[U-Boot] [PATCH 0/8] pmic: stpmic1: rename and update stpmic1 driver
This patchset renames the stpmu1 driver to stpmic1, prepares alignment with latest kernel device tree and udpates it with the latest ST patches.
The driver uses the final marketing name for STMicroelectronics PMIC = STPMIC1 and use the kernel driver name & binding introduced by https://patchwork.kernel.org/cover/10761943/
This patch is applicable on the top of the serie "stm32mp1: add trusted boot with TF-A"
http://patchwork.ozlabs.org/project/uboot/list/?series=88521
Patrick Delaunay (8): regulator: stpmu1: update buck1 range power: stpmu1: rename files to stpmic1 power: rename stpmu1 to official name stpmic1 stpmic1: update register names pmic: stpmu1: add power switch off support stm32mp1: add command poweroff stm32mp1: dts: activate psci-1.0 stpmic1: add NVM update support in fuse command
MAINTAINERS | 2 + arch/arm/Kconfig | 1 + arch/arm/dts/stm32mp157c-ed1.dts | 8 +- arch/arm/dts/stm32mp157c.dtsi | 2 +- arch/arm/mach-stm32mp/Makefile | 3 + arch/arm/mach-stm32mp/cmd_poweroff.c | 24 ++ board/st/stm32mp1/README | 6 +- board/st/stm32mp1/board.c | 47 +-- board/st/stm32mp1/spl.c | 12 +- configs/stm32mp15_basic_defconfig | 4 +- configs/stm32mp15_trusted_defconfig | 4 +- drivers/misc/stm32mp_fuse.c | 28 ++ drivers/power/pmic/Kconfig | 6 +- drivers/power/pmic/Makefile | 2 +- drivers/power/pmic/stpmic1.c | 255 +++++++++++++ drivers/power/pmic/stpmu1.c | 95 ----- drivers/power/regulator/Kconfig | 14 +- drivers/power/regulator/Makefile | 2 +- drivers/power/regulator/stpmic1.c | 672 +++++++++++++++++++++++++++++++++++ drivers/power/regulator/stpmu1.c | 671 ---------------------------------- include/dt-bindings/mfd/st,stpmic1.h | 46 +++ include/dt-bindings/mfd/st,stpmu1.h | 60 ---- include/power/stpmic1.h | 117 ++++++ include/power/stpmu1.h | 85 ----- 24 files changed, 1205 insertions(+), 961 deletions(-) create mode 100644 arch/arm/mach-stm32mp/cmd_poweroff.c create mode 100644 drivers/power/pmic/stpmic1.c delete mode 100644 drivers/power/pmic/stpmu1.c create mode 100644 drivers/power/regulator/stpmic1.c delete mode 100644 drivers/power/regulator/stpmu1.c create mode 100644 include/dt-bindings/mfd/st,stpmic1.h delete mode 100644 include/dt-bindings/mfd/st,stpmu1.h create mode 100644 include/power/stpmic1.h delete mode 100644 include/power/stpmu1.h
SW impact for Rev 1.2 of STPMIC1 in U-Boot: Buck converters output voltage change for Buck1 => Vdd min 0,725 to max 1,5V instead of 0.6V to 1.35V (see STPMIC1 datasheet / chapter 5.3 Buck converters)
Signed-off-by: Patrick Delaunay patrick.delaunay@st.com ---
drivers/power/regulator/stpmu1.c | 5 +++-- 1 file changed, 3 insertions(+), 2 deletions(-)
diff --git a/drivers/power/regulator/stpmu1.c b/drivers/power/regulator/stpmu1.c index 6eb2420..2e64051 100644 --- a/drivers/power/regulator/stpmu1.c +++ b/drivers/power/regulator/stpmu1.c @@ -83,8 +83,9 @@ static int stpmu1_output_find_sel(int uv, */
static const struct stpmu1_range buck1_ranges[] = { - STPMU1_RANGE(600000, 0, 30, 25000), - STPMU1_RANGE(1350000, 31, 63, 0), + STPMU1_RANGE(725000, 0, 4, 0), + STPMU1_RANGE(725000, 5, 36, 25000), + STPMU1_RANGE(1500000, 37, 63, 0), };
static const struct stpmu1_range buck2_ranges[] = {
Prepare file modification for kernel alignment and rename driver to stpmic1.
arch/arm/dts/stm32mp157c-ed1.dts | 2 +- board/st/stm32mp1/board.c | 2 +- board/st/stm32mp1/spl.c | 2 +- drivers/power/pmic/Makefile | 2 +- drivers/power/pmic/{stpmu1.c => stpmic1.c} | 2 +- drivers/power/regulator/Makefile | 2 +- drivers/power/regulator/{stpmu1.c => stpmic1.c} | 2 +- include/dt-bindings/mfd/{st,stpmu1.h => st,stpmic1.h} | 0 include/power/{stpmu1.h => stpmic1.h} | 0 9 files changed, 7 insertions(+), 7 deletions(-) rename drivers/power/pmic/{stpmu1.c => stpmic1.c} (98%) rename drivers/power/regulator/{stpmu1.c => stpmic1.c} (99%) rename include/dt-bindings/mfd/{st,stpmu1.h => st,stpmic1.h} (100%) rename include/power/{stpmu1.h => stpmic1.h} (100%)
diff --git a/arch/arm/dts/stm32mp157c-ed1.dts b/arch/arm/dts/stm32mp157c-ed1.dts index 7a9b742..ddee286 100644 --- a/arch/arm/dts/stm32mp157c-ed1.dts +++ b/arch/arm/dts/stm32mp157c-ed1.dts @@ -8,7 +8,7 @@ #include "stm32mp157c.dtsi" #include "stm32mp157-pinctrl.dtsi" #include <dt-bindings/gpio/gpio.h> -#include <dt-bindings/mfd/st,stpmu1.h> +#include <dt-bindings/mfd/st,stpmic1.h>
/ { model = "STMicroelectronics STM32MP157C eval daughter"; diff --git a/board/st/stm32mp1/board.c b/board/st/stm32mp1/board.c index 5f31ea9..1bb9779 100644 --- a/board/st/stm32mp1/board.c +++ b/board/st/stm32mp1/board.c @@ -8,7 +8,7 @@ #include <asm/io.h> #include <asm/arch/ddr.h> #include <power/pmic.h> -#include <power/stpmu1.h> +#include <power/stpmic1.h>
#ifdef CONFIG_DEBUG_UART_BOARD_INIT void board_debug_uart_init(void) diff --git a/board/st/stm32mp1/spl.c b/board/st/stm32mp1/spl.c index f3db0d6..1202297 100644 --- a/board/st/stm32mp1/spl.c +++ b/board/st/stm32mp1/spl.c @@ -11,7 +11,7 @@ #include <asm/io.h> #include <post.h> #include <power/pmic.h> -#include <power/stpmu1.h> +#include <power/stpmic1.h> #include <asm/arch/ddr.h>
void spl_board_init(void) diff --git a/drivers/power/pmic/Makefile b/drivers/power/pmic/Makefile index 637352a..147ac76 100644 --- a/drivers/power/pmic/Makefile +++ b/drivers/power/pmic/Makefile @@ -23,7 +23,7 @@ obj-$(CONFIG_DM_PMIC_TPS65910) += pmic_tps65910_dm.o obj-$(CONFIG_$(SPL_)PMIC_PALMAS) += palmas.o obj-$(CONFIG_$(SPL_)PMIC_LP873X) += lp873x.o obj-$(CONFIG_$(SPL_)PMIC_LP87565) += lp87565.o -obj-$(CONFIG_PMIC_STPMU1) += stpmu1.o +obj-$(CONFIG_PMIC_STPMU1) += stpmic1.o
obj-$(CONFIG_POWER_LTC3676) += pmic_ltc3676.o obj-$(CONFIG_POWER_MAX77696) += pmic_max77696.o diff --git a/drivers/power/pmic/stpmu1.c b/drivers/power/pmic/stpmic1.c similarity index 98% rename from drivers/power/pmic/stpmu1.c rename to drivers/power/pmic/stpmic1.c index 47af012..157ce8b 100644 --- a/drivers/power/pmic/stpmu1.c +++ b/drivers/power/pmic/stpmic1.c @@ -8,7 +8,7 @@ #include <errno.h> #include <i2c.h> #include <power/pmic.h> -#include <power/stpmu1.h> +#include <power/stpmic1.h>
#define STMPU1_NUM_OF_REGS 0x100
diff --git a/drivers/power/regulator/Makefile b/drivers/power/regulator/Makefile index f617ce7..cfc91e8 100644 --- a/drivers/power/regulator/Makefile +++ b/drivers/power/regulator/Makefile @@ -24,4 +24,4 @@ obj-$(CONFIG_$(SPL_)DM_REGULATOR_LP873X) += lp873x_regulator.o obj-$(CONFIG_$(SPL_)DM_REGULATOR_LP87565) += lp87565_regulator.o obj-$(CONFIG_$(SPL_)DM_REGULATOR_STM32_VREFBUF) += stm32-vrefbuf.o obj-$(CONFIG_DM_REGULATOR_TPS65910) += tps65910_regulator.o -obj-$(CONFIG_$(SPL_)DM_REGULATOR_STPMU1) += stpmu1.o +obj-$(CONFIG_$(SPL_)DM_REGULATOR_STPMU1) += stpmic1.o diff --git a/drivers/power/regulator/stpmu1.c b/drivers/power/regulator/stpmic1.c similarity index 99% rename from drivers/power/regulator/stpmu1.c rename to drivers/power/regulator/stpmic1.c index 2e64051..c62a19a 100644 --- a/drivers/power/regulator/stpmu1.c +++ b/drivers/power/regulator/stpmic1.c @@ -9,7 +9,7 @@ #include <errno.h> #include <power/pmic.h> #include <power/regulator.h> -#include <power/stpmu1.h> +#include <power/stpmic1.h>
struct stpmu1_range { int min_uv; diff --git a/include/dt-bindings/mfd/st,stpmu1.h b/include/dt-bindings/mfd/st,stpmic1.h similarity index 100% rename from include/dt-bindings/mfd/st,stpmu1.h rename to include/dt-bindings/mfd/st,stpmic1.h diff --git a/include/power/stpmu1.h b/include/power/stpmic1.h similarity index 100% rename from include/power/stpmu1.h rename to include/power/stpmic1.h
On Mon, 4 Feb 2019 11:26:16 +0100 Patrick Delaunay patrick.delaunay@st.com wrote:
Reviewed-by: Lukasz Majewski lukma@denx.de
Lukasz Majewski
DENX Software Engineering GmbH, Managing Director: Wolfgang Denk HRB 165235 Munich, Office: Kirchenstr.5, D-82194 Groebenzell, Germany Phone: (+49)-8142-66989-59 Fax: (+49)-8142-66989-80 Email: lukma@denx.de
Alignment with kernel driver name & binding introduced by https://patchwork.kernel.org/cover/10761943/ to use the final marketing name = STPMIC1.
MAINTAINERS | 2 + arch/arm/dts/stm32mp157c-ed1.dts | 6 +- board/st/stm32mp1/README | 6 +- board/st/stm32mp1/board.c | 45 ++-- board/st/stm32mp1/spl.c | 10 +- configs/stm32mp15_basic_defconfig | 4 +- configs/stm32mp15_trusted_defconfig | 4 +- drivers/power/pmic/Kconfig | 6 +- drivers/power/pmic/Makefile | 2 +- drivers/power/pmic/stpmic1.c | 62 ++--- drivers/power/regulator/Kconfig | 14 +- drivers/power/regulator/Makefile | 2 +- drivers/power/regulator/stpmic1.c | 504 +++++++++++++++++------------------ include/dt-bindings/mfd/st,stpmic1.h | 88 +++--- include/power/stpmic1.h | 135 +++++----- 15 files changed, 446 insertions(+), 444 deletions(-)
diff --git a/MAINTAINERS b/MAINTAINERS index f86fdf9..43479ca 100644 --- a/MAINTAINERS +++ b/MAINTAINERS @@ -264,7 +264,9 @@ F: drivers/misc/stm32mp_fuse.c F: drivers/mmc/stm32_sdmmc2.c F: drivers/phy/phy-stm32-usbphyc.c F: drivers/pinctrl/pinctrl_stm32.c +F: drivers/power/pmic/stpmic1.c F: drivers/power/regulator/stm32-vrefbuf.c +F: drivers/power/regulator/stpmic1.c F: drivers/ram/stm32mp1/ F: drivers/misc/stm32_rcc.c F: drivers/reset/stm32-reset.c diff --git a/arch/arm/dts/stm32mp157c-ed1.dts b/arch/arm/dts/stm32mp157c-ed1.dts index ddee286..1d0306e 100644 --- a/arch/arm/dts/stm32mp157c-ed1.dts +++ b/arch/arm/dts/stm32mp157c-ed1.dts @@ -54,8 +54,8 @@ i2c-scl-falling-time-ns = <20>; status = "okay";
- pmic: stpmu1@33 { - compatible = "st,stpmu1"; + pmic: stpmic1@33 { + compatible = "st,stpmic1"; reg = <0x33>; interrupts = <0 2>; interrupt-parent = <&gpioa>; @@ -68,7 +68,7 @@ st,usb_control_register = <0x30>;
regulators { - compatible = "st,stpmu1-regulators"; + compatible = "st,stpmic1-regulators";
ldo1-supply = <&v3v3>; ldo2-supply = <&v3v3>; diff --git a/board/st/stm32mp1/README b/board/st/stm32mp1/README index 1c3e865..72b28fa 100644 --- a/board/st/stm32mp1/README +++ b/board/st/stm32mp1/README @@ -28,7 +28,7 @@ Everything is supported in Linux but U-Boot is limited to:
And the necessary drivers 1. I2C -2. STPMU1 (PMIC and regulator) +2. STPMIC1 (PMIC and regulator) 3. Clock, Reset, Sysreset 4. Fuse
@@ -70,10 +70,10 @@ Each board is configurated only with the associated device tree. You need to select the appropriate device tree for your board, the supported device trees for stm32mp157 are:
-+ ev1: eval board with pmic stpmu1 (ev1 = mother board + daughter ed1) ++ ev1: eval board with pmic stpmic1 (ev1 = mother board + daughter ed1) dts: stm32mp157c-ev1
-+ ed1: daughter board with pmic stpmu1 ++ ed1: daughter board with pmic stpmic1 dts: stm32mp157c-ed1
5. Build Procedure diff --git a/board/st/stm32mp1/board.c b/board/st/stm32mp1/board.c index 1bb9779..2a94f10 100644 --- a/board/st/stm32mp1/board.c +++ b/board/st/stm32mp1/board.c @@ -37,64 +37,65 @@ void board_debug_uart_init(void) } #endif
-#ifdef CONFIG_PMIC_STPMU1 +#ifdef CONFIG_PMIC_STPMIC1 int board_ddr_power_init(void) { struct udevice *dev; int ret;
ret = uclass_get_device_by_driver(UCLASS_PMIC, - DM_GET_DRIVER(pmic_stpmu1), &dev); + DM_GET_DRIVER(pmic_stpmic1), &dev); if (ret) /* No PMIC on board */ return 0;
- /* Set LDO3 to sync mode */ - ret = pmic_reg_read(dev, STPMU1_LDOX_CTRL_REG(STPMU1_LDO3)); + /* VTT = Set LDO3 to sync mode */ + ret = pmic_reg_read(dev, STPMIC1_LDOX_CTRL_REG(STPMIC1_LDO3)); if (ret < 0) return ret;
- ret &= ~STPMU1_LDO3_MODE; - ret &= ~STPMU1_LDO12356_OUTPUT_MASK; - ret |= STPMU1_LDO3_DDR_SEL << STPMU1_LDO12356_OUTPUT_SHIFT; + ret &= ~STPMIC1_LDO3_MODE; + ret &= ~STPMIC1_LDO12356_OUTPUT_MASK; + ret |= STPMIC1_LDO3_DDR_SEL << STPMIC1_LDO12356_OUTPUT_SHIFT;
- ret = pmic_reg_write(dev, STPMU1_LDOX_CTRL_REG(STPMU1_LDO3), + ret = pmic_reg_write(dev, STPMIC1_LDOX_CTRL_REG(STPMIC1_LDO3), ret); if (ret < 0) return ret;
- /* Set BUCK2 to 1.35V */ + /* VDD_DDR = Set BUCK2 to 1.35V */ ret = pmic_clrsetbits(dev, - STPMU1_BUCKX_CTRL_REG(STPMU1_BUCK2), - STPMU1_BUCK_OUTPUT_MASK, - STPMU1_BUCK2_1350000V); + STPMIC1_BUCKX_CTRL_REG(STPMIC1_BUCK2), + STPMIC1_BUCK_OUTPUT_MASK, + STPMIC1_BUCK2_1350000V); if (ret < 0) return ret;
- /* Enable BUCK2 and VREF */ + /* Enable VDD_DDR = BUCK2 */ ret = pmic_clrsetbits(dev, - STPMU1_BUCKX_CTRL_REG(STPMU1_BUCK2), - STPMU1_BUCK_EN, STPMU1_BUCK_EN); + STPMIC1_BUCKX_CTRL_REG(STPMIC1_BUCK2), + STPMIC1_BUCK_EN, STPMIC1_BUCK_EN); if (ret < 0) return ret;
- mdelay(STPMU1_DEFAULT_START_UP_DELAY_MS); + mdelay(STPMIC1_DEFAULT_START_UP_DELAY_MS);
- ret = pmic_clrsetbits(dev, STPMU1_VREF_CTRL_REG, - STPMU1_VREF_EN, STPMU1_VREF_EN); + /* Enable VREF */ + ret = pmic_clrsetbits(dev, STPMIC1_VREF_CTRL_REG, + STPMIC1_VREF_EN, STPMIC1_VREF_EN); if (ret < 0) return ret;
/* Enable LDO3 */ ret = pmic_clrsetbits(dev, - STPMU1_LDOX_CTRL_REG(STPMU1_LDO3), - STPMU1_LDO_EN, STPMU1_LDO_EN); + STPMIC1_LDOX_CTRL_REG(STPMIC1_LDO3), + STPMIC1_LDO_EN, STPMIC1_LDO_EN); if (ret < 0) return ret;
return 0; } diff --git a/board/st/stm32mp1/spl.c b/board/st/stm32mp1/spl.c index 1202297..546a923 100644 --- a/board/st/stm32mp1/spl.c +++ b/board/st/stm32mp1/spl.c @@ -17,16 +17,16 @@ void spl_board_init(void) { /* Keep vdd on during the reset cycle */ -#if defined(CONFIG_PMIC_STPMU1) && defined(CONFIG_SPL_POWER_SUPPORT) +#if defined(CONFIG_PMIC_STPMIC1) && defined(CONFIG_SPL_POWER_SUPPORT) struct udevice *dev; int ret;
ret = uclass_get_device_by_driver(UCLASS_PMIC, - DM_GET_DRIVER(pmic_stpmu1), &dev); + DM_GET_DRIVER(pmic_stpmic1), &dev); if (!ret) pmic_clrsetbits(dev, - STPMU1_MASK_RESET_BUCK, - STPMU1_MASK_RESET_BUCK3, - STPMU1_MASK_RESET_BUCK3); + STPMIC1_MASK_RESET_BUCK, + STPMIC1_MASK_RESET_BUCK3, + STPMIC1_MASK_RESET_BUCK3); #endif } diff --git a/configs/stm32mp15_basic_defconfig b/configs/stm32mp15_basic_defconfig index 304688e..ac597c7 100644 --- a/configs/stm32mp15_basic_defconfig +++ b/configs/stm32mp15_basic_defconfig @@ -46,11 +46,11 @@ CONFIG_PHY_STM32_USBPHYC=y # CONFIG_SPL_PINCTRL_FULL is not set CONFIG_DM_PMIC=y # CONFIG_SPL_PMIC_CHILDREN is not set -CONFIG_PMIC_STPMU1=y +CONFIG_PMIC_STPMIC1=y CONFIG_DM_REGULATOR_FIXED=y CONFIG_DM_REGULATOR_GPIO=y CONFIG_DM_REGULATOR_STM32_VREFBUF=y -CONFIG_DM_REGULATOR_STPMU1=y +CONFIG_DM_REGULATOR_STPMIC1=y CONFIG_SERIAL_RX_BUFFER=y CONFIG_STM32_SERIAL=y CONFIG_USB=y diff --git a/configs/stm32mp15_trusted_defconfig b/configs/stm32mp15_trusted_defconfig index e905ae1..3e8a6fd 100644 --- a/configs/stm32mp15_trusted_defconfig +++ b/configs/stm32mp15_trusted_defconfig @@ -37,11 +37,11 @@ CONFIG_PHY=y CONFIG_PHY_STM32_USBPHYC=y # CONFIG_PINCTRL_FULL is not set CONFIG_DM_PMIC=y -CONFIG_PMIC_STPMU1=y +CONFIG_PMIC_STPMIC1=y CONFIG_DM_REGULATOR_FIXED=y CONFIG_DM_REGULATOR_GPIO=y CONFIG_DM_REGULATOR_STM32_VREFBUF=y -CONFIG_DM_REGULATOR_STPMU1=y +CONFIG_DM_REGULATOR_STPMIC1=y CONFIG_SERIAL_RX_BUFFER=y CONFIG_STM32_SERIAL=y CONFIG_USB=y diff --git a/drivers/power/pmic/Kconfig b/drivers/power/pmic/Kconfig index 8cf60eb..b0cd260 100644 --- a/drivers/power/pmic/Kconfig +++ b/drivers/power/pmic/Kconfig @@ -231,10 +231,10 @@ config DM_PMIC_TPS65910 DC-DC converter, 8 LDOs and a RTC. This driver binds the SMPS and LDO pmic children.
