_set); @@ -214,7 +213,7 @@ void *video_hw_init(void) printf("%s\n", panel.modeIdent);
/* Start framebuffer */ - mxs_lcd_init(&panel, &mode, bpp); + mxs_lcd_init(panel.frameAdrs, &mode, bpp);
#ifdef CONFIG_VIDEO_MXS_MODE_SYSTEM /*
Follow alphabetical order of includes, which simplifies detecting duplicate includes etc.
Signed-off-by: Igor Opaniuk igor.opaniuk@toradex.com --- drivers/video/mxsfb.c | 7 +++---- 1 file changed, 3 insertions(+), 4 deletions(-)
diff --git a/drivers/video/mxsfb.c b/drivers/video/mxsfb.c index 0f3a10b0f6..059fbf2b05 100644 --- a/drivers/video/mxsfb.c +++ b/drivers/video/mxsfb.c @@ -5,16 +5,15 @@ * Copyright (C) 2011-2013 Marek Vasut marex@denx.de */ #include <common.h> +#include <linux/errno.h> #include <malloc.h> #include <video_fb.h>
-#include <asm/arch/imx-regs.h> #include <asm/arch/clock.h> +#include <asm/arch/imx-regs.h> #include <asm/arch/sys_proto.h> -#include <linux/errno.h> -#include <asm/io.h> - #include <asm/mach-imx/dma.h> +#include <asm/io.h>
#include "videomodes.h"
Refactor video_hw_init() function, and introduce an independent function for the common procedure of initialization.
Currently video_hw_init() is only in charge of parsing configuration from env("videomode") and filling struct GraphicPanel, and new mxs_probe_common() does hw specific initialization (invocation of mxs_lcd_init() etc.)
Signed-off-by: Igor Opaniuk igor.opaniuk@toradex.com --- drivers/video/mxsfb.c | 68 ++++++++++++++++++++++++++----------------- 1 file changed, 41 insertions(+), 27 deletions(-)
diff --git a/drivers/video/mxsfb.c b/drivers/video/mxsfb.c index 059fbf2b05..6e269409d6 100644 --- a/drivers/video/mxsfb.c +++ b/drivers/video/mxsfb.c @@ -128,6 +128,37 @@ static void mxs_lcd_init(u32 fb_addr, struct ctfb_res_modes *mode, int bpp) writel(LCDIF_CTRL_RUN, ®s->hw_lcdif_ctrl_set); }
+static int mxs_probe_common(struct ctfb_res_modes *mode, int bpp, void *fb) +{ + /* Start framebuffer */ + mxs_lcd_init((u32)fb, mode, bpp); + +#ifdef CONFIG_VIDEO_MXS_MODE_SYSTEM + /* + * If the LCD runs in system mode, the LCD refresh has to be triggered + * manually by setting the RUN bit in HW_LCDIF_CTRL register. To avoid + * having to set this bit manually after every single change in the + * framebuffer memory, we set up specially crafted circular DMA, which + * sets the RUN bit, then waits until it gets cleared and repeats this + * infinitelly. This way, we get smooth continuous updates of the LCD. + */ + struct mxs_lcdif_regs *regs = (struct mxs_lcdif_regs *)MXS_LCDIF_BASE; + + memset(&desc, 0, sizeof(struct mxs_dma_desc)); + desc.address = (dma_addr_t)&desc; + desc.cmd.data = MXS_DMA_DESC_COMMAND_NO_DMAXFER | MXS_DMA_DESC_CHAIN | + MXS_DMA_DESC_WAIT4END | + (1 << MXS_DMA_DESC_PIO_WORDS_OFFSET); + desc.cmd.pio_words[0] = readl(®s->hw_lcdif_ctrl) | LCDIF_CTRL_RUN; + desc.cmd.next = (uint32_t)&desc.cmd; + + /* Execute the DMA chain. */ + mxs_dma_circ_start(MXS_DMA_CHANNEL_AHB_APBH_LCDIF, &desc); +#endif + + return 0; +} + void lcdif_power_down(void) { struct mxs_lcdif_regs *regs = (struct mxs_lcdif_regs *)MXS_LCDIF_BASE; @@ -151,8 +182,9 @@ void lcdif_power_down(void) void *video_hw_init(void) { int bpp = -1; + int ret = 0; char *penv; - void *fb; + void *fb = NULL; struct ctfb_res_modes mode;
