[PATCH V3] usb: ehci-mx6: Enable OTG detection on imx8mm and imx8mn
The imx8mm and imx8mn appear compatible with imx7d-usb flags in the OTG driver. If the dr_mode is defined as host or peripheral, the device appears to operate correctly, however the auto host/peripheral detection results in an error.
The solution isn't just adding checks for imx8mm and imx8mn to the check for imx7, because the USB clock needs to be running to read from the USBNC_PHY_STATUS_OFFSET register or it will hang.
Marek requested that I not enable the clocks in ehci_usb_of_to_plat, so I modified that function to return an unknown state if the device tree does not explicitly state whether it is a host or a peripheral.
When the driver probes, it looks to see if it's in the unknown state, and only then will it read the register to auto-detect.
Signed-off-by: Adam Ford aford173@gmail.com --- V3: Keep ehci_usb_of_to_plat but add the ability to return and unknown state instead of reading the register. If the probe determines the states is unknown, it will query the register after the clocks have been enabled. Because of the slight behavior change, I removed any review or tested tags.
V2: Rename ehci_usb_of_to_plat to ehci_usb_dr_mode and call it from the probe after the clocks are enabled, but before the data is needed.
diff --git a/drivers/usb/host/ehci-mx6.c b/drivers/usb/host/ehci-mx6.c index 1bd6147c76..cf44e53ff7 100644 --- a/drivers/usb/host/ehci-mx6.c +++ b/drivers/usb/host/ehci-mx6.c @@ -543,7 +543,7 @@ static int ehci_usb_phy_mode(struct udevice *dev) plat->init_type = USB_INIT_DEVICE; else plat->init_type = USB_INIT_HOST; - } else if (is_mx7()) { + } else if (is_mx7() || is_imx8mm() || is_imx8mn()) { phy_status = (void __iomem *)(addr + USBNC_PHY_STATUS_OFFSET); val = readl(phy_status); @@ -573,9 +573,8 @@ static int ehci_usb_of_to_plat(struct udevice *dev) case USB_DR_MODE_PERIPHERAL: plat->init_type = USB_INIT_DEVICE; break; - case USB_DR_MODE_OTG: - case USB_DR_MODE_UNKNOWN: - return ehci_usb_phy_mode(dev); + default: + plat->init_type = USB_INIT_UNKNOWN; };
return 0; @@ -677,6 +676,20 @@ static int ehci_usb_probe(struct udevice *dev) mdelay(1); #endif
+ /* + * If the device tree didn't specify host or device, + * the default is USB_INIT_UNKNOWN, so we need to check + * the register. For imx8mm and imx8mn, the clocks need to be + * running first, so we defer the check until they are. + */ + if (priv->init_type == USB_INIT_UNKNOWN) { + ret = ehci_usb_phy_mode(dev); + if (ret) + goto err_clk; + else + priv->init_type = plat->init_type; + } + #if CONFIG_IS_ENABLED(DM_REGULATOR) ret = device_get_supply_regulator(dev, "vbus-supply", &priv->vbus_supply); diff --git a/include/usb.h b/include/usb.h index b3851fdb4f..47d738a786 100644 --- a/include/usb.h +++ b/include/usb.h @@ -163,7 +163,8 @@ struct int_queue; */ enum usb_init_type { USB_INIT_HOST, - USB_INIT_DEVICE + USB_INIT_DEVICE, + USB_INIT_UNKNOWN, };
default:
plat->init_type = USB_INIT_UNKNOWN; }; return 0;
if (ret)
goto err_clk;
else
USB_INIT_DEVICE
USB_INIT_DEVICE,
USB_INIT_UNKNOWN,
2.32.0
Adam,
For v3:
tested on imx8mm_venice_defconfig as USB host with USB_ETHER_ASIX and as gadget with CMD_USB_MASS_STORAGE (ums 0 mmc 2).
Tested-By: Tim Harvey tharvey@gateworks.com
Best Regards,
Tim
Hi Adam,
Unfortunately, v3 breaks 'ums 0 mmc 0' on the imx7s-warp board.
The eMMC is no longer mounted and the board hangs.
On Mon, Jan 17, 2022 at 7:46 PM Fabio Estevam festevam@gmail.com wrote:
Hi Adam,
Thanks for testing it.