-config PMIC_STPMU1 - bool "Enable support for STMicroelectronics STPMU1 PMIC" +config PMIC_STPMIC1 + bool "Enable support for STMicroelectronics STPMIC1 PMIC" depends on DM_PMIC && DM_I2C ---help--- - The STPMU1 PMIC provides 4 BUCKs, 6 LDOs, 1 VREF and 2 power switches. + The STPMIC1 PMIC provides 4 BUCKs, 6 LDOs, 1 VREF and 2 power switches. It is accessed via an I2C interface. The device is used with STM32MP1 SoCs. This driver implements register read/write operations. diff --git a/drivers/power/pmic/Makefile b/drivers/power/pmic/Makefile index 147ac76..ce250cb 100644 --- a/drivers/power/pmic/Makefile +++ b/drivers/power/pmic/Makefile @@ -23,7 +23,7 @@ obj-$(CONFIG_DM_PMIC_TPS65910) += pmic_tps65910_dm.o obj-$(CONFIG_$(SPL_)PMIC_PALMAS) += palmas.o obj-$(CONFIG_$(SPL_)PMIC_LP873X) += lp873x.o obj-$(CONFIG_$(SPL_)PMIC_LP87565) += lp87565.o -obj-$(CONFIG_PMIC_STPMU1) += stpmic1.o +obj-$(CONFIG_PMIC_STPMIC1) += stpmic1.o
obj-$(CONFIG_POWER_LTC3676) += pmic_ltc3676.o obj-$(CONFIG_POWER_MAX77696) += pmic_max77696.o diff --git a/drivers/power/pmic/stpmic1.c b/drivers/power/pmic/stpmic1.c index 157ce8b..25450eb 100644 --- a/drivers/power/pmic/stpmic1.c +++ b/drivers/power/pmic/stpmic1.c @@ -10,26 +10,26 @@ #include <power/pmic.h> #include <power/stpmic1.h>
-#define STMPU1_NUM_OF_REGS 0x100 - -#ifndef CONFIG_SPL_BUILD -static const struct pmic_child_info stpmu1_children_info[] = { - { .prefix = "ldo", .driver = "stpmu1_ldo" }, - { .prefix = "buck", .driver = "stpmu1_buck" }, - { .prefix = "vref_ddr", .driver = "stpmu1_vref_ddr" }, - { .prefix = "pwr_sw", .driver = "stpmu1_pwr_sw" }, - { .prefix = "boost", .driver = "stpmu1_boost" }, +#define STPMIC1_NUM_OF_REGS 0x100 + +#if CONFIG_IS_ENABLED(DM_REGULATOR) +static const struct pmic_child_info stpmic1_children_info[] = { + { .prefix = "ldo", .driver = "stpmic1_ldo" }, + { .prefix = "buck", .driver = "stpmic1_buck" }, + { .prefix = "vref_ddr", .driver = "stpmic1_vref_ddr" }, + { .prefix = "pwr_sw", .driver = "stpmic1_pwr_sw" }, + { .prefix = "boost", .driver = "stpmic1_boost" }, { }, }; -#endif /* CONFIG_SPL_BUILD */ +#endif /* DM_REGULATOR */
-static int stpmu1_reg_count(struct udevice *dev) +static int stpmic1_reg_count(struct udevice *dev) { - return STMPU1_NUM_OF_REGS; + return STPMIC1_NUM_OF_REGS; }
-static int stpmu1_write(struct udevice *dev, uint reg, const uint8_t *buff, - int len) +static int stpmic1_write(struct udevice *dev, uint reg, const uint8_t *buff, + int len) { int ret;
@@ -41,7 +41,7 @@ static int stpmu1_write(struct udevice *dev, uint reg, const uint8_t *buff, return ret; }
-static int stpmu1_read(struct udevice *dev, uint reg, uint8_t *buff, int len) +static int stpmic1_read(struct udevice *dev, uint reg, uint8_t *buff, int len) { int ret;
@@ -53,43 +53,43 @@ static int stpmu1_read(struct udevice *dev, uint reg, uint8_t *buff, int len) return ret; }
-static int stpmu1_bind(struct udevice *dev) +static int stpmic1_bind(struct udevice *dev) { -#ifndef CONFIG_SPL_BUILD +#if CONFIG_IS_ENABLED(DM_REGULATOR) ofnode regulators_node; int children;
regulators_node = dev_read_subnode(dev, "regulators"); if (!ofnode_valid(regulators_node)) { - dev_dbg(dev, "regulators subnode not found!\n"); + dev_dbg(dev, "regulators subnode not found!"); return -ENXIO; } dev_dbg(dev, "found regulators subnode\n");
children = pmic_bind_children(dev, regulators_node, - stpmu1_children_info); + stpmic1_children_info); if (!children) dev_dbg(dev, "no child found\n"); -#endif /* CONFIG_SPL_BUILD */ +#endif /* DM_REGULATOR */
return 0; }
-static struct dm_pmic_ops stpmu1_ops = { - .reg_count = stpmu1_reg_count, - .read = stpmu1_read, - .write = stpmu1_write, +static struct dm_pmic_ops stpmic1_ops = { + .reg_count = stpmic1_reg_count, + .read = stpmic1_read, + .write = stpmic1_write, };
-static const struct udevice_id stpmu1_ids[] = { - { .compatible = "st,stpmu1" }, +static const struct udevice_id stpmic1_ids[] = { + { .compatible = "st,stpmic1" }, { } };
-U_BOOT_DRIVER(pmic_stpmu1) = { - .name = "stpmu1_pmic", +U_BOOT_DRIVER(pmic_stpmic1) = { + .name = "stpmic1_pmic", .id = UCLASS_PMIC, - .of_match = stpmu1_ids, - .bind = stpmu1_bind, - .ops = &stpmu1_ops, + .of_match = stpmic1_ids, + .bind = stpmic1_bind, + .ops = &stpmic1_ops, }; diff --git a/drivers/power/regulator/Kconfig b/drivers/power/regulator/Kconfig index 3ed0dd2..72dfc48 100644 --- a/drivers/power/regulator/Kconfig +++ b/drivers/power/regulator/Kconfig @@ -244,11 +244,17 @@ config DM_REGULATOR_TPS65910 regulator types of the TPS65910 (BUCK, BOOST and LDO). It implements the get/set api for value and enable.
-config DM_REGULATOR_STPMU1 - bool "Enable driver for STPMU1 regulators" - depends on DM_REGULATOR && PMIC_STPMU1 +config DM_REGULATOR_STPMIC1 + bool "Enable driver for STPMIC1 regulators" + depends on DM_REGULATOR && PMIC_STPMIC1 ---help--- - Enable support for the regulator functions of the STPMU1 PMIC. The + Enable support for the regulator functions of the STPMIC1 PMIC. The driver implements get/set api for the various BUCKS and LDOs supported by the PMIC device. This driver is controlled by a device tree node which includes voltage limits. + +config SPL_DM_REGULATOR_STPMIC1 + bool "Enable driver for STPMIC1 regulators in SPL" + depends on SPL_DM_REGULATOR && PMIC_STPMIC1 + help + Enable support for the regulator functions of the STPMIC1 PMIC in SPL. diff --git a/drivers/power/regulator/Makefile b/drivers/power/regulator/Makefile index cfc91e8..8c1506c 100644 --- a/drivers/power/regulator/Makefile +++ b/drivers/power/regulator/Makefile @@ -24,4 +24,4 @@ obj-$(CONFIG_$(SPL_)DM_REGULATOR_LP873X) += lp873x_regulator.o obj-$(CONFIG_$(SPL_)DM_REGULATOR_LP87565) += lp87565_regulator.o obj-$(CONFIG_$(SPL_)DM_REGULATOR_STM32_VREFBUF) += stm32-vrefbuf.o obj-$(CONFIG_DM_REGULATOR_TPS65910) += tps65910_regulator.o -obj-$(CONFIG_$(SPL_)DM_REGULATOR_STPMU1) += stpmic1.o +obj-$(CONFIG_$(SPL_)DM_REGULATOR_STPMIC1) += stpmic1.o diff --git a/drivers/power/regulator/stpmic1.c b/drivers/power/regulator/stpmic1.c index c62a19a..8602583 100644 --- a/drivers/power/regulator/stpmic1.c +++ b/drivers/power/regulator/stpmic1.c @@ -11,44 +11,44 @@ #include <power/regulator.h> #include <power/stpmic1.h>
-struct stpmu1_range { +struct stpmic1_range { int min_uv; int min_sel; int max_sel; int step; };
-struct stpmu1_output_range { - const struct stpmu1_range *ranges; +struct stpmic1_output { + const struct stpmic1_range *ranges; int nbranges; };
-#define STPMU1_MODE(_id, _val, _name) { \ +#define STPMIC1_MODE(_id, _val, _name) { \ .id = _id, \ .register_value = _val, \ .name = _name, \ }
-#define STPMU1_RANGE(_min_uv, _min_sel, _max_sel, _step) { \ +#define STPMIC1_RANGE(_min_uv, _min_sel, _max_sel, _step) { \ .min_uv = _min_uv, \ .min_sel = _min_sel, \ .max_sel = _max_sel, \ .step = _step, \ }
-#define STPMU1_OUTPUT_RANGE(_ranges, _nbranges) { \ +#define STPMIC1_OUTPUT(_ranges, _nbranges) { \ .ranges = _ranges, \ .nbranges = _nbranges, \ }
-static int stpmu1_output_find_uv(int sel, - const struct stpmu1_output_range *output_range) +static int stpmic1_output_find_uv(int sel, + const struct stpmic1_output *output) { - const struct stpmu1_range *range; + const struct stpmic1_range *range; int i;
- for (i = 0, range = output_range->ranges; - i < output_range->nbranges; i++, range++) { + for (i = 0, range = output->ranges; + i < output->nbranges; i++, range++) { if (sel >= range->min_sel && sel <= range->max_sel) return range->min_uv + (sel - range->min_sel) * range->step; @@ -57,14 +57,14 @@ static int stpmu1_output_find_uv(int sel, return -EINVAL; }
-static int stpmu1_output_find_sel(int uv, - const struct stpmu1_output_range *output_range) +static int stpmic1_output_find_sel(int uv, + const struct stpmic1_output *output) { - const struct stpmu1_range *range; + const struct stpmic1_range *range; int i;
- for (i = 0, range = output_range->ranges; - i < output_range->nbranges; i++, range++) { + for (i = 0, range = output->ranges; + i < output->nbranges; i++, range++) { if (uv == range->min_uv && !range->step) return range->min_sel;
@@ -82,157 +82,157 @@ static int stpmu1_output_find_sel(int uv, * BUCK regulators */
-static const struct stpmu1_range buck1_ranges[] = { - STPMU1_RANGE(725000, 0, 4, 0), - STPMU1_RANGE(725000, 5, 36, 25000), - STPMU1_RANGE(1500000, 37, 63, 0), +static const struct stpmic1_range buck1_ranges[] = { + STPMIC1_RANGE(725000, 0, 4, 0), + STPMIC1_RANGE(725000, 5, 36, 25000), + STPMIC1_RANGE(1500000, 37, 63, 0), };
-static const struct stpmu1_range buck2_ranges[] = { - STPMU1_RANGE(1000000, 0, 17, 0), - STPMU1_RANGE(1050000, 18, 19, 0), - STPMU1_RANGE(1100000, 20, 21, 0), - STPMU1_RANGE(1150000, 22, 23, 0), - STPMU1_RANGE(1200000, 24, 25, 0), - STPMU1_RANGE(1250000, 26, 27, 0), - STPMU1_RANGE(1300000, 28, 29, 0), - STPMU1_RANGE(1350000, 30, 31, 0), - STPMU1_RANGE(1400000, 32, 33, 0), - STPMU1_RANGE(1450000, 34, 35, 0), - STPMU1_RANGE(1500000, 36, 63, 0), +static const struct stpmic1_range buck2_ranges[] = { + STPMIC1_RANGE(1000000, 0, 17, 0), + STPMIC1_RANGE(1050000, 18, 19, 0), + STPMIC1_RANGE(1100000, 20, 21, 0), + STPMIC1_RANGE(1150000, 22, 23, 0), + STPMIC1_RANGE(1200000, 24, 25, 0), + STPMIC1_RANGE(1250000, 26, 27, 0), + STPMIC1_RANGE(1300000, 28, 29, 0), + STPMIC1_RANGE(1350000, 30, 31, 0), + STPMIC1_RANGE(1400000, 32, 33, 0), + STPMIC1_RANGE(1450000, 34, 35, 0), + STPMIC1_RANGE(1500000, 36, 63, 0), };
-static const struct stpmu1_range buck3_ranges[] = { - STPMU1_RANGE(1000000, 0, 19, 0), - STPMU1_RANGE(1100000, 20, 23, 0), - STPMU1_RANGE(1200000, 24, 27, 0), - STPMU1_RANGE(1300000, 28, 31, 0), - STPMU1_RANGE(1400000, 32, 35, 0), - STPMU1_RANGE(1500000, 36, 55, 100000), - STPMU1_RANGE(3400000, 56, 63, 0), +static const struct stpmic1_range buck3_ranges[] = { + STPMIC1_RANGE(1000000, 0, 19, 0), + STPMIC1_RANGE(1100000, 20, 23, 0), + STPMIC1_RANGE(1200000, 24, 27, 0), + STPMIC1_RANGE(1300000, 28, 31, 0), + STPMIC1_RANGE(1400000, 32, 35, 0), + STPMIC1_RANGE(1500000, 36, 55, 100000), + STPMIC1_RANGE(3400000, 56, 63, 0), };
-static const struct stpmu1_range buck4_ranges[] = { - STPMU1_RANGE(600000, 0, 27, 25000), - STPMU1_RANGE(1300000, 28, 29, 0), - STPMU1_RANGE(1350000, 30, 31, 0), - STPMU1_RANGE(1400000, 32, 33, 0), - STPMU1_RANGE(1450000, 34, 35, 0), - STPMU1_RANGE(1500000, 36, 60, 100000), - STPMU1_RANGE(3900000, 61, 63, 0), +static const struct stpmic1_range buck4_ranges[] = { + STPMIC1_RANGE(600000, 0, 27, 25000), + STPMIC1_RANGE(1300000, 28, 29, 0), + STPMIC1_RANGE(1350000, 30, 31, 0), + STPMIC1_RANGE(1400000, 32, 33, 0), + STPMIC1_RANGE(1450000, 34, 35, 0), + STPMIC1_RANGE(1500000, 36, 60, 100000), + STPMIC1_RANGE(3900000, 61, 63, 0), };
