[U-Boot] [PATCH v3 1/4] exynos: Properly zero initialize host in s5p_sdhci_init()
This makes sure that setting the host_caps in s5p_sdhci_core_init() doesn't operate on potentially uninitialized memory.
Acked-by: Lukasz Majewski l.majewski@samsung.com Signed-off-by: Tobias Jakobi tjakobi@math.uni-bielefeld.de --- drivers/mmc/s5p_sdhci.c | 4 ++-- 1 file changed, 2 insertions(+), 2 deletions(-)
diff --git a/drivers/mmc/s5p_sdhci.c b/drivers/mmc/s5p_sdhci.c index 4db51d6..911e7a8 100644 --- a/drivers/mmc/s5p_sdhci.c +++ b/drivers/mmc/s5p_sdhci.c @@ -84,9 +84,9 @@ static int s5p_sdhci_core_init(struct sdhci_host *host)
int s5p_sdhci_init(u32 regbase, int index, int bus_width) { - struct sdhci_host *host = malloc(sizeof(struct sdhci_host)); + struct sdhci_host *host = calloc(1, sizeof(struct sdhci_host)); if (!host) { - printf("sdhci__host malloc fail!\n"); + printf("sdhci__host allocation fail!\n"); return 1; } host->ioaddr = (void *)regbase;
exynos_mmc_init() always returns zero, so for the caller it looks like it never fails.
Correct this by returning the error code of process_nodes(). For process_nodes() do something similar and return early when do_sdhci_init() fails.
v2: Only fail in process_nodes() if we fail on all available nodes.
Acked-by: Przemyslaw Marczak p.marczak@samsung.com Signed-off-by: Tobias Jakobi tjakobi@math.uni-bielefeld.de --- drivers/mmc/s5p_sdhci.c | 18 ++++++++++++------ 1 file changed, 12 insertions(+), 6 deletions(-)
diff --git a/drivers/mmc/s5p_sdhci.c b/drivers/mmc/s5p_sdhci.c index 911e7a8..bd9e014 100644 --- a/drivers/mmc/s5p_sdhci.c +++ b/drivers/mmc/s5p_sdhci.c @@ -171,6 +171,7 @@ static int process_nodes(const void *blob, int node_list[], int count) { struct sdhci_host *host; int i, node; + int failed = 0;
debug("%s: count = %d\n", __func__, count);
@@ -184,11 +185,18 @@ static int process_nodes(const void *blob, int node_list[], int count)
if (sdhci_get_config(blob, node, host)) { printf("%s: failed to decode dev %d\n", __func__, i); - return -1; + failed++; + continue; + } + + if (do_sdhci_init(host)) { + printf("%s: failed to initialize dev %d\n", __func__, i); + failed++; } - do_sdhci_init(host); } - return 0; + + /* we only consider it an error when all nodes fail */ + return (failed == count ? -1 : 0); }
int exynos_mmc_init(const void *blob) @@ -200,8 +208,6 @@ int exynos_mmc_init(const void *blob) COMPAT_SAMSUNG_EXYNOS_MMC, node_list, SDHCI_MAX_HOSTS);
- process_nodes(blob, node_list, count); - - return 0; + return process_nodes(blob, node_list, count); } #endif
applied to u-boot-samsung.
Thanks, Minkyu Kang.
In case sdhci_get_config() or do_sdhci_init() fail, show the error code that was returned.
Acked-by: Przemyslaw Marczak p.marczak@samsung.com Signed-off-by: Tobias Jakobi tjakobi@math.uni-bielefeld.de --- drivers/mmc/s5p_sdhci.c | 12 +++++++----- 1 file changed, 7 insertions(+), 5 deletions(-)
diff --git a/drivers/mmc/s5p_sdhci.c b/drivers/mmc/s5p_sdhci.c index bd9e014..b203bee 100644 --- a/drivers/mmc/s5p_sdhci.c +++ b/drivers/mmc/s5p_sdhci.c @@ -170,7 +170,7 @@ static int sdhci_get_config(const void *blob, int node, struct sdhci_host *host) static int process_nodes(const void *blob, int node_list[], int count) { struct sdhci_host *host; - int i, node; + int i, node, ret; int failed = 0;
debug("%s: count = %d\n", __func__, count); @@ -183,14 +183,16 @@ static int process_nodes(const void *blob, int node_list[], int count)
host = &sdhci_host[i];
- if (sdhci_get_config(blob, node, host)) { - printf("%s: failed to decode dev %d\n", __func__, i); + ret = sdhci_get_config(blob, node, host); + if (ret) { + printf("%s: failed to decode dev %d (%d)\n", __func__, i, ret); failed++; continue; }
- if (do_sdhci_init(host)) { - printf("%s: failed to initialize dev %d\n", __func__, i); + ret = do_sdhci_init(host); + if (ret) { + printf("%s: failed to initialize dev %d (%d)\n", __func__, i, ret); failed++; } }
Add more debug printfs in do_sdhci_init() for calls that can potentially fail.