puts("Video: "); @@ -167,8 +199,7 @@ void *video_hw_init(void) bpp = video_get_params(&mode, penv);
/* fill in Graphic device struct */ - sprintf(panel.modeIdent, "%dx%dx%d", - mode.xres, mode.yres, bpp); + sprintf(panel.modeIdent, "%dx%dx%d", mode.xres, mode.yres, bpp);
panel.winSizeX = mode.xres; panel.winSizeY = mode.yres; @@ -211,31 +242,14 @@ void *video_hw_init(void)
- /* Start framebuffer */ - mxs_lcd_init(panel.frameAdrs, &mode, bpp); - -#ifdef CONFIG_VIDEO_MXS_MODE_SYSTEM - /* - * If the LCD runs in system mode, the LCD refresh has to be triggered - * manually by setting the RUN bit in HW_LCDIF_CTRL register. To avoid - * having to set this bit manually after every single change in the - * framebuffer memory, we set up specially crafted circular DMA, which - * sets the RUN bit, then waits until it gets cleared and repeats this - * infinitelly. This way, we get smooth continuous updates of the LCD. - */ - struct mxs_lcdif_regs *regs = (struct mxs_lcdif_regs *)MXS_LCDIF_BASE; + ret = mxs_probe_common(&mode, bpp, fb); + if (ret) + goto dealloc_fb;
- memset(&desc, 0, sizeof(struct mxs_dma_desc)); - desc.address = (dma_addr_t)&desc; - desc.cmd.data = MXS_DMA_DESC_COMMAND_NO_DMAXFER | MXS_DMA_DESC_CHAIN | - MXS_DMA_DESC_WAIT4END | - (1 << MXS_DMA_DESC_PIO_WORDS_OFFSET); - desc.cmd.pio_words[0] = readl(®s->hw_lcdif_ctrl) | LCDIF_CTRL_RUN; - desc.cmd.next = (uint32_t)&desc.cmd; + return (void *)&panel;
- /* Execute the DMA chain. */ - mxs_dma_circ_start(MXS_DMA_CHANNEL_AHB_APBH_LCDIF, &desc); -#endif +dealloc_fb: + free(fb);
- return (void *)&panel; + return NULL; }
Extend the driver to build with DM_VIDEO enabled. DTS files must additionally include 'u-boot,dm-pre-reloc' property in soc and child nodes to enable driver binding to mxsfb device.
Signed-off-by: Igor Opaniuk igor.opaniuk@toradex.com --- arch/arm/mach-imx/cpu.c | 2 +- arch/arm/mach-imx/mx7/soc.c | 2 +- drivers/video/mxsfb.c | 145 +++++++++++++++++++++++++++++++-- include/configs/colibri_imx7.h | 2 +- 4 files changed, 139 insertions(+), 12 deletions(-)
diff --git a/arch/arm/mach-imx/cpu.c b/arch/arm/mach-imx/cpu.c index 6b83f92662..64a0670fcf 100644 --- a/arch/arm/mach-imx/cpu.c +++ b/arch/arm/mach-imx/cpu.c @@ -298,7 +298,7 @@ void arch_preboot_os(void) /* disable video before launching O/S */ ipuv3_fb_shutdown(); #endif -#if defined(CONFIG_VIDEO_MXS) +#if defined(CONFIG_VIDEO_MXS) && !defined(CONFIG_DM_VIDEO) lcdif_power_down(); #endif } diff --git a/arch/arm/mach-imx/mx7/soc.c b/arch/arm/mach-imx/mx7/soc.c index 7cfdff0981..4a914fca5e 100644 --- a/arch/arm/mach-imx/mx7/soc.c +++ b/arch/arm/mach-imx/mx7/soc.c @@ -369,7 +369,7 @@ void s_init(void) void reset_misc(void) { #ifndef CONFIG_SPL_BUILD -#ifdef CONFIG_VIDEO_MXS +#if defined(CONFIG_VIDEO_MXS) && !defined(CONFIG_DM_VIDEO) lcdif_power_down(); #endif #endif diff --git a/drivers/video/mxsfb.c b/drivers/video/mxsfb.c index 6e269409d6..f02ba20138 100644 --- a/drivers/video/mxsfb.c +++ b/drivers/video/mxsfb.c @@ -5,8 +5,10 @@ * Copyright (C) 2011-2013 Marek Vasut marex@denx.de */ #include <common.h> +#include <dm.h> #include <linux/errno.h> #include <malloc.h> +#include <video.h> #include <video_fb.h>
#include <asm/arch/clock.h> @@ -18,8 +20,11 @@ #include "videomodes.h"
#define PS2KHZ(ps) (1000000000UL / (ps)) +#define HZ2PS(hz) (1000000000UL / ((hz) / 1000)) + +#define BITS_PP 18 +#define BYTES_PP 4
