Can someone clear me purpose of mii_phy.h? It looks like that it is really ancient file which hasn't been touched from 2003.
It is use for two files [monstr@monstr u-boot]$ grep -rn "mii_phy.h" * board/ep8260/mii_phy.c:2:#include <mii_phy.h> board/rpxsuper/mii_phy.c:2:#include <mii_phy.h>
+ different numbers of arguments against new "version" [monstr@monstr u-boot]$ grep -rn "mii_discover_phy" * arch/m68k/include/asm/fec.h:359:int mii_discover_phy(struct eth_device *dev); arch/powerpc/cpu/mpc8xx/fec.c:63:static int mii_discover_phy(struct eth_device *dev); arch/powerpc/cpu/mpc8xx/fec.c:728: efis->actual_phy_addr = mii_discover_phy (dev); arch/powerpc/cpu/mpc8xx/fec.c:872:static int mii_discover_phy(struct eth_device *dev) arch/powerpc/cpu/mpc85xx/ether_fcc.c:237: mii_discover_phy(); arch/powerpc/cpu/mpc8260/ether_fcc.c:234: mii_discover_phy(); board/ep8260/mii_phy.c:10:mii_discover_phy(void) board/rpxsuper/mii_phy.c:10:mii_discover_phy(void) drivers/net/mcfmii.c:150:int mii_discover_phy(struct eth_device *dev) drivers/net/mcfmii.c:253: info->phy_addr = mii_discover_phy(dev); include/mii_phy.h:4:void mii_discover_phy(void);
+ that functions without arg are not called either arch/powerpc/cpu/mpc85xx/ether_fcc.c:237: mii_discover_phy(); arch/powerpc/cpu/mpc8260/ether_fcc.c:234: mii_discover_phy();
I found that Frank Panno is ep8260 maintainer. Any comment?
The best will be to remove mii_phy entirely. Wolfgang: What do you think?
Thanks, Michal
yes, if you look at old files, you often see people using generic names when they should have been driver or arch specific, or people who thought about starting a framework but then nothing ever materialized.
sounds good to me ... i imagine the existing functionality might need to be converted into one of the common net frameworks that has been adopted ? -mike
Who is responsible for ep8260 and rpxsuper boards?
For ep8260: I cc'ed Frank Panno but his email address doesn't work.
Thanks, Michal
Dear Michal Simek,
I guess it's safe to assume these boards are orphaned / unmaintained.
Shall we remove them?
Michal Simek
Mike Frysinger