Acked-by: Przemyslaw Marczak p.marczak@samsung.com Signed-off-by: Tobias Jakobi tjakobi@math.uni-bielefeld.de --- drivers/mmc/s5p_sdhci.c | 20 +++++++++++--------- 1 file changed, 11 insertions(+), 9 deletions(-)
diff --git a/drivers/mmc/s5p_sdhci.c b/drivers/mmc/s5p_sdhci.c index b203bee..15ecfee 100644 --- a/drivers/mmc/s5p_sdhci.c +++ b/drivers/mmc/s5p_sdhci.c @@ -101,29 +101,31 @@ struct sdhci_host sdhci_host[SDHCI_MAX_HOSTS];
static int do_sdhci_init(struct sdhci_host *host) { - int dev_id, flag; - int err = 0; + int dev_id, flag, ret;
flag = host->bus_width == 8 ? PINMUX_FLAG_8BIT_MODE : PINMUX_FLAG_NONE; dev_id = host->index + PERIPH_ID_SDMMC0;
if (dm_gpio_is_valid(&host->pwr_gpio)) { dm_gpio_set_value(&host->pwr_gpio, 1); - err = exynos_pinmux_config(dev_id, flag); - if (err) { + ret = exynos_pinmux_config(dev_id, flag); + if (ret) { debug("MMC not configured\n"); - return err; + return ret; } }
if (dm_gpio_is_valid(&host->cd_gpio)) { - if (dm_gpio_get_value(&host->cd_gpio)) + ret = dm_gpio_get_value(&host->cd_gpio); + if (ret) { + debug("no SD card detected (%d)\n", ret); return -ENODEV; + }
- err = exynos_pinmux_config(dev_id, flag); - if (err) { + ret = exynos_pinmux_config(dev_id, flag); + if (ret) { printf("external SD not configured\n"); - return err; + return ret; } }
Hi, All.
- int dev_id, flag;
- int err = 0;
if (err) {
return err;
return ret;
if (ret) {
This patch was already applied. But i didn't know why used "ret" at here. If cd-gpio is active-high, this should be always returned "no SD card detected". Even if commonly cd-gpio is active-low, we don't know whether cd-gpio is active-low or not.
And dm_gpio_get_value() should be returned error for only one case.
Best Regards, Jaehoon Chung
if (err) {
return err;
} }return ret;
Hello Jaehoon,
On 10/28/2015 07:33 AM, Jaehoon Chung wrote:
Hi, All.
- int dev_id, flag;
- int err = 0;
if (err) {
return err;
return ret;
if (ret) {
Could you precise, where is the problem exactly? The active low or high can be set in device tree, so the code can be still common.
And the ret value can inform, if card is not detected or the error is in GPIO subsystem(ret < 0). So where is the problem?
if (err) {
return err;
} }return ret;
Hi, Przemyslaw.
On 10/28/2015 08:33 PM, Przemyslaw Marczak wrote:
Hello Jaehoon,
Hi, All.
- int dev_id, flag;
- int err = 0;
if (err) {
return err;
return ret; } } if (dm_gpio_is_valid(&host->cd_gpio)) {
if (ret) {
How can active low or high be set in device tree? I can't find any information.
Anyway, I have tested on Odroid-x2 board. And i have tried to boot with SD-card. In that case, host can't detect SD-card.
MMC: process_nodes: failed to initialize dev 0 (-19)
After Enable debug message..
no SD card detected (1) process_nodes: failed to initialize dev 0 (-19)
no SD card detected (1) -> 1 is just gpio value. it should be to 0. Do you distinguish between 0 and 1? We don't know whether gpio is active-low or high. I don't think that included information.
It's just my thinking...other people should be helpful.
And I'm making some patches...and below is one of them for detecting SD-card.
Subject: [PATCH] mmc: s5p_sdhci: change the flags of cd-gpio to ACTIVE_LOW
In case of exynos, "cd-gpio" is commonly used the active-low. So it changed the flags of gpio from GPIOD_IS_IN to GPIOD_ACTIVE_LOW.
