[U-Boot] Pull request #2: u-boot-arm/master
Hi Wolfgang,
The following changes since commit a21c65115bd95572cc80092a31b0e9ecb8710e9f:
ARM: lib: Remove CONFIG_ARCH_CPU_INIT dependency (2012-07-20 14:24:08 +0200)
git://git.denx.de/u-boot-arm master
for you to fetch changes up to 6b8ac524e7bcfd4853bb4f494e539a63d894a46f:
mx6: Make pad name macro consistent with the datasheet (2012-07-20 23:03:28 +0200)
---------------------------------------------------------------- Anatolij Gustschin (1): mx28: Fix elftosb source link in README.mx28_common
Ashok (1): mx6: Make pad name macro consistent with the datasheet
Fabio Estevam (1): doc: README.mx28_common: Add missing entry into Contents
arch/arm/include/asm/arch-mx6/mx6x_pins.h | 4 ++-- doc/README.mx28_common | 9 +++++---- 2 files changed, 7 insertions(+), 6 deletions(-)
Amicalement,
On Fri, 20 Jul 2012 23:08:55 +0200, Albert ARIBAUD albert.u.boot@aribaud.net wrote:
Hi Wolfgang,
Please ignore this pull request. Sending #3 right now.
Amicalement,
Albert ARIBAUD
