[U-Boot] [PATCH v4 0/1] mmc: sdhci: Add support for frequency constrained peripheral interfaces
From: Stefan Herbrechtsmeier stefan.herbrechtsmeier@weidmueller.com
The sdhci controller assumes that the base clock frequency is fully supported by the peripheral and doesn't support hardware limitations. Distinguish between base clock of the host controller and maximal supported peripheral clock frequency of the peripheral interface. This is needed for the zynq platform to support two sdhci ports with different IO routings.
Changes in v4: - Remove zynq specific patches - Rebase onto latest master
Changes in v3: - Rename arguments of sdhci_setup_cfg function from max_clk/min_clk to f_max/f_min
Changes in v2: - None
Stefan Herbrechtsmeier (1): mmc: sdhci: Distinguish between base clock and maximum peripheral frequency
drivers/mmc/atmel_sdhci.c | 7 +++++-- drivers/mmc/bcm2835_sdhci.c | 3 ++- drivers/mmc/ftsdc021_sdhci.c | 3 ++- drivers/mmc/kona_sdhci.c | 3 ++- drivers/mmc/msm_sdhci.c | 2 ++ drivers/mmc/mv_sdhci.c | 3 ++- drivers/mmc/pci_mmc.c | 1 + drivers/mmc/pic32_sdhci.c | 4 +++- drivers/mmc/rockchip_sdhci.c | 4 ++-- drivers/mmc/s5p_sdhci.c | 5 +++-- drivers/mmc/sdhci.c | 34 ++++++++++++++++++---------------- drivers/mmc/zynq_sdhci.c | 4 +++- include/sdhci.h | 13 +++++++------ 13 files changed, 52 insertions(+), 34 deletions(-)
The sdhci controller assumes that the base clock frequency is fully supported by the peripheral and doesn't support hardware limitations. The Linux kernel distinguishes between base clock (max_clk) of the host controller and maximum frequency (f_max) of the card interface. Use the same differentiation and allow the platform to constrain the peripheral interface.
Signed-off-by: Stefan Herbrechtsmeier stefan.herbrechtsmeier@weidmueller.com
diff --git a/drivers/mmc/atmel_sdhci.c b/drivers/mmc/atmel_sdhci.c index 6654b54..62cb242 100644 --- a/drivers/mmc/atmel_sdhci.c +++ b/drivers/mmc/atmel_sdhci.c @@ -35,8 +35,9 @@ int atmel_sdhci_init(void *regbase, u32 id) free(host); return -ENODEV; } + host->max_clk = max_clk;
- add_sdhci(host, max_clk, min_clk); + add_sdhci(host, 0, min_clk);
return 0; } @@ -95,7 +96,9 @@ static int atmel_sdhci_probe(struct udevice *dev) if (!max_clk) return -EINVAL;
- ret = sdhci_setup_cfg(&plat->cfg, host, max_clk, ATMEL_SDHC_MIN_FREQ); + host->max_clk = max_clk; + + ret = sdhci_setup_cfg(&plat->cfg, host, 0, ATMEL_SDHC_MIN_FREQ); if (ret) return ret;
diff --git a/drivers/mmc/bcm2835_sdhci.c b/drivers/mmc/bcm2835_sdhci.c index cb2bd40..29c2a85 100644 --- a/drivers/mmc/bcm2835_sdhci.c +++ b/drivers/mmc/bcm2835_sdhci.c @@ -181,10 +181,11 @@ int bcm2835_sdhci_init(u32 regbase, u32 emmc_freq) host->ioaddr = (void *)(unsigned long)regbase; host->quirks = SDHCI_QUIRK_BROKEN_VOLTAGE | SDHCI_QUIRK_BROKEN_R1B | SDHCI_QUIRK_WAIT_SEND_CMD | SDHCI_QUIRK_NO_HISPD_BIT; + host->max_clk = emmc_freq; host->voltages = MMC_VDD_32_33 | MMC_VDD_33_34 | MMC_VDD_165_195; host->ops = &bcm2835_ops;
- add_sdhci(host, emmc_freq, MIN_FREQ); + add_sdhci(host, 0, MIN_FREQ);
