[U-Boot] [PATCH 1/2] ARM: tegra: fix GPIO init table programming
Tegra's gpio_config_table() currently uses common GPIO APIs. These used to work without requesting the GPIO, but since commit 2fccd2d96bad "tegra: Convert tegra GPIO driver to use driver model" no longer do so. This prevents any of the GPIO initialization table from being applied to HW. Fix gpio_config_table() to directly program the HW to solve this.
Fixes: 2fccd2d96bad ("tegra: Convert tegra GPIO driver to use driver model") Signed-off-by: Stephen Warren swarren@nvidia.com --- drivers/gpio/tegra_gpio.c | 8 +++++--- 1 file changed, 5 insertions(+), 3 deletions(-)
diff --git a/drivers/gpio/tegra_gpio.c b/drivers/gpio/tegra_gpio.c index 4921f0ff42e9..c0ae7719e2c9 100644 --- a/drivers/gpio/tegra_gpio.c +++ b/drivers/gpio/tegra_gpio.c @@ -211,13 +211,15 @@ void gpio_config_table(const struct tegra_gpio_config *config, int len) for (i = 0; i < len; i++) { switch (config[i].init) { case TEGRA_GPIO_INIT_IN: - gpio_direction_input(config[i].gpio); + set_direction(config[i].gpio, 0); break; case TEGRA_GPIO_INIT_OUT0: - gpio_direction_output(config[i].gpio, 0); + set_level(config[i].gpio, 0); + set_direction(config[i].gpio, 1); break; case TEGRA_GPIO_INIT_OUT1: - gpio_direction_output(config[i].gpio, 1); + set_level(config[i].gpio, 1); + set_direction(config[i].gpio, 1); break; } set_config(config[i].gpio, 1);
Tegra's GPIO driver currently enables pins as GPIO as soon as they're requested. This is not safe, since the desired direction and output value are not yet known. This could cause a glitch on the output pins between gpio_request() and gpio_direction_*(), depending on what values happen to be in the GPIO controller's in/out and out-value registers vs. the final desired configuration.
To solve this, defer enabling pins as GPIOs until some gpio_direction_*() is invoked, and the desired configuration is explicitly programmed.
In theory this change could cause regressions, if code exists that claims a GPIO, never explicitly sets a direction, and then gets/sets the GPIO value based on that assumption. However, I've read through all the Tegra- related board files and device drivers that touch GPIOs and I do not see such buggy code anywhere.
Signed-off-by: Stephen Warren swarren@nvidia.com --- drivers/gpio/tegra_gpio.c | 18 ++++++------------ 1 file changed, 6 insertions(+), 12 deletions(-)
diff --git a/drivers/gpio/tegra_gpio.c b/drivers/gpio/tegra_gpio.c index c0ae7719e2c9..2dfd02d62053 100644 --- a/drivers/gpio/tegra_gpio.c +++ b/drivers/gpio/tegra_gpio.c @@ -136,17 +136,6 @@ static void set_level(unsigned gpio, int high) * Generic_GPIO primitives. */
-static int tegra_gpio_request(struct udevice *dev, unsigned offset, - const char *label) -{ - struct tegra_port_info *state = dev_get_priv(dev); - - /* Configure as a GPIO */ - set_config(state->base_gpio + offset, 1); - - return 0; -} - /* set GPIO pin 'gpio' as an input */ static int tegra_gpio_direction_input(struct udevice *dev, unsigned offset) { @@ -155,6 +144,9 @@ static int tegra_gpio_direction_input(struct udevice *dev, unsigned offset) /* Configure GPIO direction as input. */ set_direction(state->base_gpio + offset, 0);
+ /* Enable the pin as a GPIO */ + set_config(state->base_gpio + offset, 1); + return 0; }
@@ -171,6 +163,9 @@ static int tegra_gpio_direction_output(struct udevice *dev, unsigned offset, /* Configure GPIO direction as output. */ set_direction(gpio, 1);
@@ -256,7 +251,6 @@ static int tegra_gpio_xlate(struct udevice *dev, struct gpio_desc *desc, }
static const struct dm_gpio_ops gpio_tegra_ops = { - .request = tegra_gpio_request, .direction_input = tegra_gpio_direction_input, .direction_output = tegra_gpio_direction_output, .get_value = tegra_gpio_get_value,
Stephen Warren