/* BUCK: 1,2,3,4 - voltage ranges */ -static const struct stpmu1_output_range buck_voltage_range[] = { - STPMU1_OUTPUT_RANGE(buck1_ranges, ARRAY_SIZE(buck1_ranges)), - STPMU1_OUTPUT_RANGE(buck2_ranges, ARRAY_SIZE(buck2_ranges)), - STPMU1_OUTPUT_RANGE(buck3_ranges, ARRAY_SIZE(buck3_ranges)), - STPMU1_OUTPUT_RANGE(buck4_ranges, ARRAY_SIZE(buck4_ranges)), +static const struct stpmic1_output buck_voltage_range[] = { + STPMIC1_OUTPUT(buck1_ranges, ARRAY_SIZE(buck1_ranges)), + STPMIC1_OUTPUT(buck2_ranges, ARRAY_SIZE(buck2_ranges)), + STPMIC1_OUTPUT(buck3_ranges, ARRAY_SIZE(buck3_ranges)), + STPMIC1_OUTPUT(buck4_ranges, ARRAY_SIZE(buck4_ranges)), };
/* BUCK modes */ static const struct dm_regulator_mode buck_modes[] = { - STPMU1_MODE(STPMU1_BUCK_MODE_HP, STPMU1_BUCK_MODE_HP, "HP"), - STPMU1_MODE(STPMU1_BUCK_MODE_LP, STPMU1_BUCK_MODE_LP, "LP"), + STPMIC1_MODE(STPMIC1_BUCK_MODE_HP, STPMIC1_BUCK_MODE_HP, "HP"), + STPMIC1_MODE(STPMIC1_BUCK_MODE_LP, STPMIC1_BUCK_MODE_LP, "LP"), };
-static int stpmu1_buck_get_uv(struct udevice *dev, int buck) +static int stpmic1_buck_get_uv(struct udevice *dev, int buck) { int sel;
- sel = pmic_reg_read(dev, STPMU1_BUCKX_CTRL_REG(buck)); + sel = pmic_reg_read(dev, STPMIC1_BUCKX_CTRL_REG(buck)); if (sel < 0) return sel;
- sel &= STPMU1_BUCK_OUTPUT_MASK; - sel >>= STPMU1_BUCK_OUTPUT_SHIFT; + sel &= STPMIC1_BUCK_OUTPUT_MASK; + sel >>= STPMIC1_BUCK_OUTPUT_SHIFT;
- return stpmu1_output_find_uv(sel, &buck_voltage_range[buck]); + return stpmic1_output_find_uv(sel, &buck_voltage_range[buck]); }
-static int stpmu1_buck_get_value(struct udevice *dev) +static int stpmic1_buck_get_value(struct udevice *dev) { - return stpmu1_buck_get_uv(dev->parent, dev->driver_data - 1); + return stpmic1_buck_get_uv(dev->parent, dev->driver_data - 1); }
-static int stpmu1_buck_set_value(struct udevice *dev, int uv) +static int stpmic1_buck_set_value(struct udevice *dev, int uv) { int sel, buck = dev->driver_data - 1;
- sel = stpmu1_output_find_sel(uv, &buck_voltage_range[buck]); + sel = stpmic1_output_find_sel(uv, &buck_voltage_range[buck]); if (sel < 0) return sel;
return pmic_clrsetbits(dev->parent, - STPMU1_BUCKX_CTRL_REG(buck), - STPMU1_BUCK_OUTPUT_MASK, - sel << STPMU1_BUCK_OUTPUT_SHIFT); + STPMIC1_BUCKX_CTRL_REG(buck), + STPMIC1_BUCK_OUTPUT_MASK, + sel << STPMIC1_BUCK_OUTPUT_SHIFT); }
-static int stpmu1_buck_get_enable(struct udevice *dev) +static int stpmic1_buck_get_enable(struct udevice *dev) { int ret;
ret = pmic_reg_read(dev->parent, - STPMU1_BUCKX_CTRL_REG(dev->driver_data - 1)); + STPMIC1_BUCKX_CTRL_REG(dev->driver_data - 1)); if (ret < 0) return false;
- return ret & STPMU1_BUCK_EN ? true : false; + return ret & STPMIC1_BUCK_EN ? true : false; }
-static int stpmu1_buck_set_enable(struct udevice *dev, bool enable) +static int stpmic1_buck_set_enable(struct udevice *dev, bool enable) { struct dm_regulator_uclass_platdata *uc_pdata; - int delay = enable ? STPMU1_DEFAULT_START_UP_DELAY_MS : - STPMU1_DEFAULT_STOP_DELAY_MS; + int delay = enable ? STPMIC1_DEFAULT_START_UP_DELAY_MS : + STPMIC1_DEFAULT_STOP_DELAY_MS; int ret, uv;
/* if regulator is already in the wanted state, nothing to do */ - if (stpmu1_buck_get_enable(dev) == enable) + if (stpmic1_buck_get_enable(dev) == enable) return 0;
if (enable) { uc_pdata = dev_get_uclass_platdata(dev); - uv = stpmu1_buck_get_value(dev); - if ((uv < uc_pdata->min_uV) || (uv > uc_pdata->max_uV)) - stpmu1_buck_set_value(dev, uc_pdata->min_uV); + uv = stpmic1_buck_get_value(dev); + if (uv < uc_pdata->min_uV || uv > uc_pdata->max_uV) + stpmic1_buck_set_value(dev, uc_pdata->min_uV); }
ret = pmic_clrsetbits(dev->parent, - STPMU1_BUCKX_CTRL_REG(dev->driver_data - 1), - STPMU1_BUCK_EN, enable ? STPMU1_BUCK_EN : 0); + STPMIC1_BUCKX_CTRL_REG(dev->driver_data - 1), + STPMIC1_BUCK_EN, enable ? STPMIC1_BUCK_EN : 0); mdelay(delay);
return ret; }
-static int stpmu1_buck_get_mode(struct udevice *dev) +static int stpmic1_buck_get_mode(struct udevice *dev) { int ret;
ret = pmic_reg_read(dev->parent, - STPMU1_BUCKX_CTRL_REG(dev->driver_data - 1)); + STPMIC1_BUCKX_CTRL_REG(dev->driver_data - 1)); if (ret < 0) return ret;
- return ret & STPMU1_BUCK_MODE ? STPMU1_BUCK_MODE_LP : - STPMU1_BUCK_MODE_HP; + return ret & STPMIC1_BUCK_MODE ? STPMIC1_BUCK_MODE_LP : + STPMIC1_BUCK_MODE_HP; }
-static int stpmu1_buck_set_mode(struct udevice *dev, int mode) +static int stpmic1_buck_set_mode(struct udevice *dev, int mode) { return pmic_clrsetbits(dev->parent, - STPMU1_BUCKX_CTRL_REG(dev->driver_data - 1), - STPMU1_BUCK_MODE, - mode ? STPMU1_BUCK_MODE : 0); + STPMIC1_BUCKX_CTRL_REG(dev->driver_data - 1), + STPMIC1_BUCK_MODE, + mode ? STPMIC1_BUCK_MODE : 0); }
-static int stpmu1_buck_probe(struct udevice *dev) +static int stpmic1_buck_probe(struct udevice *dev) { struct dm_regulator_uclass_platdata *uc_pdata;
- if (!dev->driver_data || dev->driver_data > STPMU1_MAX_BUCK) + if (!dev->driver_data || dev->driver_data > STPMIC1_MAX_BUCK) return -EINVAL;
uc_pdata = dev_get_uclass_platdata(dev); @@ -244,206 +244,206 @@ static int stpmu1_buck_probe(struct udevice *dev) return 0; }
-static const struct dm_regulator_ops stpmu1_buck_ops = { - .get_value = stpmu1_buck_get_value, - .set_value = stpmu1_buck_set_value, - .get_enable = stpmu1_buck_get_enable, - .set_enable = stpmu1_buck_set_enable, - .get_mode = stpmu1_buck_get_mode, - .set_mode = stpmu1_buck_set_mode, +static const struct dm_regulator_ops stpmic1_buck_ops = { + .get_value = stpmic1_buck_get_value, + .set_value = stpmic1_buck_set_value, + .get_enable = stpmic1_buck_get_enable, + .set_enable = stpmic1_buck_set_enable, + .get_mode = stpmic1_buck_get_mode, + .set_mode = stpmic1_buck_set_mode, };
-U_BOOT_DRIVER(stpmu1_buck) = { - .name = "stpmu1_buck", +U_BOOT_DRIVER(stpmic1_buck) = { + .name = "stpmic1_buck", .id = UCLASS_REGULATOR, - .ops = &stpmu1_buck_ops, - .probe = stpmu1_buck_probe, + .ops = &stpmic1_buck_ops, + .probe = stpmic1_buck_probe, };
/* * LDO regulators */
-static const struct stpmu1_range ldo12_ranges[] = { - STPMU1_RANGE(1700000, 0, 7, 0), - STPMU1_RANGE(1700000, 8, 24, 100000), - STPMU1_RANGE(3300000, 25, 31, 0), +static const struct stpmic1_range ldo12_ranges[] = { + STPMIC1_RANGE(1700000, 0, 7, 0), + STPMIC1_RANGE(1700000, 8, 24, 100000), + STPMIC1_RANGE(3300000, 25, 31, 0), };
-static const struct stpmu1_range ldo3_ranges[] = { - STPMU1_RANGE(1700000, 0, 7, 0), - STPMU1_RANGE(1700000, 8, 24, 100000), - STPMU1_RANGE(3300000, 25, 30, 0), +static const struct stpmic1_range ldo3_ranges[] = { + STPMIC1_RANGE(1700000, 0, 7, 0), + STPMIC1_RANGE(1700000, 8, 24, 100000), + STPMIC1_RANGE(3300000, 25, 30, 0), /* Sel 31 is special case when LDO3 is in mode sync_source (BUCK2/2) */ };
-static const struct stpmu1_range ldo5_ranges[] = { - STPMU1_RANGE(1700000, 0, 7, 0), - STPMU1_RANGE(1700000, 8, 30, 100000), - STPMU1_RANGE(3900000, 31, 31, 0), +static const struct stpmic1_range ldo5_ranges[] = { + STPMIC1_RANGE(1700000, 0, 7, 0), + STPMIC1_RANGE(1700000, 8, 30, 100000), + STPMIC1_RANGE(3900000, 31, 31, 0), };
-static const struct stpmu1_range ldo6_ranges[] = { - STPMU1_RANGE(900000, 0, 24, 100000), - STPMU1_RANGE(3300000, 25, 31, 0), +static const struct stpmic1_range ldo6_ranges[] = { + STPMIC1_RANGE(900000, 0, 24, 100000), + STPMIC1_RANGE(3300000, 25, 31, 0), };
/* LDO: 1,2,3,4,5,6 - voltage ranges */ -static const struct stpmu1_output_range ldo_voltage_range[] = { - STPMU1_OUTPUT_RANGE(ldo12_ranges, ARRAY_SIZE(ldo12_ranges)), - STPMU1_OUTPUT_RANGE(ldo12_ranges, ARRAY_SIZE(ldo12_ranges)), - STPMU1_OUTPUT_RANGE(ldo3_ranges, ARRAY_SIZE(ldo3_ranges)), - STPMU1_OUTPUT_RANGE(NULL, 0), - STPMU1_OUTPUT_RANGE(ldo5_ranges, ARRAY_SIZE(ldo5_ranges)), - STPMU1_OUTPUT_RANGE(ldo6_ranges, ARRAY_SIZE(ldo6_ranges)), +static const struct stpmic1_output ldo_voltage_range[] = { + STPMIC1_OUTPUT(ldo12_ranges, ARRAY_SIZE(ldo12_ranges)), + STPMIC1_OUTPUT(ldo12_ranges, ARRAY_SIZE(ldo12_ranges)), + STPMIC1_OUTPUT(ldo3_ranges, ARRAY_SIZE(ldo3_ranges)), + STPMIC1_OUTPUT(NULL, 0), + STPMIC1_OUTPUT(ldo5_ranges, ARRAY_SIZE(ldo5_ranges)), + STPMIC1_OUTPUT(ldo6_ranges, ARRAY_SIZE(ldo6_ranges)), };
/* LDO modes */ static const struct dm_regulator_mode ldo_modes[] = { - STPMU1_MODE(STPMU1_LDO_MODE_NORMAL, - STPMU1_LDO_MODE_NORMAL, "NORMAL"), - STPMU1_MODE(STPMU1_LDO_MODE_BYPASS, - STPMU1_LDO_MODE_BYPASS, "BYPASS"), - STPMU1_MODE(STPMU1_LDO_MODE_SINK_SOURCE, - STPMU1_LDO_MODE_SINK_SOURCE, "SINK SOURCE"), + STPMIC1_MODE(STPMIC1_LDO_MODE_NORMAL, + STPMIC1_LDO_MODE_NORMAL, "NORMAL"), + STPMIC1_MODE(STPMIC1_LDO_MODE_BYPASS, + STPMIC1_LDO_MODE_BYPASS, "BYPASS"), + STPMIC1_MODE(STPMIC1_LDO_MODE_SINK_SOURCE, + STPMIC1_LDO_MODE_SINK_SOURCE, "SINK SOURCE"), };
-static int stpmu1_ldo_get_value(struct udevice *dev) +static int stpmic1_ldo_get_value(struct udevice *dev) { int sel, ldo = dev->driver_data - 1;
- sel = pmic_reg_read(dev->parent, STPMU1_LDOX_CTRL_REG(ldo)); + sel = pmic_reg_read(dev->parent, STPMIC1_LDOX_CTRL_REG(ldo)); if (sel < 0) return sel;
/* ldo4 => 3,3V */ - if (ldo == STPMU1_LDO4) - return STPMU1_LDO4_UV; + if (ldo == STPMIC1_LDO4) + return STPMIC1_LDO4_UV;
- sel &= STPMU1_LDO12356_OUTPUT_MASK; - sel >>= STPMU1_LDO12356_OUTPUT_SHIFT; + sel &= STPMIC1_LDO12356_OUTPUT_MASK; + sel >>= STPMIC1_LDO12356_OUTPUT_SHIFT;
/* ldo3, sel = 31 => BUCK2/2 */ - if (ldo == STPMU1_LDO3 && sel == STPMU1_LDO3_DDR_SEL) - return stpmu1_buck_get_uv(dev->parent, STPMU1_BUCK2) / 2; + if (ldo == STPMIC1_LDO3 && sel == STPMIC1_LDO3_DDR_SEL) + return stpmic1_buck_get_uv(dev->parent, STPMIC1_BUCK2) / 2;
- return stpmu1_output_find_uv(sel, &ldo_voltage_range[ldo]); + return stpmic1_output_find_uv(sel, &ldo_voltage_range[ldo]); }
-static int stpmu1_ldo_set_value(struct udevice *dev, int uv) +static int stpmic1_ldo_set_value(struct udevice *dev, int uv) { int sel, ldo = dev->driver_data - 1;
/* ldo4 => not possible */ - if (ldo == STPMU1_LDO4) + if (ldo == STPMIC1_LDO4) return -EINVAL;
- sel = stpmu1_output_find_sel(uv, &ldo_voltage_range[ldo]); + sel = stpmic1_output_find_sel(uv, &ldo_voltage_range[ldo]); if (sel < 0) return sel;