-static GraphicDevice panel; struct mxs_dma_desc desc;
/** @@ -128,10 +133,10 @@ static void mxs_lcd_init(u32 fb_addr, struct ctfb_res_modes *mode, int bpp) writel(LCDIF_CTRL_RUN, ®s->hw_lcdif_ctrl_set); }
-static int mxs_probe_common(struct ctfb_res_modes *mode, int bpp, void *fb) +static int mxs_probe_common(struct ctfb_res_modes *mode, int bpp, u32 fb) { /* Start framebuffer */ - mxs_lcd_init((u32)fb, mode, bpp); + mxs_lcd_init(fb, mode, bpp);
#ifdef CONFIG_VIDEO_MXS_MODE_SYSTEM /* @@ -159,16 +164,16 @@ static int mxs_probe_common(struct ctfb_res_modes *mode, int bpp, void *fb) return 0; }
-void lcdif_power_down(void) +static int mxs_remove_common(u32 fb) { struct mxs_lcdif_regs *regs = (struct mxs_lcdif_regs *)MXS_LCDIF_BASE; int timeout = 1000000;
- if (!panel.frameAdrs) - return; + if (!fb) + return -EINVAL;
- writel(panel.frameAdrs, ®s->hw_lcdif_cur_buf_reg); - writel(panel.frameAdrs, ®s->hw_lcdif_next_buf_reg); + writel(fb, ®s->hw_lcdif_cur_buf_reg); + writel(fb, ®s->hw_lcdif_next_buf_reg); writel(LCDIF_CTRL1_VSYNC_EDGE_IRQ, ®s->hw_lcdif_ctrl1_clr); while (--timeout) { if (readl(®s->hw_lcdif_ctrl1_reg) & @@ -177,6 +182,17 @@ void lcdif_power_down(void) udelay(1); } mxs_reset_block((struct mxs_register_32 *)®s->hw_lcdif_ctrl_reg); + + return 0; +} + +#ifndef CONFIG_DM_VIDEO + +static GraphicDevice panel; + +void lcdif_power_down(void) +{ + mxs_remove_common(panel.frameAdrs); }
void *video_hw_init(void) @@ -242,7 +258,7 @@ void *video_hw_init(void)
- ret = mxs_probe_common(&mode, bpp, fb); + ret = mxs_probe_common(&mode, bpp, (u32)fb); if (ret) goto dealloc_fb;
@@ -253,3 +269,114 @@ dealloc_fb:
return NULL; } +#else /* ifndef CONFIG_DM_VIDEO */ + +static int mxs_video_probe(struct udevice *dev) +{ + struct video_uc_platdata *plat = dev_get_uclass_platdata(dev); + struct video_priv *uc_priv = dev_get_uclass_priv(dev); + + struct ctfb_res_modes mode; + struct display_timing timings; + int bpp = -1; + u32 fb_start, fb_end; + int ret; + + debug("%s() plat: base 0x%lx, size 0x%x\n", + __func__, plat->base, plat->size); + + ret = ofnode_decode_display_timing(dev_ofnode(dev), 0, &timings); + if (ret) { + dev_err(dev, "failed to get any display timings\n"); + return -EINVAL; + } + + mode.xres = timings.hactive.typ; + mode.yres = timings.vactive.typ; + mode.left_margin = timings.hback_porch.typ; + mode.right_margin = timings.hfront_porch.typ; + mode.upper_margin = timings.vback_porch.typ; + mode.lower_margin = timings.vfront_porch.typ; + mode.hsync_len = timings.hsync_len.typ; + mode.vsync_len = timings.vsync_len.typ; + mode.pixclock = HZ2PS(timings.pixelclock.typ); + + bpp = BITS_PP; + + ret = mxs_probe_common(&mode, bpp, plat->base); + if (ret) + return ret; + + switch (bpp) { + case 24: + case 18: + uc_priv->bpix = VIDEO_BPP32; + break; + case 16: + uc_priv->bpix = VIDEO_BPP16; + break; + case 8: + uc_priv->bpix = VIDEO_BPP8; + break; + default: + dev_err(dev, "invalid bpp specified (bpp = %i)\n", bpp); + return -EINVAL; + } + + uc_priv->xsize = mode.xres; + uc_priv->ysize = mode.yres; + + /* Enable dcache for the frame buffer */ + fb_start = plat->base & ~(MMU_SECTION_SIZE - 1); + fb_end = plat->base + plat->size; + fb_end = ALIGN(fb_end, 1 << MMU_SECTION_SHIFT); + mmu_set_region_dcache_behaviour(fb_start, fb_end - fb_start, + DCACHE_WRITEBACK); + video_set_flush_dcache(dev, true); + + return ret; +} + +static int mxs_video_bind(struct udevice *dev) +{ + struct video_uc_platdata *plat = dev_get_uclass_platdata(dev); + struct display_timing timings; + int ret; + + ret = ofnode_decode_display_timing(dev_ofnode(dev), 0, &timings); + if (ret) { + dev_err(dev, "failed to get any display timings\n"); + return -EINVAL; + } + + plat->size = timings.hactive.typ * timings.vactive.typ * BYTES_PP; + + return 0; +} + +static int mxs_video_remove(struct udevice *dev) +{ + struct video_uc_platdata *plat = dev_get_uclass_platdata(dev); + + mxs_remove_common(plat->base); + + return 0; +} + +static const struct udevice_id mxs_video_ids[] = { + { .compatible = "fsl,imx23-lcdif" }, + { .compatible = "fsl,imx28-lcdif" }, + { .compatible = "fsl,imx7ulp-lcdif" }, + { /* sentinel */ } +}; + +U_BOOT_DRIVER(mxs_video) = { + .name = "mxs_video", + .id = UCLASS_VIDEO, + .of_match = mxs_video_ids, + .bind = mxs_video_bind, + .probe = mxs_video_probe, + .remove = mxs_video_remove, + .flags = DM_FLAG_PRE_RELOC, +}; +#endif /* ifndef CONFIG_DM_VIDEO */ diff --git a/include/configs/colibri_imx7.h b/include/configs/colibri_imx7.h index 7dfc92c085..c3b353b2c2 100644 --- a/include/configs/colibri_imx7.h +++ b/include/configs/colibri_imx7.h @@ -225,7 +225,7 @@ #define CONFIG_SYS_DFU_DATA_BUF_SIZE SZ_16M #define DFU_DEFAULT_POLL_TIMEOUT 300
-#ifdef CONFIG_VIDEO +#if defined(CONFIG_VIDEO) || defined(CONFIG_DM_VIDEO) #define CONFIG_VIDEO_MXS #define CONFIG_VIDEO_LOGO #define CONFIG_SPLASH_SCREEN
Extend lcdif DT node with proper display-timings for mxsfb driver.
Signed-off-by: Igor Opaniuk igor.opaniuk@toradex.com --- arch/arm/dts/imx7-colibri-emmc.dts | 2 ++ arch/arm/dts/imx7-colibri.dtsi | 28 ++++++++++++++++++++++++++++ 2 files changed, 30 insertions(+)
diff --git a/arch/arm/dts/imx7-colibri-emmc.dts b/arch/arm/dts/imx7-colibri-emmc.dts index efd600091d..8db2a62707 100644 --- a/arch/arm/dts/imx7-colibri-emmc.dts +++ b/arch/arm/dts/imx7-colibri-emmc.dts @@ -11,8 +11,10 @@ compatible = "toradex,imx7d-colibri-emmc", "fsl,imx7d";
aliases { + u-boot,dm-pre-reloc; mmc0 = &usdhc3; mmc1 = &usdhc1; + display1 = &lcdif; };
chosen { diff --git a/arch/arm/dts/imx7-colibri.dtsi b/arch/arm/dts/imx7-colibri.dtsi index a85702f519..81717c233d 100644 --- a/arch/arm/dts/imx7-colibri.dtsi +++ b/arch/arm/dts/imx7-colibri.dtsi @@ -111,3 +111,31 @@ >; }; }; + +&lcdif { + u-boot,dm-pre-reloc; + status = "okay"; + + display-timings { + native-mode = <&timing_vga>; + + /* Standard VGA timing */ + timing_vga: 640x480 { + u-boot,dm-pre-reloc; + clock-frequency = <25175000>; + hactive = <640>; + vactive = <480>; + hback-porch = <48>; + hfront-porch = <16>; + vback-porch = <33>; + vfront-porch = <10>; + hsync-len = <96>; + vsync-len = <2>; + + de-active = <1>; + hsync-active = <0>; + vsync-active = <0>; + pixelclk-active = <0>; + }; + }; +};
Hi Igor,
On Mon, Jun 3, 2019 at 6:06 PM Igor Opaniuk igor.opaniuk@gmail.com wrote:
+&lcdif {
status = "okay";
display-timings {
hactive = <640>;
vactive = <480>;
hback-porch = <48>;
vback-porch = <33>;
hsync-len = <96>;
vsync-len = <2>;
de-active = <1>;
hsync-active = <0>;
vsync-active = <0>;
This is the deprecated style mxsfb fbdev binding.
