[U-Boot-Users] Top Boot Flash Init Code
Hello All,
We are using Inca-IP board with U-Boot loader. In our board, we are using top boot flash. Present Inca-IP board is having only uniform boot flash init code. So I took the top boot flash init code form another board and added it in the flash_get_offsets().
/* set sector offsets for top boot block type */ else if (((info->flash_id & FLASH_TYPEMASK) == FLASH_AM320T) || ((info->flash_id & FLASH_TYPEMASK) == FLASH_AM640T)) { /* 8 x 8K Top boot sectors */ for (i = 0; i < info->sector_count; i++) info->start[i] = base + (i * (0x00010000 << FLASH_SHIFT));
for (; i < info->sector_count; i++) info->start[i] = base + (i * (0x00002000 << FLASH_SHIFT)); }
Is it right ??
Bye :)
In message Pine.LNX.4.44.0504291247000.24392-100000@bharathi.midascomm.com you wrote:
Is it right ??
How could we know? You did not bother to mention WHICH flash chips you are using.
We are using AMD compatible Spansion 8MB Flash chips. FLASH_AM640T 0x00A4 /*Spansion S29GL064M90TAIR3 (64Mb)*/
Bye :)
In message Pine.LNX.4.44.0505171449530.11703-100000@bharathi.midascomm.com you wrote:
Are they using the same vendor ID as AMD ??
Yes, Manufacture ID is equal to AMD_MANUFACT 0x00010001 and Device ID is equal to AMD_ID_LV642D 0x227E227E /*29LV642D ID*/. Bcoz it is AMD compatible, So I am setting the flash ID as FLASH_AM640T.
Bye :)
Bharathi Subramanian