return pmic_clrsetbits(dev->parent, - STPMU1_LDOX_CTRL_REG(ldo), - STPMU1_LDO12356_OUTPUT_MASK, - sel << STPMU1_LDO12356_OUTPUT_SHIFT); + STPMIC1_LDOX_CTRL_REG(ldo), + STPMIC1_LDO12356_OUTPUT_MASK, + sel << STPMIC1_LDO12356_OUTPUT_SHIFT); }
-static int stpmu1_ldo_get_enable(struct udevice *dev) +static int stpmic1_ldo_get_enable(struct udevice *dev) { int ret;
ret = pmic_reg_read(dev->parent, - STPMU1_LDOX_CTRL_REG(dev->driver_data - 1)); + STPMIC1_LDOX_CTRL_REG(dev->driver_data - 1)); if (ret < 0) return false;
- return ret & STPMU1_LDO_EN ? true : false; + return ret & STPMIC1_LDO_EN ? true : false; }
-static int stpmu1_ldo_set_enable(struct udevice *dev, bool enable) +static int stpmic1_ldo_set_enable(struct udevice *dev, bool enable) { struct dm_regulator_uclass_platdata *uc_pdata; - int delay = enable ? STPMU1_DEFAULT_START_UP_DELAY_MS : - STPMU1_DEFAULT_STOP_DELAY_MS; + int delay = enable ? STPMIC1_DEFAULT_START_UP_DELAY_MS : + STPMIC1_DEFAULT_STOP_DELAY_MS; int ret, uv;
/* if regulator is already in the wanted state, nothing to do */ - if (stpmu1_ldo_get_enable(dev) == enable) + if (stpmic1_ldo_get_enable(dev) == enable) return 0;
if (enable) { uc_pdata = dev_get_uclass_platdata(dev); - uv = stpmu1_ldo_get_value(dev); - if ((uv < uc_pdata->min_uV) || (uv > uc_pdata->max_uV)) - stpmu1_ldo_set_value(dev, uc_pdata->min_uV); + uv = stpmic1_ldo_get_value(dev); + if (uv < uc_pdata->min_uV || uv > uc_pdata->max_uV) + stpmic1_ldo_set_value(dev, uc_pdata->min_uV); }
ret = pmic_clrsetbits(dev->parent, - STPMU1_LDOX_CTRL_REG(dev->driver_data - 1), - STPMU1_LDO_EN, enable ? STPMU1_LDO_EN : 0); + STPMIC1_LDOX_CTRL_REG(dev->driver_data - 1), + STPMIC1_LDO_EN, enable ? STPMIC1_LDO_EN : 0); mdelay(delay);
return ret; }
-static int stpmu1_ldo_get_mode(struct udevice *dev) +static int stpmic1_ldo_get_mode(struct udevice *dev) { int ret, ldo = dev->driver_data - 1;
- if (ldo != STPMU1_LDO3) + if (ldo != STPMIC1_LDO3) return -EINVAL;
- ret = pmic_reg_read(dev->parent, STPMU1_LDOX_CTRL_REG(ldo)); + ret = pmic_reg_read(dev->parent, STPMIC1_LDOX_CTRL_REG(ldo)); if (ret < 0) return ret;
- if (ret & STPMU1_LDO3_MODE) - return STPMU1_LDO_MODE_BYPASS; + if (ret & STPMIC1_LDO3_MODE) + return STPMIC1_LDO_MODE_BYPASS;
- ret &= STPMU1_LDO12356_OUTPUT_MASK; - ret >>= STPMU1_LDO12356_OUTPUT_SHIFT; + ret &= STPMIC1_LDO12356_OUTPUT_MASK; + ret >>= STPMIC1_LDO12356_OUTPUT_SHIFT;
- return ret == STPMU1_LDO3_DDR_SEL ? STPMU1_LDO_MODE_SINK_SOURCE : - STPMU1_LDO_MODE_NORMAL; + return ret == STPMIC1_LDO3_DDR_SEL ? STPMIC1_LDO_MODE_SINK_SOURCE : + STPMIC1_LDO_MODE_NORMAL; }
-static int stpmu1_ldo_set_mode(struct udevice *dev, int mode) +static int stpmic1_ldo_set_mode(struct udevice *dev, int mode) { int ret, ldo = dev->driver_data - 1;
switch (mode) { - case STPMU1_LDO_MODE_SINK_SOURCE: - ret &= ~STPMU1_LDO12356_OUTPUT_MASK; - ret |= STPMU1_LDO3_DDR_SEL << STPMU1_LDO12356_OUTPUT_SHIFT; - case STPMU1_LDO_MODE_NORMAL: - ret &= ~STPMU1_LDO3_MODE; + case STPMIC1_LDO_MODE_SINK_SOURCE: + ret &= ~STPMIC1_LDO12356_OUTPUT_MASK; + ret |= STPMIC1_LDO3_DDR_SEL << STPMIC1_LDO12356_OUTPUT_SHIFT; + case STPMIC1_LDO_MODE_NORMAL: + ret &= ~STPMIC1_LDO3_MODE; break; - case STPMU1_LDO_MODE_BYPASS: - ret |= STPMU1_LDO3_MODE; + case STPMIC1_LDO_MODE_BYPASS: + ret |= STPMIC1_LDO3_MODE; break; }
- return pmic_reg_write(dev->parent, STPMU1_LDOX_CTRL_REG(ldo), ret); + return pmic_reg_write(dev->parent, STPMIC1_LDOX_CTRL_REG(ldo), ret); }
-static int stpmu1_ldo_probe(struct udevice *dev) +static int stpmic1_ldo_probe(struct udevice *dev) { struct dm_regulator_uclass_platdata *uc_pdata;
- if (!dev->driver_data || dev->driver_data > STPMU1_MAX_LDO) + if (!dev->driver_data || dev->driver_data > STPMIC1_MAX_LDO) return -EINVAL;
uc_pdata->type = REGULATOR_TYPE_LDO; - if (dev->driver_data - 1 == STPMU1_LDO3) { + if (dev->driver_data - 1 == STPMIC1_LDO3) { uc_pdata->mode = (struct dm_regulator_mode *)ldo_modes; uc_pdata->mode_count = ARRAY_SIZE(ldo_modes); } else { @@ -453,61 +453,61 @@ static int stpmu1_ldo_probe(struct udevice *dev) return 0; }
-static const struct dm_regulator_ops stpmu1_ldo_ops = { - .get_value = stpmu1_ldo_get_value, - .set_value = stpmu1_ldo_set_value, - .get_enable = stpmu1_ldo_get_enable, - .set_enable = stpmu1_ldo_set_enable, - .get_mode = stpmu1_ldo_get_mode, - .set_mode = stpmu1_ldo_set_mode, +static const struct dm_regulator_ops stpmic1_ldo_ops = { + .get_value = stpmic1_ldo_get_value, + .set_value = stpmic1_ldo_set_value, + .get_enable = stpmic1_ldo_get_enable, + .set_enable = stpmic1_ldo_set_enable, + .get_mode = stpmic1_ldo_get_mode, + .set_mode = stpmic1_ldo_set_mode, };
-U_BOOT_DRIVER(stpmu1_ldo) = { - .name = "stpmu1_ldo", +U_BOOT_DRIVER(stpmic1_ldo) = { + .name = "stpmic1_ldo", .id = UCLASS_REGULATOR, - .ops = &stpmu1_ldo_ops, - .probe = stpmu1_ldo_probe, + .ops = &stpmic1_ldo_ops, + .probe = stpmic1_ldo_probe, };
/* * VREF DDR regulator */
-static int stpmu1_vref_ddr_get_value(struct udevice *dev) +static int stpmic1_vref_ddr_get_value(struct udevice *dev) { /* BUCK2/2 */ - return stpmu1_buck_get_uv(dev->parent, STPMU1_BUCK2) / 2; + return stpmic1_buck_get_uv(dev->parent, STPMIC1_BUCK2) / 2; }
-static int stpmu1_vref_ddr_get_enable(struct udevice *dev) +static int stpmic1_vref_ddr_get_enable(struct udevice *dev) { int ret;
- ret = pmic_reg_read(dev->parent, STPMU1_VREF_CTRL_REG); + ret = pmic_reg_read(dev->parent, STPMIC1_VREF_CTRL_REG); if (ret < 0) return false;
- return ret & STPMU1_VREF_EN ? true : false; + return ret & STPMIC1_VREF_EN ? true : false; }
-static int stpmu1_vref_ddr_set_enable(struct udevice *dev, bool enable) +static int stpmic1_vref_ddr_set_enable(struct udevice *dev, bool enable) { - int delay = enable ? STPMU1_DEFAULT_START_UP_DELAY_MS : - STPMU1_DEFAULT_STOP_DELAY_MS; + int delay = enable ? STPMIC1_DEFAULT_START_UP_DELAY_MS : + STPMIC1_DEFAULT_STOP_DELAY_MS; int ret;
/* if regulator is already in the wanted state, nothing to do */ - if (stpmu1_vref_ddr_get_enable(dev) == enable) + if (stpmic1_vref_ddr_get_enable(dev) == enable) return 0;
- ret = pmic_clrsetbits(dev->parent, STPMU1_VREF_CTRL_REG, - STPMU1_VREF_EN, enable ? STPMU1_VREF_EN : 0); + ret = pmic_clrsetbits(dev->parent, STPMIC1_VREF_CTRL_REG, + STPMIC1_VREF_EN, enable ? STPMIC1_VREF_EN : 0); mdelay(delay);
return ret; }
-static int stpmu1_vref_ddr_probe(struct udevice *dev) +static int stpmic1_vref_ddr_probe(struct udevice *dev) { struct dm_regulator_uclass_platdata *uc_pdata;
@@ -519,59 +519,59 @@ static int stpmu1_vref_ddr_probe(struct udevice *dev) return 0; }
-static const struct dm_regulator_ops stpmu1_vref_ddr_ops = { - .get_value = stpmu1_vref_ddr_get_value, - .get_enable = stpmu1_vref_ddr_get_enable, - .set_enable = stpmu1_vref_ddr_set_enable, +static const struct dm_regulator_ops stpmic1_vref_ddr_ops = { + .get_value = stpmic1_vref_ddr_get_value, + .get_enable = stpmic1_vref_ddr_get_enable, + .set_enable = stpmic1_vref_ddr_set_enable, };
-U_BOOT_DRIVER(stpmu1_vref_ddr) = { - .name = "stpmu1_vref_ddr", +U_BOOT_DRIVER(stpmic1_vref_ddr) = { + .name = "stpmic1_vref_ddr", .id = UCLASS_REGULATOR, - .ops = &stpmu1_vref_ddr_ops, - .probe = stpmu1_vref_ddr_probe, + .ops = &stpmic1_vref_ddr_ops, + .probe = stpmic1_vref_ddr_probe, };
/* * BOOST regulator */
-static int stpmu1_boost_get_enable(struct udevice *dev) +static int stpmic1_boost_get_enable(struct udevice *dev) { int ret;
- ret = pmic_reg_read(dev->parent, STPMU1_USB_CTRL_REG); + ret = pmic_reg_read(dev->parent, STPMIC1_USB_CTRL_REG); if (ret < 0) return false;
- return ret & STPMU1_USB_BOOST_EN ? true : false; + return ret & STPMIC1_USB_BOOST_EN ? true : false; }
-static int stpmu1_boost_set_enable(struct udevice *dev, bool enable) +static int stpmic1_boost_set_enable(struct udevice *dev, bool enable) { int ret;
- ret = pmic_reg_read(dev->parent, STPMU1_USB_CTRL_REG); + ret = pmic_reg_read(dev->parent, STPMIC1_USB_CTRL_REG); if (ret < 0) return ret;
- if (!enable && ret & STPMU1_USB_PWR_SW_EN) + if (!enable && ret & STPMIC1_USB_PWR_SW_EN) return -EINVAL;
/* if regulator is already in the wanted state, nothing to do */ - if (!!(ret & STPMU1_USB_BOOST_EN) == enable) + if (!!(ret & STPMIC1_USB_BOOST_EN) == enable) return 0;
- ret = pmic_clrsetbits(dev->parent, STPMU1_USB_CTRL_REG, - STPMU1_USB_BOOST_EN, - enable ? STPMU1_USB_BOOST_EN : 0); + ret = pmic_clrsetbits(dev->parent, STPMIC1_USB_CTRL_REG, + STPMIC1_USB_BOOST_EN, + enable ? STPMIC1_USB_BOOST_EN : 0); if (enable) - mdelay(STPMU1_USB_BOOST_START_UP_DELAY_MS); + mdelay(STPMIC1_USB_BOOST_START_UP_DELAY_MS);
return ret; }
-static int stpmu1_boost_probe(struct udevice *dev) +static int stpmic1_boost_probe(struct udevice *dev) { struct dm_regulator_uclass_platdata *uc_pdata;
@@ -583,42 +583,42 @@ static int stpmu1_boost_probe(struct udevice *dev) return 0; }
-static const struct dm_regulator_ops stpmu1_boost_ops = { - .get_enable = stpmu1_boost_get_enable, - .set_enable = stpmu1_boost_set_enable, +static const struct dm_regulator_ops stpmic1_boost_ops = { + .get_enable = stpmic1_boost_get_enable, + .set_enable = stpmic1_boost_set_enable, };
-U_BOOT_DRIVER(stpmu1_boost) = { - .name = "stpmu1_boost", +U_BOOT_DRIVER(stpmic1_boost) = { + .name = "stpmic1_boost", .id = UCLASS_REGULATOR, - .ops = &stpmu1_boost_ops, - .probe = stpmu1_boost_probe, + .ops = &stpmic1_boost_ops, + .probe = stpmic1_boost_probe, };
/* * USB power switch */
-static int stpmu1_pwr_sw_get_enable(struct udevice *dev) +static int stpmic1_pwr_sw_get_enable(struct udevice *dev) { uint mask = 1 << dev->driver_data; int ret;
return ret & mask ? true : false; }
-static int stpmu1_pwr_sw_set_enable(struct udevice *dev, bool enable) +static int stpmic1_pwr_sw_set_enable(struct udevice *dev, bool enable) { uint mask = 1 << dev->driver_data; - int delay = enable ? STPMU1_DEFAULT_START_UP_DELAY_MS : - STPMU1_DEFAULT_STOP_DELAY_MS; + int delay = enable ? STPMIC1_DEFAULT_START_UP_DELAY_MS : + STPMIC1_DEFAULT_STOP_DELAY_MS; int ret;
@@ -627,28 +627,28 @@ static int stpmu1_pwr_sw_set_enable(struct udevice *dev, bool enable) return 0;
