[U-Boot] [PATCH 2/2][v2] board/t104xrdb: Conditional workaround of errata A-008044
Workaround of Errata A-008044 was implemented without errata number and it is enabled by default. Errata A-008044 is only valid for T1040 Rev 1.0.
So put errata number and make it conditional.
Signed-off-by: Prabhakar Kushwaha prabhakar@freescale.com --- Changes for v2: - updated CONFIG_A08044_WORKAROUND to CONFIG_A008044_WORKAROUND
arch/powerpc/cpu/mpc85xx/cmd_errata.c | 3 ++- board/freescale/t104xrdb/spl.c | 22 ++++++++++++++-------- 2 files changed, 16 insertions(+), 9 deletions(-)
diff --git a/arch/powerpc/cpu/mpc85xx/cmd_errata.c b/arch/powerpc/cpu/mpc85xx/cmd_errata.c index b670f30..ba08330 100644 --- a/arch/powerpc/cpu/mpc85xx/cmd_errata.c +++ b/arch/powerpc/cpu/mpc85xx/cmd_errata.c @@ -310,7 +310,8 @@ static int do_errata(cmd_tbl_t *cmdtp, int flag, int argc, char * const argv[]) #endif #if defined(CONFIG_SYS_FSL_ERRATUM_A008044) && \ defined(CONFIG_A008044_WORKAROUND) - puts("Work-around for Erratum A-008044 enabled\n"); + if (IS_SVR_REV(svr, 1, 0)) + puts("Work-around for Erratum A-008044 enabled\n"); #endif return 0; } diff --git a/board/freescale/t104xrdb/spl.c b/board/freescale/t104xrdb/spl.c index 75d9d9c..e394b12 100644 --- a/board/freescale/t104xrdb/spl.c +++ b/board/freescale/t104xrdb/spl.c @@ -36,18 +36,24 @@ void board_init_f(ulong bootflag) u32 plat_ratio, sys_clk, uart_clk; #if defined(CONFIG_SPL_NAND_BOOT) && defined(CONFIG_A008044_WORKAROUND) u32 porsr1, pinctl; + u32 svr = get_svr(); #endif ccsr_gur_t *gur = (void *)CONFIG_SYS_MPC85xx_GUTS_ADDR;
#if defined(CONFIG_SPL_NAND_BOOT) && defined(CONFIG_A008044_WORKAROUND) - /* - * There is T1040 SoC issue where NOR, FPGA are inaccessible during - * NAND boot because IFC signals > IFC_AD7 are not enabled. - * This workaround changes RCW source to make all signals enabled. - */ - porsr1 = in_be32(&gur->porsr1); - pinctl = ((porsr1 & ~(FSL_CORENET_CCSR_PORSR1_RCW_MASK)) | 0x24800000); - out_be32((unsigned int *)(CONFIG_SYS_DCSRBAR + 0x20000), pinctl); + if (IS_SVR_REV(svr, 1, 0)) { + /* + * There is T1040 SoC issue where NOR, FPGA are inaccessible + * during NAND boot because IFC signals > IFC_AD7 are not + * enabled. This workaround changes RCW source to make all + * signals enabled. + */ + porsr1 = in_be32(&gur->porsr1); + pinctl = ((porsr1 & ~(FSL_CORENET_CCSR_PORSR1_RCW_MASK)) + | 0x24800000); + out_be32((unsigned int *)(CONFIG_SYS_DCSRBAR + 0x20000), + pinctl); + } #endif
/* Memcpy existing GD at CONFIG_SPL_GD_ADDR */
Changes for v2:
Applied to u-boot-mpc85xx, awaiting upstream.
York
Prabhakar Kushwaha
York Sun