return 0; } diff --git a/drivers/mmc/ftsdc021_sdhci.c b/drivers/mmc/ftsdc021_sdhci.c index 6e9fefa..4940ccb 100644 --- a/drivers/mmc/ftsdc021_sdhci.c +++ b/drivers/mmc/ftsdc021_sdhci.c @@ -27,7 +27,8 @@ int ftsdc021_sdhci_init(u32 regbase) host->name = "FTSDC021"; host->ioaddr = (void __iomem *)regbase; host->quirks = 0; - add_sdhci(host, freq, 0); + host->max_clk = freq; + add_sdhci(host, 0, 0);
return 0; } diff --git a/drivers/mmc/kona_sdhci.c b/drivers/mmc/kona_sdhci.c index 549f6bc..ddd821b 100644 --- a/drivers/mmc/kona_sdhci.c +++ b/drivers/mmc/kona_sdhci.c @@ -121,12 +121,13 @@ int kona_sdhci_init(int dev_index, u32 min_clk, u32 quirks) host->name = "kona-sdhci"; host->ioaddr = reg_base; host->quirks = quirks; + host->max_clk = max_clk;
if (init_kona_mmc_core(host)) { free(host); return -EINVAL; }
- add_sdhci(host, max_clk, min_clk); + add_sdhci(host, 0, min_clk); return ret; } diff --git a/drivers/mmc/msm_sdhci.c b/drivers/mmc/msm_sdhci.c index f33714b..1db683d 100644 --- a/drivers/mmc/msm_sdhci.c +++ b/drivers/mmc/msm_sdhci.c @@ -96,6 +96,8 @@ static int msm_sdc_probe(struct udevice *dev)
host->quirks = SDHCI_QUIRK_WAIT_SEND_CMD | SDHCI_QUIRK_BROKEN_R1B;
+ host->max_clk = 0; + /* Init clocks */ ret = msm_sdc_clk_init(dev); if (ret) diff --git a/drivers/mmc/mv_sdhci.c b/drivers/mmc/mv_sdhci.c index e388ad1..69aa87b 100644 --- a/drivers/mmc/mv_sdhci.c +++ b/drivers/mmc/mv_sdhci.c @@ -77,6 +77,7 @@ int mv_sdh_init(unsigned long regbase, u32 max_clk, u32 min_clk, u32 quirks) host->name = MVSDH_NAME; host->ioaddr = (void *)regbase; host->quirks = quirks; + host->max_clk = max_clk; #ifdef CONFIG_MMC_SDHCI_IO_ACCESSORS memset(&mv_ops, 0, sizeof(struct sdhci_ops)); mv_ops.write_b = mv_sdhci_writeb; @@ -88,5 +89,5 @@ int mv_sdh_init(unsigned long regbase, u32 max_clk, u32 min_clk, u32 quirks) sdhci_mvebu_mbus_config((void __iomem *)regbase); }
- return add_sdhci(host, max_clk, min_clk); + return add_sdhci(host, 0, min_clk); } diff --git a/drivers/mmc/pci_mmc.c b/drivers/mmc/pci_mmc.c index 3d587cc..e39b476 100644 --- a/drivers/mmc/pci_mmc.c +++ b/drivers/mmc/pci_mmc.c @@ -32,6 +32,7 @@ int pci_mmc_init(const char *name, struct pci_device_id *mmc_supported) dm_pci_read_config32(dev, PCI_BASE_ADDRESS_0, &iobase); mmc_host->ioaddr = (void *)(ulong)iobase; mmc_host->quirks = 0; + mmc_host->max_clk = 0; ret = add_sdhci(mmc_host, 0, 0); if (ret) return ret; diff --git a/drivers/mmc/pic32_sdhci.c b/drivers/mmc/pic32_sdhci.c index c06364c..1e14fa1 100644 --- a/drivers/mmc/pic32_sdhci.c +++ b/drivers/mmc/pic32_sdhci.c @@ -56,7 +56,9 @@ static int pic32_sdhci_probe(struct udevice *dev) return ret; }
- ret = add_sdhci(host, f_min_max[1], f_min_max[0]); + host->max_clk = f_min_max[1]; + + ret = add_sdhci(host, 0, f_min_max[0]); if (ret) return ret; host->mmc->dev = dev; diff --git a/drivers/mmc/rockchip_sdhci.c b/drivers/mmc/rockchip_sdhci.c index e33e35e..1358864 100644 --- a/drivers/mmc/rockchip_sdhci.c +++ b/drivers/mmc/rockchip_sdhci.c @@ -50,9 +50,9 @@ static int arasan_sdhci_probe(struct udevice *dev) }