/* Boost management */ - if (enable && !(ret & STPMU1_USB_BOOST_EN)) { - pmic_clrsetbits(dev->parent, STPMU1_USB_CTRL_REG, - STPMU1_USB_BOOST_EN, STPMU1_USB_BOOST_EN); - mdelay(STPMU1_USB_BOOST_START_UP_DELAY_MS); - } else if (!enable && ret & STPMU1_USB_BOOST_EN && - (ret & STPMU1_USB_PWR_SW_EN) != STPMU1_USB_PWR_SW_EN) { - pmic_clrsetbits(dev->parent, STPMU1_USB_CTRL_REG, - STPMU1_USB_BOOST_EN, 0); + if (enable && !(ret & STPMIC1_USB_BOOST_EN)) { + pmic_clrsetbits(dev->parent, STPMIC1_USB_CTRL_REG, + STPMIC1_USB_BOOST_EN, STPMIC1_USB_BOOST_EN); + mdelay(STPMIC1_USB_BOOST_START_UP_DELAY_MS); + } else if (!enable && ret & STPMIC1_USB_BOOST_EN && + (ret & STPMIC1_USB_PWR_SW_EN) != STPMIC1_USB_PWR_SW_EN) { + pmic_clrsetbits(dev->parent, STPMIC1_USB_CTRL_REG, + STPMIC1_USB_BOOST_EN, 0); }
- ret = pmic_clrsetbits(dev->parent, STPMU1_USB_CTRL_REG, + ret = pmic_clrsetbits(dev->parent, STPMIC1_USB_CTRL_REG, mask, enable ? mask : 0); mdelay(delay);
return ret; }
-static int stpmu1_pwr_sw_probe(struct udevice *dev) +static int stpmic1_pwr_sw_probe(struct udevice *dev) { struct dm_regulator_uclass_platdata *uc_pdata;
- if (!dev->driver_data || dev->driver_data > STPMU1_MAX_PWR_SW) + if (!dev->driver_data || dev->driver_data > STPMIC1_MAX_PWR_SW) return -EINVAL;
uc_pdata = dev_get_uclass_platdata(dev); @@ -659,14 +659,14 @@ static int stpmu1_pwr_sw_probe(struct udevice *dev) return 0; }
-static const struct dm_regulator_ops stpmu1_pwr_sw_ops = { - .get_enable = stpmu1_pwr_sw_get_enable, - .set_enable = stpmu1_pwr_sw_set_enable, +static const struct dm_regulator_ops stpmic1_pwr_sw_ops = { + .get_enable = stpmic1_pwr_sw_get_enable, + .set_enable = stpmic1_pwr_sw_set_enable, };
-U_BOOT_DRIVER(stpmu1_pwr_sw) = { - .name = "stpmu1_pwr_sw", +U_BOOT_DRIVER(stpmic1_pwr_sw) = { + .name = "stpmic1_pwr_sw", .id = UCLASS_REGULATOR, - .ops = &stpmu1_pwr_sw_ops, - .probe = stpmu1_pwr_sw_probe, + .ops = &stpmic1_pwr_sw_ops, + .probe = stpmic1_pwr_sw_probe, }; diff --git a/include/dt-bindings/mfd/st,stpmic1.h b/include/dt-bindings/mfd/st,stpmic1.h index 81982eb..b2d6c83 100644 --- a/include/dt-bindings/mfd/st,stpmic1.h +++ b/include/dt-bindings/mfd/st,stpmic1.h @@ -1,60 +1,46 @@ +/* SPDX-License-Identifier: GPL-2.0 */ /* - * This file is part of stpmu1 pmic driver - * - * Copyright (C) 2017, STMicroelectronics - All Rights Reserved - * Author: Pascal Paillet p.paillet@st.com for STMicroelectronics. - * - * License type: GPLv2 - * - * This program is free software; you can redistribute it and/or modify it - * under the terms of the GNU General Public License version 2 as published by - * the Free Software Foundation. - * - * This program is distributed in the hope that it will be useful, but - * WITHOUT ANY WARRANTY; without even the implied warranty of MERCHANTABILITY - * or FITNESS FOR A PARTICULAR PURPOSE. - * See the GNU General Public License for more details. - * - * You should have received a copy of the GNU General Public License along with - * this program. If not, see http://www.gnu.org/licenses/. + * Copyright (C) STMicroelectronics 2018 - All Rights Reserved + * Author: Philippe Peurichard philippe.peurichard@st.com, + * Pascal Paillet p.paillet@st.com for STMicroelectronics. */
-#ifndef __DT_BINDINGS_STPMU1_H__ -#define __DT_BINDINGS_STPMU1_H__ +#ifndef __DT_BINDINGS_STPMIC1_H__ +#define __DT_BINDINGS_STPMIC1_H__
/* IRQ definitions */ -#define IT_PONKEY_F 0 -#define IT_PONKEY_R 1 -#define IT_WAKEUP_F 2 -#define IT_WAKEUP_R 3 -#define IT_VBUS_OTG_F 4 -#define IT_VBUS_OTG_R 5 -#define IT_SWOUT_F 6 -#define IT_SWOUT_R 7 +#define IT_PONKEY_F 0 +#define IT_PONKEY_R 1 +#define IT_WAKEUP_F 2 +#define IT_WAKEUP_R 3 +#define IT_VBUS_OTG_F 4 +#define IT_VBUS_OTG_R 5 +#define IT_SWOUT_F 6 +#define IT_SWOUT_R 7
-#define IT_CURLIM_BUCK1 8 -#define IT_CURLIM_BUCK2 9 -#define IT_CURLIM_BUCK3 10 -#define IT_CURLIM_BUCK4 11 -#define IT_OCP_OTG 12 -#define IT_OCP_SWOUT 13 -#define IT_OCP_BOOST 14 -#define IT_OVP_BOOST 15 +#define IT_CURLIM_BUCK1 8 +#define IT_CURLIM_BUCK2 9 +#define IT_CURLIM_BUCK3 10 +#define IT_CURLIM_BUCK4 11 +#define IT_OCP_OTG 12 +#define IT_OCP_SWOUT 13 +#define IT_OCP_BOOST 14 +#define IT_OVP_BOOST 15
-#define IT_CURLIM_LDO1 16 -#define IT_CURLIM_LDO2 17 -#define IT_CURLIM_LDO3 18 -#define IT_CURLIM_LDO4 19 -#define IT_CURLIM_LDO5 20 -#define IT_CURLIM_LDO6 21 -#define IT_SHORT_SWOTG 22 -#define IT_SHORT_SWOUT 23 +#define IT_CURLIM_LDO1 16 +#define IT_CURLIM_LDO2 17 +#define IT_CURLIM_LDO3 18 +#define IT_CURLIM_LDO4 19 +#define IT_CURLIM_LDO5 20 +#define IT_CURLIM_LDO6 21 +#define IT_SHORT_SWOTG 22 +#define IT_SHORT_SWOUT 23
-#define IT_TWARN_F 24 -#define IT_TWARN_R 25 -#define IT_VINLOW_F 26 -#define IT_VINLOW_R 27 -#define IT_SWIN_F 30 -#define IT_SWIN_R 31 +#define IT_TWARN_F 24 +#define IT_TWARN_R 25 +#define IT_VINLOW_F 26 +#define IT_VINLOW_R 27 +#define IT_SWIN_F 30 +#define IT_SWIN_R 31
-#endif /* __DT_BINDINGS_STPMU1_H__ */ +#endif /* __DT_BINDINGS_STPMIC1_H__ */ diff --git a/include/power/stpmic1.h b/include/power/stpmic1.h index 5906fbf..5ed67d2 100644 --- a/include/power/stpmic1.h +++ b/include/power/stpmic1.h @@ -3,83 +3,90 @@ * Copyright (C) 2018, STMicroelectronics - All Rights Reserved */
-#ifndef __PMIC_STPMU1_H_ -#define __PMIC_STPMU1_H_ - -#define STPMU1_MASK_RESET_BUCK 0x18 -#define STPMU1_BUCKX_CTRL_REG(buck) (0x20 + (buck)) -#define STPMU1_VREF_CTRL_REG 0x24 -#define STPMU1_LDOX_CTRL_REG(ldo) (0x25 + (ldo)) -#define STPMU1_USB_CTRL_REG 0x40 -#define STPMU1_NVM_USER_STATUS_REG 0xb8 -#define STPMU1_NVM_USER_CONTROL_REG 0xb9 - -#define STPMU1_MASK_RESET_BUCK3 BIT(2) - -#define STPMU1_BUCK_EN BIT(0) -#define STPMU1_BUCK_MODE BIT(1) -#define STPMU1_BUCK_OUTPUT_MASK GENMASK(7, 2) -#define STPMU1_BUCK_OUTPUT_SHIFT 2 -#define STPMU1_BUCK2_1200000V (24 << STPMU1_BUCK_OUTPUT_SHIFT) -#define STPMU1_BUCK2_1350000V (30 << STPMU1_BUCK_OUTPUT_SHIFT) -#define STPMU1_BUCK3_1800000V (39 << STPMU1_BUCK_OUTPUT_SHIFT) - -#define STPMU1_VREF_EN BIT(0) - -#define STPMU1_LDO_EN BIT(0) -#define STPMU1_LDO12356_OUTPUT_MASK GENMASK(6, 2) -#define STPMU1_LDO12356_OUTPUT_SHIFT 2 -#define STPMU1_LDO3_MODE BIT(7) -#define STPMU1_LDO3_DDR_SEL 31 -#define STPMU1_LDO3_1800000 (9 << STPMU1_LDO12356_OUTPUT_SHIFT) -#define STPMU1_LDO4_UV 3300000 - -#define STPMU1_USB_BOOST_EN BIT(0) -#define STPMU1_USB_PWR_SW_EN GENMASK(2, 1) - -#define STPMU1_NVM_USER_CONTROL_PROGRAM BIT(0) -#define STPMU1_NVM_USER_CONTROL_READ BIT(1) - -#define STPMU1_NVM_USER_STATUS_BUSY BIT(0) -#define STPMU1_NVM_USER_STATUS_ERROR BIT(1) - -#define STPMU1_DEFAULT_START_UP_DELAY_MS 1 -#define STPMU1_DEFAULT_STOP_DELAY_MS 5 -#define STPMU1_USB_BOOST_START_UP_DELAY_MS 10 +#ifndef __PMIC_STPMIC1_H_ +#define __PMIC_STPMIC1_H_ + +#define STPMIC1_MAIN_CONTROL_REG 0x10 +#define STPMIC1_MASK_RESET_BUCK 0x18 +#define STPMIC1_MASK_RESET_LDOS 0x1a +#define STPMIC1_BUCKX_CTRL_REG(buck) (0x20 + (buck)) +#define STPMIC1_VREF_CTRL_REG 0x24 +#define STPMIC1_LDOX_CTRL_REG(ldo) (0x25 + (ldo)) +#define STPMIC1_USB_CTRL_REG 0x40 +#define STPMIC1_NVM_USER_STATUS_REG 0xb8 +#define STPMIC1_NVM_USER_CONTROL_REG 0xb9 + +/* Main PMIC Control Register (MAIN_CONTROL_REG) */ +#define STPMIC1_CTRL_SWITCH_OFF BIT(0) +#define STPMIC1_CTRL_RESTART BIT(1) + +#define STPMIC1_MASK_RESET_BUCK3 BIT(2) +#define STPMIC1_MASK_RESET_BUCK_DBG GENMASK(3, 0) +#define STPMIC1_MASK_RESET_LDOS_DBG 0x6F + +#define STPMIC1_BUCK_EN BIT(0) +#define STPMIC1_BUCK_MODE BIT(1) +#define STPMIC1_BUCK_OUTPUT_MASK GENMASK(7, 2) +#define STPMIC1_BUCK_OUTPUT_SHIFT 2 +#define STPMIC1_BUCK2_1200000V (24 << STPMIC1_BUCK_OUTPUT_SHIFT) +#define STPMIC1_BUCK2_1350000V (30 << STPMIC1_BUCK_OUTPUT_SHIFT) +#define STPMIC1_BUCK3_1800000V (39 << STPMIC1_BUCK_OUTPUT_SHIFT) + +#define STPMIC1_VREF_EN BIT(0) + +#define STPMIC1_LDO_EN BIT(0) +#define STPMIC1_LDO12356_OUTPUT_MASK GENMASK(6, 2) +#define STPMIC1_LDO12356_OUTPUT_SHIFT 2 +#define STPMIC1_LDO3_MODE BIT(7) +#define STPMIC1_LDO3_DDR_SEL 31 +#define STPMIC1_LDO3_1800000 (9 << STPMIC1_LDO12356_OUTPUT_SHIFT) +#define STPMIC1_LDO4_UV 3300000 + +#define STPMIC1_USB_BOOST_EN BIT(0) +#define STPMIC1_USB_PWR_SW_EN GENMASK(2, 1) + +#define STPMIC1_NVM_USER_CONTROL_PROGRAM BIT(0) +#define STPMIC1_NVM_USER_CONTROL_READ BIT(1) + +#define STPMIC1_NVM_USER_STATUS_BUSY BIT(0) +#define STPMIC1_NVM_USER_STATUS_ERROR BIT(1) + +#define STPMIC1_DEFAULT_START_UP_DELAY_MS 1 +#define STPMIC1_DEFAULT_STOP_DELAY_MS 5 +#define STPMIC1_USB_BOOST_START_UP_DELAY_MS 10
enum { - STPMU1_BUCK1, - STPMU1_BUCK2, - STPMU1_BUCK3, - STPMU1_BUCK4, - STPMU1_MAX_BUCK, + STPMIC1_BUCK1, + STPMIC1_BUCK2, + STPMIC1_BUCK3, + STPMIC1_BUCK4, + STPMIC1_MAX_BUCK, };
enum { - STPMU1_BUCK_MODE_HP, - STPMU1_BUCK_MODE_LP, + STPMIC1_BUCK_MODE_HP, + STPMIC1_BUCK_MODE_LP, };
enum { - STPMU1_LDO1, - STPMU1_LDO2, - STPMU1_LDO3, - STPMU1_LDO4, - STPMU1_LDO5, - STPMU1_LDO6, - STPMU1_MAX_LDO, + STPMIC1_LDO1, + STPMIC1_LDO2, + STPMIC1_LDO3, + STPMIC1_LDO4, + STPMIC1_LDO5, + STPMIC1_LDO6, + STPMIC1_MAX_LDO, };
enum { - STPMU1_LDO_MODE_NORMAL, - STPMU1_LDO_MODE_BYPASS, - STPMU1_LDO_MODE_SINK_SOURCE, + STPMIC1_LDO_MODE_NORMAL, + STPMIC1_LDO_MODE_BYPASS, + STPMIC1_LDO_MODE_SINK_SOURCE, };
enum { - STPMU1_PWR_SW1, - STPMU1_PWR_SW2, - STPMU1_MAX_PWR_SW, + STPMIC1_PWR_SW1, + STPMIC1_PWR_SW2, + STPMIC1_MAX_PWR_SW, }; - #endif
On Mon, 4 Feb 2019 11:26:17 +0100 Patrick Delaunay patrick.delaunay@st.com wrote:
- pmic: stpmu1@33 {
- pmic: stpmic1@33 {
reg = <0x33>; interrupts = <0 2>; interrupt-parent = <&gpioa>;compatible = "st,stpmic1";
regulators {
compatible = "st,stpmic1-regulators"; ldo1-supply = <&v3v3>; ldo2-supply = <&v3v3>;
diff --git a/board/st/stm32mp1/README b/board/st/stm32mp1/README index 1c3e865..72b28fa 100644 --- a/board/st/stm32mp1/README +++ b/board/st/stm32mp1/README @@ -28,7 +28,7 @@ Everything is supported in Linux but U-Boot is limited to: And the necessary drivers
- I2C
- Build Procedure
- /* VTT = Set LDO3 to sync mode */
- ret &= ~STPMIC1_LDO3_MODE;
- ret &= ~STPMIC1_LDO12356_OUTPUT_MASK;
- ret |= STPMIC1_LDO3_DDR_SEL << STPMIC1_LDO12356_OUTPUT_SHIFT;
- /* VDD_DDR = Set BUCK2 to 1.35V */ ret = pmic_clrsetbits(dev,
if (ret < 0) return ret;STPMIC1_BUCK2_1350000V);
- /* Enable VDD_DDR = BUCK2 */ ret = pmic_clrsetbits(dev,
if (ret < 0) return ret;STPMIC1_BUCK_EN, STPMIC1_BUCK_EN);
- mdelay(STPMIC1_DEFAULT_START_UP_DELAY_MS);
- /* Enable VREF */
- ret = pmic_clrsetbits(dev, STPMIC1_VREF_CTRL_REG,
if (ret < 0) return ret;STPMIC1_VREF_EN, STPMIC1_VREF_EN);
if (ret < 0) return ret;STPMIC1_LDO_EN, STPMIC1_LDO_EN);
-config PMIC_STPMU1
- bool "Enable support for STMicroelectronics STPMIC1 PMIC" depends on DM_PMIC && DM_I2C ---help---
switches.
