[U-Boot] [PATCH 3/4] DMC: exynos5420: Gate CLKM to when reading PHY_CON13
From experiments it appears that PHY_CON13 is glitchy if we sample it
when CLKM is running. If we stop CLKM when sampling it the glitches all go away, so we'll do that.
We also check the "is it locked" bits of PHY_CON13 and loop until they show that the value sampled actually represents a locked value. It doesn't appear that the glitching and "is it locked" are related, but it seems wise to wait until the PHY tells us the value is good before we use it. In practice we will not loop more than a couple times (and usually won't loop at all).
Signed-off-by: Doug Anderson dianders@chromium.org Signed-off-by: Akshay Saraswat akshay.s@samsung.com --- arch/arm/cpu/armv7/exynos/dmc_init_ddr3.c | 43 +++++++++++++++++++++++++++---- arch/arm/cpu/armv7/exynos/exynos5_setup.h | 1 + 2 files changed, 39 insertions(+), 5 deletions(-)
diff --git a/arch/arm/cpu/armv7/exynos/dmc_init_ddr3.c b/arch/arm/cpu/armv7/exynos/dmc_init_ddr3.c index 0822323..0654c6a 100644 --- a/arch/arm/cpu/armv7/exynos/dmc_init_ddr3.c +++ b/arch/arm/cpu/armv7/exynos/dmc_init_ddr3.c @@ -233,6 +233,7 @@ int ddr3_mem_ctrl_init(int reset) struct exynos5420_tzasc *tzasc0, *tzasc1; struct mem_timings *mem; uint32_t val, n_lock_r, n_lock_w_phy0, n_lock_w_phy1; + uint32_t lock0_info, lock1_info; int chip; int i;
@@ -396,7 +397,41 @@ int ddr3_mem_ctrl_init(int reset) */ dmc_config_mrs(mem, &drex0->directcmd); dmc_config_mrs(mem, &drex1->directcmd); - } else { + } + + /* + * Get PHY_CON13 from both phys. Gate CLKM around reading since + * PHY_CON13 is glitchy when CLKM is running. We're paranoid and + * wait until we get a "fine lock", though a coarse lock is probably + * OK (we only use the coarse numbers below). We try to gate the + * clock for as short a time as possible in case SDRAM is somehow + * sensitive. sdelay(10) in the loop is arbitrary to make sure + * there is some time for PHY_CON13 to get updated. In practice + * no delay appears to be needed. + */ + val = readl(&clk->gate_bus_cdrex); + while (true) { + writel(val & ~0x1, &clk->gate_bus_cdrex); + lock0_info = readl(&phy0_ctrl->phy_con13); + writel(val, &clk->gate_bus_cdrex); + + if ((lock0_info & CTRL_FINE_LOCKED) == CTRL_FINE_LOCKED) + break; + + sdelay(10); + } + while (true) { + writel(val & ~0x2, &clk->gate_bus_cdrex); + lock1_info = readl(&phy1_ctrl->phy_con13); + writel(val, &clk->gate_bus_cdrex); + + if ((lock1_info & CTRL_FINE_LOCKED) == CTRL_FINE_LOCKED) + break; + + sdelay(10); + } + + if (!reset) { /* * During Suspend-Resume & S/W-Reset, as soon as PMU releases * pad retention, CKE goes high. This causes memory contents @@ -447,15 +482,13 @@ int ddr3_mem_ctrl_init(int reset) val |= (RDLVL_PASS_ADJ_VAL << RDLVL_PASS_ADJ_OFFSET); writel(val, &phy1_ctrl->phy_con1);
- n_lock_r = readl(&phy0_ctrl->phy_con13); - n_lock_w_phy0 = (n_lock_r & CTRL_LOCK_COARSE_MASK) >> 2; + n_lock_w_phy0 = (lock0_info & CTRL_LOCK_COARSE_MASK) >> 2; n_lock_r = readl(&phy0_ctrl->phy_con12); n_lock_r &= ~CTRL_DLL_ON; n_lock_r |= n_lock_w_phy0; writel(n_lock_r, &phy0_ctrl->phy_con12);
- n_lock_r = readl(&phy1_ctrl->phy_con13); - n_lock_w_phy1 = (n_lock_r & CTRL_LOCK_COARSE_MASK) >> 2; + n_lock_w_phy1 = (lock1_info & CTRL_LOCK_COARSE_MASK) >> 2; n_lock_r = readl(&phy1_ctrl->phy_con12); n_lock_r &= ~CTRL_DLL_ON; n_lock_r |= n_lock_w_phy1; diff --git a/arch/arm/cpu/armv7/exynos/exynos5_setup.h b/arch/arm/cpu/armv7/exynos/exynos5_setup.h index b50af2f..1cf9caf 100644 --- a/arch/arm/cpu/armv7/exynos/exynos5_setup.h +++ b/arch/arm/cpu/armv7/exynos/exynos5_setup.h @@ -284,6 +284,7 @@ #define CTRL_DLL_ON (1 << 5) #define CTRL_FORCE_MASK (0x7F << 8) #define CTRL_LOCK_COARSE_MASK (0x7F << 10) +#define CTRL_FINE_LOCKED 0x7
#define CTRL_OFFSETD_RESET_VAL 0x8 #define CTRL_OFFSETD_VAL 0x7F
On 21 May 2014 23:33, Akshay Saraswat akshay.s@samsung.com wrote:
From experiments it appears that PHY_CON13 is glitchy if we sample it when CLKM is running. If we stop CLKM when sampling it the glitches all go away, so we'll do that.
Akshay Saraswat