In the kernel we no longer use this style as documented in Documentation/devicetree/bindings/display/mxsfb.txt
If we follow this route in U-Boot then we will diverge from the kernel recommended bindings.
Hi Fabio,
On Wed, Jun 5, 2019 at 1:06 AM Fabio Estevam festevam@gmail.com wrote:
Hi Igor,
+&lcdif {
status = "okay";
display-timings {
hactive = <640>;
vactive = <480>;
hback-porch = <48>;
vback-porch = <33>;
hsync-len = <96>;
vsync-len = <2>;
de-active = <1>;
hsync-active = <0>;
vsync-active = <0>;
Initially I copy-pasted the whole DT node "as it is" from the linux kernel dts, but found out that existing DT wrapper for parsing display timings (ofnode_decode_display_timing())) isn't able to parse it properly, so I just changed it to conform the same structure as similar nodes in other DTS files.
Thanks for letting me know, probably ofnode_decode_display_timing() implementation should be adjusted as well.
Regards, Igor
Hi Fabio,
On Wed, Jun 5, 2019 at 4:29 PM Igor Opaniuk igor.opaniuk@gmail.com wrote:
Hi Fabio,
Hi Igor,
+&lcdif {
status = "okay";
display-timings {
hactive = <640>;
vactive = <480>;
hback-porch = <48>;
vback-porch = <33>;
hsync-len = <96>;
vsync-len = <2>;
de-active = <1>;
hsync-active = <0>;
vsync-active = <0>;
Nevermind, I've double-checked ofnode_decode_display_timing() implementation and all instances of display-timings nodes, it definitely should be able parse the same structure as defined in the Linux devicetree bindings.
Probably I just messed up with something.
Regards, Igor
-- Best regards - Freundliche Grüsse - Meilleures salutations
Igor Opaniuk
mailto: igor.opaniuk@gmail.com skype: igor.opanyuk +380 (93) 836 40 67 http://ua.linkedin.com/in/iopaniuk
Enable DM_VIDEO for Colibri iMX7 eMMC version.
Signed-off-by: Igor Opaniuk igor.opaniuk@toradex.com --- configs/colibri_imx7_emmc_defconfig | 2 +- 1 file changed, 1 insertion(+), 1 deletion(-)
diff --git a/configs/colibri_imx7_emmc_defconfig b/configs/colibri_imx7_emmc_defconfig index f35cabaed6..392d4ab8d0 100644 --- a/configs/colibri_imx7_emmc_defconfig +++ b/configs/colibri_imx7_emmc_defconfig @@ -63,6 +63,6 @@ CONFIG_USB_GADGET_VENDOR_NUM=0x1b67 CONFIG_USB_GADGET_PRODUCT_NUM=0x4000 CONFIG_CI_UDC=y CONFIG_USB_GADGET_DOWNLOAD=y -CONFIG_VIDEO=y +CONFIG_DM_VIDEO=y CONFIG_FAT_WRITE=y CONFIG_OF_LIBFDT_OVERLAY=y
On Tue, 4 Jun 2019 00:05:55 +0300 Igor Opaniuk igor.opaniuk@gmail.com wrote: ...
Series applied to u-boot-video/master, thanks!
-- Anatolij
Anatolij Gustschin
Fabio Estevam
Igor Opaniuk