- The STPMIC1 PMIC provides 4 BUCKs, 6 LDOs, 1 VREF and 2
- { .prefix = "ldo", .driver = "stpmic1_ldo" },
- { .prefix = "buck", .driver = "stpmic1_buck" },
- { .prefix = "vref_ddr", .driver = "stpmic1_vref_ddr" },
- { .prefix = "pwr_sw", .driver = "stpmic1_pwr_sw" },
- { .prefix = "boost", .driver = "stpmic1_boost" }, { },
- return STPMIC1_NUM_OF_REGS;
int len)
int len)
{ int ret;
if (!children) dev_dbg(dev, "no child found\n");stpmic1_children_info);
return 0; }
- .reg_count = stpmic1_reg_count,
- .read = stpmic1_read,
- .write = stpmic1_write,
- { .compatible = "st,stpmic1" }, { }
- .name = "stpmic1_pmic", .id = UCLASS_PMIC,
- .of_match = stpmic1_ids,
- .bind = stpmic1_bind,
- .ops = &stpmic1_ops,
- bool "Enable driver for STPMIC1 regulators"
- depends on DM_REGULATOR && PMIC_STPMIC1 ---help---
PMIC. The
- Enable support for the regulator functions of the STPMIC1
- bool "Enable driver for STPMIC1 regulators in SPL"
- depends on SPL_DM_REGULATOR && PMIC_STPMIC1
- help
- const struct stpmic1_range *ranges; int nbranges;
*output) {
- const struct stpmic1_range *range; int i;
- for (i = 0, range = output->ranges;
if (sel >= range->min_sel && sel <= range->max_sel) return range->min_uv + (sel - range->min_sel) * range->step;i < output->nbranges; i++, range++) {
*output) {
if (uv == range->min_uv && !range->step) return range->min_sel;i < output->nbranges; i++, range++) {
- BUCK regulators
- STPMIC1_RANGE(725000, 0, 4, 0),
- STPMIC1_RANGE(725000, 5, 36, 25000),
- STPMIC1_RANGE(1500000, 37, 63, 0),
- STPMIC1_RANGE(1000000, 0, 17, 0),
- STPMIC1_RANGE(1050000, 18, 19, 0),
- STPMIC1_RANGE(1100000, 20, 21, 0),
- STPMIC1_RANGE(1150000, 22, 23, 0),
- STPMIC1_RANGE(1200000, 24, 25, 0),
- STPMIC1_RANGE(1250000, 26, 27, 0),
- STPMIC1_RANGE(1300000, 28, 29, 0),
- STPMIC1_RANGE(1350000, 30, 31, 0),
- STPMIC1_RANGE(1400000, 32, 33, 0),
- STPMIC1_RANGE(1450000, 34, 35, 0),
- STPMIC1_RANGE(1500000, 36, 63, 0),
- STPMIC1_RANGE(1000000, 0, 19, 0),
- STPMIC1_RANGE(1100000, 20, 23, 0),
- STPMIC1_RANGE(1200000, 24, 27, 0),
- STPMIC1_RANGE(1300000, 28, 31, 0),
- STPMIC1_RANGE(1400000, 32, 35, 0),
- STPMIC1_RANGE(1500000, 36, 55, 100000),
- STPMIC1_RANGE(3400000, 56, 63, 0),
- STPMIC1_RANGE(600000, 0, 27, 25000),
- STPMIC1_RANGE(1500000, 36, 60, 100000),
- STPMIC1_RANGE(3900000, 61, 63, 0),
- STPMIC1_OUTPUT(buck1_ranges, ARRAY_SIZE(buck1_ranges)),
- STPMIC1_OUTPUT(buck2_ranges, ARRAY_SIZE(buck2_ranges)),
- STPMIC1_OUTPUT(buck3_ranges, ARRAY_SIZE(buck3_ranges)),
- STPMIC1_OUTPUT(buck4_ranges, ARRAY_SIZE(buck4_ranges)),
- STPMIC1_MODE(STPMIC1_BUCK_MODE_HP, STPMIC1_BUCK_MODE_HP,
"HP"),
- STPMIC1_MODE(STPMIC1_BUCK_MODE_LP, STPMIC1_BUCK_MODE_LP,
"LP"), };
- sel = pmic_reg_read(dev, STPMIC1_BUCKX_CTRL_REG(buck)); if (sel < 0) return sel;
- sel &= STPMIC1_BUCK_OUTPUT_MASK;
- sel >>= STPMIC1_BUCK_OUTPUT_SHIFT;
- return stpmic1_output_find_uv(sel,
- return stpmic1_buck_get_uv(dev->parent, dev->driver_data -
1); }
1));
- return ret & STPMIC1_BUCK_EN ? true : false;
int ret, uv;
do */
uc_pdata->max_uV))
- 1),
return ret; }
1));
- return ret & STPMIC1_BUCK_MODE ? STPMIC1_BUCK_MODE_LP :
STPMU1_BUCK_MODE,
STPMIC1_BUCK_MODE,
- .get_value = stpmic1_buck_get_value,
- .set_value = stpmic1_buck_set_value,
- .get_enable = stpmic1_buck_get_enable,
- .set_enable = stpmic1_buck_set_enable,
- .get_mode = stpmic1_buck_get_mode,
- .set_mode = stpmic1_buck_set_mode,
- .name = "stpmic1_buck", .id = UCLASS_REGULATOR,
- .ops = &stpmic1_buck_ops,
- .probe = stpmic1_buck_probe,
- LDO regulators
- STPMIC1_RANGE(1700000, 0, 7, 0),
- STPMIC1_RANGE(1700000, 8, 24, 100000),
- STPMIC1_RANGE(3300000, 25, 31, 0),
- STPMIC1_RANGE(3300000, 25, 30, 0), /* Sel 31 is special case when LDO3 is in mode sync_source
(BUCK2/2) */ };
- STPMIC1_RANGE(1700000, 8, 30, 100000),
- STPMIC1_RANGE(3900000, 31, 31, 0),
- STPMIC1_RANGE(900000, 0, 24, 100000),
- STPMIC1_OUTPUT(ldo12_ranges, ARRAY_SIZE(ldo12_ranges)),
- STPMIC1_OUTPUT(ldo3_ranges, ARRAY_SIZE(ldo3_ranges)),
- STPMIC1_OUTPUT(NULL, 0),
- STPMIC1_OUTPUT(ldo5_ranges, ARRAY_SIZE(ldo5_ranges)),
- STPMIC1_OUTPUT(ldo6_ranges, ARRAY_SIZE(ldo6_ranges)),
- STPMIC1_MODE(STPMIC1_LDO_MODE_NORMAL,
- STPMIC1_MODE(STPMIC1_LDO_MODE_BYPASS,
- STPMIC1_MODE(STPMIC1_LDO_MODE_SINK_SOURCE,
/* ldo4 => 3,3V */
- if (ldo == STPMIC1_LDO4)
STPMU1_BUCK2) / 2;
- if (ldo == STPMIC1_LDO3 && sel == STPMIC1_LDO3_DDR_SEL)
STPMIC1_BUCK2) / 2;
- return stpmic1_output_find_uv(sel, &ldo_voltage_range[ldo]);
- if (ldo == STPMIC1_LDO4) return -EINVAL;
1));
- return ret & STPMIC1_LDO_EN ? true : false;
int ret, uv;
do */
uc_pdata->max_uV))
- 1),
STPMU1_LDO_EN : 0);
- 1),
return ret; }
- if (ldo != STPMIC1_LDO3) return -EINVAL;
- ret = pmic_reg_read(dev->parent, STPMIC1_LDOX_CTRL_REG(ldo)); if (ret < 0) return ret;
- if (ret & STPMIC1_LDO3_MODE)
- ret &= STPMIC1_LDO12356_OUTPUT_MASK;
- ret >>= STPMIC1_LDO12356_OUTPUT_SHIFT;
- return ret == STPMIC1_LDO3_DDR_SEL ?
switch (mode) {
- case STPMIC1_LDO_MODE_SINK_SOURCE:
- case STPMIC1_LDO_MODE_NORMAL:
break;ret &= ~STPMIC1_LDO3_MODE;
- case STPMIC1_LDO_MODE_BYPASS:
break; }ret |= STPMIC1_LDO3_MODE;
- if (dev->driver_data - 1 == STPMIC1_LDO3) { uc_pdata->mode = (struct dm_regulator_mode
- .get_value = stpmic1_ldo_get_value,
- .set_value = stpmic1_ldo_set_value,
- .get_enable = stpmic1_ldo_get_enable,
- .set_enable = stpmic1_ldo_set_enable,
- .get_mode = stpmic1_ldo_get_mode,
- .set_mode = stpmic1_ldo_set_mode,
- .name = "stpmic1_ldo", .id = UCLASS_REGULATOR,
- .ops = &stpmic1_ldo_ops,
- .probe = stpmic1_ldo_probe,
- VREF DDR regulator
- return stpmic1_buck_get_uv(dev->parent, STPMIC1_BUCK2) / 2;
- ret = pmic_reg_read(dev->parent, STPMIC1_VREF_CTRL_REG); if (ret < 0) return false;
- return ret & STPMIC1_VREF_EN ? true : false;
int ret;
do */
- if (stpmic1_vref_ddr_get_enable(dev) == enable) return 0;
- ret = pmic_clrsetbits(dev->parent, STPMIC1_VREF_CTRL_REG,
return ret; }
- .get_value = stpmic1_vref_ddr_get_value,
- .get_enable = stpmic1_vref_ddr_get_enable,
- .set_enable = stpmic1_vref_ddr_set_enable,
- .name = "stpmic1_vref_ddr", .id = UCLASS_REGULATOR,
- .ops = &stpmic1_vref_ddr_ops,
- .probe = stpmic1_vref_ddr_probe,
- BOOST regulator
- ret = pmic_reg_read(dev->parent, STPMIC1_USB_CTRL_REG); if (ret < 0) return false;
- return ret & STPMIC1_USB_BOOST_EN ? true : false;
- ret = pmic_reg_read(dev->parent, STPMIC1_USB_CTRL_REG); if (ret < 0) return ret;
do */
- if (!!(ret & STPMIC1_USB_BOOST_EN) == enable) return 0;
- ret = pmic_clrsetbits(dev->parent, STPMIC1_USB_CTRL_REG,
if (enable)enable ? STPMIC1_USB_BOOST_EN : 0);
return ret;
- .get_enable = stpmic1_boost_get_enable,
- .set_enable = stpmic1_boost_set_enable,
- .name = "stpmic1_boost", .id = UCLASS_REGULATOR,
- .ops = &stpmic1_boost_ops,
- .probe = stpmic1_boost_probe,
- USB power switch
- int delay = enable ? STPMIC1_DEFAULT_START_UP_DELAY_MS :
int ret;STPMIC1_DEFAULT_STOP_DELAY_MS;
- if (enable && !(ret & STPMIC1_USB_BOOST_EN)) {
- } else if (!enable && ret & STPMIC1_USB_BOOST_EN &&
}STPMIC1_USB_BOOST_EN, 0);
return ret;
STPMU1_MAX_PWR_SW)
- .get_enable = stpmic1_pwr_sw_get_enable,
- .set_enable = stpmic1_pwr_sw_set_enable,
- .name = "stpmic1_pwr_sw", .id = UCLASS_REGULATOR,
- .ops = &stpmic1_pwr_sw_ops,
- .probe = stpmic1_pwr_sw_probe,
- This file is part of stpmu1 pmic driver
- Copyright (C) 2017, STMicroelectronics - All Rights Reserved
- Author: Pascal Paillet p.paillet@st.com for STMicroelectronics.
- License type: GPLv2
modify it
- under the terms of the GNU General Public License version 2 as
published by
- the Free Software Foundation.
but
- WITHOUT ANY WARRANTY; without even the implied warranty of
MERCHANTABILITY
- or FITNESS FOR A PARTICULAR PURPOSE.
- See the GNU General Public License for more details.
along with
- this program. If not, see http://www.gnu.org/licenses/.
- Copyright (C) STMicroelectronics 2018 - All Rights Reserved
- Author: Philippe Peurichard philippe.peurichard@st.com,
- Pascal Paillet p.paillet@st.com for STMicroelectronics.
- Copyright (C) 2018, STMicroelectronics - All Rights Reserved
enum {
- STPMU1_BUCK1,
- STPMU1_BUCK2,
- STPMU1_BUCK3,
- STPMU1_BUCK4,
- STPMU1_MAX_BUCK,
- STPMIC1_BUCK1,
- STPMIC1_BUCK2,
- STPMIC1_BUCK3,
- STPMIC1_BUCK4,
- STPMIC1_MAX_BUCK,
enum {
- STPMIC1_BUCK_MODE_HP,
- STPMIC1_BUCK_MODE_LP,
enum {
- STPMU1_LDO1,
- STPMU1_LDO2,
- STPMU1_LDO3,
- STPMU1_LDO4,
- STPMU1_LDO5,
- STPMU1_LDO6,
- STPMU1_MAX_LDO,
- STPMIC1_LDO1,
- STPMIC1_LDO2,
- STPMIC1_LDO3,
- STPMIC1_LDO4,
- STPMIC1_LDO5,
- STPMIC1_LDO6,
- STPMIC1_MAX_LDO,
enum {
- STPMIC1_LDO_MODE_NORMAL,
- STPMIC1_LDO_MODE_BYPASS,
- STPMIC1_LDO_MODE_SINK_SOURCE,
enum {
- STPMU1_PWR_SW1,
- STPMU1_PWR_SW2,
- STPMIC1_PWR_SW1,
- STPMIC1_PWR_SW2,
- STPMIC1_MAX_PWR_SW,
#endif
Lukasz Majewski
Alignment with STPMIC1 datasheet s/MAIN_CONTROL_REG/MAIN_CR/g s/MASK_RESET_BUCK/BUCKS_MRST_CR/g s/MASK_RESET_LDOS/LDOS_MRST_CR/g s/BUCKX_CTRL_REG/BUCKX_MAIN_CR/g s/VREF_CTRL_REG/REFDDR_MAIN_CR/g s/LDOX_CTRL_REG/LDOX_MAIN_CR/g s/USB_CTRL_REG/BST_SW_CR/g s/STPMIC1_NVM_USER_STATUS_REG/STPMIC1_NVM_SR/g s/STPMIC1_NVM_USER_CONTROL_REG/STPMIC1_NVM_CR/g and update all the associated defines.