host->quirks = SDHCI_QUIRK_WAIT_SEND_CMD; + host->max_clk = max_frequency;
- ret = sdhci_setup_cfg(&plat->cfg, host, max_frequency, - EMMC_MIN_FREQ); + ret = sdhci_setup_cfg(&plat->cfg, host, 0, EMMC_MIN_FREQ);
host->mmc = &plat->mmc; if (ret) diff --git a/drivers/mmc/s5p_sdhci.c b/drivers/mmc/s5p_sdhci.c index 1f1d2ed..28327d5 100644 --- a/drivers/mmc/s5p_sdhci.c +++ b/drivers/mmc/s5p_sdhci.c @@ -91,6 +91,7 @@ static int s5p_sdhci_core_init(struct sdhci_host *host) host->quirks = SDHCI_QUIRK_NO_HISPD_BIT | SDHCI_QUIRK_BROKEN_VOLTAGE | SDHCI_QUIRK_32BIT_DMA_ADDR | SDHCI_QUIRK_WAIT_SEND_CMD | SDHCI_QUIRK_USE_WIDE8; + host->max_clk = 52000000; host->voltages = MMC_VDD_32_33 | MMC_VDD_33_34 | MMC_VDD_165_195; host->ops = &s5p_sdhci_ops;
@@ -98,7 +99,7 @@ static int s5p_sdhci_core_init(struct sdhci_host *host) host->host_caps |= MMC_MODE_8BIT;
#ifndef CONFIG_BLK - return add_sdhci(host, 52000000, 400000); + return add_sdhci(host, 0, 400000); #else return 0; #endif @@ -254,7 +255,7 @@ static int s5p_sdhci_probe(struct udevice *dev) if (ret) return ret;
- ret = sdhci_setup_cfg(&plat->cfg, host, 52000000, 400000); + ret = sdhci_setup_cfg(&plat->cfg, host, 0, 400000); if (ret) return ret;
diff --git a/drivers/mmc/sdhci.c b/drivers/mmc/sdhci.c index 5b404ff..84e0581 100644 --- a/drivers/mmc/sdhci.c +++ b/drivers/mmc/sdhci.c @@ -325,7 +325,7 @@ static int sdhci_set_clock(struct mmc *mmc, unsigned int clock) */ if (host->clk_mul) { for (div = 1; div <= 1024; div++) { - if ((mmc->cfg->f_max * host->clk_mul / div) + if ((host->max_clk * host->clk_mul / div) <= clock) break; } @@ -338,13 +338,13 @@ static int sdhci_set_clock(struct mmc *mmc, unsigned int clock) div--; } else { /* Version 3.00 divisors must be a multiple of 2. */ - if (mmc->cfg->f_max <= clock) { + if (host->max_clk <= clock) { div = 1; } else { for (div = 2; div < SDHCI_MAX_DIV_SPEC_300; div += 2) { - if ((mmc->cfg->f_max / div) <= clock) + if ((host->max_clk / div) <= clock) break; } } @@ -353,7 +353,7 @@ static int sdhci_set_clock(struct mmc *mmc, unsigned int clock) } else { /* Version 2.00 divisors must be a power of 2. */ for (div = 1; div < SDHCI_MAX_DIV_SPEC_200; div *= 2) { - if ((mmc->cfg->f_max / div) <= clock) + if ((host->max_clk / div) <= clock) break; } div >>= 1; @@ -513,7 +513,7 @@ static const struct mmc_ops sdhci_ops = { #endif
int sdhci_setup_cfg(struct mmc_config *cfg, struct sdhci_host *host, - u32 max_clk, u32 min_clk) + u32 f_max, u32 f_min) { u32 caps, caps_1;
@@ -536,24 +536,26 @@ int sdhci_setup_cfg(struct mmc_config *cfg, struct sdhci_host *host, #ifndef CONFIG_DM_MMC_OPS cfg->ops = &sdhci_ops; #endif - if (max_clk) - cfg->f_max = max_clk; - else { + if (host->max_clk == 0) { if (SDHCI_GET_VERSION(host) >= SDHCI_SPEC_300) - cfg->f_max = (caps & SDHCI_CLOCK_V3_BASE_MASK) >> + host->max_clk = (caps & SDHCI_CLOCK_V3_BASE_MASK) >> SDHCI_CLOCK_BASE_SHIFT; else - cfg->f_max = (caps & SDHCI_CLOCK_BASE_MASK) >> + host->max_clk = (caps & SDHCI_CLOCK_BASE_MASK) >> SDHCI_CLOCK_BASE_SHIFT; - cfg->f_max *= 1000000; + host->max_clk *= 1000000; } - if (cfg->f_max == 0) { + if (host->max_clk == 0) { printf("%s: Hardware doesn't specify base clock frequency\n", __func__); return -EINVAL; } - if (min_clk) - cfg->f_min = min_clk; + if (f_max && (f_max < host->max_clk)) + cfg->f_max = f_max; + else + cfg->f_max = host->max_clk; + if (f_min) + cfg->f_min = f_min; else { if (SDHCI_GET_VERSION(host) >= SDHCI_SPEC_300) cfg->f_min = cfg->f_max / SDHCI_MAX_DIV_SPEC_300; @@ -598,11 +600,11 @@ int sdhci_bind(struct udevice *dev, struct mmc *mmc, struct mmc_config *cfg) return mmc_bind(dev, mmc, cfg); } #else -int add_sdhci(struct sdhci_host *host, u32 max_clk, u32 min_clk) +int add_sdhci(struct sdhci_host *host, u32 f_max, u32 f_min) { int ret;
- ret = sdhci_setup_cfg(&host->cfg, host, max_clk, min_clk); + ret = sdhci_setup_cfg(&host->cfg, host, f_max, f_min); if (ret) return ret;
diff --git a/drivers/mmc/zynq_sdhci.c b/drivers/mmc/zynq_sdhci.c index 3da1385..69efa38 100644 --- a/drivers/mmc/zynq_sdhci.c +++ b/drivers/mmc/zynq_sdhci.c @@ -36,7 +36,9 @@ static int arasan_sdhci_probe(struct udevice *dev) host->quirks |= SDHCI_QUIRK_NO_HISPD_BIT; #endif
- ret = sdhci_setup_cfg(&plat->cfg, host, CONFIG_ZYNQ_SDHCI_MAX_FREQ, + host->max_clk = CONFIG_ZYNQ_SDHCI_MAX_FREQ; + + ret = sdhci_setup_cfg(&plat->cfg, host, 0, CONFIG_ZYNQ_SDHCI_MIN_FREQ); host->mmc = &plat->mmc; if (ret) diff --git a/include/sdhci.h b/include/sdhci.h index 7544b49..fdef7c4 100644 --- a/include/sdhci.h +++ b/include/sdhci.h @@ -244,6 +244,7 @@ struct sdhci_host { unsigned int quirks; unsigned int host_caps; unsigned int version; + unsigned int max_clk; /* Maximum Base Clock frequency */ unsigned int clk_mul; /* Clock Multiplier value */ unsigned int clock; struct mmc *mmc; @@ -371,11 +372,11 @@ static inline u8 sdhci_readb(struct sdhci_host *host, int reg) * * @cfg: Configuration structure to fill in (generally &plat->mmc) * @host: SDHCI host structure - * @max_clk: Maximum supported clock speed in HZ (0 for default) - * @min_clk: Minimum supported clock speed in HZ (0 for default) + * @f_max: Maximum supported clock frequency in HZ (0 for default) + * @f_min: Minimum supported clock frequency in HZ (0 for default) */ int sdhci_setup_cfg(struct mmc_config *cfg, struct sdhci_host *host, - u32 max_clk, u32 min_clk); + u32 f_max, u32 f_min);
/** * sdhci_bind() - Set up a new MMC block device @@ -401,11 +402,11 @@ int sdhci_bind(struct udevice *dev, struct mmc *mmc, struct mmc_config *cfg); * This is used when you are not using CONFIG_BLK. Convert your driver over! * * @host: SDHCI host structure - * @max_clk: Maximum supported clock speed in HZ (0 for default) - * @min_clk: Minimum supported clock speed in HZ (0 for default) + * @f_max: Maximum supported clock frequency in HZ (0 for default) + * @f_min: Minimum supported clock frequency in HZ (0 for default) * @return 0 if OK, -ve on error */ -int add_sdhci(struct sdhci_host *host, u32 max_clk, u32 min_clk); +int add_sdhci(struct sdhci_host *host, u32 f_max, u32 f_min); #endif /* !CONFIG_BLK */
#ifdef CONFIG_DM_MMC_OPS
Hi Stefan,
Applied on u-boot-mmc. Thanks!