I am not really sure what's significantly different between them. Do you get any errors when you run UMS?
Hi Adam,
Just realized the problem I am seeing is unrelated to your patch. I will need to debug it.
diff --git a/drivers/usb/host/ehci-mx6.c b/drivers/usb/host/ehci-mx6.c index 1bd6147c76..cf44e53ff7 100644 --- a/drivers/usb/host/ehci-mx6.c +++ b/drivers/usb/host/ehci-mx6.c @@ -543,7 +543,7 @@ static int ehci_usb_phy_mode(struct udevice *dev) plat->init_type = USB_INIT_DEVICE; else plat->init_type = USB_INIT_HOST; - } else if (is_mx7()) { + } else if (is_mx7() || is_imx8mm() || is_imx8mn()) { phy_status = (void __iomem *)(addr + USBNC_PHY_STATUS_OFFSET); val = readl(phy_status); @@ -573,9 +573,8 @@ static int ehci_usb_of_to_plat(struct udevice *dev) case USB_DR_MODE_PERIPHERAL: plat->init_type = USB_INIT_DEVICE; break; - case USB_DR_MODE_OTG: - case USB_DR_MODE_UNKNOWN: - return ehci_usb_phy_mode(dev); + default: + plat->init_type = USB_INIT_UNKNOWN; }; return 0; @@ -677,6 +676,20 @@ static int ehci_usb_probe(struct udevice *dev) mdelay(1); #endif + /* + * If the device tree didn't specify host or device, + * the default is USB_INIT_UNKNOWN, so we need to check + * the register. For imx8mm and imx8mn, the clocks need to be + * running first, so we defer the check until they are. + */ + if (priv->init_type == USB_INIT_UNKNOWN) { + ret = ehci_usb_phy_mode(dev); + if (ret) + goto err_clk;
Hm, unfortunately, that label is gated by an ifdef leading to the following on colibri_imx7:
drivers/usb/host/ehci-mx6.c: In function ‘ehci_usb_probe’: drivers/usb/host/ehci-mx6.c:688:4: error: label ‘err_clk’ used but not defined 688 | goto err_clk; | ^~~~ make[1]: *** [scripts/Makefile.build:254: drivers/usb/host/ehci-mx6.o] Error 1
I have to admit that maybe we should indeed run it with DM_REGULATOR but that won't change anything on this issue. I guess one should really not have any gotos to a label err_clk being ifdefed from somewhere not ifdefed.
#if CONFIG_IS_ENABLED(DM_REGULATOR) ret = device_get_supply_regulator(dev, "vbus-supply", &priv->vbus_supply); diff --git a/include/usb.h b/include/usb.h index b3851fdb4f..47d738a786 100644 --- a/include/usb.h +++ b/include/usb.h @@ -163,7 +163,8 @@ struct int_queue; */ enum usb_init_type { USB_INIT_HOST, - USB_INIT_DEVICE + USB_INIT_DEVICE, + USB_INIT_UNKNOWN, }; /**********************************************************************
On Tue, Jan 25, 2022 at 12:44 AM Marcel Ziswiler marcel.ziswiler@toradex.com wrote:
default:
if (ret)
goto err_clk;
Adam,
Can you re-submit this with an ifdef to handle the correct goto when DM_REGULATOR is undefined?
It looks like Fabio figured out his issue with his board and it was unrelated to this (fixed by 'mmc: fsl_esdhc_imx: fix watermark level in dma') so I think Marcel's point is the only blocker on this patch unless there is more discussion needed with Michael or some feedback needed from Marek?
Tim
default:
if (ret)
goto err_clk;
Adam,
Tim, Not a problem. I was waiting for feedback from Marek in case there were more issues, but I can fix the goto reference and resubmit. I'm build-testing the colibri_imx7 now.
I'm just moving the 'err_clk' reference out of the #ifdef so the same reference can be used. It doesn't look like it should be inside the #ifdef anyway.
You should see something shortly, and I'll add you to the CC list.
adam
Tim
participants (5)
Adam Ford
Fabio Estevam
Marcel Ziswiler
Marcel Ziswiler
Tim Harvey
