RE: [U-Boot-Users] mpc8260 reset procedure
Also, debuggers do NOT like having the IMMR change by the software they are debugging. They don't have any way of knowing that your software changed the IMMR, so they will be using the wrong IMMR, causing problems like you are seeing.
Tip: set the IMMR to where you want it (or can live with it) using the HRCW and DO NOT CHANGE IT in software. Your phrase "as soon as the code starts to manage IMMR" is something that should not be said. "Manageing" the IMMR causes problems for (a) debuggers, (b) software, (c) software resets/restarts, (d) code readability, ...
gvb
-----Original Message----- From: u-boot-users-admin@lists.sourceforge.net [mailto:u-boot-users-admin@lists.sourceforge.net]On Behalf Of Ho Lee Sent: Thursday, June 10, 2004 2:47 AM To: u-boot-users@lists.sourceforge.net Cc: walter dicarlo Subject: Re: [U-Boot-Users] mpc8260 reset procedure
Hi Walter,
According to your HRCW configuration, IMMR is set to 0x0f000000 after reset. CFG_DEFAULT_IMMR must be the IMMR after system reset (in your configuration, 0x0f000000 not 0x00010000), and CFG_IMMR is the IMMR that you would like to use inside u-boot. Since you keep the IMMR defined by HRCW, you don't need to define the CFG_DEFAULT_IMMR. Just comment out the CFG_DEFAULT_IMMR definition, and I guess it will fix your problem.
Sincerely, Ho
----- Original Message ----- From: "walter dicarlo" walter_dicarlo@yahoo.com To: u-boot-users@lists.sourceforge.net Sent: Wednesday, June 09, 2004 7:58 AM Subject: [U-Boot-Users] mpc8260 reset procedure
Hi all, I am new to embedded world and I am trying to port u-boot on a board based on the mpc8260. I hope I can bore you a little bit with a simple question. I use the Lauterbach Trace32 to program the 4Mb flash. I compile u-boot 1.0.2 using the following settings: TEXT_BASE = fff00000 CFG_DEFAULT_IMMR = 00010000 CFG_IMMR = 0f000000 CFG_SDRAM_BASE = 00000000 CFG_FLASH_BASE = ffc00000 CFG_BR0_PRELIM = ffc01001 CFG_OR0_PRELIM = ffc00856 CFG_BR1_PRELIM = 00000041 CFG_OR1_PRELIM = f8002b00 HRCW = 08 c2 01 07 Note that I use three Trace32 scripts to:
- init the board
- store the HRCW at the begin of the flash (FFC00000)
- store the u-boot.bin at fff00000
My problem is with the HRCW and the reset procedure. It is not clear how it works and what steps I should follow to setup everything.
When I start debugging, the Program Counter starts correctly from fff00100, but as soon as the code starts to manage IMMR everything seems to not work. It is like the code expect the registers in one position but in reality it is in another location.
I know it is basic knoledge about the mpc8260 but do you have any advices? Thanks
Walter
This SF.Net email is sponsored by: GNOME Foundation Hackers Unite! GUADEC: The world's #1 Open Source Desktop Event. GNOME Users and Developers European Conference, 28-30th June in Norway http://2004/guadec.org _______________________________________________ U-Boot-Users mailing list U-Boot-Users@lists.sourceforge.net https://lists.sourceforge.net/lists/listinfo/u-boot-users
****************************************** The information contained in, or attached to, this e-mail, may contain confidential information and is intended solely for the use of the individual or entity to whom they are addressed and may be subject to legal privilege. If you have received this e-mail in error you should notify the sender immediately by reply e-mail, delete the message from your system and notify your system manager. Please do not copy it for any purpose, or disclose its contents to any other person. The views or opinions presented in this e-mail are solely those of the author and do not necessarily represent those of the company. The recipient should check this e-mail and any attachments for the presence of viruses. The company accepts no liability for any damage caused, directly or indirectly, by any virus transmitted in this email. ******************************************
VanBaren, Gerald (AGRE)