Best Regards, Jaehoon Chung
Changes in v4:
Changes in v3:
Changes in v2:
- None
- host->max_clk = max_clk;
- ret = sdhci_setup_cfg(&plat->cfg, host, 0, ATMEL_SDHC_MIN_FREQ); if (ret) return ret;
- host->max_clk = emmc_freq; host->voltages = MMC_VDD_32_33 | MMC_VDD_33_34 | MMC_VDD_165_195; host->ops = &bcm2835_ops;
- add_sdhci(host, 0, min_clk); return ret;
- host->max_clk = 0;
- /* Init clocks */ ret = msm_sdc_clk_init(dev); if (ret)
- return add_sdhci(host, 0, min_clk);
ret = add_sdhci(mmc_host, 0, 0); if (ret) return ret;mmc_host->max_clk = 0;
- host->max_clk = f_min_max[1];
- ret = add_sdhci(host, 0, f_min_max[0]); if (ret) return ret; host->mmc->dev = dev;
- host->max_clk = max_frequency;
EMMC_MIN_FREQ);
- host->max_clk = 52000000; host->voltages = MMC_VDD_32_33 | MMC_VDD_33_34 | MMC_VDD_165_195; host->ops = &s5p_sdhci_ops;
#ifndef CONFIG_BLK
- return add_sdhci(host, 0, 400000);
- ret = sdhci_setup_cfg(&plat->cfg, host, 0, 400000); if (ret) return ret;
} div >>= 1;if ((host->max_clk / div) <= clock) break;
{ u32 caps, caps_1;
- if (max_clk)
- else {
- if (host->max_clk == 0) { if (SDHCI_GET_VERSION(host) >= SDHCI_SPEC_300)
elsehost->max_clk = (caps & SDHCI_CLOCK_V3_BASE_MASK) >> SDHCI_CLOCK_BASE_SHIFT;
}host->max_clk *= 1000000;
- if (host->max_clk == 0) { printf("%s: Hardware doesn't specify base clock frequency\n", __func__); return -EINVAL; }
- if (min_clk)
- if (f_max && (f_max < host->max_clk))
cfg->f_max = f_max;
- else
- if (f_min)
else { if (SDHCI_GET_VERSION(host) >= SDHCI_SPEC_300) cfg->f_min = cfg->f_max / SDHCI_MAX_DIV_SPEC_300;cfg->f_min = f_min;
- ret = sdhci_setup_cfg(&host->cfg, host, f_max, f_min); if (ret) return ret;
- host->max_clk = CONFIG_ZYNQ_SDHCI_MAX_FREQ;
- ret = sdhci_setup_cfg(&plat->cfg, host, 0, CONFIG_ZYNQ_SDHCI_MIN_FREQ); host->mmc = &plat->mmc; if (ret)
- unsigned int max_clk; /* Maximum Base Clock frequency */ unsigned int clk_mul; /* Clock Multiplier value */ unsigned int clock; struct mmc *mmc;
- @cfg: Configuration structure to fill in (generally &plat->mmc)
- @host: SDHCI host structure
- @max_clk: Maximum supported clock speed in HZ (0 for default)
- @min_clk: Minimum supported clock speed in HZ (0 for default)
- @f_max: Maximum supported clock frequency in HZ (0 for default)
- @f_min: Minimum supported clock frequency in HZ (0 for default)
- sdhci_bind() - Set up a new MMC block device
- This is used when you are not using CONFIG_BLK. Convert your driver over!
- @return 0 if OK, -ve on error
Jaehoon Chung
