[PATCH 1/1] test: typo curren
Fix typos in test_eficonfig.py: %s/curren/current/
Signed-off-by: Heinrich Schuchardt heinrich.schuchardt@canonical.com --- test/py/tests/test_eficonfig/test_eficonfig.py | 6 +++--- 1 file changed, 3 insertions(+), 3 deletions(-)
diff --git a/test/py/tests/test_eficonfig/test_eficonfig.py b/test/py/tests/test_eficonfig/test_eficonfig.py index b0a6cc47df2..1d8e033f75d 100644 --- a/test/py/tests/test_eficonfig/test_eficonfig.py +++ b/test/py/tests/test_eficonfig/test_eficonfig.py @@ -224,7 +224,7 @@ def test_efi_eficonfig(u_boot_console, efi_eficonfig_data):
# Change the Boot Order press_up_down_enter_and_wait(0, 2, True, None) - # Check the curren BootOrder + # Check the current BootOrder for i in ('test 2', 'test 1', 'host 0:1', 'Save', 'Quit'): u_boot_console.p.expect([i]) # move 'test 2' to the second entry @@ -269,7 +269,7 @@ def test_efi_eficonfig(u_boot_console, efi_eficonfig_data): u_boot_console.run_command('eficonfig', wait_for_prompt=False) # Select 'Edit Boot Option' press_up_down_enter_and_wait(0, 1, True, None) - # Check the curren BootOrder + # Check the current BootOrder for i in ('test 1', 'Quit'): u_boot_console.p.expect([i]) press_up_down_enter_and_wait(0, 0, True, None) @@ -326,7 +326,7 @@ def test_efi_eficonfig(u_boot_console, efi_eficonfig_data):
# Select 'Delete Boot Option' press_up_down_enter_and_wait(0, 3, True, None) - # Check the curren BootOrder + # Check the current BootOrder for i in ('test 3', 'Quit'): u_boot_console.p.expect([i])
On Tue, Apr 9, 2024 at 9:56 AM Heinrich Schuchardt heinrich.schuchardt@canonical.com wrote:
-- 2.43.0
Reviewed-by: Igor Opaniuk igor.opaniuk@gmail.com
Igor Opaniuk