Signed-off-by: Patrick Delaunay patrick.delaunay@st.com ---
board/st/stm32mp1/board.c | 24 ++++---- board/st/stm32mp1/spl.c | 6 +- drivers/power/regulator/stpmic1.c | 114 +++++++++++++++++++------------------- include/power/stpmic1.h | 98 +++++++++++++++++++------------- 4 files changed, 130 insertions(+), 112 deletions(-)
diff --git a/board/st/stm32mp1/board.c b/board/st/stm32mp1/board.c index 2a94f10..5c1acca 100644 --- a/board/st/stm32mp1/board.c +++ b/board/st/stm32mp1/board.c @@ -50,39 +50,39 @@ int board_ddr_power_init(void) return 0;
/* VTT = Set LDO3 to sync mode */ - ret = pmic_reg_read(dev, STPMIC1_LDOX_CTRL_REG(STPMIC1_LDO3)); + ret = pmic_reg_read(dev, STPMIC1_LDOX_MAIN_CR(STPMIC1_LDO3)); if (ret < 0) return ret;
ret &= ~STPMIC1_LDO3_MODE; - ret &= ~STPMIC1_LDO12356_OUTPUT_MASK; - ret |= STPMIC1_LDO3_DDR_SEL << STPMIC1_LDO12356_OUTPUT_SHIFT; + ret &= ~STPMIC1_LDO12356_VOUT_MASK; + ret |= STPMIC1_LDO_VOUT(STPMIC1_LDO3_DDR_SEL);
- ret = pmic_reg_write(dev, STPMIC1_LDOX_CTRL_REG(STPMIC1_LDO3), + ret = pmic_reg_write(dev, STPMIC1_LDOX_MAIN_CR(STPMIC1_LDO3), ret); if (ret < 0) return ret;
/* VDD_DDR = Set BUCK2 to 1.35V */ ret = pmic_clrsetbits(dev, - STPMIC1_BUCKX_CTRL_REG(STPMIC1_BUCK2), - STPMIC1_BUCK_OUTPUT_MASK, + STPMIC1_BUCKX_MAIN_CR(STPMIC1_BUCK2), + STPMIC1_BUCK_VOUT_MASK, STPMIC1_BUCK2_1350000V); if (ret < 0) return ret;
/* Enable VDD_DDR = BUCK2 */ ret = pmic_clrsetbits(dev, - STPMIC1_BUCKX_CTRL_REG(STPMIC1_BUCK2), - STPMIC1_BUCK_EN, STPMIC1_BUCK_EN); + STPMIC1_BUCKX_MAIN_CR(STPMIC1_BUCK2), + STPMIC1_BUCK_ENA, STPMIC1_BUCK_ENA); if (ret < 0) return ret;
/* Enable VREF */ - ret = pmic_clrsetbits(dev, STPMIC1_VREF_CTRL_REG, - STPMIC1_VREF_EN, STPMIC1_VREF_EN); + ret = pmic_clrsetbits(dev, STPMIC1_REFDDR_MAIN_CR, + STPMIC1_VREF_ENA, STPMIC1_VREF_ENA); if (ret < 0) return ret;
@@ -90,8 +90,8 @@ int board_ddr_power_init(void)
/* Enable LDO3 */ ret = pmic_clrsetbits(dev, - STPMIC1_LDOX_CTRL_REG(STPMIC1_LDO3), - STPMIC1_LDO_EN, STPMIC1_LDO_EN); + STPMIC1_LDOX_MAIN_CR(STPMIC1_LDO3), + STPMIC1_LDO_ENA, STPMIC1_LDO_ENA); if (ret < 0) return ret;
diff --git a/board/st/stm32mp1/spl.c b/board/st/stm32mp1/spl.c index 546a923..a7844f2 100644 --- a/board/st/stm32mp1/spl.c +++ b/board/st/stm32mp1/spl.c @@ -25,8 +25,8 @@ void spl_board_init(void) DM_GET_DRIVER(pmic_stpmic1), &dev); if (!ret) pmic_clrsetbits(dev, - STPMIC1_MASK_RESET_BUCK, - STPMIC1_MASK_RESET_BUCK3, - STPMIC1_MASK_RESET_BUCK3); + STPMIC1_BUCKS_MRST_CR, + STPMIC1_MRST_BUCK(STPMIC1_BUCK3), + STPMIC1_MRST_BUCK(STPMIC1_BUCK3)); #endif } diff --git a/drivers/power/regulator/stpmic1.c b/drivers/power/regulator/stpmic1.c index 8602583..50ef2a2 100644 --- a/drivers/power/regulator/stpmic1.c +++ b/drivers/power/regulator/stpmic1.c @@ -132,20 +132,20 @@ static const struct stpmic1_output buck_voltage_range[] = {
/* BUCK modes */ static const struct dm_regulator_mode buck_modes[] = { - STPMIC1_MODE(STPMIC1_BUCK_MODE_HP, STPMIC1_BUCK_MODE_HP, "HP"), - STPMIC1_MODE(STPMIC1_BUCK_MODE_LP, STPMIC1_BUCK_MODE_LP, "LP"), + STPMIC1_MODE(STPMIC1_PREG_MODE_HP, STPMIC1_PREG_MODE_HP, "HP"), + STPMIC1_MODE(STPMIC1_PREG_MODE_LP, STPMIC1_PREG_MODE_LP, "LP"), };
- sel = pmic_reg_read(dev, STPMIC1_BUCKX_CTRL_REG(buck)); + sel = pmic_reg_read(dev, STPMIC1_BUCKX_MAIN_CR(buck)); if (sel < 0) return sel;
- sel &= STPMIC1_BUCK_OUTPUT_MASK; - sel >>= STPMIC1_BUCK_OUTPUT_SHIFT; + sel &= STPMIC1_BUCK_VOUT_MASK; + sel >>= STPMIC1_BUCK_VOUT_SHIFT;
return stpmic1_output_find_uv(sel, &buck_voltage_range[buck]); } @@ -164,9 +164,9 @@ static int stpmic1_buck_set_value(struct udevice *dev, int uv) return sel;
return pmic_clrsetbits(dev->parent, - STPMIC1_BUCKX_CTRL_REG(buck), - STPMIC1_BUCK_OUTPUT_MASK, - sel << STPMIC1_BUCK_OUTPUT_SHIFT); + STPMIC1_BUCKX_MAIN_CR(buck), + STPMIC1_BUCK_VOUT_MASK, + sel << STPMIC1_BUCK_VOUT_SHIFT); }
static int stpmic1_buck_get_enable(struct udevice *dev) @@ -174,11 +174,11 @@ static int stpmic1_buck_get_enable(struct udevice *dev) int ret;
ret = pmic_reg_read(dev->parent, - STPMIC1_BUCKX_CTRL_REG(dev->driver_data - 1)); + STPMIC1_BUCKX_MAIN_CR(dev->driver_data - 1)); if (ret < 0) return false;
- return ret & STPMIC1_BUCK_EN ? true : false; + return ret & STPMIC1_BUCK_ENA ? true : false; }
static int stpmic1_buck_set_enable(struct udevice *dev, bool enable) @@ -200,8 +200,8 @@ static int stpmic1_buck_set_enable(struct udevice *dev, bool enable) }
ret = pmic_clrsetbits(dev->parent, - STPMIC1_BUCKX_CTRL_REG(dev->driver_data - 1), - STPMIC1_BUCK_EN, enable ? STPMIC1_BUCK_EN : 0); + STPMIC1_BUCKX_MAIN_CR(dev->driver_data - 1), + STPMIC1_BUCK_ENA, enable ? STPMIC1_BUCK_ENA : 0); mdelay(delay);
return ret; @@ -212,20 +212,20 @@ static int stpmic1_buck_get_mode(struct udevice *dev) int ret;
ret = pmic_reg_read(dev->parent, - STPMIC1_BUCKX_CTRL_REG(dev->driver_data - 1)); + STPMIC1_BUCKX_MAIN_CR(dev->driver_data - 1)); if (ret < 0) return ret;
- return ret & STPMIC1_BUCK_MODE ? STPMIC1_BUCK_MODE_LP : - STPMIC1_BUCK_MODE_HP; + return ret & STPMIC1_BUCK_PREG_MODE ? STPMIC1_PREG_MODE_LP : + STPMIC1_PREG_MODE_HP; }
static int stpmic1_buck_set_mode(struct udevice *dev, int mode) { return pmic_clrsetbits(dev->parent, - STPMIC1_BUCKX_CTRL_REG(dev->driver_data - 1), - STPMIC1_BUCK_MODE, - mode ? STPMIC1_BUCK_MODE : 0); + STPMIC1_BUCKX_MAIN_CR(dev->driver_data - 1), + STPMIC1_BUCK_PREG_MODE, + mode ? STPMIC1_BUCK_PREG_MODE : 0); }
static int stpmic1_buck_probe(struct udevice *dev) @@ -312,7 +312,7 @@ static int stpmic1_ldo_get_value(struct udevice *dev) { int sel, ldo = dev->driver_data - 1;
- sel = pmic_reg_read(dev->parent, STPMIC1_LDOX_CTRL_REG(ldo)); + sel = pmic_reg_read(dev->parent, STPMIC1_LDOX_MAIN_CR(ldo)); if (sel < 0) return sel;
@@ -320,8 +320,8 @@ static int stpmic1_ldo_get_value(struct udevice *dev) if (ldo == STPMIC1_LDO4) return STPMIC1_LDO4_UV;
- sel &= STPMIC1_LDO12356_OUTPUT_MASK; - sel >>= STPMIC1_LDO12356_OUTPUT_SHIFT; + sel &= STPMIC1_LDO12356_VOUT_MASK; + sel >>= STPMIC1_LDO12356_VOUT_SHIFT;
/* ldo3, sel = 31 => BUCK2/2 */ if (ldo == STPMIC1_LDO3 && sel == STPMIC1_LDO3_DDR_SEL) @@ -343,9 +343,9 @@ static int stpmic1_ldo_set_value(struct udevice *dev, int uv) return sel;
return pmic_clrsetbits(dev->parent, - STPMIC1_LDOX_CTRL_REG(ldo), - STPMIC1_LDO12356_OUTPUT_MASK, - sel << STPMIC1_LDO12356_OUTPUT_SHIFT); + STPMIC1_LDOX_MAIN_CR(ldo), + STPMIC1_LDO12356_VOUT_MASK, + sel << STPMIC1_LDO12356_VOUT_SHIFT); }
static int stpmic1_ldo_get_enable(struct udevice *dev) @@ -353,11 +353,11 @@ static int stpmic1_ldo_get_enable(struct udevice *dev) int ret;
ret = pmic_reg_read(dev->parent, - STPMIC1_LDOX_CTRL_REG(dev->driver_data - 1)); + STPMIC1_LDOX_MAIN_CR(dev->driver_data - 1)); if (ret < 0) return false;
- return ret & STPMIC1_LDO_EN ? true : false; + return ret & STPMIC1_LDO_ENA ? true : false; }
static int stpmic1_ldo_set_enable(struct udevice *dev, bool enable) @@ -379,8 +379,8 @@ static int stpmic1_ldo_set_enable(struct udevice *dev, bool enable) }
ret = pmic_clrsetbits(dev->parent, - STPMIC1_LDOX_CTRL_REG(dev->driver_data - 1), - STPMIC1_LDO_EN, enable ? STPMIC1_LDO_EN : 0); + STPMIC1_LDOX_MAIN_CR(dev->driver_data - 1), + STPMIC1_LDO_ENA, enable ? STPMIC1_LDO_ENA : 0); mdelay(delay);
return ret; @@ -393,15 +393,15 @@ static int stpmic1_ldo_get_mode(struct udevice *dev) if (ldo != STPMIC1_LDO3) return -EINVAL;
- ret = pmic_reg_read(dev->parent, STPMIC1_LDOX_CTRL_REG(ldo)); + ret = pmic_reg_read(dev->parent, STPMIC1_LDOX_MAIN_CR(ldo)); if (ret < 0) return ret;
if (ret & STPMIC1_LDO3_MODE) return STPMIC1_LDO_MODE_BYPASS;
- ret &= STPMIC1_LDO12356_OUTPUT_MASK; - ret >>= STPMIC1_LDO12356_OUTPUT_SHIFT; + ret &= STPMIC1_LDO12356_VOUT_MASK; + ret >>= STPMIC1_LDO12356_VOUT_SHIFT;
return ret == STPMIC1_LDO3_DDR_SEL ? STPMIC1_LDO_MODE_SINK_SOURCE : STPMIC1_LDO_MODE_NORMAL; @@ -414,14 +414,14 @@ static int stpmic1_ldo_set_mode(struct udevice *dev, int mode) if (ldo != STPMIC1_LDO3) return -EINVAL;
switch (mode) { case STPMIC1_LDO_MODE_SINK_SOURCE: - ret &= ~STPMIC1_LDO12356_OUTPUT_MASK; - ret |= STPMIC1_LDO3_DDR_SEL << STPMIC1_LDO12356_OUTPUT_SHIFT; + ret &= ~STPMIC1_LDO12356_VOUT_MASK; + ret |= STPMIC1_LDO3_DDR_SEL << STPMIC1_LDO12356_VOUT_SHIFT; case STPMIC1_LDO_MODE_NORMAL: ret &= ~STPMIC1_LDO3_MODE; break; @@ -430,7 +430,7 @@ static int stpmic1_ldo_set_mode(struct udevice *dev, int mode) break; }
- return pmic_reg_write(dev->parent, STPMIC1_LDOX_CTRL_REG(ldo), ret); + return pmic_reg_write(dev->parent, STPMIC1_LDOX_MAIN_CR(ldo), ret); }
static int stpmic1_ldo_probe(struct udevice *dev) @@ -483,11 +483,11 @@ static int stpmic1_vref_ddr_get_enable(struct udevice *dev) { int ret;
- ret = pmic_reg_read(dev->parent, STPMIC1_VREF_CTRL_REG); + ret = pmic_reg_read(dev->parent, STPMIC1_REFDDR_MAIN_CR); if (ret < 0) return false;
- return ret & STPMIC1_VREF_EN ? true : false; + return ret & STPMIC1_VREF_ENA ? true : false; }
static int stpmic1_vref_ddr_set_enable(struct udevice *dev, bool enable) @@ -500,8 +500,8 @@ static int stpmic1_vref_ddr_set_enable(struct udevice *dev, bool enable) if (stpmic1_vref_ddr_get_enable(dev) == enable) return 0;
- ret = pmic_clrsetbits(dev->parent, STPMIC1_VREF_CTRL_REG, - STPMIC1_VREF_EN, enable ? STPMIC1_VREF_EN : 0); + ret = pmic_clrsetbits(dev->parent, STPMIC1_REFDDR_MAIN_CR, + STPMIC1_VREF_ENA, enable ? STPMIC1_VREF_ENA : 0); mdelay(delay);
return ret; @@ -540,31 +540,31 @@ static int stpmic1_boost_get_enable(struct udevice *dev) { int ret;
- ret = pmic_reg_read(dev->parent, STPMIC1_USB_CTRL_REG); + ret = pmic_reg_read(dev->parent, STPMIC1_BST_SW_CR); if (ret < 0) return false;
- return ret & STPMIC1_USB_BOOST_EN ? true : false; + return ret & STPMIC1_BST_ON ? true : false; }
- ret = pmic_reg_read(dev->parent, STPMIC1_USB_CTRL_REG); + ret = pmic_reg_read(dev->parent, STPMIC1_BST_SW_CR); if (ret < 0) return ret;
- if (!enable && ret & STPMIC1_USB_PWR_SW_EN) + if (!enable && ret & STPMIC1_PWR_SW_ON) return -EINVAL;
/* if regulator is already in the wanted state, nothing to do */ - if (!!(ret & STPMIC1_USB_BOOST_EN) == enable) + if (!!(ret & STPMIC1_BST_ON) == enable) return 0;
- ret = pmic_clrsetbits(dev->parent, STPMIC1_USB_CTRL_REG, - STPMIC1_USB_BOOST_EN, - enable ? STPMIC1_USB_BOOST_EN : 0); + ret = pmic_clrsetbits(dev->parent, STPMIC1_BST_SW_CR, + STPMIC1_BST_ON, + enable ? STPMIC1_BST_ON : 0); if (enable) mdelay(STPMIC1_USB_BOOST_START_UP_DELAY_MS);
@@ -604,7 +604,7 @@ static int stpmic1_pwr_sw_get_enable(struct udevice *dev) uint mask = 1 << dev->driver_data; int ret;
@@ -618,7 +618,7 @@ static int stpmic1_pwr_sw_set_enable(struct udevice *dev, bool enable) STPMIC1_DEFAULT_STOP_DELAY_MS; int ret;
@@ -627,17 +627,17 @@ static int stpmic1_pwr_sw_set_enable(struct udevice *dev, bool enable) return 0;
/* Boost management */ - if (enable && !(ret & STPMIC1_USB_BOOST_EN)) { - pmic_clrsetbits(dev->parent, STPMIC1_USB_CTRL_REG, - STPMIC1_USB_BOOST_EN, STPMIC1_USB_BOOST_EN); + if (enable && !(ret & STPMIC1_BST_ON)) { + pmic_clrsetbits(dev->parent, STPMIC1_BST_SW_CR, + STPMIC1_BST_ON, STPMIC1_BST_ON); mdelay(STPMIC1_USB_BOOST_START_UP_DELAY_MS); - } else if (!enable && ret & STPMIC1_USB_BOOST_EN && - (ret & STPMIC1_USB_PWR_SW_EN) != STPMIC1_USB_PWR_SW_EN) { - pmic_clrsetbits(dev->parent, STPMIC1_USB_CTRL_REG, - STPMIC1_USB_BOOST_EN, 0); + } else if (!enable && ret & STPMIC1_BST_ON && + (ret & STPMIC1_PWR_SW_ON) != STPMIC1_PWR_SW_ON) { + pmic_clrsetbits(dev->parent, STPMIC1_BST_SW_CR, + STPMIC1_BST_ON, 0); }
- ret = pmic_clrsetbits(dev->parent, STPMIC1_USB_CTRL_REG, + ret = pmic_clrsetbits(dev->parent, STPMIC1_BST_SW_CR, mask, enable ? mask : 0); mdelay(delay);
diff --git a/include/power/stpmic1.h b/include/power/stpmic1.h index 5ed67d2..ea91b75 100644 --- a/include/power/stpmic1.h +++ b/include/power/stpmic1.h @@ -6,51 +6,69 @@ #ifndef __PMIC_STPMIC1_H_ #define __PMIC_STPMIC1_H_
-#define STPMIC1_MAIN_CONTROL_REG 0x10 -#define STPMIC1_MASK_RESET_BUCK 0x18 -#define STPMIC1_MASK_RESET_LDOS 0x1a -#define STPMIC1_BUCKX_CTRL_REG(buck) (0x20 + (buck)) -#define STPMIC1_VREF_CTRL_REG 0x24 -#define STPMIC1_LDOX_CTRL_REG(ldo) (0x25 + (ldo)) -#define STPMIC1_USB_CTRL_REG 0x40 -#define STPMIC1_NVM_USER_STATUS_REG 0xb8 -#define STPMIC1_NVM_USER_CONTROL_REG 0xb9 - -/* Main PMIC Control Register (MAIN_CONTROL_REG) */ -#define STPMIC1_CTRL_SWITCH_OFF BIT(0) -#define STPMIC1_CTRL_RESTART BIT(1) - -#define STPMIC1_MASK_RESET_BUCK3 BIT(2) -#define STPMIC1_MASK_RESET_BUCK_DBG GENMASK(3, 0) -#define STPMIC1_MASK_RESET_LDOS_DBG 0x6F - -#define STPMIC1_BUCK_EN BIT(0) -#define STPMIC1_BUCK_MODE BIT(1) -#define STPMIC1_BUCK_OUTPUT_MASK GENMASK(7, 2) -#define STPMIC1_BUCK_OUTPUT_SHIFT 2 -#define STPMIC1_BUCK2_1200000V (24 << STPMIC1_BUCK_OUTPUT_SHIFT) -#define STPMIC1_BUCK2_1350000V (30 << STPMIC1_BUCK_OUTPUT_SHIFT) -#define STPMIC1_BUCK3_1800000V (39 << STPMIC1_BUCK_OUTPUT_SHIFT) - -#define STPMIC1_VREF_EN BIT(0) - -#define STPMIC1_LDO_EN BIT(0) -#define STPMIC1_LDO12356_OUTPUT_MASK GENMASK(6, 2) -#define STPMIC1_LDO12356_OUTPUT_SHIFT 2 +#define STPMIC1_MAIN_CR 0x10 +#define STPMIC1_BUCKS_MRST_CR 0x18 +#define STPMIC1_LDOS_MRST_CR 0x1a +#define STPMIC1_BUCKX_MAIN_CR(buck) (0x20 + (buck)) +#define STPMIC1_REFDDR_MAIN_CR 0x24 +#define STPMIC1_LDOX_MAIN_CR(ldo) (0x25 + (ldo)) +#define STPMIC1_BST_SW_CR 0x40 +#define STPMIC1_NVM_SR 0xb8 +#define STPMIC1_NVM_CR 0xb9 + +/* Main PMIC Control Register (MAIN_CR) */ +#define STPMIC1_SWOFF BIT(0) +#define STPMIC1_RREQ_EN BIT(1) + +/* BUCKS_MRST_CR */ +#define STPMIC1_MRST_BUCK(buck) BIT(buck) +#define STPMIC1_MRST_BUCK_ALL GENMASK(3, 0) + +/* LDOS_MRST_CR */ +#define STPMIC1_MRST_LDO(ldo) BIT(ldo) +#define STPMIC1_MRST_LDO_ALL GENMASK(6, 0) + +/* BUCKx_MAIN_CR (x=1...4) */ +#define STPMIC1_BUCK_ENA BIT(0) +#define STPMIC1_BUCK_PREG_MODE BIT(1) +#define STPMIC1_BUCK_VOUT_MASK GENMASK(7, 2) +#define STPMIC1_BUCK_VOUT_SHIFT 2 +#define STPMIC1_BUCK_VOUT(sel) (sel << STPMIC1_BUCK_VOUT_SHIFT) + +#define STPMIC1_BUCK2_1200000V STPMIC1_BUCK_VOUT(24) +#define STPMIC1_BUCK2_1350000V STPMIC1_BUCK_VOUT(30) + +#define STPMIC1_BUCK3_1800000V STPMIC1_BUCK_VOUT(39) + +/* REFDDR_MAIN_CR */ +#define STPMIC1_VREF_ENA BIT(0) + +/* LDOX_MAIN_CR */ +#define STPMIC1_LDO_ENA BIT(0) +#define STPMIC1_LDO12356_VOUT_MASK GENMASK(6, 2) +#define STPMIC1_LDO12356_VOUT_SHIFT 2 +#define STPMIC1_LDO_VOUT(sel) (sel << STPMIC1_LDO12356_VOUT_SHIFT) + #define STPMIC1_LDO3_MODE BIT(7) #define STPMIC1_LDO3_DDR_SEL 31 -#define STPMIC1_LDO3_1800000 (9 << STPMIC1_LDO12356_OUTPUT_SHIFT) +#define STPMIC1_LDO3_1800000 STPMIC1_LDO_VOUT(9) + #define STPMIC1_LDO4_UV 3300000
-#define STPMIC1_USB_BOOST_EN BIT(0) -#define STPMIC1_USB_PWR_SW_EN GENMASK(2, 1) +/* BST_SW_CR */ +#define STPMIC1_BST_ON BIT(0) +#define STPMIC1_VBUSOTG_ON BIT(1) +#define STPMIC1_SWOUT_ON BIT(2) +#define STPMIC1_PWR_SW_ON (STPMIC1_VBUSOTG_ON | STPMIC1_SWOUT_ON)
-#define STPMIC1_NVM_USER_CONTROL_PROGRAM BIT(0) -#define STPMIC1_NVM_USER_CONTROL_READ BIT(1) +/* NVM_SR */ +#define STPMIC1_NVM_BUSY BIT(0)
-#define STPMIC1_NVM_USER_STATUS_BUSY BIT(0) -#define STPMIC1_NVM_USER_STATUS_ERROR BIT(1) +/* NVM_CR */ +#define STPMIC1_NVM_CMD_PROGRAM 1 +#define STPMIC1_NVM_CMD_READ 2
+/* Timeout */ #define STPMIC1_DEFAULT_START_UP_DELAY_MS 1 #define STPMIC1_DEFAULT_STOP_DELAY_MS 5 #define STPMIC1_USB_BOOST_START_UP_DELAY_MS 10 @@ -64,8 +82,8 @@ enum { };
enum { - STPMIC1_BUCK_MODE_HP, - STPMIC1_BUCK_MODE_LP, + STPMIC1_PREG_MODE_HP, + STPMIC1_PREG_MODE_LP, };
enum {
Add sysreset support, and support power switch off request, needed by poweroff command.
