[U-Boot] [PATCH] arm, imx6: add support for SD/MMC Manufacture Mode
This patch adds support for booting blank i.MX6 devices in SD/MMC Manufacture Mode: a fallback mode which the boot ROM enters when no fuses or boot mode pins have been set, the USB serial downloader connection is inactive, and there is an SD card inserted into uSDHC1. The i.MX7 and i.MX8, which both have a Boot_SW_Info data structure which can be parsed to determine boot source, is unaffected by this patch. --- arch/arm/mach-imx/spl.c | 10 ++++++++++ 1 file changed, 10 insertions(+)
diff --git a/arch/arm/mach-imx/spl.c b/arch/arm/mach-imx/spl.c index a20b30d154..8ecae8605c 100644 --- a/arch/arm/mach-imx/spl.c +++ b/arch/arm/mach-imx/spl.c @@ -43,6 +43,16 @@ u32 spl_boot_device(void) */ if (is_usbotg_phy_active()) return BOOT_DEVICE_BOARD; + + /** + * To support SD/MMC Manufacture Mode, we check that BOOT_MODE == 0 + * and that BT_FUSE_SEL == 0. If this was disabled via + * blowing DISABLE_SDMMC_MFG, or if SDMMC MFG mode failed, + * we would be in USB download mode, which the previous line would + * have detected. + */ + if (((bmode >> 24) & 0x03) == 0x00 && (bmode >> 4) == 0x00) + return BOOT_DEVICE_MMC1;
/* BOOT_CFG1[7:4] - see IMX6DQRM Table 8-8 */ switch ((reg & IMX6_BMODE_MASK) >> IMX6_BMODE_SHIFT) {
Please wrap lines in 80 cols and add the missing signed-off-by.
Jay Carlson
Otavio Salvador