Signed-off-by: Jaehoon Chung jh80.chung@samsung.com --- drivers/mmc/s5p_sdhci.c | 5 +++-- 1 file changed, 3 insertions(+), 2 deletions(-)
diff --git a/drivers/mmc/s5p_sdhci.c b/drivers/mmc/s5p_sdhci.c index 15ecfee..26a8fe8 100644 --- a/drivers/mmc/s5p_sdhci.c +++ b/drivers/mmc/s5p_sdhci.c @@ -164,7 +164,7 @@ static int sdhci_get_config(const void *blob, int node, struct sdhci_host *host) gpio_request_by_name_nodev(blob, node, "pwr-gpios", 0, &host->pwr_gpio, GPIOD_IS_OUT); gpio_request_by_name_nodev(blob, node, "cd-gpios", 0, &host->cd_gpio, - GPIOD_IS_IN); + GPIOD_ACTIVE_LOW);
return 0; } @@ -187,7 +187,8 @@ static int process_nodes(const void *blob, int node_list[], int count)
ret = sdhci_get_config(blob, node, host); if (ret) { - printf("%s: failed to decode dev %d (%d)\n", __func__, i, ret); + printf("%s: failed to decode dev %d (%d)\n", + __func__, i, ret); failed++; continue; } --
if (err) {
return err;
return ret; } }
Hello Jaehoon,
On 10/28/2015 01:30 PM, Jaehoon Chung wrote:
Hi, Przemyslaw.
Hello Jaehoon,
Hi, All.
- int dev_id, flag;
- int err = 0;
if (err) {
return err;
if (ret) {
It is defined here: arch/arm/dts/include/dt-bindings/gpio/gpio.h and is used by gpio's phandle, e.g.: sdhci@12530000 { samsung,bus-width = <4>; samsung,timing = <1 2 3>; cd-gpios = <&gpk2 2 0>; }
Can you also see this error: ----------------------------------------------------------- DRAM: 2 GiB __of_translate_address: Bad cell count for gpf0 __of_translate_address: Bad cell count for gpj0 __of_translate_address: Bad cell count for gpk0 __of_translate_address: Bad cell count for gpm0 __of_translate_address: Bad cell count for gpx0 LDO20@VDDQ_EMMC_1.8V: set 1800000 uV; enabling LDO22@VDDQ_EMMC_2.8V: set 2800000 uV; enabling LDO21@TFLASH_2.8V: set 2800000 uV; enabling MMC: process_nodes: failed to initialize dev 0 (-19) -----------------------------------------------------------
This is caused by this commit: commit ef5cd33064f83db6f6cfe774ecdb36e32ac1d232 dm: core: Enable optional use of fdt_translate_address()
And it's not related to GPIO configuration.
Right now, I'm looking on how to fix it.
GPIOD_IS_IN);
GPIOD_ACTIVE_LOW);
This change, is a bad idea.
We uses this flag to set the direction (input/output), and also the flag GPIOD_ACTIVE_LOW is checked for output only in this function.
Your commit fixes the SD detection issue by a mistake.
I will send the fix in a moment, then you will see what is wrong.
if (err) {
return err;
return ret; } }
Hi, Przemyslaw.
On 10/28/2015 10:46 PM, Przemyslaw Marczak wrote:
Hello Jaehoon,
Hi, Przemyslaw.
Hello Jaehoon,
Hi, All.
- int dev_id, flag;
- int err = 0;
if (err) {
return err;
if (ret) {
Yes, I have checked.
Yes, i also found those message. I'm also finding solution.
GPIOD_IS_IN);
GPIOD_ACTIVE_LOW);
Yep, it's not good idea. I'm not sure, cd-gpio pin has to set GPIOD_IS_IN. I can't find the any information about gpio direction. Tomorrow, when i go to the office, i will check.
Well, i didn't minutely see u-boot code during long time. So i may miss something..I will check more for u-boot code.
Thanks for pointing out. :)
if (err) {
return err;
return ret; } }
Hello Jaehoon,
On 10/28/2015 03:36 PM, Jaehoon Chung wrote:
Hi, Przemyslaw.
Hello Jaehoon,
Hi, Przemyslaw.
Hello Jaehoon,
Hi, All.
- int dev_id, flag;
- int err = 0;
if (err) {
return err;
if (ret) {
Please check the patches for which you're Cc'ed :)
1 fdt fix: https://patchwork.ozlabs.org/patch/537372/
2 patches for sd detection fix: https://patchwork.ozlabs.org/patch/537381/ https://patchwork.ozlabs.org/patch/537379/
Tested for X2 and U3.
GPIOD_IS_IN);
GPIOD_ACTIVE_LOW);
Please see the schematic of U3 and also XU3, the CD-det pin is pulled up. When you insert the card, it's mechanically pulled down - so card is detected for low state.
No problem, thanks for mention about this issue:)
if (err) {
return err;
return ret; } }
participants (5)
Jaehoon Chung
Jaehoon Chung
Minkyu Kang
Przemyslaw Marczak
Tobias Jakobi