drivers/power/pmic/stpmic1.c | 46 ++++++++++++++++++++++++++++++++++++++++++++ 1 file changed, 46 insertions(+)
diff --git a/drivers/power/pmic/stpmic1.c b/drivers/power/pmic/stpmic1.c index 25450eb..c962160 100644 --- a/drivers/power/pmic/stpmic1.c +++ b/drivers/power/pmic/stpmic1.c @@ -7,6 +7,9 @@ #include <dm.h> #include <errno.h> #include <i2c.h> +#include <sysreset.h> +#include <dm/device.h> +#include <dm/lists.h> #include <power/pmic.h> #include <power/stpmic1.h>
@@ -72,6 +75,10 @@ static int stpmic1_bind(struct udevice *dev) dev_dbg(dev, "no child found\n"); #endif /* DM_REGULATOR */
+ if (CONFIG_IS_ENABLED(SYSRESET)) + return device_bind_driver(dev, "stpmic1-sysreset", + "stpmic1-sysreset", NULL); + return 0; }
@@ -93,3 +100,42 @@ U_BOOT_DRIVER(pmic_stpmic1) = { .bind = stpmic1_bind, .ops = &stpmic1_ops, }; + +#ifdef CONFIG_SYSRESET +static int stpmic1_sysreset_request(struct udevice *dev, enum sysreset_t type) +{ + struct udevice *pmic_dev; + int ret; + + if (type != SYSRESET_POWER) + return -EPROTONOSUPPORT; + + ret = uclass_get_device_by_driver(UCLASS_PMIC, + DM_GET_DRIVER(pmic_stpmic1), + &pmic_dev); + + if (ret) + return -EOPNOTSUPP; + + ret = pmic_reg_read(pmic_dev, STPMIC1_MAIN_CR); + if (ret < 0) + return ret; + + ret = pmic_reg_write(pmic_dev, STPMIC1_MAIN_CR, + ret | STPMIC1_SWOFF | STPMIC1_RREQ_EN); + if (ret < 0) + return ret; + + return -EINPROGRESS; +} + +static struct sysreset_ops stpmic1_sysreset_ops = { + .request = stpmic1_sysreset_request, +}; + +U_BOOT_DRIVER(stpmic1_sysreset) = { + .name = "stpmic1-sysreset", + .id = UCLASS_SYSRESET, + .ops = &stpmic1_sysreset_ops, +}; +#endif
Activate the command poweroff by default for STM32MP1: - with PCSI from TF-A for trusted boot - with PMIC sysreset request for basic boot (SYSRESET_POWER)
arch/arm/Kconfig | 1 + arch/arm/mach-stm32mp/Makefile | 3 +++ arch/arm/mach-stm32mp/cmd_poweroff.c | 24 ++++++++++++++++++++++++ 3 files changed, 28 insertions(+) create mode 100644 arch/arm/mach-stm32mp/cmd_poweroff.c
diff --git a/arch/arm/Kconfig b/arch/arm/Kconfig index 2ee1dfe..94988bc 100644 --- a/arch/arm/Kconfig +++ b/arch/arm/Kconfig @@ -1348,6 +1348,7 @@ config ARCH_STM32MP select SYSRESET select SYS_THUMB_BUILD imply CMD_DM + imply CMD_POWEROFF help Support for STM32MP SoC family developed by STMicroelectronics, MPUs based on ARM cortex A core diff --git a/arch/arm/mach-stm32mp/Makefile b/arch/arm/mach-stm32mp/Makefile index f59ced5..1493914 100644 --- a/arch/arm/mach-stm32mp/Makefile +++ b/arch/arm/mach-stm32mp/Makefile @@ -11,6 +11,9 @@ ifdef CONFIG_SPL_BUILD obj-y += spl.o else obj-y += bsec.o +ifndef CONFIG_STM32MP1_TRUSTED +obj-$(CONFIG_SYSRESET) += cmd_poweroff.o +endif endif obj-$(CONFIG_ARMV7_PSCI) += psci.o obj-$(CONFIG_$(SPL_)DM_REGULATOR) += pwr_regulator.o diff --git a/arch/arm/mach-stm32mp/cmd_poweroff.c b/arch/arm/mach-stm32mp/cmd_poweroff.c new file mode 100644 index 0000000..f54dd1d --- /dev/null +++ b/arch/arm/mach-stm32mp/cmd_poweroff.c @@ -0,0 +1,24 @@ +// SPDX-License-Identifier: GPL-2.0+ OR BSD-3-Clause +/* + * Copyright (C) 2019, STMicroelectronics - All Rights Reserved + */ + +#include <common.h> +#include <command.h> +#include <sysreset.h> + +int do_poweroff(cmd_tbl_t *cmdtp, int flag, int argc, char * const argv[]) +{ + int ret; + + puts("poweroff ...\n"); + mdelay(100); + + ret = sysreset_walk(SYSRESET_POWER); + + if (ret == -EINPROGRESS) + mdelay(1000); + + /*NOTREACHED when power off*/ + return CMD_RET_FAILURE; +}
Updates the stm32mp157c devicetree to bind the U-Boot PSCI driver need for power off command; TF-A for stm32mp15x supports PSCI 1.0.
arch/arm/dts/stm32mp157c.dtsi | 2 +- 1 file changed, 1 insertion(+), 1 deletion(-)
diff --git a/arch/arm/dts/stm32mp157c.dtsi b/arch/arm/dts/stm32mp157c.dtsi index 37cadfa..1a5f047 100644 --- a/arch/arm/dts/stm32mp157c.dtsi +++ b/arch/arm/dts/stm32mp157c.dtsi @@ -29,7 +29,7 @@ };
psci { - compatible = "arm,psci"; + compatible = "arm,psci-1.0"; method = "smc"; cpu_off = <0x84000002>; cpu_on = <0x84000003>;
Add functions to read/update the non volatile memory of STPMIC1 (8 bytes-register at 0xF8 address) and allow access with fuse command (bank=1, word > 0xF8).
For example:
STM32MP> fuse read 1 0xf8 8 Reading bank 1:
Word 0x000000f8: 000000ee 00000092 000000c0 00000002 Word 0x000000fc: 000000f2 00000080 00000002 00000033
drivers/misc/stm32mp_fuse.c | 28 +++++++++++ drivers/power/pmic/stpmic1.c | 114 +++++++++++++++++++++++++++++++++++++++++++ include/power/stpmic1.h | 7 +++ 3 files changed, 149 insertions(+)
diff --git a/drivers/misc/stm32mp_fuse.c b/drivers/misc/stm32mp_fuse.c index 33943a2..8dc246b 100644 --- a/drivers/misc/stm32mp_fuse.c +++ b/drivers/misc/stm32mp_fuse.c @@ -9,8 +9,10 @@ #include <errno.h> #include <dm/device.h> #include <dm/uclass.h> +#include <power/stpmic1.h>
#define STM32MP_OTP_BANK 0 +#define STM32MP_NVM_BANK 1
/* * The 'fuse' command API @@ -34,6 +36,13 @@ int fuse_read(u32 bank, u32 word, u32 *val) ret = 0; break;
+#ifdef CONFIG_PMIC_STPMIC1 + case STM32MP_NVM_BANK: + *val = 0; + ret = stpmic1_shadow_read_byte(word, (u8 *)val); + break; +#endif /* CONFIG_PMIC_STPMIC1 */ + default: printf("stm32mp %s: wrong value for bank %i\n", __func__, bank); ret = -EINVAL; @@ -62,6 +71,12 @@ int fuse_prog(u32 bank, u32 word, u32 val) ret = 0; break;
+#ifdef CONFIG_PMIC_STPMIC1 + case STM32MP_NVM_BANK: + ret = stpmic1_nvm_write_byte(word, (u8 *)&val); + break; +#endif /* CONFIG_PMIC_STPMIC1 */ + default: printf("stm32mp %s: wrong value for bank %i\n", __func__, bank); ret = -EINVAL; @@ -89,6 +104,13 @@ int fuse_sense(u32 bank, u32 word, u32 *val) ret = 0; break;
+#ifdef CONFIG_PMIC_STPMIC1 + case STM32MP_NVM_BANK: + *val = 0; + ret = stpmic1_nvm_read_byte(word, (u8 *)val); + break; +#endif /* CONFIG_PMIC_STPMIC1 */ + default: printf("stm32mp %s: wrong value for bank %i\n", __func__, bank); ret = -EINVAL; @@ -117,6 +139,12 @@ int fuse_override(u32 bank, u32 word, u32 val) ret = 0; break;
+#ifdef CONFIG_PMIC_STPMIC1 + case STM32MP_NVM_BANK: + ret = stpmic1_shadow_write_byte(word, (u8 *)&val); + break; +#endif /* CONFIG_PMIC_STPMIC1 */ + default: printf("stm32mp %s: wrong value for bank %i\n", __func__, bank); diff --git a/drivers/power/pmic/stpmic1.c b/drivers/power/pmic/stpmic1.c index c962160..65296c5 100644 --- a/drivers/power/pmic/stpmic1.c +++ b/drivers/power/pmic/stpmic1.c @@ -15,6 +15,17 @@
#define STPMIC1_NUM_OF_REGS 0x100
+#define STPMIC1_NVM_SIZE 8 +#define STPMIC1_NVM_POLL_TIMEOUT 100000 +#define STPMIC1_NVM_START_ADDRESS 0xf8 + +enum pmic_nvm_op { + SHADOW_READ, + SHADOW_WRITE, + NVM_READ, + NVM_WRITE, +}; + #if CONFIG_IS_ENABLED(DM_REGULATOR) static const struct pmic_child_info stpmic1_children_info[] = { { .prefix = "ldo", .driver = "stpmic1_ldo" }, @@ -101,6 +112,109 @@ U_BOOT_DRIVER(pmic_stpmic1) = { .ops = &stpmic1_ops, };
+#ifndef CONFIG_SPL_BUILD +static int stpmic1_nvm_rw(u8 addr, u8 *buf, int buf_len, enum pmic_nvm_op op) +{ + struct udevice *dev; + unsigned long timeout; + u8 cmd = STPMIC1_NVM_CMD_READ; + int ret; + + ret = uclass_get_device_by_driver(UCLASS_PMIC, + DM_GET_DRIVER(pmic_stpmic1), &dev); + if (ret) + /* No PMIC on power discrete board */ + return -EOPNOTSUPP; + + if (addr < STPMIC1_NVM_START_ADDRESS) + return -EACCES; + + if (op == SHADOW_READ) + return pmic_read(dev, addr, buf, buf_len); + + if (op == SHADOW_WRITE) + return pmic_write(dev, addr, buf, buf_len); + + if (op == NVM_WRITE) { + cmd = STPMIC1_NVM_CMD_PROGRAM; + + ret = pmic_write(dev, addr, buf, buf_len); + if (ret < 0) + return ret; + } + + ret = pmic_reg_read(dev, STPMIC1_NVM_CR); + if (ret < 0) + return ret; + + ret = pmic_reg_write(dev, STPMIC1_NVM_CR, ret | cmd); + if (ret < 0) + return ret; + + timeout = timer_get_us() + STPMIC1_NVM_POLL_TIMEOUT; + for (;;) { + ret = pmic_reg_read(dev, STPMIC1_NVM_SR); + if (ret < 0) + return ret; + + if (!(ret & STPMIC1_NVM_BUSY)) + break; + + if (time_after(timer_get_us(), timeout)) + break; + } + + if (ret & STPMIC1_NVM_BUSY) + return -ETIMEDOUT; + + if (op == NVM_READ) { + ret = pmic_read(dev, addr, buf, buf_len); + if (ret < 0) + return ret; + } + + return 0; +} + +int stpmic1_shadow_read_byte(u8 addr, u8 *buf) +{ + return stpmic1_nvm_rw(addr, buf, 1, SHADOW_READ); +} + +int stpmic1_shadow_write_byte(u8 addr, u8 *buf) +{ + return stpmic1_nvm_rw(addr, buf, 1, SHADOW_WRITE); +} + +int stpmic1_nvm_read_byte(u8 addr, u8 *buf) +{ + return stpmic1_nvm_rw(addr, buf, 1, NVM_READ); +} + +int stpmic1_nvm_write_byte(u8 addr, u8 *buf) +{ + return stpmic1_nvm_rw(addr, buf, 1, NVM_WRITE); +} + +int stpmic1_nvm_read_all(u8 *buf, int buf_len) +{ + if (buf_len != STPMIC1_NVM_SIZE) + return -EINVAL; + + return stpmic1_nvm_rw(STPMIC1_NVM_START_ADDRESS, + buf, buf_len, NVM_READ); +} + +int stpmic1_nvm_write_all(u8 *buf, int buf_len) +{ + if (buf_len != STPMIC1_NVM_SIZE) + return -EINVAL; + + return stpmic1_nvm_rw(STPMIC1_NVM_START_ADDRESS, + buf, buf_len, NVM_WRITE); +} +#endif /* CONFIG_SPL_BUILD */ + #ifdef CONFIG_SYSRESET static int stpmic1_sysreset_request(struct udevice *dev, enum sysreset_t type) { diff --git a/include/power/stpmic1.h b/include/power/stpmic1.h index ea91b75..0e6721d 100644 --- a/include/power/stpmic1.h +++ b/include/power/stpmic1.h @@ -107,4 +107,11 @@ enum { STPMIC1_PWR_SW2, STPMIC1_MAX_PWR_SW, }; + +int stpmic1_shadow_read_byte(u8 addr, u8 *buf); +int stpmic1_shadow_write_byte(u8 addr, u8 *buf); +int stpmic1_nvm_read_byte(u8 addr, u8 *buf); +int stpmic1_nvm_write_byte(u8 addr, u8 *buf); +int stpmic1_nvm_read_all(u8 *buf, int buf_len); +int stpmic1_nvm_write_all(u8 *buf, int buf_len); #endif
Lukasz Majewski
Patrick Delaunay
